> IAR EVARM 5.30, Вышел патч 5.30.5
IgorKossak
сообщение May 19 2009, 12:59
Шаман
Из: Киев, Украина
Пользователь №: 221
EWARM patch release version 5.30.5 build 1361
1. Purpose
This patch release contains the following additions and fixes to EWARM 5.30.5.
Section placement could fail with an internal error [range allocation inconsistency] when the needed range for a place at command partially overlapped a place in command with a larger start address.
[EW20817]
When building initialization tables in link jobs with multiple zero or copy areas not inside blocks, an internal calculation error in the linker could cause section placement to fail with error Lp011.
[EW20968,20986]
Complex class inheritance structures with classes with methods taking more than two parameters could lead to broken thunks in Thumb mode.
[EW21014]
Member accesses to auto structs assigned with memcpy could in some cases be optimized incorrectly.
[EW21020]
Не позволяют скачать. Может у кого есть?
маша
сообщение May 20 2009, 08:54
Пользователь №: 10 537
Залито в upload/MCs/ARM/IAR/Patches/
+ EWARM patch release version 5.30.7 build 1348
IgorKossak
сообщение May 22 2009, 07:00
Шаман
Из: Киев, Украина
Пользователь №: 221
Это совсем другой патч.
1. Purpose
This patch release contains the following additions and fixes to EWARM evaluation version 5.30.2.
Adds support for the J-Trace Cortex-M3 probe.
Для тех, кто пользуется ARM от Atmel, вышел патч загрузчика, скачать дают свободно.
IAR Embedded Workbench for ARM 5.30 - Patch release 2009-05-13
In these release notes, when referring to a directory in your product installation, for example arm\config, the full path to the location is assumed, for example c:\Program Files\IAR Systems\Embedded Workbench 5.4\arm\config.
1. Purpose
This patch release contains the following corrections to EWARM 5.30:
Downloading your application to flash memory failed on Atmel AT91SAM9XE devices.
[EW20908]
OLEG_BOS
сообщение May 22 2009, 07:54
Пользователь №: 11 639
RSS Текстовая версия Сейчас: 28th July 2025 - 22:39
Страница сгенерированна за 0.01375 секунд с 7
