MSP-GCC 4. Кто-нибудь пробовал?, Случайно наткнулся:) |
Oct 6 2009, 11:27
фанат дивана
Из: Уфа
Пользователь №: 29 684
http://mspgcc4.sourceforge.net/Пишут, что Цитата GCC 4.x has several advantages over the old 3.2.3 branch. Here are the most important: - Better optimization. The generated code is typically 7%-10% smaller than code generated by MSPGCC-3.2.3
- Better debug info support. The objdump utility displays the mixed assembly/code correctly.
- Better C++ and inlining support. Unused local variables are automatically filtered out. Inline functions are implemented in a much more compact way.
- Support for various handy features. For example, gcc 4.3 correctly handles the #pragma once statements.
- Additionally, the MSPGCC4 port fixes the data-sections bug present in all original MSPGCC versions, allowing using -ffunction-sections and -fdata-sections switches.
Насчёт -ffunction-sections and -fdata-sections врут похоже, у меня и с ними и в текущем msp-gcc нет проблем. Короче, если кто-то пробовал, поделитесь пожалуйста впечатлениями.
Nov 6 2009, 12:49
Беспросветный оптимист
Из: Н.Новгород
Пользователь №: 33 646
CODE #if !defined(__msp430_headers_usci_h__) #define __msp430_headers_usci_h__
/* usi.h * * mspgcc project: MSP430 device headers * USCI module header * * © 2006 by Steve Underwood <steveu@coppice.org> * Originally based in part on work by Texas Instruments Inc. * * $Id: usci.h,v 1.7 2009/06/04 21:55:18 cliechti Exp $ * * 2008-02-05 - modifications by G.Lemm <msp430@daqtix.com> * - added UC1IE and UC1IFG registers * - added UC*1*IE and UC*1*IFG bit definitions * 2009-05-19 - modifications by S. Balling <praktikum@innoventis.de> * - added switch for USCI0 * - added USCI0_5 * - added USCI1_5 * - added USCI2_5 * - added USCI3_5 */
/* Switches: __MSP430_HAS_USCI0__ - if device has USCI0 __MSP430_HAS_USCI1__ - if device has USCI1 __MSP430_HAS_USCI0_5__ - if device has USCI0 and is part of family 5 __MSP430_HAS_USCI1_5__ - if device has USCI1 and is part of family 5 __MSP430_HAS_USCI2_5__ - if device has USCI2 and is part of family 5 __MSP430_HAS_USCI3_5__ - if device has USCI3 and is part of family 5
#define USIPE7 (0x80) /* USI Port Enable Px.7 */ #define USIPE6 (0x40) /* USI Port Enable Px.6 */ #define USIPE5 (0x20) /* USI Port Enable Px.5 */ #define USILSB (0x10) /* USI LSB first 1:LSB / 0:MSB */ #define USIMST (0x08) /* USI Master Select 0:Slave / 1:Master */ #define USIGE (0x04) /* USI General Output Enable Latch */ #define USIOE (0x02) /* USI Output Enable */ #define USISWRST (0x01) /* USI Software Reset */
#define USICKPH (0x80) /* USI Sync. Mode: Clock Phase */ #define USII2C (0x40) /* USI I2C Mode */ #define USISTTIE (0x20) /* USI START Condition interrupt enable */ #define USIIE (0x10) /* USI Counter Interrupt enable */ #define USIAL (0x08) /* USI Arbitration Lost */ #define USISTP (0x04) /* USI STOP Condition received */ #define USISTTIFG (0x02) /* USI START Condition interrupt Flag */ #define USIIFG (0x01) /* USI Counter Interrupt Flag */
#define USIDIV2 (0x80) /* USI Clock Divider 2 */ #define USIDIV1 (0x40) /* USI Clock Divider 1 */ #define USIDIV0 (0x20) /* USI Clock Divider 0 */ #define USISSEL2 (0x10) /* USI Clock Source Select 2 */ #define USISSEL1 (0x08) /* USI Clock Source Select 1 */ #define USISSEL0 (0x04) /* USI Clock Source Select 0 */ #define USICKPL (0x02) /* USI Clock Polarity 0:Inactive=Low / 1:Inactive=High */ #define USISWCLK (0x01) /* USI Software Clock */
#define USIDIV_0 (0x00) /* USI Clock Divider: 0 */ #define USIDIV_1 (0x20) /* USI Clock Divider: 1 */ #define USIDIV_2 (0x40) /* USI Clock Divider: 2 */ #define USIDIV_3 (0x60) /* USI Clock Divider: 3 */ #define USIDIV_4 (0x80) /* USI Clock Divider: 4 */ #define USIDIV_5 (0xA0) /* USI Clock Divider: 5 */ #define USIDIV_6 (0xC0) /* USI Clock Divider: 6 */ #define USIDIV_7 (0xE0) /* USI Clock Divider: 7 */
#define USISSEL_0 (0x00) /* USI Clock Source: 0 */ #define USISSEL_1 (0x04) /* USI Clock Source: 1 */ #define USISSEL_2 (0x08) /* USI Clock Source: 2 */ #define USISSEL_3 (0x0C) /* USI Clock Source: 3 */ #define USISSEL_4 (0x10) /* USI Clock Source: 4 */ #define USISSEL_5 (0x14) /* USI Clock Source: 5 */ #define USISSEL_6 (0x18) /* USI Clock Source: 6 */ #define USISSEL_7 (0x1C) /* USI Clock Source: 7 */
#define USISCLREL (0x80) /* USI SCL Released */ #define USI16B (0x40) /* USI 16 Bit Shift Register Enable */ #define USIFGDC (0x20) /* USI Interrupt Flag don't clear */ #define USICNT4 (0x10) /* USI Bit Count 4 */ #define USICNT3 (0x08) /* USI Bit Count 3 */ #define USICNT2 (0x04) /* USI Bit Count 2 */ #define USICNT1 (0x02) /* USI Bit Count 1 */ #define USICNT0 (0x01) /* USI Bit Count 0 */
// UART-Mode Bits #define UCPEN (0x80) /* Async. Mode: Parity enable */ #define UCPAR (0x40) /* Async. Mode: Parity 0:odd / 1:even */ #define UCMSB (0x20) /* Async. Mode: MSB first 0:LSB / 1:MSB */ #define UC7BIT (0x10) /* Async. Mode: Data Bits 0:8-bits / 1:7-bits */ #define UCSPB (0x08) /* Async. Mode: Stop Bits 0:one / 1: two */ #define UCMODE1 (0x04) /* Async. Mode: USCI Mode 1 */ #define UCMODE0 (0x02) /* Async. Mode: USCI Mode 0 */ #define UCSYNC (0x01) /* Sync-Mode 0:UART-Mode / 1:SPI-Mode */
// SPI-Mode Bits #define UCCKPH (0x80) /* Sync. Mode: Clock Phase */ #define UCCKPL (0x40) /* Sync. Mode: Clock Polarity */ #define UCMST (0x08) /* Sync. Mode: Master Select */
// I2C-Mode Bits #define UCA10 (0x80) /* 10-bit Address Mode */ #define UCSLA10 (0x40) /* 10-bit Slave Address Mode */ #define UCMM (0x20) /* Multi-Master Environment */ //#define res (0x10) /* reserved */ #define UCMODE_0 (0<<1) /* Sync. Mode: USCI Mode: 0 */ #define UCMODE_1 (1<<1) /* Sync. Mode: USCI Mode: 1 */ #define UCMODE_2 (2<<1) /* Sync. Mode: USCI Mode: 2 */ #define UCMODE_3 (3<<1) /* Sync. Mode: USCI Mode: 3 */
// UART-Mode Bits #define UCSSEL1 (0x80) /* USCI 0 Clock Source Select 1 */ #define UCSSEL0 (0x40) /* USCI 0 Clock Source Select 0 */ #define UCRXEIE (0x20) /* RX Error interrupt enable */ #define UCBRKIE (0x10) /* Break interrupt enable */ #define UCDORM (0x08) /* Dormant (Sleep) Mode */ #define UCTXADDR (0x04) /* Send next Data as Address */ #define UCTXBRK (0x02) /* Send next Data as Break */ #define UCSWRST (0x01) /* USCI Software Reset */
// SPI-Mode Bits //#define res (0x20) /* reserved */ //#define res (0x10) /* reserved */ //#define res (0x08) /* reserved */ //#define res (0x04) /* reserved */ //#define res (0x02) /* reserved */
// I2C-Mode Bits //#define res (0x20) /* reserved */ #define UCTR (0x10) /* Transmit/Receive Select/Flag */ #define UCTXNACK (0x08) /* Transmit NACK */ #define UCTXSTP (0x04) /* Transmit STOP */ #define UCTXSTT (0x02) /* Transmit START */ #define UCSSEL_0 (0<<6) /* USCI 0 Clock Source: 0 */ #define UCSSEL_1 (1<<6) /* USCI 0 Clock Source: 1 */ #define UCSSEL_2 (2<<6) /* USCI 0 Clock Source: 2 */ #define UCSSEL_3 (3<<6) /* USCI 0 Clock Source: 3 */
#define UCBRF3 (0x80) /* USCI First Stage Modulation Select 3 */ #define UCBRF2 (0x40) /* USCI First Stage Modulation Select 2 */ #define UCBRF1 (0x20) /* USCI First Stage Modulation Select 1 */ #define UCBRF0 (0x10) /* USCI First Stage Modulation Select 0 */ #define UCBRS2 (0x08) /* USCI Second Stage Modulation Select 2 */ #define UCBRS1 (0x04) /* USCI Second Stage Modulation Select 1 */ #define UCBRS0 (0x02) /* USCI Second Stage Modulation Select 0 */ #define UCOS16 (0x01) /* USCI 16-times Oversampling enable */
#define UCBRF_0 (0x0<<4) /* USCI First Stage Modulation: 0 */ #define UCBRF_1 (0x1<<4) /* USCI First Stage Modulation: 1 */ #define UCBRF_2 (0x2<<4) /* USCI First Stage Modulation: 2 */ #define UCBRF_3 (0x3<<4) /* USCI First Stage Modulation: 3 */ #define UCBRF_4 (0x4<<4) /* USCI First Stage Modulation: 4 */ #define UCBRF_5 (0x5<<4) /* USCI First Stage Modulation: 5 */ #define UCBRF_6 (0x6<<4) /* USCI First Stage Modulation: 6 */ #define UCBRF_7 (0x7<<4) /* USCI First Stage Modulation: 7 */ #define UCBRF_8 (0x8<<4) /* USCI First Stage Modulation: 8 */ #define UCBRF_9 (0x9<<4) /* USCI First Stage Modulation: 9 */ #define UCBRF_10 (0xA<<4) /* USCI First Stage Modulation: A */ #define UCBRF_11 (0xB<<4) /* USCI First Stage Modulation: B */ #define UCBRF_12 (0xC<<4) /* USCI First Stage Modulation: C */ #define UCBRF_13 (0xD<<4) /* USCI First Stage Modulation: D */ #define UCBRF_14 (0xE<<4) /* USCI First Stage Modulation: E */ #define UCBRF_15 (0xF<<4) /* USCI First Stage Modulation: F */
#define UCBRS_0 (0<<1) /* USCI Second Stage Modulation: 0 */ #define UCBRS_1 (1<<1) /* USCI Second Stage Modulation: 1 */ #define UCBRS_2 (2<<1) /* USCI Second Stage Modulation: 2 */ #define UCBRS_3 (3<<1) /* USCI Second Stage Modulation: 3 */ #define UCBRS_4 (4<<1) /* USCI Second Stage Modulation: 4 */ #define UCBRS_5 (5<<1) /* USCI Second Stage Modulation: 5 */ #define UCBRS_6 (6<<1) /* USCI Second Stage Modulation: 6 */ #define UCBRS_7 (7<<1) /* USCI Second Stage Modulation: 7 */
#define UCLISTEN (0x80) /* USCI Listen mode */ #define UCFE (0x40) /* USCI Frame Error Flag */ #define UCOE (0x20) /* USCI Overrun Error Flag */ #define UCPE (0x10) /* USCI Parity Error Flag */ #define UCBRK (0x08) /* USCI Break received */ #define UCRXERR (0x04) /* USCI RX Error Flag */ #define UCADDR (0x02) /* USCI Address received Flag */ #define UCBUSY (0x01) /* USCI Busy Flag */ #define UCIDLE (0x02) /* USCI Idle line detected Flag */
//#define res (0x80) /* reserved */ //#define res (0x40) /* reserved */ //#define res (0x20) /* reserved */ //#define res (0x10) /* reserved */ #define UCNACKIE (0x08) /* NACK Condition interrupt enable */ #define UCSTPIE (0x04) /* STOP Condition interrupt enable */ #define UCSTTIE (0x02) /* START Condition interrupt enable */ #define UCALIE (0x01) /* Arbitration Lost interrupt enable */
#define UCSCLLOW (0x40) /* SCL low */ #define UCGC (0x20) /* General Call address received Flag */ #define UCBBUSY (0x10) /* Bus Busy Flag */ #define UCNACKIFG (0x08) /* NAK Condition interrupt Flag */ #define UCSTPIFG (0x04) /* STOP Condition interrupt Flag */ #define UCSTTIFG (0x02) /* START Condition interrupt Flag */ #define UCALIFG (0x01) /* Arbitration Lost interrupt Flag */
#define UCIRTXPL5 (0x80) /* IRDA Transmit Pulse Length 5 */ #define UCIRTXPL4 (0x40) /* IRDA Transmit Pulse Length 4 */ #define UCIRTXPL3 (0x20) /* IRDA Transmit Pulse Length 3 */ #define UCIRTXPL2 (0x10) /* IRDA Transmit Pulse Length 2 */ #define UCIRTXPL1 (0x08) /* IRDA Transmit Pulse Length 1 */ #define UCIRTXPL0 (0x04) /* IRDA Transmit Pulse Length 0 */ #define UCIRTXCLK (0x02) /* IRDA Transmit Pulse Clock Select */ #define UCIREN (0x01) /* IRDA Encoder/Decoder enable */
#define UCIRRXFL5 (0x80) /* IRDA Receive Filter Length 5 */ #define UCIRRXFL4 (0x40) /* IRDA Receive Filter Length 4 */ #define UCIRRXFL3 (0x20) /* IRDA Receive Filter Length 3 */ #define UCIRRXFL2 (0x10) /* IRDA Receive Filter Length 2 */ #define UCIRRXFL1 (0x08) /* IRDA Receive Filter Length 1 */ #define UCIRRXFL0 (0x04) /* IRDA Receive Filter Length 0 */ #define UCIRRXPL (0x02) /* IRDA Receive Input Polarity */ #define UCIRRXFE (0x01) /* IRDA Receive Filter enable */
//#define res (0x80) /* reserved */ //#define res (0x40) /* reserved */ #define UCDELIM1 (0x20) /* Break Sync Delimiter 1 */ #define UCDELIM0 (0x10) /* Break Sync Delimiter 0 */ #define UCSTOE (0x08) /* Sync-Field Timeout error */ #define UCBTOE (0x04) /* Break Timeout error */ //#define res (0x02) /* reserved */ #define UCABDEN (0x01) /* Auto Baud Rate detect enable */
#define UCGCEN (0x8000) /* I2C General Call enable */ #define UCOA9 (0x0200) /* I2C Own Address 9 */ #define UCOA8 (0x0100) /* I2C Own Address 8 */ #define UCOA7 (0x0080) /* I2C Own Address 7 */ #define UCOA6 (0x0040) /* I2C Own Address 6 */ #define UCOA5 (0x0020) /* I2C Own Address 5 */ #define UCOA4 (0x0010) /* I2C Own Address 4 */ #define UCOA3 (0x0008) /* I2C Own Address 3 */ #define UCOA2 (0x0004) /* I2C Own Address 2 */ #define UCOA1 (0x0002) /* I2C Own Address 1 */ #define UCOA0 (0x0001) /* I2C Own Address 0 */
#define UCSA9 (0x0200) /* I2C Slave Address 9 */ #define UCSA8 (0x0100) /* I2C Slave Address 8 */ #define UCSA7 (0x0080) /* I2C Slave Address 7 */ #define UCSA6 (0x0040) /* I2C Slave Address 6 */ #define UCSA5 (0x0020) /* I2C Slave Address 5 */ #define UCSA4 (0x0010) /* I2C Slave Address 4 */ #define UCSA3 (0x0008) /* I2C Slave Address 3 */ #define UCSA2 (0x0004) /* I2C Slave Address 2 */ #define UCSA1 (0x0002) /* I2C Slave Address 1 */ #define UCSA0 (0x0001) /* I2C Slave Address 0 */
/* Aliases by mspgcc */ #define UCSSEL_UCLKI UCSSEL_0 #define UCSSEL_ACLK UCSSEL_1 #define UCSSEL_SMCLK UCSSEL_2
#if defined(__MSP430_HAS_USCI0__)
/* -------- USCI0 */
#define UCA0CTL0_ 0x0060 /* USCI A0 Control Register 0 */ sfrb(UCA0CTL0, UCA0CTL0_); #define UCA0CTL1_ 0x0061 /* USCI A0 Control Register 1 */ sfrb(UCA0CTL1, UCA0CTL1_); #define UCA0BR0_ 0x0062 /* USCI A0 Baud Rate 0 */ sfrb(UCA0BR0, UCA0BR0_); #define UCA0BR1_ 0x0063 /* USCI A0 Baud Rate 1 */ sfrb(UCA0BR1, UCA0BR1_); #define UCA0MCTL_ 0x0064 /* USCI A0 Modulation Control */ sfrb(UCA0MCTL, UCA0MCTL_); #define UCA0STAT_ 0x0065 /* USCI A0 Status Register */ sfrb(UCA0STAT, UCA0STAT_); #define UCA0RXBUF_ 0x0066 /* USCI A0 Receive Buffer */ /*READ_ONLY*/ sfrb(UCA0RXBUF, UCA0RXBUF_); #define UCA0TXBUF_ 0x0067 /* USCI A0 Transmit Buffer */ sfrb(UCA0TXBUF, UCA0TXBUF_); #define UCA0ABCTL_ 0x005D /* USCI A0 Auto baud/LIN Control */ sfrb(UCA0ABCTL, UCA0ABCTL_); #define UCA0IRTCTL_ 0x005E /* USCI A0 IrDA Transmit Control */ sfrb(UCA0IRTCTL, UCA0IRTCTL_); #define UCA0IRRCTL_ 0x005F /* USCI A0 IrDA Receive Control */ sfrb(UCA0IRRCTL, UCA0IRRCTL_);
#define UCB0CTL0_ 0x0068 /* USCI B0 Control Register 0 */ sfrb(UCB0CTL0, UCB0CTL0_); #define UCB0CTL1_ 0x0069 /* USCI B0 Control Register 1 */ sfrb(UCB0CTL1, UCB0CTL1_); #define UCB0BR0_ 0x006A /* USCI B0 Baud Rate 0 */ sfrb(UCB0BR0, UCB0BR0_); #define UCB0BR1_ 0x006B /* USCI B0 Baud Rate 1 */ sfrb(UCB0BR1, UCB0BR1_); #define UCB0I2CIE_ 0x006C /* USCI B0 I2C Interrupt Enable Register */ sfrb(UCB0I2CIE, UCB0I2CIE_); #define UCB0STAT_ 0x006D /* USCI B0 Status Register */ sfrb(UCB0STAT, UCB0STAT_); #define UCB0RXBUF_ 0x006E /* USCI B0 Receive Buffer */ /*READ_ONLY*/ sfrb(UCB0RXBUF, UCB0RXBUF_); #define UCB0TXBUF_ 0x006F /* USCI B0 Transmit Buffer */ sfrb(UCB0TXBUF, UCB0TXBUF_); #define UCB0I2COA_ 0x0118 /* USCI B0 I2C Own Address */ sfrw(UCB0I2COA, UCB0I2COA_); #define UCB0I2CSA_ 0x011A /* USCI B0 I2C Slave Address */ sfrw(UCB0I2CSA, UCB0I2CSA_); #endif /* __MSP430_HAS_USCI0__ */
#if defined(__MSP430_HAS_USCI1__)
/* -------- USCI1 */
#define UCA1CTL0_ 0x00D0 /* USCI A1 Control Register 0 */ sfrb(UCA1CTL0, UCA1CTL0_); #define UCA1CTL1_ 0x00D1 /* USCI A1 Control Register 1 */ sfrb(UCA1CTL1, UCA1CTL1_); #define UCA1BR0_ 0x00D2 /* USCI A1 Baud Rate 0 */ sfrb(UCA1BR0, UCA1BR0_); #define UCA1BR1_ 0x00D3 /* USCI A1 Baud Rate 1 */ sfrb(UCA1BR1, UCA1BR1_); #define UCA1MCTL_ 0x00D4 /* USCI A1 Modulation Control */ sfrb(UCA1MCTL, UCA1MCTL_); #define UCA1STAT_ 0x00D5 /* USCI A1 Status Register */ sfrb(UCA1STAT, UCA1STAT_); #define UCA1RXBUF_ 0x00D6 /* USCI A1 Receive Buffer */ /*READ_ONLY*/ sfrb(UCA1RXBUF, UCA1RXBUF_); #define UCA1TXBUF_ 0x00D7 /* USCI A1 Transmit Buffer */ sfrb(UCA1TXBUF, UCA1TXBUF_); #define UCA1ABCTL_ 0x00CD /* USCI A1 Auto baud/LIN Control */ sfrb(UCA1ABCTL, UCA1ABCTL_); #define UCA1IRTCTL_ 0x00CE /* USCI A1 IrDA Transmit Control */ sfrb(UCA1IRTCTL, UCA1IRTCTL_); #define UCA1IRRCTL_ 0x00CF /* USCI A1 IrDA Receive Control */ sfrb(UCA1IRRCTL, UCA1IRRCTL_);
#define UCB1CTL0_ 0x00D8 /* USCI B1 Control Register 0 */ sfrb(UCB1CTL0, UCB1CTL0_); #define UCB1CTL1_ 0x00D9 /* USCI B1 Control Register 1 */ sfrb(UCB1CTL1, UCB1CTL1_); #define UCB1BR0_ 0x00DA /* USCI B1 Baud Rate 0 */ sfrb(UCB1BR0, UCB1BR0_); #define UCB1BR1_ 0x00DB /* USCI B1 Baud Rate 1 */ sfrb(UCB1BR1, UCB1BR1_); #define UCB1I2CIE_ 0x00DC /* USCI B1 I2C Interrupt Enable Register */ sfrb(UCB1I2CIE, UCB1I2CIE_); #define UCB1STAT_ 0x00DD /* USCI B1 Status Register */ sfrb(UCB1STAT, UCB1STAT_); #define UCB1RXBUF_ 0x00DE /* USCI B1 Receive Buffer */ /*READ_ONLY*/ sfrb(UCB1RXBUF, UCB1RXBUF_); #define UCB1TXBUF_ 0x00DF /* USCI B1 Transmit Buffer */ sfrb(UCB1TXBUF, UCB1TXBUF_); #define UCB1I2COA_ 0x017C /* USCI B1 I2C Own Address */ sfrw(UCB1I2COA, UCB1I2COA_); #define UCB1I2CSA_ 0x017E /* USCI B1 I2C Slave Address */ sfrw(UCB1I2CSA, UCB1I2CSA_);
#define UC1IE_ 0x0006 /* USCI A1/B1 Interrupt enable register */ sfrb(UC1IE, UC1IE_); #define UC1IFG_ 0x0007 /* USCI A1/B1 Interrupt flag register */ sfrb(UC1IFG, UC1IFG_);
#define UCA1RXIE (1<<0) #define UCA1TXIE (1<<1) #define UCB1RXIE (1<<2) #define UCB1TXIE (1<<3)
#define UCA1RXIFG (1<<0) #define UCA1TXIFG (1<<1) #define UCB1RXIFG (1<<2) #define UCB1TXIFG (1<<3) #endif /* __MSP430_HAS_USCI1__ */
#if defined(__MSP430_HAS_USCI0_5__)
/* -------- USCI0_5 */
#define UCA0CTL0_ 0x05C1 sfrb(UCA0CTL0, UCA0CTL0_); #define UCA0CTL1_ 0x05C0 sfrb(UCA0CTL1, UCA0CTL1_); #define UCA0BR0_ 0x05C6 sfrb(UCA0BR0, UCA0BR0_); #define UCA0BR1_ 0x05C7 sfrb(UCA0BR1, UCA0BR1_); #define UCA0MCTL_ 0x05C8 sfrb(UCA0MCTL, UCA0MCTL_); #define UCA0STAT_ 0x05CA sfrb(UCA0STAT, UCA0STAT_); #define UCA0RXBUF_ 0x05CC sfrb(UCA0RXBUF, UCA0RXBUF_); #define UCA0TXBUF_ 0x05CE sfrb(UCA0TXBUF, UCA0TXBUF_); #define UCA0ABCTL_ 0x05D0 sfrb(UCA0ABCTL, UCA0ABCTL_); #define UCA0IRTCTL_ 0x05D2 sfrb(UCA0IRTCTL, UCA0IRTCTL_); #define UCA0IRRCTL_ 0x05D3 sfrb(UCA0IRRCTL, UCA0IRRCTL_); #define UCA0IE_ 0x05DC sfrb(UCA0IE, UCA0IE_); #define UCA0IFG_ 0x05DD sfrb(UCA0IFG, UCA0IFG_); #define UCA0IV_ 0x05DE sfrw(UCA0IV, UCA0IV_); #define UCA0IV_L_ 0x05DE sfrb(UCA0IV_L, UCA0IV_L_); #define UCA0IV_H_ 0x05DF sfrb(UCA0IV_H, UCA0IV_H_);
#define UCB0CTL0_ 0x05E1 sfrb(UCB0CTL0, UCB0CTL0_); #define UCB0CTL1_ 0x05E0 sfrb(UCB0CTL1, UCB0CTL1_); #define UCB0BR0_ 0x05E6 sfrb(UCB0BR0, UCB0BR0_); #define UCB0BR1_ 0x05E7 sfrb(UCB0BR1, UCB0BR1_); #define UCB0MCTL_ 0x05E8 sfrb(UCB0MCTL, UCB0MCTL_); #define UCB0STAT_ 0x05EA sfrb(UCB0STAT, UCB0STAT_); #define UCB0RXBUF_ 0x05EC sfrb(UCB0RXBUF, UCB0RXBUF_); #define UCB0TXBUF_ 0x05EE sfrb(UCB0TXBUF, UCB0TXBUF_); #define UCB0I2COA_ 0x05F0 sfrb(UCB0I2COA, UCB0I2COA_); #define UCB0I2CSA_ 0x05F2 sfrb(UCB0I2CSA, UCB0I2CSA_); #define UCB0IE_ 0x05FC sfrb(UCB0IE, UCB0IE_); #define UCB0IFG_ 0x05FD sfrb(UCB0IFG, UCB0IFG_); #define UCB0IV_ 0x05FE sfrw(UCB0IV, UCB0IV_); #define UCB0IV_L_ 0x05FE sfrb(UCB0IV_L, UCB0IV_L_); #define UCB0IV_H_ 0x05FF sfrb(UCB0IV_H, UCB0IV_H_);
#endif /* __MSP430_HAS_USCI0_5__ */
#if defined(__MSP430_HAS_USCI1_5__)
/* -------- USCI1_5 */
// tbd /*#define UCA1CTL0_ 0x0601 #define UCA1CTL0_L 0x0601 #define UCA1CTL0_H 0x0602 #define UCA1CTL1_ 0x0600 #define UCA1CTL1_L 0x0600 #define UCA1CTL1_H 0x0601 #define UCA1BR0_ 0x0606 #define UCA1BR0_L 0x0606 #define UCA1BR0_H 0x0607 #define UCA1BR1_ 0x0607 #define UCA1BR1_L 0x0607 #define UCA1BR1_H 0x0608 #define UCA1MCTL_ 0x0608 #define UCA1MCTL_L 0x0608 #define UCA1MCTL_H 0x0609 #define UCA1STAT_ 0x060A #define UCA1STAT_L 0x060A #define UCA1STAT_H 0x060B #define UCA1RXBUF 0x060C #define UCA1RXBUF_L 0x060C #define UCA1RXBUF_H 0x060D #define UCA1TXBUF 0x060E #define UCA1TXBUF_L 0x060E #define UCA1TXBUF_H 0x060F #define UCA1ABCTL 0x0610 #define UCA1ABCTL_L 0x0610 #define UCA1ABCTL_H 0x0611 #define UCA1IRTCTL 0x0612 #define UCA1IRTCTL_L 0x0612 #define UCA1IRTCTL_H 0x0613 #define UCA1IRRCTL 0x0613 #define UCA1IRRCTL_L 0x0613 #define UCA1IRRCTL_H 0x0614 #define UCA1IE_ 0x061C #define UCA1IE_L_ 0x061C #define UCA1IE_H_ 0x061D #define UCA1IFG_ 0x061D #define UCA1IFG_L 0x061D #define UCA1IFG_H 0x061E #define UCA1IV_ 0x061E #define UCA1IV_L_ 0x061E #define UCA1IV_H_ 0x061F #define UCB1CTL0_ 0x0621 #define UCB1CTL0_L 0x0621 #define UCB1CTL0_H 0x0622 #define UCB1CTL1_ 0x0620 #define UCB1CTL1_L 0x0620 #define UCB1CTL1_H 0x0621 #define UCB1BR0_ 0x0626 #define UCB1BR0_L 0x0626 #define UCB1BR0_H 0x0627 #define UCB1BR1_ 0x0627 #define UCB1BR1_L 0x0627 #define UCB1BR1_H 0x0628 #define UCB1STAT_ 0x062A #define UCB1STAT_L 0x062A #define UCB1STAT_H 0x062B #define UCB1RXBUF 0x062C #define UCB1RXBUF_L 0x062C #define UCB1RXBUF_H 0x062D #define UCB1TXBUF 0x062E #define UCB1TXBUF_L 0x062E #define UCB1TXBUF_H 0x062F #define UCB1I2COA 0x0630 #define UCB1I2COA_L 0x0630 #define UCB1I2COA_H 0x0631 #define UCB1I2CSA 0x0632 #define UCB1I2CSA_L 0x0632 #define UCB1I2CSA_H 0x0633 #define UCB1IE_ 0x063C #define UCB1IE_L_ 0x063C #define UCB1IE_H_ 0x063D #define UCB1IFG_ 0x063D #define UCB1IFG_L 0x063D #define UCB1IFG_H 0x063E #define UCB1IV_ 0x063E #define UCB1IV_L_ 0x063E #define UCB1IV_H_ 0x063F */ #endif /* __MSP430_HAS_USCI1_5__ */
#if defined(__MSP430_HAS_USCI2_5__)
/* -------- USCI2_5 */
// tbd /*#define UCA2CTL0_ 0x0641 #define UCA2CTL0_L 0x0641 #define UCA2CTL0_H 0x0642 #define UCA2CTL1_ 0x0640 #define UCA2CTL1_L 0x0640 #define UCA2CTL1_H 0x0641 #define UCA2BR0_ 0x0646 #define UCA2BR0_L 0x0646 #define UCA2BR0_H 0x0647 #define UCA2BR1_ 0x0647 #define UCA2BR1_L 0x0647 #define UCA2BR1_H 0x0648 #define UCA2MCTL_ 0x0648 #define UCA2MCTL_L 0x0648 #define UCA2MCTL_H 0x0649 #define UCA2STAT_ 0x064A #define UCA2STAT_L 0x064A #define UCA2STAT_H 0x064B #define UCA2RXBUF 0x064C #define UCA2RXBUF_L 0x064C #define UCA2RXBUF_H 0x064D #define UCA2TXBUF 0x064E #define UCA2TXBUF_L 0x064E #define UCA2TXBUF_H 0x064F #define UCA2ABCTL 0x0650 #define UCA2ABCTL_L 0x0650 #define UCA2ABCTL_H 0x0651 #define UCA2IRTCTL 0x0652 #define UCA2IRTCTL_L 0x0652 #define UCA2IRTCTL_H 0x0653 #define UCA2IRRCTL 0x0653 #define UCA2IRRCTL_L 0x0653 #define UCA2IRRCTL_H 0x0654 #define UCA2IE_ 0x065C #define UCA2IE_L_ 0x065C #define UCA2IE_H_ 0x065D #define UCA2IFG_ 0x065D #define UCA2IFG_L 0x065D #define UCA2IFG_H 0x065E #define UCA2IV_ 0x065E #define UCA2IV_L_ 0x065E #define UCA2IV_H_ 0x065F #define UCB2CTL0_ 0x0661 #define UCB2CTL0_L 0x0661 #define UCB2CTL0_H 0x0662 #define UCB2CTL1_ 0x0660 #define UCB2CTL1_L 0x0660 #define UCB2CTL1_H 0x0661 #define UCB2BR0_ 0x0666 #define UCB2BR0_L 0x0666 #define UCB2BR0_H 0x0667 #define UCB2BR1_ 0x0667 #define UCB2BR1_L 0x0667 #define UCB2BR1_H 0x0668 #define UCB2STAT_ 0x066A #define UCB2STAT_L 0x066A #define UCB2STAT_H 0x066B #define UCB2RXBUF 0x066C #define UCB2RXBUF_L 0x066C #define UCB2RXBUF_H 0x066D #define UCB2TXBUF 0x066E #define UCB2TXBUF_L 0x066E #define UCB2TXBUF_H 0x066F #define UCB2I2COA 0x0670 #define UCB2I2COA_L 0x0670 #define UCB2I2COA_H 0x0671 #define UCB2I2CSA 0x0672 #define UCB2I2CSA_L 0x0672 #define UCB2I2CSA_H 0x0673 #define UCB2IE_ 0x067C #define UCB2IE_L_ 0x067C #define UCB2IE_H_ 0x067D #define UCB2IFG_ 0x067D #define UCB2IFG_L 0x067D #define UCB2IFG_H 0x067E #define UCB2IV_ 0x067E #define UCB2IV_L_ 0x067E #define UCB2IV_H_ 0x067F */ #endif /* __MSP430_HAS_USCI2_5__ */
#if defined(__MSP430_HAS_USCI3_5__)
/* -------- USCI3_5 */ // tbd /*#define UCA3CTL0_ 0x0681 #define UCA3CTL0_L 0x0681 #define UCA3CTL0_H 0x0682 #define UCA3CTL1_ 0x0680 #define UCA3CTL1_L 0x0680 #define UCA3CTL1_H 0x0681 #define UCA3BR0_ 0x0686 #define UCA3BR0_L 0x0686 #define UCA3BR0_H 0x0687 #define UCA3BR1_ 0x0687 #define UCA3BR1_L 0x0687 #define UCA3BR1_H 0x0688 #define UCA3MCTL_ 0x0688 #define UCA3MCTL_L 0x0688 #define UCA3MCTL_H 0x0689 #define UCA3STAT_ 0x068A #define UCA3STAT_L 0x068A #define UCA3STAT_H 0x068B #define UCA3RXBUF 0x068C #define UCA3RXBUF_L 0x068C #define UCA3RXBUF_H 0x068D #define UCA3TXBUF 0x068E #define UCA3TXBUF_L 0x068E #define UCA3TXBUF_H 0x068F #define UCA3ABCTL 0x0690 #define UCA3ABCTL_L 0x0690 #define UCA3ABCTL_H 0x0691 #define UCA3IRTCTL 0x0692 #define UCA3IRTCTL_L 0x0692 #define UCA3IRTCTL_H 0x0693 #define UCA3IRRCTL 0x0693 #define UCA3IRRCTL_L 0x0693 #define UCA3IRRCTL_H 0x0694 #define UCA3IE_ 0x069C #define UCA3IE_L_ 0x069C #define UCA3IE_H_ 0x069D #define UCA3IFG_ 0x069D #define UCA3IFG_L 0x069D #define UCA3IFG_H 0x069E #define UCA3IV_ 0x069E #define UCA3IV_L_ 0x069E #define UCA3IV_H_ 0x069F #define UCB3CTL0_ 0x06A1 #define UCB3CTL0_L 0x06A1 #define UCB3CTL0_H 0x06A2 #define UCB3CTL1_ 0x06A0 #define UCB3CTL1_L 0x06A0 #define UCB3CTL1_H 0x06A1 #define UCB3BR0_ 0x06A6 #define UCB3BR0_L 0x06A6 #define UCB3BR0_H 0x06A7 #define UCB3BR1_ 0x06A7 #define UCB3BR1_L 0x06A7 #define UCB3BR1_H 0x06A8 #define UCB3STAT_ 0x06AA #define UCB3STAT_L 0x06AA #define UCB3STAT_H 0x06AB #define UCB3RXBUF 0x06AC #define UCB3RXBUF_L 0x06AC #define UCB3RXBUF_H 0x06AD #define UCB3TXBUF 0x06AE #define UCB3TXBUF_L 0x06AE #define UCB3TXBUF_H 0x06AF #define UCB3I2COA 0x06B0 #define UCB3I2COA_L 0x06B0 #define UCB3I2COA_H 0x06B1 #define UCB3I2CSA 0x06B2 #define UCB3I2CSA_L 0x06B2 #define UCB3I2CSA_H 0x06B3 #define UCB3IE_ 0x06BC #define UCB3IE_L_ 0x06BC #define UCB3IE_H_ 0x06BD #define UCB3IFG_ 0x06BD #define UCB3IFG_L 0x06BD #define UCB3IFG_H 0x06BE #define UCB3IV_ 0x06BE #define UCB3IV_L_ 0x06BE #define UCB3IV_H_ 0x06BF */ #endif /* __MSP430_HAS_USCI3_5__ */
#endif Прогресс прогрессирует?
Программирование делится на системное и бессистемное. ©Моё :) — а для кого-то БГ — это Bill Gilbert =)
Nov 6 2009, 13:56
Начинающий профессионал
Из: СПб
Пользователь №: 21 648
Цитата(MrYuran @ Nov 6 2009, 15:49)  CODE #if !defined(__msp430_headers_usci_h__) #if defined(__MSP430_HAS_USCI3_5__)
/* -------- USCI3_5 */ // tbd /*#define UCA3CTL0_ 0x0681 <!!!!!!!!!!!!!!!! comment begin #define UCA3CTL0_L 0x0681 #define UCA3CTL0_H 0x0682 #define UCA3CTL1_ 0x0680 #define UCA3CTL1_L 0x0680 #define UCA3CTL1_H 0x0681 #define UCA3BR0_ 0x0686 #define UCA3BR0_L 0x0686 #define UCA3BR0_H 0x0687 #define UCA3BR1_ 0x0687 #define UCA3BR1_L 0x0687 #define UCA3BR1_H 0x0688 #define UCA3MCTL_ 0x0688 #define UCA3MCTL_L 0x0688 #define UCA3MCTL_H 0x0689 #define UCA3STAT_ 0x068A #define UCA3STAT_L 0x068A #define UCA3STAT_H 0x068B #define UCA3RXBUF 0x068C #define UCA3RXBUF_L 0x068C #define UCA3RXBUF_H 0x068D #define UCA3TXBUF 0x068E #define UCA3TXBUF_L 0x068E #define UCA3TXBUF_H 0x068F #define UCA3ABCTL 0x0690 #define UCA3ABCTL_L 0x0690 #define UCA3ABCTL_H 0x0691 #define UCA3IRTCTL 0x0692 #define UCA3IRTCTL_L 0x0692 #define UCA3IRTCTL_H 0x0693 #define UCA3IRRCTL 0x0693 #define UCA3IRRCTL_L 0x0693 #define UCA3IRRCTL_H 0x0694 #define UCA3IE_ 0x069C #define UCA3IE_L_ 0x069C #define UCA3IE_H_ 0x069D #define UCA3IFG_ 0x069D #define UCA3IFG_L 0x069D #define UCA3IFG_H 0x069E #define UCA3IV_ 0x069E #define UCA3IV_L_ 0x069E #define UCA3IV_H_ 0x069F #define UCB3CTL0_ 0x06A1 #define UCB3CTL0_L 0x06A1 #define UCB3CTL0_H 0x06A2 #define UCB3CTL1_ 0x06A0 #define UCB3CTL1_L 0x06A0 #define UCB3CTL1_H 0x06A1 #define UCB3BR0_ 0x06A6 #define UCB3BR0_L 0x06A6 #define UCB3BR0_H 0x06A7 #define UCB3BR1_ 0x06A7 #define UCB3BR1_L 0x06A7 #define UCB3BR1_H 0x06A8 #define UCB3STAT_ 0x06AA #define UCB3STAT_L 0x06AA #define UCB3STAT_H 0x06AB #define UCB3RXBUF 0x06AC #define UCB3RXBUF_L 0x06AC #define UCB3RXBUF_H 0x06AD #define UCB3TXBUF 0x06AE #define UCB3TXBUF_L 0x06AE #define UCB3TXBUF_H 0x06AF #define UCB3I2COA 0x06B0 #define UCB3I2COA_L 0x06B0 #define UCB3I2COA_H 0x06B1 #define UCB3I2CSA 0x06B2 #define UCB3I2CSA_L 0x06B2 #define UCB3I2CSA_H 0x06B3 #define UCB3IE_ 0x06BC #define UCB3IE_L_ 0x06BC #define UCB3IE_H_ 0x06BD #define UCB3IFG_ 0x06BD #define UCB3IFG_L 0x06BD #define UCB3IFG_H 0x06BE #define UCB3IV_ 0x06BE #define UCB3IV_L_ 0x06BE #define UCB3IV_H_ 0x06BF */ <!!!!!!!!!!!!!!!! comment end #endif /* __MSP430_HAS_USCI3_5__ */
#endif Прогресс прогрессирует? Указал на пример комментариев в файле. Цитата(Сергей Борщ @ Nov 6 2009, 16:09)  P.S. Вы так настойчиво ждете каких-то дополнений в этом файле, что можно было уже 10 раз написать их самостоятельно, оттестировать и послать патч Крису. P.P.S. В списке рассылки проскакивала информация, что репозиторий будут перетаскивать под bazaar. Чем закончилось - не знаю. Когда (?) будет время, то хочу попробовать собрать для MSP-EXP430F5438 демонстрационный пример, скорректировав исходный код IAR (CCE). Для этого надо иметь _полный_ комплект описаний регистров в заголовочных файлах.
Nov 6 2009, 16:45
Из: Рига, Латвия
Пользователь №: 17 095
Цитата(mdmitry @ Nov 6 2009, 17:46)  Имеется прецедент в виде файла gpio_5xxx.h специально для этой серии. На мой взгляд и остальная периферия получается в этом же виде (отдельные файлы hardmodulname_54xxx.h). Ну usi.h и usci.h ведь не смущают - разная периферия, разные файлы. Периферия семейства 5xxx настолько существенно отличается от предыдущих семейств, что мне показалось логичным вынести ее в отдельный файл. Может название не совсем уданое, но ничего лучше в голову не пришло. Цитата(mdmitry @ Nov 6 2009, 17:46)  похоже на латание дыр для совместимости с предыдущими семействами. Есть предложения как улучшить - пишите в список рассылки, там последний год оживление наблюдается.
На любой вопрос даю любой ответ"Write code that is guaranteed to work, not code that doesn’t seem to break" ( C++ FAQ)
AHTOXA MSP-GCC 4. Кто-нибудь пробовал? Oct 6 2009, 11:27 Ko4egap Отличная новость! Завтра буду пробовать. Надею... Oct 11 2009, 08:23 mdmitry Цитата(Ko4egap @ Oct 11 2009, 12:23) Отли... Oct 11 2009, 19:02 MrYuran Выкачал, стал запускать - пишет, мол, файл исполня... Nov 1 2009, 13:32 AHTOXA Цитата(MrYuran @ Nov 1 2009, 18:32) Радуе... Nov 1 2009, 21:27  MrYuran Цитата(AHTOXA @ Nov 2 2009, 00:27) Наскол... Nov 2 2009, 06:07   mdmitry Цитата(MrYuran @ Nov 2 2009, 09:07) Кстат... Nov 2 2009, 12:22    MrYuran Цитата(mdmitry @ Nov 2 2009, 15:22) У IAR... Nov 2 2009, 12:39     mdmitry Цитата(MrYuran @ Nov 2 2009, 15:39) Ну та... Nov 2 2009, 16:29 MrYuran Таки распаковал... Йошкин кот!
265 МЕТРОВ... Nov 6 2009, 10:14 mdmitry Цитата(MrYuran @ Nov 6 2009, 13:14) Кстат... Nov 6 2009, 12:45 Сергей Борщ Цитата(MrYuran @ Nov 6 2009, 12:14) Кстат... Nov 6 2009, 13:09     mdmitry Цитата(Сергей Борщ @ Nov 6 2009, 19:45) Н... Nov 6 2009, 17:25      Сергей Борщ Цитата(mdmitry @ Nov 6 2009, 19:25) Получ... Nov 6 2009, 18:03       mdmitry Цитата(Сергей Борщ @ Nov 6 2009, 21:03) В... Nov 6 2009, 21:25        Сергей Борщ Цитата(mdmitry @ Nov 6 2009, 23:25) msp43... Nov 7 2009, 07:45         mdmitry Цитата(Сергей Борщ @ Nov 7 2009, 10:45) В... Nov 7 2009, 14:08          Сергей Борщ Цитата(mdmitry @ Nov 7 2009, 16:08) Хочет... Nov 7 2009, 18:33 MrYuran Таки попробовал...
Компилятор что-то компилит.
А в... May 21 2010, 11:41 MrYuran Нашёл предварительно, где копать:
stdlib.h:
Кодex... May 21 2010, 13:06 Сергей Борщ Цитата(MrYuran @ May 21 2010, 15:48) Ну и... May 21 2010, 13:14  MrYuran Цитата(Сергей Борщ @ May 21 2010, 17:14) ... May 21 2010, 13:19 AHTOXA Цитата(MrYuran @ May 21 2010, 19:06) Ну н... May 21 2010, 13:22  demiurg_spb Цитата(AHTOXA @ May 21 2010, 17:22) Это о... May 21 2010, 14:01   MrYuran Цитата(demiurg_spb @ May 21 2010, 18:01) ... May 24 2010, 09:37    demiurg_spb Цитата(MrYuran @ May 24 2010, 13:37) По о... May 24 2010, 10:40     AHTOXA Цитата(MrYuran @ May 24 2010, 15:37) По о... May 24 2010, 13:50      MrYuran Цитата(AHTOXA @ May 24 2010, 17:50) Круто... May 25 2010, 05:43       demiurg_spb Цитата(MrYuran @ May 25 2010, 09:43) Тако... May 25 2010, 09:24        MrYuran Цитата(demiurg_spb @ May 25 2010, 13:24) ... May 25 2010, 09:40         demiurg_spb Давайте посмотрим на всю стоку целиком.
Вот как у ... May 25 2010, 10:00 MrYuran ЦитатаЗа ключики спасибо, буду играться.
КодBuild ... May 21 2010, 13:34 MrYuran А как заставить make выводить весь поток полностью... May 25 2010, 10:23 AHTOXA make -n ? May 25 2010, 10:28 demiurg_spb Цитата(MrYuran @ May 25 2010, 14:23) А ка... May 25 2010, 11:33 MrYuran Цитатаd:\WORK\PROJECTS\MARK-1002T... May 25 2010, 10:55 MrYuran Короче, я понял.
Он все секции мапит на 0x0000, в ... May 25 2010, 12:06 MrYuran Противоречивые какие-то чувства навевает...
Поигра... Jun 11 2010, 13:29 demiurg_spb Цитата(MrYuran @ Jun 11 2010, 17:29) если... Jun 13 2010, 11:08 MrYuran ААААААААААААААААААААААААААААААА!!!... Jun 17 2010, 07:31 MrYuran Вот кстати интересно:
Кто структуры пакует - компи... Jun 17 2010, 08:45 demiurg_spb Про упаковку всех структур:
КодCFLAGS += -fpack-st... Jun 17 2010, 09:25  MrYuran Цитата(demiurg_spb @ Jun 17 2010, 13:25) ... Jun 17 2010, 09:31   Сергей Борщ Цитата(MrYuran @ Jun 17 2010, 12:31) Ура,... Jun 17 2010, 12:34    MrYuran Цитата(Сергей Борщ @ Jun 17 2010, 16:34) ... Jun 17 2010, 15:49 MrYuran Перекомпилил старый ИАРовский прожект, который ран... Jul 6 2010, 06:41 MrYuran В последнее время проект реанимирован, произошло (... Apr 5 2012, 06:16 MrYuran Попробовал дополнительные ключики
ЦитатаCFLAGS += ... Apr 5 2012, 07:40 AHTOXA Это про какой mspgcc? Про просто mspgcc или про ms... Apr 5 2012, 07:59  MrYuran Цитата(AHTOXA @ Apr 5 2012, 11:59) Это пр... Apr 5 2012, 08:21   AHTOXA А, ну с этим мы уже немножко познакомились Apr 5 2012, 08:32    MrYuran Цитата(AHTOXA @ Apr 5 2012, 12:32) А, ну ... Apr 5 2012, 08:36 MrYuran Попробовали крайнюю версию 4.6.2 - опять -combine ... Apr 5 2012, 10:54 AHTOXA Цитата(MrYuran @ Apr 5 2012, 14:36) Там ч... Apr 5 2012, 13:02 MrYuran Цитата(AHTOXA @ Apr 5 2012, 17:02) Глюки ... Apr 6 2012, 09:44 MrYuran Сегодня обнаружил эпический глюк в этой версии.
Вс... May 24 2012, 09:01 alx2 Цитата(MrYuran @ May 24 2012, 14:01) Сего... May 25 2012, 03:25  MrYuran Цитата(alx2 @ May 25 2012, 07:25) Если ош... May 25 2012, 05:04   Сергей Борщ Давно не работаю с MSP, но при беглом просмотре бр... May 25 2012, 06:27   alx2 Цитата(MrYuran @ May 25 2012, 10:04) При ... May 28 2012, 05:07 MrYuran Вот листинг старой версии (трэш и угар но работае... May 25 2012, 08:05 Сергей Борщ QUOTE (MrYuran @ May 25 2012, 11:05) Попу... May 25 2012, 08:59
