> Soft UART
Серега
сообщение Nov 17 2005, 14:52
Пользователь №: 9 660
Помогите пожалуйста. Проблема с софт УАПП.
Взял пример. Работает.
//  MSP-FET430x110 Demo - Timer_A UART 115k, 16MHz DCO SMCLK
//  Description: This program demonstrates a full-duplex 115k-baud UART using
//  Timer_A3 and a the DCO. A character is echoed on the Hyperterminal of a
//  a PC. The DCO frequency settings are stored in INFOA flash segment.
//  ACLK = LFXT1 = 32768, MCLK = SMCLK = saved DCO 16MHz
//  //* External watch crystal installed on XIN XOUT is required for ACLK *//
//               MSP430F21x1
//        /|\|              XIN|-
//         | |                 | 32kHz
//         --|RST          XOUT|-
//           |             P1.3|--------> Power for MAX3221
//           |   CCI0A/TXD/P1.1|-------->
//           |                 | 115200 8N1
//           |   CCI0B/RXD/P2.2|<--------
//   H. Grewal / A. Dannenberg
//   Texas Instruments, Inc
//   July 2005
//   Built with IAR Embedded Workbench Version: 3.30A
#include <msp430x21x1.h>
#define RXD   0x04                          // RXD on P2.2
#define TXD   0x02                          // TXD on P1.1
//   Conditions for 115200 Baud SW UART, DCO = 16000000Hz
#define Bitime_5  69                       // ~ 0.5 bit length
#define Bitime    138                      // ~ 115942 baud
unsigned int RXTXData;
unsigned char BitCnt;
void TX_Byte(void);
void RX_Ready(void);
void main (void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  BCSCTL1 = CALBC1_16MHZ;                   // Set DCO
  DCOCTL = CALDCO_16MHZ;
  TACTL = TASSEL_2 + MC_2 + TACLR;          // SMCLK, cont-mode, clear
  CCTL0 = OUT;                              // TXD Idle as Mark
  P1SEL = TXD;                              // P1.1/TA0 for TXD function
  P1DIR = TXD;                              // TXD output on P1
  P2SEL = RXD;                              // P2.2/TA0 as RXD input
  P1DIR |= 0x08;                            // Power MAX3221
  P1OUT |= 0x08;                            //
// Mainloop
  for (;;)
  RX_Ready();                               // UART ready to RX one Byte
  _BIS_SR(LPM3_bits + GIE);                 // Enter LPM3 w/ interr until char RXed
  TX_Byte();                                // TX Back RXed Byte Received
// Function Transmits Character from RXTXData Buffer
void TX_Byte (void)
  BitCnt = 0xA;                             // Load Bit counter, 8data + ST/SP
  CCR0 = TAR;                               // Current state of TA counter
  CCR0 += Bitime;                           // Some time till first bit
  RXTXData |= 0x100;                        // Add mark stop bit to RXTXData
  RXTXData = RXTXData << 1;                 // Add space start bit
  CCTL0 = OUTMOD0 + CCIE;                   // TXD = mark = idle
  while ( CCTL0 & CCIE );                   // Wait for TX completion
// Function Readies UART to Receive Character into RXTXData Buffer
// Sync capture not possible as DCO=TACLK=SMCLK can be off !!
void RX_Ready (void)
  BitCnt = 0x8;                             // Load Bit counter
  CCTL0 = CM1 + CCIS0 + OUTMOD0 + CAP + CCIE; // Neg Edge, Cap
// Timer A0 interrupt service routine
#pragma vector=TIMERA0_VECTOR
__interrupt void Timer_A (void)
  CCR0 += Bitime;                           // Add Offset to CCR0
// RX
  if (CCTL0 & CCIS0)                        // RX on CCI0B?
    if( CCTL0 & CAP )                       // Capture mode = start bit edge
    CCTL0 &= ~ CAP;                         // Switch from capture to compare mode
    CCR0 += Bitime_5;
    _BIC_SR_IRQ(SCG1 + SCG0);               // DCO reamins on after reti
    else
    RXTXData = RXTXData >> 1;
      if (CCTL0 & SCCI)                     // Get bit waiting in receive latch
      RXTXData |= 0x80;
      BitCnt --;                            // All bits RXed?
      if ( BitCnt == 0)
//>>>>>>>>>> Decode of Received Byte Here <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      CCTL0 &= ~ CCIE;                      // All bits RXed, disable interrupt
      _BIC_SR_IRQ(LPM3_bits);               // Clear LPM3 bits from 0(SR)
// TX
  else
    if ( BitCnt == 0)
    CCTL0 &= ~ CCIE;                        // All bits TXed, disable interrupt
    else
      CCTL0 |=  OUTMOD2;                    // TX Space
      if (RXTXData & 0x01)
      CCTL0 &= ~ OUTMOD2;                   // TX Mark
      BitCnt --;
Далее переделал для работы от кварца и на другую скорость. Выше скорости 2800 бод/с посылает нули вместо данных. Скорость же нужна 115200 бод/с.
#define TXD   0x02
// 2800 бод
#define Bitime_5  1786
#define Bitime    3571
unsigned int RXTXData, i;
void TX_Byte(void);
void main (void)
    BCSCTL1 = XTS;
    BCSCTL2 = SELM_3 + SELS;
    BCSCTL3 = LFXT1S_2;
    TACTL = TASSEL_2 + MC_2;              // SMCLK, cont-mode, clear
  _EINT();
  for (;;)
    RXTXData = 0x71;
    TX_Byte();
    for (i = 0xFFF; i > 0; i--);        // Delay
void TX_Byte (void)
// TX
    if ( BitCnt == 0)
    else
      BitCnt --;
Серега
сообщение Nov 17 2005, 19:08
Сорри, кварц на 16 МГц.
"Это очень жестоко. Особенно приём."
Идет в основном передача данных, пока можно и без приема обойтись.
Проблема в том что при внешнем кварце скорость выше 2800 бод/с достигнуть не удается.
Сообщение отредактировал Серега - Nov 17 2005, 19:09
RSS Текстовая версия Сейчас: 3rd August 2025 - 08:13
