> Проблема с Астро, Не запускается...
starley
сообщение Feb 19 2009, 16:44
Пользователь №: 43 085
При попытке запуска Астро пишет segmentation violation. ОС Linux RedHat Enterprise, дома на Дебиане - тоже самое. Некоторые другие тузлы, например, Astro IU работают. Может кто сталкивался и подскажет, что в Линухе подкрутить надо?
oratie
сообщение Mar 4 2009, 11:07
Пользователь №: 21 900
Из SolvNet
Прикрепленный файл  createNplace_bondpads.txt ( 9.6 килобайт ) Кол-во скачиваний: 352
Download the file "createNplace_bondpads.pl" and change the permissions to
executable.
Edit the createNplace_bondpads.pl file HEADER section per your design
specifications.
#Header
$stagger_bond = 1;
$bond1_master = "PADIZ40.FRAM";
$bond2_master = "PADOZ40.FRAM";
$bond1_instance = "sbond";
$bond2_instance = "lbond";
$bond1_pad_height = 89.8;
$bond2_pad_height = 204.8;
$bond_pad_width = 40;
$signal_pad_width = 40;
$x_origin_shift = 0;
$y_origin_shift = 0;
Hints for setting values:
If the design is an in-line structure, you need to only supply bond1_*
variables. Bond2_* variables are not used by the script if you set stagger to 0.
x_origin_shift/y_origin_shift = if the bond pad boundary left-bottom corner is
not zero, you need to set this variables, if it coincides with (0,0) then set
to 0 and 0
You can also supply variables as command line options.
Dump the I/O placement file with using following command and options from
Apollo and Astro:
axgDumpPlacement
setToggleField "Dump Placement" "Type" "io" 1
setFormField "Dump Placement" "Output Filename" "io_placement.dump"
formOK "Dump Placement"
Remove the lines corresponding to the corner pads from the io_place.dmp file
and the createNplace_bondpads.pl script produces a -pfile argument. This script
creates a file called addbumppadsNplace.cmd or the file name given for the
command line option -out. You can load this file directly from the Apollo and
Astro command line. Make sure you have saved the cell before loading the
command file.
If you find misalignment in bond placement, fine tune the variables in the head
section or command line options. Re-run the script to generate the command
file. Open the previously saved CEL file and re-load the newly generated
command file.
- starley   Проблема с Астро   Feb 19 2009, 16:44
- - SM   А virsim от VCS падает? Если да, то вам туда, пунк...   Feb 19 2009, 17:23
- - strofim   Было тоже самое с Milkyway. Нашел следующее решени...   Feb 24 2009, 15:37
- - starley   Спасибо за ответы Ошибка возникала при вызове s...   Feb 26 2009, 21:07
- - starley   Новый трабл образовался Делаю милкивей библиот...   Feb 28 2009, 20:09
|- - grigorik   Цитата(starley @ Mar 1 2009, 00:09) Новый...   Mar 1 2009, 10:09
- - starley   Спасибо за ответ. Похоже, проблема была в том, что...   Mar 3 2009, 13:16
|- - designner   Цитата(starley @ Mar 3 2009, 16:16) Спаси...   Mar 3 2009, 14:50
- - starley   Пытался сделать в Астро расстановку ячеек. Стандар...   Mar 3 2009, 16:35
|- - designner   Цитата(starley @ Mar 3 2009, 19:35) Пытал...   Mar 3 2009, 18:08
|- - starley   Цитата(designner @ Mar 3 2009, 21:08) Мес...   Mar 4 2009, 05:39
||- - sleep   Цитата(starley @ Mar 4 2009, 08:39) Понят...   Mar 4 2009, 05:47
|- - SM   Цитата(designner @ Mar 3 2009, 21:08) Мес...   Mar 4 2009, 05:50
- - starley   Назрел тут еще вопрос относительно выбора способа ...   Mar 4 2009, 07:42
- - starley   Объясните еще неразумному, плиз, как делается ИО р...   Mar 4 2009, 10:32
- - SM   Пады в RTL-коде не нужны, их просто расставить скр...   Mar 4 2009, 12:41
- - starley   Спасибо за скрипт. Завтра опробую. Планирую делать...   Mar 4 2009, 21:17
RSS Текстовая версия Сейчас: 20th August 2025 - 09:01
Страница сгенерированна за 0.01388 секунд с 7
