> MSP-GCC 4. Кто-нибудь пробовал?, Случайно наткнулся:)
AHTOXA
сообщение Oct 6 2009, 11:27
фанат дивана
Из: Уфа
Пользователь №: 29 684
http://mspgcc4.sourceforge.net/
Пишут, что
GCC 4.x has several advantages over the old 3.2.3 branch. Here are the most important:
  • Better optimization. The generated code is typically 7%-10% smaller than code generated by MSPGCC-3.2.3
  • Better debug info support. The objdump utility displays the mixed assembly/code correctly.
  • Better C++ and inlining support. Unused local variables are automatically filtered out. Inline functions are implemented in a much more compact way.
  • Support for various handy features. For example, gcc 4.3 correctly handles the #pragma once statements.
  • Additionally, the MSPGCC4 port fixes the data-sections bug present in all original MSPGCC versions, allowing using -ffunction-sections and -fdata-sections switches.
Насчёт -ffunction-sections and -fdata-sections врут похоже, у меня и с ними и в текущем msp-gcc нет проблем.
Короче, если кто-то пробовал, поделитесь пожалуйста впечатлениями.
MrYuran
сообщение Nov 6 2009, 12:49
Беспросветный оптимист
Из: Н.Новгород
Пользователь №: 33 646
CODE
#if !defined(__msp430_headers_usci_h__)
#define __msp430_headers_usci_h__
/* usi.h
* mspgcc project: MSP430 device headers
* USCI module header
* © 2006 by Steve Underwood <steveu@coppice.org>
* Originally based in part on work by Texas Instruments Inc.
* $Id: usci.h,v 1.7 2009/06/04 21:55:18 cliechti Exp $
* 2008-02-05 - modifications by G.Lemm <msp430@daqtix.com>
* - added UC1IE and UC1IFG registers
* - added UC*1*IE and UC*1*IFG bit definitions
* 2009-05-19 - modifications by S. Balling <praktikum@innoventis.de>
* - added switch for USCI0
* - added USCI0_5
* - added USCI1_5
* - added USCI2_5
* - added USCI3_5
/* Switches:
__MSP430_HAS_USCI0__ - if device has USCI0
__MSP430_HAS_USCI1__ - if device has USCI1
__MSP430_HAS_USCI0_5__ - if device has USCI0 and is part of family 5
__MSP430_HAS_USCI1_5__ - if device has USCI1 and is part of family 5
__MSP430_HAS_USCI2_5__ - if device has USCI2 and is part of family 5
__MSP430_HAS_USCI3_5__ - if device has USCI3 and is part of family 5
#define USIPE7 (0x80) /* USI Port Enable Px.7 */
#define USIPE6 (0x40) /* USI Port Enable Px.6 */
#define USIPE5 (0x20) /* USI Port Enable Px.5 */
#define USILSB (0x10) /* USI LSB first 1:LSB / 0:MSB */
#define USIMST (0x08) /* USI Master Select 0:Slave / 1:Master */
#define USIGE (0x04) /* USI General Output Enable Latch */
#define USIOE (0x02) /* USI Output Enable */
#define USISWRST (0x01) /* USI Software Reset */
#define USICKPH (0x80) /* USI Sync. Mode: Clock Phase */
#define USII2C (0x40) /* USI I2C Mode */
#define USISTTIE (0x20) /* USI START Condition interrupt enable */
#define USIIE (0x10) /* USI Counter Interrupt enable */
#define USIAL (0x08) /* USI Arbitration Lost */
#define USISTP (0x04) /* USI STOP Condition received */
#define USISTTIFG (0x02) /* USI START Condition interrupt Flag */
#define USIIFG (0x01) /* USI Counter Interrupt Flag */
#define USIDIV2 (0x80) /* USI Clock Divider 2 */
#define USIDIV1 (0x40) /* USI Clock Divider 1 */
#define USIDIV0 (0x20) /* USI Clock Divider 0 */
#define USISSEL2 (0x10) /* USI Clock Source Select 2 */
#define USISSEL1 (0x08) /* USI Clock Source Select 1 */
#define USISSEL0 (0x04) /* USI Clock Source Select 0 */
#define USICKPL (0x02) /* USI Clock Polarity 0:Inactive=Low / 1:Inactive=High */
#define USISWCLK (0x01) /* USI Software Clock */
#define USIDIV_0 (0x00) /* USI Clock Divider: 0 */
#define USIDIV_1 (0x20) /* USI Clock Divider: 1 */
#define USIDIV_2 (0x40) /* USI Clock Divider: 2 */
#define USIDIV_3 (0x60) /* USI Clock Divider: 3 */
#define USIDIV_4 (0x80) /* USI Clock Divider: 4 */
#define USIDIV_5 (0xA0) /* USI Clock Divider: 5 */
#define USIDIV_6 (0xC0) /* USI Clock Divider: 6 */
#define USIDIV_7 (0xE0) /* USI Clock Divider: 7 */
#define USISSEL_0 (0x00) /* USI Clock Source: 0 */
#define USISSEL_1 (0x04) /* USI Clock Source: 1 */
#define USISSEL_2 (0x08) /* USI Clock Source: 2 */
#define USISSEL_3 (0x0C) /* USI Clock Source: 3 */
#define USISSEL_4 (0x10) /* USI Clock Source: 4 */
#define USISSEL_5 (0x14) /* USI Clock Source: 5 */
#define USISSEL_6 (0x18) /* USI Clock Source: 6 */
#define USISSEL_7 (0x1C) /* USI Clock Source: 7 */
#define USISCLREL (0x80) /* USI SCL Released */
#define USI16B (0x40) /* USI 16 Bit Shift Register Enable */
#define USIFGDC (0x20) /* USI Interrupt Flag don't clear */
#define USICNT4 (0x10) /* USI Bit Count 4 */
#define USICNT3 (0x08) /* USI Bit Count 3 */
#define USICNT2 (0x04) /* USI Bit Count 2 */
#define USICNT1 (0x02) /* USI Bit Count 1 */
#define USICNT0 (0x01) /* USI Bit Count 0 */
// UART-Mode Bits
#define UCPEN (0x80) /* Async. Mode: Parity enable */
#define UCPAR (0x40) /* Async. Mode: Parity 0:odd / 1:even */
#define UCMSB (0x20) /* Async. Mode: MSB first 0:LSB / 1:MSB */
#define UC7BIT (0x10) /* Async. Mode: Data Bits 0:8-bits / 1:7-bits */
#define UCSPB (0x08) /* Async. Mode: Stop Bits 0:one / 1: two */
#define UCMODE1 (0x04) /* Async. Mode: USCI Mode 1 */
#define UCMODE0 (0x02) /* Async. Mode: USCI Mode 0 */
#define UCSYNC (0x01) /* Sync-Mode 0:UART-Mode / 1:SPI-Mode */
// SPI-Mode Bits
#define UCCKPH (0x80) /* Sync. Mode: Clock Phase */
#define UCCKPL (0x40) /* Sync. Mode: Clock Polarity */
#define UCMST (0x08) /* Sync. Mode: Master Select */
// I2C-Mode Bits
#define UCA10 (0x80) /* 10-bit Address Mode */
#define UCSLA10 (0x40) /* 10-bit Slave Address Mode */
#define UCMM (0x20) /* Multi-Master Environment */
//#define res (0x10) /* reserved */
#define UCMODE_0 (0<<1) /* Sync. Mode: USCI Mode: 0 */
#define UCMODE_1 (1<<1) /* Sync. Mode: USCI Mode: 1 */
#define UCMODE_2 (2<<1) /* Sync. Mode: USCI Mode: 2 */
#define UCMODE_3 (3<<1) /* Sync. Mode: USCI Mode: 3 */
// UART-Mode Bits
#define UCSSEL1 (0x80) /* USCI 0 Clock Source Select 1 */
#define UCSSEL0 (0x40) /* USCI 0 Clock Source Select 0 */
#define UCRXEIE (0x20) /* RX Error interrupt enable */
#define UCBRKIE (0x10) /* Break interrupt enable */
#define UCDORM (0x08) /* Dormant (Sleep) Mode */
#define UCTXADDR (0x04) /* Send next Data as Address */
#define UCTXBRK (0x02) /* Send next Data as Break */
#define UCSWRST (0x01) /* USCI Software Reset */
// SPI-Mode Bits
//#define res (0x20) /* reserved */
//#define res (0x08) /* reserved */
//#define res (0x04) /* reserved */
//#define res (0x02) /* reserved */
// I2C-Mode Bits
#define UCTR (0x10) /* Transmit/Receive Select/Flag */
#define UCTXNACK (0x08) /* Transmit NACK */
#define UCTXSTP (0x04) /* Transmit STOP */
#define UCTXSTT (0x02) /* Transmit START */
#define UCSSEL_0 (0<<6) /* USCI 0 Clock Source: 0 */
#define UCSSEL_1 (1<<6) /* USCI 0 Clock Source: 1 */
#define UCSSEL_2 (2<<6) /* USCI 0 Clock Source: 2 */
#define UCSSEL_3 (3<<6) /* USCI 0 Clock Source: 3 */
#define UCBRF3 (0x80) /* USCI First Stage Modulation Select 3 */
#define UCBRF2 (0x40) /* USCI First Stage Modulation Select 2 */
#define UCBRF1 (0x20) /* USCI First Stage Modulation Select 1 */
#define UCBRF0 (0x10) /* USCI First Stage Modulation Select 0 */
#define UCBRS2 (0x08) /* USCI Second Stage Modulation Select 2 */
#define UCBRS1 (0x04) /* USCI Second Stage Modulation Select 1 */
#define UCBRS0 (0x02) /* USCI Second Stage Modulation Select 0 */
#define UCOS16 (0x01) /* USCI 16-times Oversampling enable */
#define UCBRF_0 (0x0<<4) /* USCI First Stage Modulation: 0 */
#define UCBRF_1 (0x1<<4) /* USCI First Stage Modulation: 1 */
#define UCBRF_2 (0x2<<4) /* USCI First Stage Modulation: 2 */
#define UCBRF_3 (0x3<<4) /* USCI First Stage Modulation: 3 */
#define UCBRF_4 (0x4<<4) /* USCI First Stage Modulation: 4 */
#define UCBRF_5 (0x5<<4) /* USCI First Stage Modulation: 5 */
#define UCBRF_6 (0x6<<4) /* USCI First Stage Modulation: 6 */
#define UCBRF_7 (0x7<<4) /* USCI First Stage Modulation: 7 */
#define UCBRF_8 (0x8<<4) /* USCI First Stage Modulation: 8 */
#define UCBRF_9 (0x9<<4) /* USCI First Stage Modulation: 9 */
#define UCBRF_10 (0xA<<4) /* USCI First Stage Modulation: A */
#define UCBRF_11 (0xB<<4) /* USCI First Stage Modulation: B */
#define UCBRF_12 (0xC<<4) /* USCI First Stage Modulation: C */
#define UCBRF_13 (0xD<<4) /* USCI First Stage Modulation: D */
#define UCBRF_14 (0xE<<4) /* USCI First Stage Modulation: E */
#define UCBRF_15 (0xF<<4) /* USCI First Stage Modulation: F */
#define UCBRS_0 (0<<1) /* USCI Second Stage Modulation: 0 */
#define UCBRS_1 (1<<1) /* USCI Second Stage Modulation: 1 */
#define UCBRS_2 (2<<1) /* USCI Second Stage Modulation: 2 */
#define UCBRS_3 (3<<1) /* USCI Second Stage Modulation: 3 */
#define UCBRS_4 (4<<1) /* USCI Second Stage Modulation: 4 */
#define UCBRS_5 (5<<1) /* USCI Second Stage Modulation: 5 */
#define UCBRS_6 (6<<1) /* USCI Second Stage Modulation: 6 */
#define UCBRS_7 (7<<1) /* USCI Second Stage Modulation: 7 */
#define UCLISTEN (0x80) /* USCI Listen mode */
#define UCFE (0x40) /* USCI Frame Error Flag */
#define UCOE (0x20) /* USCI Overrun Error Flag */
#define UCPE (0x10) /* USCI Parity Error Flag */
#define UCBRK (0x08) /* USCI Break received */
#define UCRXERR (0x04) /* USCI RX Error Flag */
#define UCADDR (0x02) /* USCI Address received Flag */
#define UCBUSY (0x01) /* USCI Busy Flag */
#define UCIDLE (0x02) /* USCI Idle line detected Flag */
//#define res (0x80) /* reserved */
//#define res (0x40) /* reserved */
#define UCNACKIE (0x08) /* NACK Condition interrupt enable */
#define UCSTPIE (0x04) /* STOP Condition interrupt enable */
#define UCSTTIE (0x02) /* START Condition interrupt enable */
#define UCALIE (0x01) /* Arbitration Lost interrupt enable */
#define UCSCLLOW (0x40) /* SCL low */
#define UCGC (0x20) /* General Call address received Flag */
#define UCBBUSY (0x10) /* Bus Busy Flag */
#define UCNACKIFG (0x08) /* NAK Condition interrupt Flag */
#define UCSTPIFG (0x04) /* STOP Condition interrupt Flag */
#define UCSTTIFG (0x02) /* START Condition interrupt Flag */
#define UCALIFG (0x01) /* Arbitration Lost interrupt Flag */
#define UCIRTXPL5 (0x80) /* IRDA Transmit Pulse Length 5 */
#define UCIRTXPL4 (0x40) /* IRDA Transmit Pulse Length 4 */
#define UCIRTXPL3 (0x20) /* IRDA Transmit Pulse Length 3 */
#define UCIRTXPL2 (0x10) /* IRDA Transmit Pulse Length 2 */
#define UCIRTXPL1 (0x08) /* IRDA Transmit Pulse Length 1 */
#define UCIRTXPL0 (0x04) /* IRDA Transmit Pulse Length 0 */
#define UCIRTXCLK (0x02) /* IRDA Transmit Pulse Clock Select */
#define UCIREN (0x01) /* IRDA Encoder/Decoder enable */
#define UCIRRXFL5 (0x80) /* IRDA Receive Filter Length 5 */
#define UCIRRXFL4 (0x40) /* IRDA Receive Filter Length 4 */
#define UCIRRXFL3 (0x20) /* IRDA Receive Filter Length 3 */
#define UCIRRXFL2 (0x10) /* IRDA Receive Filter Length 2 */
#define UCIRRXFL1 (0x08) /* IRDA Receive Filter Length 1 */
#define UCIRRXFL0 (0x04) /* IRDA Receive Filter Length 0 */
#define UCIRRXPL (0x02) /* IRDA Receive Input Polarity */
#define UCIRRXFE (0x01) /* IRDA Receive Filter enable */
#define UCDELIM1 (0x20) /* Break Sync Delimiter 1 */
#define UCDELIM0 (0x10) /* Break Sync Delimiter 0 */
#define UCSTOE (0x08) /* Sync-Field Timeout error */
#define UCBTOE (0x04) /* Break Timeout error */
#define UCABDEN (0x01) /* Auto Baud Rate detect enable */
#define UCGCEN (0x8000) /* I2C General Call enable */
#define UCOA9 (0x0200) /* I2C Own Address 9 */
#define UCOA8 (0x0100) /* I2C Own Address 8 */
#define UCOA7 (0x0080) /* I2C Own Address 7 */
#define UCOA6 (0x0040) /* I2C Own Address 6 */
#define UCOA5 (0x0020) /* I2C Own Address 5 */
#define UCOA4 (0x0010) /* I2C Own Address 4 */
#define UCOA3 (0x0008) /* I2C Own Address 3 */
#define UCOA2 (0x0004) /* I2C Own Address 2 */
#define UCOA1 (0x0002) /* I2C Own Address 1 */
#define UCOA0 (0x0001) /* I2C Own Address 0 */
#define UCSA9 (0x0200) /* I2C Slave Address 9 */
#define UCSA8 (0x0100) /* I2C Slave Address 8 */
#define UCSA7 (0x0080) /* I2C Slave Address 7 */
#define UCSA6 (0x0040) /* I2C Slave Address 6 */
#define UCSA5 (0x0020) /* I2C Slave Address 5 */
#define UCSA4 (0x0010) /* I2C Slave Address 4 */
#define UCSA3 (0x0008) /* I2C Slave Address 3 */
#define UCSA2 (0x0004) /* I2C Slave Address 2 */
#define UCSA1 (0x0002) /* I2C Slave Address 1 */
#define UCSA0 (0x0001) /* I2C Slave Address 0 */
/* Aliases by mspgcc */
#define UCSSEL_UCLKI UCSSEL_0
#define UCSSEL_ACLK UCSSEL_1
#define UCSSEL_SMCLK UCSSEL_2
#if defined(__MSP430_HAS_USCI0__)
/* -------- USCI0 */
#define UCA0CTL0_ 0x0060 /* USCI A0 Control Register 0 */
sfrb(UCA0CTL0, UCA0CTL0_);
#define UCA0CTL1_ 0x0061 /* USCI A0 Control Register 1 */
sfrb(UCA0CTL1, UCA0CTL1_);
#define UCA0BR0_ 0x0062 /* USCI A0 Baud Rate 0 */
sfrb(UCA0BR0, UCA0BR0_);
#define UCA0BR1_ 0x0063 /* USCI A0 Baud Rate 1 */
sfrb(UCA0BR1, UCA0BR1_);
#define UCA0MCTL_ 0x0064 /* USCI A0 Modulation Control */
sfrb(UCA0MCTL, UCA0MCTL_);
#define UCA0STAT_ 0x0065 /* USCI A0 Status Register */
sfrb(UCA0STAT, UCA0STAT_);
#define UCA0RXBUF_ 0x0066 /* USCI A0 Receive Buffer */
/*READ_ONLY*/ sfrb(UCA0RXBUF, UCA0RXBUF_);
#define UCA0TXBUF_ 0x0067 /* USCI A0 Transmit Buffer */
sfrb(UCA0TXBUF, UCA0TXBUF_);
#define UCA0ABCTL_ 0x005D /* USCI A0 Auto baud/LIN Control */
sfrb(UCA0ABCTL, UCA0ABCTL_);
#define UCA0IRTCTL_ 0x005E /* USCI A0 IrDA Transmit Control */
sfrb(UCA0IRTCTL, UCA0IRTCTL_);
#define UCA0IRRCTL_ 0x005F /* USCI A0 IrDA Receive Control */
sfrb(UCA0IRRCTL, UCA0IRRCTL_);
#define UCB0CTL0_ 0x0068 /* USCI B0 Control Register 0 */
sfrb(UCB0CTL0, UCB0CTL0_);
#define UCB0CTL1_ 0x0069 /* USCI B0 Control Register 1 */
sfrb(UCB0CTL1, UCB0CTL1_);
#define UCB0BR0_ 0x006A /* USCI B0 Baud Rate 0 */
sfrb(UCB0BR0, UCB0BR0_);
#define UCB0BR1_ 0x006B /* USCI B0 Baud Rate 1 */
sfrb(UCB0BR1, UCB0BR1_);
#define UCB0I2CIE_ 0x006C /* USCI B0 I2C Interrupt Enable Register */
sfrb(UCB0I2CIE, UCB0I2CIE_);
#define UCB0STAT_ 0x006D /* USCI B0 Status Register */
sfrb(UCB0STAT, UCB0STAT_);
#define UCB0RXBUF_ 0x006E /* USCI B0 Receive Buffer */
/*READ_ONLY*/ sfrb(UCB0RXBUF, UCB0RXBUF_);
#define UCB0TXBUF_ 0x006F /* USCI B0 Transmit Buffer */
sfrb(UCB0TXBUF, UCB0TXBUF_);
#define UCB0I2COA_ 0x0118 /* USCI B0 I2C Own Address */
sfrw(UCB0I2COA, UCB0I2COA_);
#define UCB0I2CSA_ 0x011A /* USCI B0 I2C Slave Address */
sfrw(UCB0I2CSA, UCB0I2CSA_);
#endif /* __MSP430_HAS_USCI0__ */
#if defined(__MSP430_HAS_USCI1__)
/* -------- USCI1 */
#define UCA1CTL0_ 0x00D0 /* USCI A1 Control Register 0 */
sfrb(UCA1CTL0, UCA1CTL0_);
#define UCA1CTL1_ 0x00D1 /* USCI A1 Control Register 1 */
sfrb(UCA1CTL1, UCA1CTL1_);
#define UCA1BR0_ 0x00D2 /* USCI A1 Baud Rate 0 */
sfrb(UCA1BR0, UCA1BR0_);
#define UCA1BR1_ 0x00D3 /* USCI A1 Baud Rate 1 */
sfrb(UCA1BR1, UCA1BR1_);
#define UCA1MCTL_ 0x00D4 /* USCI A1 Modulation Control */
sfrb(UCA1MCTL, UCA1MCTL_);
#define UCA1STAT_ 0x00D5 /* USCI A1 Status Register */
sfrb(UCA1STAT, UCA1STAT_);
#define UCA1RXBUF_ 0x00D6 /* USCI A1 Receive Buffer */
/*READ_ONLY*/ sfrb(UCA1RXBUF, UCA1RXBUF_);
#define UCA1TXBUF_ 0x00D7 /* USCI A1 Transmit Buffer */
sfrb(UCA1TXBUF, UCA1TXBUF_);
#define UCA1ABCTL_ 0x00CD /* USCI A1 Auto baud/LIN Control */
sfrb(UCA1ABCTL, UCA1ABCTL_);
#define UCA1IRTCTL_ 0x00CE /* USCI A1 IrDA Transmit Control */
sfrb(UCA1IRTCTL, UCA1IRTCTL_);
#define UCA1IRRCTL_ 0x00CF /* USCI A1 IrDA Receive Control */
sfrb(UCA1IRRCTL, UCA1IRRCTL_);
#define UCB1CTL0_ 0x00D8 /* USCI B1 Control Register 0 */
sfrb(UCB1CTL0, UCB1CTL0_);
#define UCB1CTL1_ 0x00D9 /* USCI B1 Control Register 1 */
sfrb(UCB1CTL1, UCB1CTL1_);
#define UCB1BR0_ 0x00DA /* USCI B1 Baud Rate 0 */
sfrb(UCB1BR0, UCB1BR0_);
#define UCB1BR1_ 0x00DB /* USCI B1 Baud Rate 1 */
sfrb(UCB1BR1, UCB1BR1_);
#define UCB1I2CIE_ 0x00DC /* USCI B1 I2C Interrupt Enable Register */
sfrb(UCB1I2CIE, UCB1I2CIE_);
#define UCB1STAT_ 0x00DD /* USCI B1 Status Register */
sfrb(UCB1STAT, UCB1STAT_);
#define UCB1RXBUF_ 0x00DE /* USCI B1 Receive Buffer */
/*READ_ONLY*/ sfrb(UCB1RXBUF, UCB1RXBUF_);
#define UCB1TXBUF_ 0x00DF /* USCI B1 Transmit Buffer */
sfrb(UCB1TXBUF, UCB1TXBUF_);
#define UCB1I2COA_ 0x017C /* USCI B1 I2C Own Address */
sfrw(UCB1I2COA, UCB1I2COA_);
#define UCB1I2CSA_ 0x017E /* USCI B1 I2C Slave Address */
sfrw(UCB1I2CSA, UCB1I2CSA_);
#define UC1IE_ 0x0006 /* USCI A1/B1 Interrupt enable register */
sfrb(UC1IE, UC1IE_);
#define UC1IFG_ 0x0007 /* USCI A1/B1 Interrupt flag register */
sfrb(UC1IFG, UC1IFG_);
#define UCA1RXIE (1<<0)
#define UCA1TXIE (1<<1)
#define UCB1RXIE (1<<2)
#define UCB1TXIE (1<<3)
#define UCA1RXIFG (1<<0)
#define UCA1TXIFG (1<<1)
#define UCB1RXIFG (1<<2)
#define UCB1TXIFG (1<<3)
#endif /* __MSP430_HAS_USCI1__ */
#if defined(__MSP430_HAS_USCI0_5__)
/* -------- USCI0_5 */
#define UCA0CTL0_ 0x05C1
#define UCA0CTL1_ 0x05C0
#define UCA0BR0_ 0x05C6
#define UCA0BR1_ 0x05C7
#define UCA0MCTL_ 0x05C8
#define UCA0STAT_ 0x05CA
#define UCA0RXBUF_ 0x05CC
#define UCA0TXBUF_ 0x05CE
#define UCA0ABCTL_ 0x05D0
#define UCA0IRTCTL_ 0x05D2
#define UCA0IRRCTL_ 0x05D3
#define UCA0IE_ 0x05DC
sfrb(UCA0IE, UCA0IE_);
#define UCA0IFG_ 0x05DD
sfrb(UCA0IFG, UCA0IFG_);
#define UCA0IV_ 0x05DE
sfrw(UCA0IV, UCA0IV_);
#define UCA0IV_L_ 0x05DE
sfrb(UCA0IV_L, UCA0IV_L_);
#define UCA0IV_H_ 0x05DF
sfrb(UCA0IV_H, UCA0IV_H_);
#define UCB0CTL0_ 0x05E1
#define UCB0CTL1_ 0x05E0
#define UCB0BR0_ 0x05E6
#define UCB0BR1_ 0x05E7
#define UCB0MCTL_ 0x05E8
sfrb(UCB0MCTL, UCB0MCTL_);
#define UCB0STAT_ 0x05EA
#define UCB0RXBUF_ 0x05EC
#define UCB0TXBUF_ 0x05EE
#define UCB0I2COA_ 0x05F0
sfrb(UCB0I2COA, UCB0I2COA_);
#define UCB0I2CSA_ 0x05F2
sfrb(UCB0I2CSA, UCB0I2CSA_);
#define UCB0IE_ 0x05FC
sfrb(UCB0IE, UCB0IE_);
#define UCB0IFG_ 0x05FD
sfrb(UCB0IFG, UCB0IFG_);
#define UCB0IV_ 0x05FE
sfrw(UCB0IV, UCB0IV_);
#define UCB0IV_L_ 0x05FE
sfrb(UCB0IV_L, UCB0IV_L_);
#define UCB0IV_H_ 0x05FF
sfrb(UCB0IV_H, UCB0IV_H_);
#endif /* __MSP430_HAS_USCI0_5__ */
#if defined(__MSP430_HAS_USCI1_5__)
/* -------- USCI1_5 */
// tbd
/*#define UCA1CTL0_ 0x0601
#define UCA1CTL0_L 0x0601
#define UCA1CTL0_H 0x0602
#define UCA1CTL1_ 0x0600
#define UCA1CTL1_L 0x0600
#define UCA1CTL1_H 0x0601
#define UCA1BR0_ 0x0606
#define UCA1BR0_L 0x0606
#define UCA1BR0_H 0x0607
#define UCA1BR1_ 0x0607
#define UCA1BR1_L 0x0607
#define UCA1BR1_H 0x0608
#define UCA1MCTL_ 0x0608
#define UCA1MCTL_L 0x0608
#define UCA1MCTL_H 0x0609
#define UCA1STAT_ 0x060A
#define UCA1STAT_L 0x060A
#define UCA1STAT_H 0x060B
#define UCA1RXBUF 0x060C
#define UCA1RXBUF_L 0x060C
#define UCA1RXBUF_H 0x060D
#define UCA1TXBUF 0x060E
#define UCA1TXBUF_L 0x060E
#define UCA1TXBUF_H 0x060F
#define UCA1ABCTL 0x0610
#define UCA1ABCTL_L 0x0610
#define UCA1ABCTL_H 0x0611
#define UCA1IRTCTL 0x0612
#define UCA1IRTCTL_L 0x0612
#define UCA1IRTCTL_H 0x0613
#define UCA1IRRCTL 0x0613
#define UCA1IRRCTL_L 0x0613
#define UCA1IRRCTL_H 0x0614
#define UCA1IE_ 0x061C
#define UCA1IE_L_ 0x061C
#define UCA1IE_H_ 0x061D
#define UCA1IFG_ 0x061D
#define UCA1IFG_L 0x061D
#define UCA1IFG_H 0x061E
#define UCA1IV_ 0x061E
#define UCA1IV_L_ 0x061E
#define UCA1IV_H_ 0x061F
#define UCB1CTL0_ 0x0621
#define UCB1CTL0_L 0x0621
#define UCB1CTL0_H 0x0622
#define UCB1CTL1_ 0x0620
#define UCB1CTL1_L 0x0620
#define UCB1CTL1_H 0x0621
#define UCB1BR0_ 0x0626
#define UCB1BR0_L 0x0626
#define UCB1BR0_H 0x0627
#define UCB1BR1_ 0x0627
#define UCB1BR1_L 0x0627
#define UCB1BR1_H 0x0628
#define UCB1STAT_ 0x062A
#define UCB1STAT_L 0x062A
#define UCB1STAT_H 0x062B
#define UCB1RXBUF 0x062C
#define UCB1RXBUF_L 0x062C
#define UCB1RXBUF_H 0x062D
#define UCB1TXBUF 0x062E
#define UCB1TXBUF_L 0x062E
#define UCB1TXBUF_H 0x062F
#define UCB1I2COA 0x0630
#define UCB1I2COA_L 0x0630
#define UCB1I2COA_H 0x0631
#define UCB1I2CSA 0x0632
#define UCB1I2CSA_L 0x0632
#define UCB1I2CSA_H 0x0633
#define UCB1IE_ 0x063C
#define UCB1IE_L_ 0x063C
#define UCB1IE_H_ 0x063D
#define UCB1IFG_ 0x063D
#define UCB1IFG_L 0x063D
#define UCB1IFG_H 0x063E
#define UCB1IV_ 0x063E
#define UCB1IV_L_ 0x063E
#define UCB1IV_H_ 0x063F
#endif /* __MSP430_HAS_USCI1_5__ */
#if defined(__MSP430_HAS_USCI2_5__)
/* -------- USCI2_5 */
// tbd
/*#define UCA2CTL0_ 0x0641
#define UCA2CTL0_L 0x0641
#define UCA2CTL0_H 0x0642
#define UCA2CTL1_ 0x0640
#define UCA2CTL1_L 0x0640
#define UCA2CTL1_H 0x0641
#define UCA2BR0_ 0x0646
#define UCA2BR0_L 0x0646
#define UCA2BR0_H 0x0647
#define UCA2BR1_ 0x0647
#define UCA2BR1_L 0x0647
#define UCA2BR1_H 0x0648
#define UCA2MCTL_ 0x0648
#define UCA2MCTL_L 0x0648
#define UCA2MCTL_H 0x0649
#define UCA2STAT_ 0x064A
#define UCA2STAT_L 0x064A
#define UCA2STAT_H 0x064B
#define UCA2RXBUF 0x064C
#define UCA2RXBUF_L 0x064C
#define UCA2RXBUF_H 0x064D
#define UCA2TXBUF 0x064E
#define UCA2TXBUF_L 0x064E
#define UCA2TXBUF_H 0x064F
#define UCA2ABCTL 0x0650
#define UCA2ABCTL_L 0x0650
#define UCA2ABCTL_H 0x0651
#define UCA2IRTCTL 0x0652
#define UCA2IRTCTL_L 0x0652
#define UCA2IRTCTL_H 0x0653
#define UCA2IRRCTL 0x0653
#define UCA2IRRCTL_L 0x0653
#define UCA2IRRCTL_H 0x0654
#define UCA2IE_ 0x065C
#define UCA2IE_L_ 0x065C
#define UCA2IE_H_ 0x065D
#define UCA2IFG_ 0x065D
#define UCA2IFG_L 0x065D
#define UCA2IFG_H 0x065E
#define UCA2IV_ 0x065E
#define UCA2IV_L_ 0x065E
#define UCA2IV_H_ 0x065F
#define UCB2CTL0_ 0x0661
#define UCB2CTL0_L 0x0661
#define UCB2CTL0_H 0x0662
#define UCB2CTL1_ 0x0660
#define UCB2CTL1_L 0x0660
#define UCB2CTL1_H 0x0661
#define UCB2BR0_ 0x0666
#define UCB2BR0_L 0x0666
#define UCB2BR0_H 0x0667
#define UCB2BR1_ 0x0667
#define UCB2BR1_L 0x0667
#define UCB2BR1_H 0x0668
#define UCB2STAT_ 0x066A
#define UCB2STAT_L 0x066A
#define UCB2STAT_H 0x066B
#define UCB2RXBUF 0x066C
#define UCB2RXBUF_L 0x066C
#define UCB2RXBUF_H 0x066D
#define UCB2TXBUF 0x066E
#define UCB2TXBUF_L 0x066E
#define UCB2TXBUF_H 0x066F
#define UCB2I2COA 0x0670
#define UCB2I2COA_L 0x0670
#define UCB2I2COA_H 0x0671
#define UCB2I2CSA 0x0672
#define UCB2I2CSA_L 0x0672
#define UCB2I2CSA_H 0x0673
#define UCB2IE_ 0x067C
#define UCB2IE_L_ 0x067C
#define UCB2IE_H_ 0x067D
#define UCB2IFG_ 0x067D
#define UCB2IFG_L 0x067D
#define UCB2IFG_H 0x067E
#define UCB2IV_ 0x067E
#define UCB2IV_L_ 0x067E
#define UCB2IV_H_ 0x067F
#endif /* __MSP430_HAS_USCI2_5__ */
#if defined(__MSP430_HAS_USCI3_5__)
/* -------- USCI3_5 */
// tbd
/*#define UCA3CTL0_ 0x0681
#define UCA3CTL0_L 0x0681
#define UCA3CTL0_H 0x0682
#define UCA3CTL1_ 0x0680
#define UCA3CTL1_L 0x0680
#define UCA3CTL1_H 0x0681
#define UCA3BR0_ 0x0686
#define UCA3BR0_L 0x0686
#define UCA3BR0_H 0x0687
#define UCA3BR1_ 0x0687
#define UCA3BR1_L 0x0687
#define UCA3BR1_H 0x0688
#define UCA3MCTL_ 0x0688
#define UCA3MCTL_L 0x0688
#define UCA3MCTL_H 0x0689
#define UCA3STAT_ 0x068A
#define UCA3STAT_L 0x068A
#define UCA3STAT_H 0x068B
#define UCA3RXBUF 0x068C
#define UCA3RXBUF_L 0x068C
#define UCA3RXBUF_H 0x068D
#define UCA3TXBUF 0x068E
#define UCA3TXBUF_L 0x068E
#define UCA3TXBUF_H 0x068F
#define UCA3ABCTL 0x0690
#define UCA3ABCTL_L 0x0690
#define UCA3ABCTL_H 0x0691
#define UCA3IRTCTL 0x0692
#define UCA3IRTCTL_L 0x0692
#define UCA3IRTCTL_H 0x0693
#define UCA3IRRCTL 0x0693
#define UCA3IRRCTL_L 0x0693
#define UCA3IRRCTL_H 0x0694
#define UCA3IE_ 0x069C
#define UCA3IE_L_ 0x069C
#define UCA3IE_H_ 0x069D
#define UCA3IFG_ 0x069D
#define UCA3IFG_L 0x069D
#define UCA3IFG_H 0x069E
#define UCA3IV_ 0x069E
#define UCA3IV_L_ 0x069E
#define UCA3IV_H_ 0x069F
#define UCB3CTL0_ 0x06A1
#define UCB3CTL0_L 0x06A1
#define UCB3CTL0_H 0x06A2
#define UCB3CTL1_ 0x06A0
#define UCB3CTL1_L 0x06A0
#define UCB3CTL1_H 0x06A1
#define UCB3BR0_ 0x06A6
#define UCB3BR0_L 0x06A6
#define UCB3BR0_H 0x06A7
#define UCB3BR1_ 0x06A7
#define UCB3BR1_L 0x06A7
#define UCB3BR1_H 0x06A8
#define UCB3STAT_ 0x06AA
#define UCB3STAT_L 0x06AA
#define UCB3STAT_H 0x06AB
#define UCB3RXBUF 0x06AC
#define UCB3RXBUF_L 0x06AC
#define UCB3RXBUF_H 0x06AD
#define UCB3TXBUF 0x06AE
#define UCB3TXBUF_L 0x06AE
#define UCB3TXBUF_H 0x06AF
#define UCB3I2COA 0x06B0
#define UCB3I2COA_L 0x06B0
#define UCB3I2COA_H 0x06B1
#define UCB3I2CSA 0x06B2
#define UCB3I2CSA_L 0x06B2
#define UCB3I2CSA_H 0x06B3
#define UCB3IE_ 0x06BC
#define UCB3IE_L_ 0x06BC
#define UCB3IE_H_ 0x06BD
#define UCB3IFG_ 0x06BD
#define UCB3IFG_L 0x06BD
#define UCB3IFG_H 0x06BE
#define UCB3IV_ 0x06BE
#define UCB3IV_L_ 0x06BE
#define UCB3IV_H_ 0x06BF
#endif /* __MSP430_HAS_USCI3_5__ */
#endif
Прогресс прогрессирует?
mdmitry
сообщение Nov 6 2009, 13:56
Начинающий профессионал
Из: СПб
Пользователь №: 21 648
Цитата(MrYuran @ Nov 6 2009, 15:49) *
CODE
// tbd
/*#define UCA3CTL0_ 0x0681 <!!!!!!!!!!!!!!!! comment begin
*/ <!!!!!!!!!!!!!!!! comment end
#endif
Указал на пример комментариев в файле.
Цитата(Сергей Борщ @ Nov 6 2009, 16:09) *
P.S. Вы так настойчиво ждете каких-то дополнений в этом файле, что можно было уже 10 раз написать их самостоятельно, оттестировать и послать патч Крису.
P.P.S. В списке рассылки проскакивала информация, что репозиторий будут перетаскивать под bazaar. Чем закончилось - не знаю.
Когда (?) будет время, то хочу попробовать собрать для MSP-EXP430F5438 демонстрационный пример, скорректировав исходный код IAR (CCE). Для этого надо иметь _полный_ комплект описаний регистров в заголовочных файлах.
Сергей Борщ
сообщение Nov 6 2009, 15:10
Из: Рига, Латвия
Пользователь №: 17 095
Так возьмите и допишите. Это не архисложная задача - читать даташит и вписывать из него #define, она не требует знания потрохов компилятора. А чтобы другие не изобретали велосипед - поделитесь результатом своих трудов.
- AHTOXA   MSP-GCC 4. Кто-нибудь пробовал?   Oct 6 2009, 11:27
- - Ko4egap   Отличная новость! Завтра буду пробовать. Надею...   Oct 11 2009, 08:23
|- - mdmitry   Цитата(Ko4egap @ Oct 11 2009, 12:23) Отли...   Oct 11 2009, 19:02
- - MrYuran   Выкачал, стал запускать - пишет, мол, файл исполня...   Nov 1 2009, 13:32
|- - AHTOXA   Цитата(MrYuran @ Nov 1 2009, 18:32) Радуе...   Nov 1 2009, 21:27
|- - MrYuran   Цитата(AHTOXA @ Nov 2 2009, 00:27) Наскол...   Nov 2 2009, 06:07
|- - mdmitry   Цитата(MrYuran @ Nov 2 2009, 09:07) Кстат...   Nov 2 2009, 12:22
|- - MrYuran   Цитата(mdmitry @ Nov 2 2009, 15:22) У IAR...   Nov 2 2009, 12:39
|- - mdmitry   Цитата(MrYuran @ Nov 2 2009, 15:39) Ну та...   Nov 2 2009, 16:29
- - MrYuran   Таки распаковал... Йошкин кот! 265 МЕТРОВ...   Nov 6 2009, 10:14
|- - mdmitry   Цитата(MrYuran @ Nov 6 2009, 13:14) Кстат...   Nov 6 2009, 12:45
|- - Сергей Борщ   Цитата(MrYuran @ Nov 6 2009, 12:14) Кстат...   Nov 6 2009, 13:09
|- - mdmitry   Цитата(Сергей Борщ @ Nov 6 2009, 18:10) Т...   Nov 6 2009, 15:46
|- - Сергей Борщ   Цитата(mdmitry @ Nov 6 2009, 17:46) Имеет...   Nov 6 2009, 16:45
|- - mdmitry   Цитата(Сергей Борщ @ Nov 6 2009, 19:45) Н...   Nov 6 2009, 17:25
|- - Сергей Борщ   Цитата(mdmitry @ Nov 6 2009, 19:25) Получ...   Nov 6 2009, 18:03
|- - mdmitry   Цитата(Сергей Борщ @ Nov 6 2009, 21:03) В...   Nov 6 2009, 21:25
|- - Сергей Борщ   Цитата(mdmitry @ Nov 6 2009, 23:25) msp43...   Nov 7 2009, 07:45
|- - mdmitry   Цитата(Сергей Борщ @ Nov 7 2009, 10:45) В...   Nov 7 2009, 14:08
|- - Сергей Борщ   Цитата(mdmitry @ Nov 7 2009, 16:08) Хочет...   Nov 7 2009, 18:33
- - MrYuran   Таки попробовал... Компилятор что-то компилит. А в...   May 21 2010, 11:41
- - MrYuran   Нашёл предварительно, где копать: stdlib.h: Кодex...   May 21 2010, 13:06
|- - Сергей Борщ   Цитата(MrYuran @ May 21 2010, 15:48) Ну и...   May 21 2010, 13:14
||- - MrYuran   Цитата(Сергей Борщ @ May 21 2010, 17:14) ...   May 21 2010, 13:19
|- - AHTOXA   Цитата(MrYuran @ May 21 2010, 19:06) Ну н...   May 21 2010, 13:22
|- - demiurg_spb   Цитата(AHTOXA @ May 21 2010, 17:22) Это о...   May 21 2010, 14:01
|- - MrYuran   Цитата(demiurg_spb @ May 21 2010, 18:01) ...   May 24 2010, 09:37
|- - demiurg_spb   Цитата(MrYuran @ May 24 2010, 13:37) По о...   May 24 2010, 10:40
|- - AHTOXA   Цитата(MrYuran @ May 24 2010, 15:37) По о...   May 24 2010, 13:50
|- - MrYuran   Цитата(AHTOXA @ May 24 2010, 17:50) Круто...   May 25 2010, 05:43
|- - demiurg_spb   Цитата(MrYuran @ May 25 2010, 09:43) Тако...   May 25 2010, 09:24
|- - MrYuran   Цитата(demiurg_spb @ May 25 2010, 13:24) ...   May 25 2010, 09:40
|- - demiurg_spb   Давайте посмотрим на всю стоку целиком. Вот как у ...   May 25 2010, 10:00
- - MrYuran   ЦитатаЗа ключики спасибо, буду играться. КодBuild ...   May 21 2010, 13:34
- - MrYuran   А как заставить make выводить весь поток полностью...   May 25 2010, 10:23
|- - AHTOXA   make -n ?   May 25 2010, 10:28
|- - demiurg_spb   Цитата(MrYuran @ May 25 2010, 14:23) А ка...   May 25 2010, 11:33
- - MrYuran   Цитатаd:\WORK\PROJECTS\MARK-1002T...   May 25 2010, 10:55
- - MrYuran   Короче, я понял. Он все секции мапит на 0x0000, в ...   May 25 2010, 12:06
- - MrYuran   Противоречивые какие-то чувства навевает... Поигра...   Jun 11 2010, 13:29
|- - demiurg_spb   Цитата(MrYuran @ Jun 11 2010, 17:29) если...   Jun 13 2010, 11:08
- - MrYuran   ААААААААААААААААААААААААААААААА!!!...   Jun 17 2010, 07:31
- - MrYuran   Вот кстати интересно: Кто структуры пакует - компи...   Jun 17 2010, 08:45
|- - demiurg_spb   Про упаковку всех структур: КодCFLAGS += -fpack-st...   Jun 17 2010, 09:25
|- - MrYuran   Цитата(demiurg_spb @ Jun 17 2010, 13:25) ...   Jun 17 2010, 09:31
|- - Сергей Борщ   Цитата(MrYuran @ Jun 17 2010, 12:31) Ура,...   Jun 17 2010, 12:34
|- - MrYuran   Цитата(Сергей Борщ @ Jun 17 2010, 16:34) ...   Jun 17 2010, 15:49
- - MrYuran   Перекомпилил старый ИАРовский прожект, который ран...   Jul 6 2010, 06:41
- - MrYuran   В последнее время проект реанимирован, произошло (...   Apr 5 2012, 06:16
- - MrYuran   Попробовал дополнительные ключики ЦитатаCFLAGS += ...   Apr 5 2012, 07:40
|- - AHTOXA   Это про какой mspgcc? Про просто mspgcc или про ms...   Apr 5 2012, 07:59
|- - MrYuran   Цитата(AHTOXA @ Apr 5 2012, 11:59) Это пр...   Apr 5 2012, 08:21
|- - AHTOXA   А, ну с этим мы уже немножко познакомились   Apr 5 2012, 08:32
|- - MrYuran   Цитата(AHTOXA @ Apr 5 2012, 12:32) А, ну ...   Apr 5 2012, 08:36
- - MrYuran   Попробовали крайнюю версию 4.6.2 - опять -combine ...   Apr 5 2012, 10:54
- - AHTOXA   Цитата(MrYuran @ Apr 5 2012, 14:36) Там ч...   Apr 5 2012, 13:02
|- - MrYuran   Цитата(AHTOXA @ Apr 5 2012, 17:02) Глюки ...   Apr 6 2012, 09:44
- - MrYuran   Сегодня обнаружил эпический глюк в этой версии. Вс...   May 24 2012, 09:01
|- - alx2   Цитата(MrYuran @ May 24 2012, 14:01) Сего...   May 25 2012, 03:25
|- - MrYuran   Цитата(alx2 @ May 25 2012, 07:25) Если ош...   May 25 2012, 05:04
|- - Сергей Борщ   Давно не работаю с MSP, но при беглом просмотре бр...   May 25 2012, 06:27
|- - alx2   Цитата(MrYuran @ May 25 2012, 10:04) При ...   May 28 2012, 05:07
- - MrYuran   Вот листинг старой версии (трэш и угар но работае...   May 25 2012, 08:05
- - Сергей Борщ   QUOTE (MrYuran @ May 25 2012, 11:05) Попу...   May 25 2012, 08:59
RSS Текстовая версия Сейчас: 29th July 2025 - 09:44
Страница сгенерированна за 0.01569 секунд с 7
