> Frequency counter, на LPC2214
Shedon
сообщение Nov 17 2005, 09:52
Из: Nizhny Novgorod
Пользователь №: 1 262
Есть желание зделать на capture LPC2214 подсчёт импульсов, вопрос до какой максимальной частоты я смогу считать импульсы и с какой точностью ? Fosc = 10MHz(с кварцевого генератора "СОНАТА" класса А), pll будет множить на 6, т.е. частота cclk=60MHz.
Shedon
сообщение Nov 18 2005, 14:37
Из: Nizhny Novgorod
Вообще надо подсчитать сколько тактов на все деяния уходит, тогда точно предельную частоту узнаем.
Вот что по этому поводу в Technical Reference Manual пишут:
2.9 Interrupt latencies
The calculations for maximum and minimum latency are described in:
• Maximum interrupt latencies
• Minimum interrupt latencies.
2.9.1 Maximum interrupt latencies
When FIQs are enabled, the worst-case latency for FIQ comprises a combination of:
Tsyncmax The longest time the request can take to pass through the synchronizer.
Tsyncmax is four processor cycles.
Tldm The time for the longest instruction to complete. The longest instruction
is an LDM that loads all the registers including the PC. Tldm is 20 cycles
in a zero wait state system.
Texc The time for the Data Abort entry. Texc is three cycles.
Tfiq The time for FIQ entry. Tfiq is two cycles.
The total latency is therefore 29 processor cycles, just over 0.7 microseconds in a
system that uses a continuous 40MHz processor clock. At the end of this time, the
ARM7TDMI processor executes the instruction at 0x1c.
The maximum IRQ latency calculation is similar, but must allow for the fact that FIQ,
having higher priority, can delay entry into the IRQ handling routine for an arbitrary
length of time.
2.9.2 Minimum interrupt latencies
The minimum latency for FIQ or IRQ is the shortest time the request can take through
the synchronizer, Tsyncmin, plus Tfiq, a total of five processor cycles.
- Shedon   Frequency counter   Nov 17 2005, 09:52
- - Serjio   Если имульсы подавать на счетчик - то только его б...   Nov 18 2005, 09:04
|- - KRS   Цитата(Shedon @ Nov 17 2005, 12:52) Есть ...   Nov 18 2005, 09:23
- - Shedon   Цитатаесли настроить таймер с минимальным прескале...   Nov 18 2005, 11:41
|- - KRS   Цитата(Shedon @ Nov 18 2005, 14:41) Цитат...   Nov 18 2005, 11:53
- - Shedon   ЦитатаВот если надо померять частоту это другой во...   Nov 18 2005, 11:55
|- - KRS   Цитата(Shedon @ Nov 18 2005, 14:55) Цитат...   Nov 18 2005, 12:12
- - Shedon   ЦитатаЗесечь время можно довольно точно на LPC про...   Nov 18 2005, 12:19
- - bombastic   2Shedon Не парься, возми 51, его таймер умеет счит...   Nov 18 2005, 12:38
- - Shedon   ЦитатаНе парься, возми 51, его таймер умеет считат...   Nov 18 2005, 12:43
- - rezident   Есть два способа реализации частотомера. Метод ...   Nov 18 2005, 13:18
- - Shedon   Наверное придётся делить частоту, и мерить период.   Nov 18 2005, 13:28
- - moonrock   Даа, касяк.. Не думал что у LPC нету счетного вход...   Nov 18 2005, 14:11
- - Shedon   ну я здесь не вижу преимуществ перед capture, т.е....   Nov 18 2005, 14:17
- - moonrock   Ну да..тоже должно получиться. Вам ведь 4 МГц надо...   Nov 18 2005, 14:21
- - zltigo   Цитата(Shedon @ Nov 17 2005, 12:52) Есть ...   Nov 18 2005, 15:16
|- - Perepic   Цитата(zltigo @ Nov 18 2005, 19:16) Качес...   May 31 2007, 07:44
|- - zltigo   Цитата(Perepic @ May 31 2007, 10:44) Ну э...   May 31 2007, 21:11
- - rezident   Про Interrupt latency ARMов недавно в пустыне обсу...   Nov 18 2005, 15:19
- - moonrock   Shedon: Похоже мы вас в заблуждение ввели. В ман...   Nov 21 2005, 06:46
|- - KRS   Цитата(moonrock @ Nov 21 2005, 09:46) She...   Nov 21 2005, 08:28
- - moonrock   Стреляйте! Я на другой проц даташит открыл. Де...   Nov 21 2005, 08:39
- - Make_Pic   Цитата(moonrock @ Nov 21 2005, 11:39) Ст...   Jun 1 2007, 08:23
- - viael   Цитата(Make_Pic @ Jun 1 2007, 12:23) Став...   Jun 4 2007, 07:06
RSS Текстовая версия Сейчас: 26th July 2025 - 06:17
Страница сгенерированна за 0.0137 секунд с 7
