EE2007.7 и Linux, Не работает |
Nov 12 2009, 14:56
Из: Нижний Новгород
Пользователь №: 13 319
При запуске viewdraw программка vnsd выдает сообщения об ошибках: CODE Failed initialization vipc: Error 1172: VNSD failed opening input channel +vipc: Warning 1343: Unable to start a 6.00 VNSD. If an earlier version VNSD is running, a- MAKE SURE ALL TOOLS ARE IDLE, b- ALL DATA IS SAVED TO DISK, AND c- THE ENVIRONMENT VARIABLE IS SET as follows (or in an equivalent manner):
setenv VIPC_KILL_PRE_60_VNSD TRUE
d- then restart the tool.
If a 6.00 tool can run, there is no need to take any further action.
+vipc: Error 1082: Failed creating end point struct during inet socket open +vipc: Error 1088: Failed bind call for ITC inet socket creation (Address already in use) - there may be another process using the requested port number (or another VNSD already running!) +vipc: Error 1082: Failed creating end point struct during inet socket open +vipc: Error 1088: Failed bind call for ITC inet socket creation (Address already in use) - there may be another process using the requested port number (or another VNSD already running!) Note: the log file may contain more information Vnsd exiting viewdraw не запускается, vnsd остается висеть. PS. Вообще у кого-нибудь установлена нормально EE под линукс? Заранее спасибо.
jericho EE2007.7 и Linux Nov 12 2009, 14:56 SM Цитата(jericho @ Nov 12 2009, 17:56) PS. ... Nov 12 2009, 16:25 jericho Цитата(SM @ Nov 12 2009, 19:25) По делу -... Nov 13 2009, 07:44  SM Цитата(jericho @ Nov 13 2009, 10:44) Став... Nov 13 2009, 08:08 jericho И PATH и SDD_HOME, SDD_LOCAL, SDD_PLATFORM, MGC_HO... Nov 13 2009, 10:49 SM Цитата(jericho @ Nov 13 2009, 13:49) Все-... Nov 13 2009, 11:00 jericho С strace знаком, сейчас попробую...
Однако снача... Nov 13 2009, 11:54 SM Цитата(jericho @ Nov 13 2009, 14:54) у Ва... Nov 13 2009, 12:10 jericho Сделал strace. Результат примерно такой: последняя... Nov 13 2009, 16:40 SM Цитата(jericho @ Nov 13 2009, 19:40) А са... Nov 13 2009, 16:49 jericho Cейчас делаю "strace -o out_file -f vnsd... Nov 13 2009, 18:33 SM Цитата(jericho @ Nov 13 2009, 21:33) Боль... Nov 14 2009, 00:00 Harbour угм, там же в логе написано что порт занят:
netst... Nov 14 2009, 08:06 jericho Код11016 socket(PF_INET, SOCK_DGRAM, IPPROTO_I... Nov 14 2009, 10:08 SM А так... На всякий случай... Что в /etc/hosts и чт... Nov 14 2009, 10:23 jericho Код# cat /etc/hosts
127.0.0.1 localhost
:... Nov 14 2009, 11:43 SM Попробуйте с таким хостсом
127.0.0.1 localhost lo... Nov 14 2009, 18:44 Harbour Как раз в строчке "127.0.0.1 localhost" ... Nov 15 2009, 07:04 SM Цитата(Harbour @ Nov 15 2009, 10:04) Как ... Nov 15 2009, 10:02 gotty Доброго времени суток.
Пробую установить ee2007.7 ... Nov 28 2009, 18:39 SM Что-то недоставилось или недоконфигурировалось. Он... Nov 28 2009, 19:18 gotty Ставил всё, после установки делал Verify, все тест... Nov 29 2009, 10:34  Vadim Цитата(gotty @ Nov 29 2009, 14:34) Не зна... Nov 30 2009, 07:35 jericho Интересно, а HyperLynx для Linux существует? Dec 23 2009, 08:09 SM Определенно да:
Platforms Supported
• Windows 200... Dec 23 2009, 08:22 fill Цитата(SM @ Dec 23 2009, 11:22) Определен... Dec 23 2009, 13:24 jericho А может еще знаете где его взять?
PS И еще: Hyper... Dec 23 2009, 08:32 lepert Цитата(jericho @ Dec 23 2009, 11:32) А мо... Dec 23 2009, 09:15 jericho Evaluation есть только для винды. Версии 7.5. 10МБ... Dec 23 2009, 09:57 fill Цитата(jericho @ Dec 23 2009, 12:57) Eval... Dec 23 2009, 10:13 SM Т.е. там вкралась ошибка?
http://www.mentor.com/p... Dec 23 2009, 13:31 fill Цитата(SM @ Dec 23 2009, 16:31) Т.е. там ... Dec 23 2009, 15:18 jericho Спасибо, что прояснили ситуацию. Придется перейти ... Dec 24 2009, 07:55 fill Цитата(jericho @ Dec 24 2009, 10:55) Спас... Dec 24 2009, 11:15 SM Цитата(jericho @ Dec 24 2009, 10:55) P.S.... Dec 24 2009, 14:02  fill Цитата(SM @ Dec 24 2009, 17:02) Вроде, ес... Dec 25 2009, 07:49   baken Цитата(fill @ Dec 25 2009, 11:49) Поправо... Dec 25 2009, 07:59 jericho Можно тогда вопрос как к специалистам?
Моделирова... Dec 25 2009, 09:43 baken Цитата(jericho @ Dec 25 2009, 13:43) Моде... Dec 25 2009, 10:52  fill Цитата(baken @ Dec 25 2009, 13:52) 1. Мож... Dec 25 2009, 12:51 cioma И целостность питания (power integrity) им не прос... Dec 25 2009, 14:00 baken Если уж использовать Hyperlynx для PI, тогда имеет... Dec 25 2009, 15:05 Juzujka у кого-нибудь заработало на OpenSUSE11.1?
Dashboar... Jan 20 2010, 13:48 SM Цитата(Juzujka @ Jan 20 2010, 16:48) Файл... Jan 20 2010, 15:31  Juzujka Цитата(SM @ Jan 20 2010, 18:31) Сомневаюс... Jan 20 2010, 22:04 vugluskr Цитата(Juzujka @ Jan 20 2010, 16:48) у ко... Feb 10 2010, 15:20  Vadim Цитата(vugluskr @ Feb 10 2010, 19:20) при... Feb 10 2010, 16:05   vugluskr Цитата(Vadim @ Feb 10 2010, 19:05) Это во... Feb 10 2010, 17:04    Vadim Цитата(vugluskr @ Feb 10 2010, 21:04) я д... Feb 10 2010, 18:31     vugluskr 1) пинок EE выглядит так:
2) echo $MGLS_LIC... Feb 10 2010, 19:01  Juzujka Цитата(vugluskr @ Feb 10 2010, 18:20) из ... Feb 10 2010, 22:33   vugluskr Цитата(Juzujka @ Feb 11 2010, 02:33) Вы н... Feb 11 2010, 05:22    Vadim Цитата(vugluskr @ Feb 11 2010, 08:22) А к... Feb 11 2010, 07:10     vugluskr Цитата(Vadim @ Feb 11 2010, 11:10) EE из-... Feb 11 2010, 07:17      Vadim 1) ОК
2) OK
3) Проверьте права на выполнение mgls_... Feb 11 2010, 07:26       vugluskr Цитата(Vadim @ Feb 11 2010, 11:26) ЗЫ. У ... Feb 11 2010, 07:43     vugluskr Цитата(Vadim @ Feb 11 2010, 11:10) Конечн... Feb 11 2010, 07:30 wolfman Господа, а не подскажите как файл лицензии подцепи... Feb 2 2010, 18:49 wolfman Цитата(Juzujka @ Feb 11 2010, 08:03) Вы н... Feb 11 2010, 06:38 wolfman ЦитатаЗЫ. У Вас лицензия сетевая или "нормаль... Feb 11 2010, 07:37 Vadim Цитата(wolfman @ Feb 11 2010, 10:37) меня... Feb 11 2010, 07:55  vugluskr Цитата(Vadim @ Feb 11 2010, 11:55) ???
Н... Feb 11 2010, 08:04   Vadim Цитата(vugluskr @ Feb 11 2010, 12:04) все... Feb 11 2010, 08:33    vugluskr Цитата(Vadim @ Feb 11 2010, 11:33) Скорее... Feb 11 2010, 09:18 fill Цитата(wolfman @ Feb 11 2010, 10:37) меня... Feb 11 2010, 08:20 wolfman Цитата(Vadim @ Feb 11 2010, 17:25) ???
Н... Feb 11 2010, 08:03 wolfman Цитата(fill @ Feb 11 2010, 17:50)
Прост... Feb 11 2010, 08:52 Vadim Цитата(wolfman @ Feb 11 2010, 12:52) А ку... Feb 11 2010, 08:54 wolfman Цитата(Vadim @ Feb 11 2010, 18:24) Ну вед... Feb 11 2010, 09:20 vugluskr Качаю CentOS 5.4 Feb 11 2010, 09:53 Vadim Радикально Feb 11 2010, 10:11  vugluskr просто общаться будем тогда на одном языке, тут ве... Feb 11 2010, 10:13 wolfman вобщем прописал переменную, теперь такая же пробле... Feb 11 2010, 10:43 fill У легальных пользователей таких проблем не бывает ... Feb 11 2010, 12:48 wolfman вы не поверите, но лицензии куплены вполне легальн... Feb 11 2010, 13:08 fill 1. Ну если вы легальный пользователь, то почему не... Feb 11 2010, 13:29 wolfman Название фирмы отправил в личку.
К нам приезжал то... Feb 11 2010, 13:38 fill 1. С данными лицензиями могут работать только DxDe... Feb 11 2010, 13:50 wolfman Ага, тогда просветите товарища Селиванова на этот ... Feb 11 2010, 13:57 fill 3. Вы можете поставить DxDesigner в Linux и работа... Feb 11 2010, 14:06 wolfman Хм, так я и борюсь EE2007.8_ESDM.rhel4. Feb 11 2010, 14:08 fill
Значит остается только вариант обновления файлов... Feb 11 2010, 14:14 wolfman Такой вопрос, у нас куплено некоторое небольшое ко... Feb 11 2010, 14:17 fill В виндах возникает сообщение типа "нет лиценз... Feb 11 2010, 14:55 wolfman Завтра попробую, возникла еще одна идея, но времен... Feb 11 2010, 17:32 wolfman попробовал на своем компе запустить lmutil lmstat ... Feb 12 2010, 07:31 fill Судя по сообщению не виден работающий лиц. сервер.... Feb 12 2010, 07:54 Juzujka Цитата(wolfman @ Feb 12 2010, 10:31) попр... Feb 12 2010, 11:08  wolfman Цитата(Juzujka @ Feb 12 2010, 21:38) И с ... Feb 12 2010, 13:11 wolfman Запустил tcp dump, затем lmutil lmstat -a.
Запуст... Feb 12 2010, 07:55 fill Цитата(wolfman @ Feb 12 2010, 10:55) буде... Feb 12 2010, 09:03 wolfman Из под линук сервак как раз видится, но не видит г... Feb 12 2010, 09:13 vugluskr переодически Дх просто вылетает, кто-нибудь сталки... Feb 13 2010, 18:24 vugluskr Открываю в Дх проект (к примеру учебный), в сеттин... Feb 14 2010, 17:06 baken Патаму что Вы должны подключить DXDatabook, а он в... Feb 14 2010, 18:48 vugluskr Цитата(baken @ Feb 14 2010, 21:48) Патаму... Feb 14 2010, 19:02 baken Я понимаю, что Вы на форуме недавно, все же прежде... Feb 15 2010, 05:24 vugluskr Цитата(baken @ Feb 15 2010, 08:24) Во вто... Feb 15 2010, 06:09 baken Как обычно, DxDatabook это надстройка НАД библиоте... Feb 15 2010, 06:21
2 страниц
1 2 >
