> Сборка arm-elf- toolchain, Не удается собрать newlib
Bulya
сообщение Oct 28 2009, 12:37
Из: Харьков
Пользователь №: 40 874
Здравствуйте.
Собираю
binutils-2.20, gcc-4.3.4, newlib-1.17.0
с ключами
--target=arm-elf --enable-interwork --enable-multilib --enable-languages="c,c++" --with-gnu-as --with-gnu-ld
--disable-shared --disable-nls --disable-newlib-supplied-syscalls --disable-newlib-io-float
компиляция newlib прекращается с ошибками в linux-syscalls0.S
.../newlib-1.17.0/libgloss/arm/linux-syscalls0.S:37: Error: missing expression -- `swi'
.../newlib-1.17.0/libgloss/arm/linux-syscalls0.S:102: Error: missing expression -- `swi'
linux-syscalls0.S:
CODE
#include "linux-syscall.h"
#if __thumb__
# define FUNC(name) .type name, %function; .thumb_func; name:
# define SET .thumb_set
#else
# define FUNC(name) .type name, %function; name:
# define SET .set
#endif
#define GLOBAL(name) .global name; FUNC(name)
#define SIZE(name) .size name, .-name
#if __thumb__
# define SYSCALL0(name) \
GLOBAL(_ ## name); \
mov r12, r7; \
mov r7, #SYS_ ## name; \
swi; \
mov r7, r12; \
b _set_errno; \
SIZE(_ ## name)
/* static int _syscall3(int a, int b, int c, int number); */
FUNC(_syscall3)
push { r7 }
mov r7, r3
swi
pop { r7 }
b _set_errno
SIZE(_syscall3)
# define SYSCALL3(name) \
mov r3, #SYS_ ## name; \
b _syscall3; \
SIZE(_ ## name)
# define SYSCALL6(name) \
push { r4 - r5, r7 }; \
ldr r4, [sp, #12]; \
ldr r5, [sp, #16]; \
swi; \
pop { r4 - r5, r7 }; \
b _set_errno; \
SIZE(_ ## name)
# define SYSCALL4(name) SYSCALL6(name)
#else /* __thumb__ */
# define SYSCALL4(name) \
swi #SYS_ ## name; \
b _set_errno; \
SIZE(_ ## name)
push { r4 - r5 }; \
ldr r4, [sp, #8]; \
ldr r5, [sp, #12]; \
pop { r4 - r5 }; \
b _set_errno; \
SIZE(_ ## name)
#define SYSCALL0(name) SYSCALL3(name)
#define SYSCALL3(name) SYSCALL4(name)
#endif /* __thumb__ */
#define SYSCALL1(name) SYSCALL3(name)
#define SYSCALL2(name) SYSCALL3(name)
#define SYSCALL5(name) SYSCALL6(name)
SYSCALL1(alarm)
SYSCALL1(brk)
SYSCALL1(chdir)
SYSCALL2(chmod)
SYSCALL3(chown)
SYSCALL1(close)
SYSCALL1(dup)
SYSCALL2(dup2)
SYSCALL3(execve)
SYSCALL1(exit)
SYSCALL3(fcntl)
SYSCALL2(fstat)
SYSCALL2(ftruncate)
SYSCALL3(getdents)
SYSCALL0(getegid)
SYSCALL0(geteuid)
SYSCALL0(getgid)
SYSCALL2(getgroups)
SYSCALL1(getpgid)
SYSCALL0(getpgrp)
SYSCALL0(getpid)
SYSCALL0(getuid)
SYSCALL2(gettimeofday)
SYSCALL3(ioctl)
SYSCALL2(kill)
SYSCALL3(lchown)
SYSCALL2(link)
SYSCALL3(lseek)
SYSCALL2(lstat)
SYSCALL2(mkdir)
SYSCALL3(mknod)
SYSCALL2(nanosleep)
SYSCALL3(open)
SYSCALL0(pause)
SYSCALL1(pipe)
SYSCALL3(read)
SYSCALL3(readlink)
SYSCALL4(reboot)
SYSCALL1(rmdir)
SYSCALL5(select)
SYSCALL2(setpgid)
SYSCALL1(setgid)
SYSCALL0(setsid)
SYSCALL1(setuid)
SYSCALL3(sigprocmask)
SYSCALL2(socketcall)
SYSCALL2(stat)
SYSCALL1(stime)
SYSCALL2(symlink)
SYSCALL1(sync)
SYSCALL1(sysinfo)
SYSCALL1(times)
SYSCALL2(truncate)
SYSCALL1(umask)
SYSCALL1(uname)
SYSCALL1(unlink)
SYSCALL2(utime)
SYSCALL0(vfork)
SYSCALL4(wait4)
SYSCALL3(write)
т.е. передача номера прерывания через регистр r7 (в __thumb__), а не в инструкции swi вызывает ошибку.
Что характерно, системные вызовы linux мне вообще не нужны для arm-elf.
Подскажите, пожалуйста, решение проблемы (правильную конфигурацию при сборке или правильный синтаксис системных вызовов).
Doka
сообщение Nov 14 2009, 07:19
Electrical Engineer
Группа: СуперМодераторы
Пользователь №: 778
а о каком CVS newlib речь??.. я брал отсюда ftp://sources.redhat.com/pub/newlib/
версия newlib-1.17.0.tar.gz датирована 22.12.2008 (собирал с правкой configure.ac как описано на http://eluaproject.dreamhosters.com/en/Bui..._GCC_for_Cortex )
Блог iDoka.ru
CV linkedin.com/in/iDoka
Sources github.com/iDoka
Never stop thinking...........................
klen
сообщение Nov 14 2009, 10:55
бессмертным стать можно тремя способами
Пользователь №: 16 912
http://ru.wikipedia.org/wiki/CVS
читать до конца
ставить CVS клиета, забирать им текщий срез дерева исходников, править и закладывать сои измения в дерево(для продвинутых smile.gif)
также читать по теме SVN,GIT,Mercurial
RSS Текстовая версия Сейчас: 27th July 2025 - 07:26
Страница сгенерированна за 0.01389 секунд с 7
