> WinAVR-20090313. Непонятная бага
_Pasha
сообщение Sep 30 2009, 16:05
Пользователь №: 29 509
Всем привет!
Исходничег:
int main(void) __attribute__ ((OS_main));
static inline uint8_t bit_swp(const uint8_t reg)__attribute__ ((always_inline));
volatile uint8_t a;
int main(void)
uint8_t b = a;
b =  bit_swp(b);
a=b;
return 0;
uint8_t www=0;
if(reg & 0x80) www |= 0x20;
if(reg & 0x40) www |= 0x80;
if(reg & 0x20) www |= 0x02;
if(reg & 0x10) www |= 0x01;
return www;
Листинг вызова bit_swp() начинается с непонятного действия
  86:    28 2f           mov    r18, r24
  88:    22 1f           adc    r18, r18
  8a:    22 27           eor    r18, r18
  8c:    22 1f           adc    r18, r18
  8e:    22 95           swap    r18
  90:    22 0f           add    r18, r18
  92:    20 7e           andi    r18, 0xE0; 224
А далее - все как должно быть
CODE
94: 86 fd sbrc r24, 6
96: 20 68 ori r18, 0x80 ; 128
98: 85 fd sbrc r24, 5
9a: 22 60 ori r18, 0x02 ; 2
9c: 84 fd sbrc r24, 4
9e: 21 60 ori r18, 0x01 ; 1
int main(void)
uint8_t b = a;
b = bit_swp(cool.gif;
a=b;
a0: 20 93 02 01 sts 0x0102, r18
return 0;
a4: 80 e0 ldi r24, 0x00 ; 0
a6: 90 e0 ldi r25, 0x00 ; 0
a8: 08 95 ret
-------- begin --------
avr-gcc (WinAVR 20090313) 4.3.2
Copyright © 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Compiling C: test.c
C:/WinAVR-20090313/bin/avr-gcc -c -mmcu=atmega48 -I. -gdwarf-2 -DF_CPU=8000000UL
-Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wst
rict-prototypes -Wa,-adhlns=./test.lst -std=gnu99 -fno-split-wide-types -mcall-
prologues --param inline-call-cost=3 -fno-unroll-loops -MMD -MP -MF .dep/test.o.
d test.c -o test.o
Linking: test.elf
C:/WinAVR-20090313/bin/avr-gcc -mmcu=atmega48 -I. -gdwarf-2 -DF_CPU=8000000UL -O
s -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstric
t-prototypes -Wa,-adhlns=test.o -std=gnu99 -fno-split-wide-types -mcall-prologu
es --param inline-call-cost=3 -fno-unroll-loops -MMD -MP -MF .dep/test.elf.d tes
t.o led7s.o --output test.elf -Wl,-Map=test.map,--cref -lm
Creating load file for Flash: test.hex
C:/WinAVR-20090313/bin/avr-objcopy -O ihex -R .eeprom -R .fuse -R .lock test.elf
test.hex
Бага или нет?
singlskv
сообщение Sep 30 2009, 17:36
дятел
Из: Питер
Пользователь №: 17 065
Цитата(_Pasha @ Sep 30 2009, 20:05) *
Бага или нет?
Ну вроде как не бага, но оптимизатор там сильно переклинило
Кстати, а какой уровень оптимизации ?
  86:    28 2f           mov    r18, r24  <- типа передаем параметр в временную переменную
  88:    22 1f           adc    r18, r18  <- ставим флаг С если (www&0x80)
  8a:    22 27           eor    r18, r18  <- обнуляем www
  8c:    22 1f           adc    r18, r18  <- пишем С в младший бит www
  8e:    22 95           swap    r18  <- переносим бит С в 4 бит(0x10) www
  90:    22 0f           add    r18, r18  <- переносим его в 5 бит(0x20) www
  92:    20 7e           andi    r18, 0xE0; 224  <- ну и еще маску зачем-то
_Pasha
сообщение Sep 30 2009, 18:02
-Os
Самое интересное: попытался поменять if(reg & 0x80) www |= 0x20; на что-нить, не связанное с инструкцией rol (т.е. не крайние биты проверять вначале) - результат тоже такой сумбурный smile.gif Именно при входе.
RSS Текстовая версия Сейчас: 29th July 2025 - 10:29
Страница сгенерированна за 0.01372 секунд с 7
