WINAvr или IAR?, для тех, кто работал в обеих средах. |
Oct 29 2005, 04:18
учащийся
Из: города контрастов
Пользователь №: 10 249
Nate, mozet prigoditsya - drayver dlya uart ucos RTOS pod avr. Mozet prigoditsya. Pisal sam .
dobavte v os_cpu_a.s90
EXTERN uart_UDREIsrAvr EXTERN uart_RXIsrAvr
COMMON INTVEC
DS 4 ; 1 RESET = $000 Reset interrupt Vector Address DS 4 ; 2 INT0addr = $002 External Interrupt0 Vector Address DS 4 ; 3 INT1addr = $004 External Interrupt1 Vector Address DS 4 ; 4 INT2addr = $006 External Interrupt2 Vector Address DS 4 ; 5 INT3addr = $008 External Interrupt3 Vector Address DS 4 ; 6 INT4addr = $00a External Interrupt4 Vector Address DS 4 ; 7 INT5addr = $00c External Interrupt5 Vector Address DS 4 ; 8 INT6addr = $00e External Interrupt6 Vector Address DS 4 ; 9 INT7addr = $010 External Interrupt7 Vector Address DS 4 ; 10 OC2addr = $012 Output Compare2 Interrupt Vector Address DS 4 ; 11 OVF2addr = $014 Overflow2 Interrupt Vector Address DS 4 ; 12 ICP1addr = $016 Input Capture1 Interrupt Vector Address DS 4 ; 13 OC1Aaddr = $018 Output Compare1A Interrupt Vector Address DS 4 ; 14 OC1Baddr = $01a Output Compare1B Interrupt Vector Address DS 4 ; 15 OVF1addr = $01c Overflow1 Interrupt Vector Address DS 4 ; 16 OC0addr = $01e Output Compare0 Interrupt Vector Address JMP OSTickISR ; 17 OVF0addr = $020 Overflow0 Interrupt Vector Address JMP spi_SpiIsr ; 18 SPIaddr = $022 SPI Interrupt Vector Address JMP uart_RXIsr0 ; 19 URXC0addr = $024 USART0 Receive Complete Interrupt Vector Address JMP uart_UDREIsr0 ; 20 UDRE0addr = $026 USART0 Data Register Empty Interrupt Vector Address DS 4 ; 21 UTXC0addr = $028 USART0 Transmit Complete Interrupt Vector Address DS 4 ; 22 ADCCaddr = $02a ADC Conversion Complete Handle JMP eep_ERDYIsr ; 23 ERDYaddr = $02c EEPROM Write Complete Handle DS 4 ; 24 ACIaddr = $02e Analog Comparator Interrupt Vector Address DS 4 ; 25 OC1Caddr = $030 Output Compare1C Interrupt Vector Address DS 4 ; 26 ICP3addr = $032 Input Capture3 Interrupt Vector Address DS 4 ; 27 OC3Aaddr = $034 Output Compare3A Interrupt Vector Address DS 4 ; 28 OC3Baddr = $036 Output Compare3B Interrupt Vector Address DS 4 ; 29 OC3Caddr = $038 Output Compare3C Interrupt Vector Address DS 4 ; 30 OVF3addr = $03A Overflow3 Interrupt Vector Address JMP uart_RXIsr1 ; 31 URXC1addr = $03C USART1 Receive Complete Interrupt Vector Address JMP uart_UDREIsr1 ; 32 UDRE1addr = $03E USART1 Data Register Empty Interrupt Vector Address DS 4 ; 33 UTXC1addr = $040 USART1 Transmit Complete Interrupt Vector Address DS 4 ; 34 TWIaddr = $042 TWI Interrupt Vector Address DS 4 ; 35 SPMRaddr = $044 Store Program Memory Ready Interrupt Vector Address END
;******************************************************************************* ************************* ; USART0 RX Complete handling ISR Routine ;******************************************************************************* *************************
uart_RXIsr0: PUSH_ALL ; Save all registers and status register IN R16,SREG ; Save the SREG but with interrupts enabled SBR R16,BIT07 ST -Y,R16 PUSH_SP ; Save the task's hardware stack pointer onto task's stack
LDS R16,OSIntNesting ; OSIntNexting++; INC R16 ; STS OSIntNesting,R16 ;
CPI R16,1 ; if (OSIntNesting == 1) { BRNE uart_rxc0_lab1 LDS R30,OSTCBCur ; OSTCBCur->OSTCBStkPtr = Y LDS R31,OSTCBCur+1 ST Z+,R28 ST Z+,R29 ; }
uart_rxc0_lab1: LDI R16, 0 ; Set previously stored port number CALL uart_RXIsrAvr ; Call ISR handling C Code function CALL OSIntExit
POP_SP ; Restore the hardware stack pointer from task's stack POP_SREG ; Restore the SREG register POP_ALL ; Restore all registers
RET ; Note: RET instead of RETI
;******************************************************************************* ************************* ; UART0 DATA REGISTER EMPTY Interrupt handling Routine ;******************************************************************************* ************************* uart_UDREIsr0: PUSH_ALL ; Save all registers and status register IN R16,SREG ; Save the SREG but with interrupts enabled SBR R16,BIT07 ST -Y,R16 PUSH_SP ; Save the task's hardware stack pointer onto task's stack LDS R16,OSIntNesting ; Notify uC/OS-II of ISR INC R16 ; STS OSIntNesting,R16 ;
CPI R16,1 ; if (OSIntNesting == 1) { BRNE uart_udre0_lab1 LDS R30,OSTCBCur ; OSTCBCur->OSTCBStkPtr = Y LDS R31,OSTCBCur+1 ST Z+,R28 ST Z+,R29 ; }
uart_udre0_lab1: LDI R16, 0 ; Set port to 0 CALL uart_UDREIsrAvr ; Call ISR handling C Code function CALL OSIntExit POP_SP ; Restore the hardware stack pointer from task's stack POP_SREG ; Restore the SREG register POP_ALL ; Restore all registers
a eto programma dlya raboti s uartom - read write with timeouts
/*@****************************************************************************** ****************************** * * * The comm.c module implementes platform independent functions for serial UART communication . * It must be cooperate with port dependent fucntions which are platform dependent . * * Data types : * typedef struct * { * INT8U state; // Port state * INT8U txstate; // Tx state * // Receive related data * OS_EVENT *rxsem; // Rx waiting semaphore * INT8U rxbuf[UART_RXBUF_SIZE]; // Pointer to UART Rx ring buffer * INT8U rxput; // Pointer to first empty pos in Rx ring buffer * INT8U rxget; // Pointer to first nonemtpy pos in Rx ring buffer * INT16U rxtimer; // Byte receive timer * // Transmit related data * OS_EVENT *txsem; // Tx waiting semaphore * INT8U txbuf[UART_TXBUF_SIZE]; // Pointer to UART Tx ring buffer * INT8U txput; // Pointer to first empty pos in Tx ring buffer * INT8U txget; // Pointer to first nonempty pos in Tx ring buffer * INT16U txtimer; // Byte transmit timer * }uart_uart; * * Functions : * Externaly UART subsystem communicates using 5 functions : * - uart_InitUart() * - uart_OpenUart() * - uart_CloseUart() * - uart_PutByte() * - uart_GetByte() * * Typical function usage is as follow : * - Initialize the whole uart subsystem with uart_InitUart() * - Then to use uart port invoke uart_OpenUart(). * - If result from uart_OpenUart() is not COM_NO_ERR it is possible to send and receive data to/from UART via * uart_PutByte() and uart_GetByte(). * - Finally if particular uart port is not needed - its resources can be deallocated by uart_CloseUart(). * ******************************************************************************** ******************************/ #include "uart.h" #include "uart_avr.h"
/******************************************************************************** ****************************** * . TYPEDEFS SECTION ******************************************************************************** ******************************/ typedef struct { INT8U state; // Port state INT8U txstate; // Tx state // Receive related data OS_EVENT *rxsem; // Rx waiting semaphore INT8U rxbuf[UART_RXBUF_SIZE]; // Pointer to UART Rx ring buffer INT8U rxput; // Pointer to first empty pos in Rx ring buffer INT8U rxget; // Pointer to first nonemtpy pos in Rx ring buffer INT16U rxtimer; // Byte receive timer // Transmit related data */ OS_EVENT *txsem; // Tx waiting semaphore INT8U txbuf[UART_TXBUF_SIZE]; // Pointer to UART Tx ring buffer INT8U txput; // Pointer to first empty pos in Tx ring buffer INT8U txget; // Pointer to first nonempty pos in Tx ring buffer INT16U txtimer; // Byte transmit timer }uart_uart;
/******************************************************************************** ****************************** * . STATIC DATA SECTION ******************************************************************************** ******************************/ static uart_uart uartbuf[UART_UART_SIZE];
/******************************************************************************** ****************************** * . DEFINITION SECTION ******************************************************************************** ******************************/ /*@-----------------------------------------------------------------------------------------------------------* | uart_InitUart() INITIALIZE UART SUBSYSTEM | | Syntax : | INT8S uart_InitUart(void) | | Arguments : | - | | Returns : | COM_NO_ERR - Function executed OK | | Description : | This function must be called at system startup before any UART related functions can be used | Function initializes UART internal data . | *------------------------------------------------------------------------------------------------------------*/ INT8S uart_InitUart(void) { INT8U cnt;
for(cnt =0; cnt < UART_UART_SIZE; cnt++) // Block all UARTs uartbuf[cnt].state = UART_STATE_CLOSE;
return COM_NO_ERR; }
/*@-----------------------------------------------------------------------------------------------------------* | uart_OpenUart() OPEN AND CONFIGURE UART PORT | | Syntax : | INT8S uart_OpenUart(INT8U port,INT16U rxtimer,INT16U txtimer,INT8U speed,INT8U length,INT8U parity,INT8U stopbit) | | Arguments : | INT8U port Port Identifier - UART_1, or UART_2 | INT8U rxtimer Receive timer value in number of clock ticks | INT8U txtimer Transmit timer value in number of clock ticks | INT8U speed UART speed - in form UART_SPEED_XXX, where XXX could be (300, 600, 1200, 2400, 4800, | 9600, 14400, 19200, 38400, 57600, 115200. | INT8U length Word data length - in form UART_SIZE_X, where X could be 5, 6, 7, 8, 9 | INT8U parity Parity setting - one of the UART_PARITY_EVEN, UART_PARITY_ODD, UART_PARITY_NONE | INT8U stopbit Stop bits setting - UART_STOPBIT_1, UART_STOPBT_15 and UART_STOPBIT_2 | | | Returns : | COM_NO_ERR If function executes OK | COM_ERR_PORTID If port identifier supplied is not correct | COM_ERR_PORT_OPEN If port is already opened | COM_ERR_TX_SEM Fault when creating Tx semaphore | COM_ERR_RX_SEM Fault when creating Rx semaphore | | Description : | *------------------------------------------------------------------------------------------------------------*/ INT8S uart_OpenUart ( INT8U port, // UART port ID INT16U rxtimer, // UART receive timeout INT16U txtimer, // UART transmit timeout INT8U speed, // UART port speed INT8U length, // UART data word size INT8U parity, // UART parity settings INT8U stopbit // UART stop bits ) { uart_uart *uart_p;
if(port >= UART_UART_SIZE ) // Check port value return COM_ERR_PORTID; // uart_p = &uartbuf[port]; // Fetch pointer to port data record // if((uart_p->rxsem = OSSemCreate(0)) == NULL) // Create RX Semaphore return COM_ERR_RX_SEM; // uart_p->rxput = 0; // Reset read position from Rx ring buffer uart_p->rxget = 0; // Reset write position to Rx ring buffer uart_p->rxtimer = rxtimer; // Set uart_uart receive timer // if((uart_p->txsem = OSSemCreate(UART_TXBUF_SIZE -1)) == NULL) // Create TX semaphore return COM_ERR_TX_SEM; // uart_p->txput = 0; // init read position from Tx ring buffer uart_p->txget = 0; // init write position to Tx ring buffer uart_p->txtimer = txtimer; // set uart_uart transmitt timer uart_p->txstate = UART_TX_STATE_OFF; // Set txstate to OFF // uart_OpenPortAvr(port, speed, length, parity, stopbit); // initalize platform dependent port data uart_p->state = UART_STATE_OPEN; // Bring port to traffic // return COM_NO_ERR; // }
/*@-----------------------------------------------------------------------------------------------------------* | uart_CloseUart() CLOSE UART PORT AND FREE ITS RESOURCES | | Syntax : | INT8S uart_CloseUart(INT8U port) | | Arguments : | COM_ERR_PORTID - Port Id assigned invalid value | COM_ERR_PORT_CLOSED - Port already in closed state | COM_NO_ERR - Function executed OK | | Returns : | COM_ERR_PORTID - Invalid (nonexisting) port referred | COM_NO_ERR - Function executed OK | | Description : | Function closes uart port and release its allocated reasources. | *------------------------------------------------------------------------------------------------------------*/ INT8S uart_CloseUart(INT8U port) { uart_uart *uart_p; INT8U err;
if(port >= UART_UART_SIZE ) // Validate port value return COM_ERR_PORTID; uart_p = &uartbuf[port]; // Select port to close if(uart_p->state == UART_STATE_CLOSE) // Check port state return COM_NO_ERR;
uart_p->state = UART_STATE_CLOSE; // Set port state uart_ClosePortAvr(port); // Down the port on platform dependent side OSSemDel(uart_p->rxsem, OS_DEL_ALWAYS, &err); // Delete receive semaphore OSSemDel(uart_p->txsem, OS_DEL_ALWAYS, &err); // Delete transmit semaphore
/*@-----------------------------------------------------------------------------------------------------------* | uart_PutByte() SEND BYTE OVER UART PORT FUNCTION | | Syntax : | INT8S uart_PutByte(INT8U portid, INT8U byte ) | | Arguments : | INT8U portid - UART port identifier | INT8U byte - byte to send | | Return values : | COM_NO_ERR Character sent to transmit buffer OK | COM_ERR_PORT_CLOSED The port where transmit is attempted is not opened | COM_ERR_TX_SEM Problem occured on UART's TX semaphore | | Description : | The function is used to transfer one single byte over UART port . | *------------------------------------------------------------------------------------------------------------*/ INT8S uart_PutByte(INT8U portid, INT8U byte ) { #if OS_CRITICAL_METHOD == 3 // Allocate storage for CPU status register OS_CPU_SR cpu_sr; // #endif // INT8U err; // temp var for error uart_uart *uart_p; // pointer to uart data structure // if(portid >= UART_UART_SIZE) // Check port value return -1; // // uart_p = &uartbuf[portid]; // Fetch pointer to uart data record if(uart_p->state == UART_STATE_CLOSE) // Validate UART state return COM_ERR_PORT_CLOSED; // // if(uart_p->txstate == UART_TX_STATE_OFF) // If no ongoing transmit is active - send byte directly to port { // uart_p->txstate = UART_TX_STATE_ON; // Mar TX is active uart_StartTxAvr(portid, byte); // Invoke port gunction to send byte to the port } // else // Else if Transmitt is ongoing - put byte to transmit buffer { // OSSemPend(uart_p->txsem, 0, &err); // Wait on Tx Semaphore if buffer full if(err != OS_NO_ERR) // If semaphore error return COM_ERR_TX_SEM; // return error // OS_ENTER_CRITICAL(); // uart_p->txbuf[uart_p->txput++] = byte; // Put byte into transmit ring buffer if(uart_p->txput == UART_TXBUF_SIZE) // Increment ring buffer pointer uart_p->txput = 0; // OS_EXIT_CRITICAL(); // } // return COM_NO_ERR; // Return OK }
/*@-----------------------------------------------------------------------------------------------------------* | uart_GetByte() RECEIVE BYTE FORM UART PORT FUNCTION | | Syntax : | INT8S uart_GetByte(INT8U port, INT8U* rxbyte) | | Arguments : | INT8U port - UART port identifier | INT8U* rxbyte - Pointer to memory where received character will be stored | | Returns : | COM_NO_ERR - OK result | COM_ERR_PORT_CLOSED - Port is not initialised | COM_ERR_RX_TIMEOUT - Receive timeout occured | COM_ERR_RX_SEM - Problem with Rx semaphore happened | | Description : | Function receives one byte from the uart port. If byte is received OK it will be stored in memory | pointed by *rxbyte. Function will return error: | - if uart_OpenUart() fucntion was not invoked before on referred port | - if no byte received within uart timeout | - if system error with rx semaphore happened | *------------------------------------------------------------------------------------------------------------*/ INT8S uart_GetByte(INT8U port, INT8U* rxbyte) { #if OS_CRITICAL_METHOD == 3 // Allocate storage for CPU status register OS_CPU_SR cpu_sr; // #endif // uart_uart *uart_p; // pointer to port data INT8U err; // error var for semaphore handling // if(port >= UART_UART_SIZE) // Check uart port id return COM_ERR_PORT_CLOSED; // uart_p = &uartbuf[port]; // select port data to use if(uart_p->state == UART_STATE_CLOSE) // if port is not opened return COM_ERR_PORT_CLOSED; // return error - 'attempt to use closed port' // OSSemPend(uart_p->rxsem, uart_p->rxtimer, &err); // Wait for byte from Rx line switch(err) // Branch on the result { // case OS_NO_ERR : break; // Byte is ready - proceed case OS_TIMEOUT: return COM_ERR_RX_TIMEOUT; // Semaphore timeout default : return COM_ERR_RX_SEM; // Semaphore or OS problem } // // if(uart_p->rxget == uart_p->rxput) // Check if there is byte to process return COM_ERR_RX_TIMEOUT; // This is not needed as semaphore handles that // Extract received character from ring buffer OS_ENTER_CRITICAL(); // *rxbyte = uart_p->rxbuf[uart_p->rxget++]; // read byte from Rx ring buffer if(uart_p->rxget== UART_RXBUF_SIZE) // if overflow on Rx ring buffer ? uart_p->rxget = 0; // wrap around ring buffer OS_EXIT_CRITICAL();
/*------------------------------------------------------------------------------------------------------------* | uart_PutByteIsr() - PUT RECEIVED BUFFER INTO RX BUFFER FUNCTION | | Syntax : | INT8S uart_PutByteIsr(INT8U port, INT8U byte) | | Arguments : | INT8U port - Uart port id | INT8U byte - Byte to store in rx buffer | | Returns : | COM_ERR_PORT_CLOSED - Port is not ready | COM_ERR_RXBUF_FULL - RX buffer full | COM_NO_ERR - Function executed OK | | Description : | The function is called from ISR device dependent uart source when new character received | from Rx line . | *------------------------------------------------------------------------------------------------------------*/ INT8S uart_PutByteIsr(INT8U port, INT8U byte) { #if OS_CRITICAL_METHOD == 3 // Allocate storage for CPU status register OS_CPU_SR cpu_sr; // #endif // uart_uart *uart_p; // // uart_p = &uartbuf[port]; // Select port data to use if(uart_p->state == UART_STATE_CLOSE) // If port is not ready return COM_ERR_PORT_CLOSED; // return error - 'attempt to use closed port' // OS_ENTER_CRITICAL(); // uart_p->rxbuf[uart_p->rxput] = byte; // Store byte in Rx ring buffer if(++(uart_p->rxput) == UART_RXBUF_SIZE) // Increment write pointer to rx buffer uart_p->rxput = 0; // wrap around Rx ring buffer read pointer // if(uart_p->rxput == uart_p->rxget) // if Rx ring buffer full ? { // uart_p->rxget++; // discard oldest character in ring buffer OS_EXIT_CRITICAL(); // disable interrupt and DO NOT POST SEMAPHORE return COM_ERR_RXBUF_FULL; // return error - 'Rx ring buffer full' } // OSSemPost(uart_p->rxsem); // Post semaphore to user task OS_EXIT_CRITICAL(); // // return COM_NO_ERR; // Return OK }
/*------------------------------------------------------------------------------------------------------------* | uart_GetByteIsr() - get byte from transmit buffer to send | | Syntax : | INT8S uart_GetByteIsr(INT8U portid, INT8U *byte) | | Arguments : | INT8U portid | INT8U *byte | | Returns : | Description : | The function is called from ISR when hardware completes character transfer on Tx line and ready to | transmit new character . When porting this code - hardware dependent function must analyse return | code from this function as follow : | - If return code is COM_NO_ERR transfer must proceed | - If return code either COM_ERR_PORT_CLOSED or COM_ERR_TXBUF_EMPTY transfer must be stopped | and Transmit interrupts must be disabled . | *------------------------------------------------------------------------------------------------------------*/ INT8S uart_GetByteIsr(INT8U portid, INT8U *byte) { #if OS_CRITICAL_METHOD == 3 // Allocate storage for CPU status register OS_CPU_SR cpu_sr; // #endif // uart_uart *uart_p; // pointer to uart data structure // uart_p = &uartbuf[portid]; // select port data // if(uart_p->state == UART_STATE_CLOSE) // if port is not opened return COM_ERR_PORT_CLOSED; // return error - 'attempt to use closed port' // Fetch byte from TX buffer if(uart_p->txget != uart_p->txput) // If TX buffer IS NOT EMPTY { // OS_ENTER_CRITICAL(); // Disable interrupts *byte = uart_p->txbuf[uart_p->txget]; // Get character from Tx ring buffer if(++(uart_p->txget) == UART_TXBUF_SIZE) // Increment read pointer uart_p->txget = 0; // OS_EXIT_CRITICAL(); // Enable interrupts OSSemPost(uart_p->txsem); // Post TX semaphore } // else // Else if Tx buffer is EMPTY { // uart_p->txstate = UART_TX_STATE_OFF; // set transimt state to passive return COM_ERR_TXBUF_EMPTY; // and report error - 'tx ring buffer empty' } // return COM_NO_ERR; // }
/******************************************************************************** ****************************** * . SECTIONS END ******************************************************************************** ******************************/
Зачем лаять на караван , когда на него можно плюнуть?
Karl WINAvr или IAR? Aug 18 2005, 09:19 IgorKossak Это не столько трата времени, сколько полезное осв... Aug 18 2005, 12:36 halfdoom С точки зрения качества генерируемого кода IAR без... Aug 19 2005, 04:42 Karl Попробую написать следующий проект на IAR. Всвязи ... Aug 19 2005, 08:24 ReAl Цитата(halfdoom @ Aug 19 2005, 07:42)С точки ... Aug 29 2005, 12:50  m16 Давно избитая тема но сравнение компиляторов ... Aug 29 2005, 13:17   IgorKossak Цитата(m16 @ Aug 29 2005, 16:17)Давно и... Aug 29 2005, 14:46    AVR ЦитатаIAR понравился сразу (ибо есть большой опыт ... Oct 26 2005, 20:34     IgorKossak Цитата(AVR @ Oct 26 2005, 23:34)Существуют ли... Oct 27 2005, 06:26      AVR Цитата(IgorKossak @ Oct 27 2005, 10:26)Цитата... Oct 27 2005, 20:18       lazycamel Цитата(AVR @ Oct 27 2005, 23:18)Есть ли прогр... Oct 28 2005, 04:21        m16 Цитата(AVR @ Oct 27 2005, 23:18)Есть ли прогр... Oct 28 2005, 07:50 VladislavS Качать однозначно последнюю с сайта разработчика. ... Aug 19 2005, 08:48 Karl Последняя версия - EWAVR 4.10B? Aug 19 2005, 09:22  Igor26 Цитата(Karl @ Aug 19 2005, 12:22)Последняя ве... Aug 19 2005, 09:33   Igor26 Цитата(Igor26 @ Aug 19 2005, 12:33)Цитата(Kar... Aug 19 2005, 09:41    Karl Цитата(Igor26 @ Aug 19 2005, 14:41)Цитата(Igo... Aug 19 2005, 10:01     Igor26 Цитата(Karl @ Aug 19 2005, 13:01)Цитата(Igor2... Aug 19 2005, 10:05      Karl А где бы раздобыть примерчики проектов под IAR? Aug 22 2005, 05:28       BVU Цитата(Karl @ Aug 22 2005, 09:28)А где бы раз... Aug 22 2005, 05:49        Karl Спасибо, tutorials.eww нашел. Изучаю Aug 22 2005, 06:18         Karl Что-то я библиотек стандартных функций в ИАР найти... Aug 22 2005, 08:46          BVU Цитата(Karl @ Aug 22 2005, 12:46)Что-то я биб... Aug 22 2005, 08:56           Karl не стандартные, но очень удобные при разработке . Aug 22 2005, 08:59            BVU Цитата(Karl @ Aug 22 2005, 12:59)не стандартн... Aug 22 2005, 09:43 axis Доброго времени, Все.
Что характерно - буржуи с a... Aug 22 2005, 12:58 dxp Цитата(axis @ Aug 22 2005, 18:58)Что характер... Aug 22 2005, 13:34  axis Цитата(dxp @ Aug 22 2005, 19:34)Цитата(axis ... Aug 23 2005, 11:26 IgorKossak Что касается буржуйских форумов, то надо знать их ... Aug 23 2005, 08:32 beer_warrior Серьезным преимуществом IAR IMHO являеться более у... Oct 27 2005, 08:15 dxp Цитата(beer_warrior @ Oct 27 2005, 14:15)Серь... Oct 27 2005, 09:41 IgorKossak Цитата(beer_warrior @ Oct 27 2005, 11:15)... ... Oct 27 2005, 10:12 ROC Кто тут "С"шные библиотеки искал?
Есть ... Oct 28 2005, 08:08 AVR Большое спасибо за эти ценные ссылки. Oct 28 2005, 17:41 INT1 тоже добавлю
http://www.procyonengineering.com/ Oct 29 2005, 05:39 AVR Цитата(INT1 @ Oct 29 2005, 09:39)тоже добавлю... Oct 29 2005, 10:32 INT1 Но вопос ведь темы WINAvr или IAR? или уже ИАР? Oct 29 2005, 17:59 Waso Спасибо за
http://ccrma.stanford.edu/courses/250a... Dec 17 2005, 20:09
