Основной код программы
CODE
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define BUFFER_SIZE 100
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
USART_InitTypeDef USART_InitStructure;
vu8 RxBuffer[BUFFER_SIZE];
vu8 RxCounter = 0;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
/* Private functions ---------------------------------------------------------*/
* @brief Main program
* @param None
* @retval : None
int main(void)
/* System Clocks Configuration */
RCC_Configuration();
/* NVIC configuration */
NVIC_Configuration();
/* Configure the GPIO ports */
GPIO_Configuration();
/* USART1 configuration ------------------------------------------------------*/
USART_InitStructure.USART_BaudRate = 57600;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
/* Configure USART1 */
USART_Init(USART1, &USART_InitStructure);
/* Enable USART1 Receive interrupt */
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
/* Enable the USART1 */
USART_Cmd(USART1, ENABLE);
while (1)
* @brief Configures the different system clocks.
* @param None
* @retval : None
/* Setup the microcontroller system. Initialize the Embedded Flash Interface,
initialize the PLL and update the SystemFrequency variable. */
SystemInit();
/* Enable USART1, GPIOA, and AFIO clocks */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA
| RCC_APB2Periph_AFIO, ENABLE);
* @brief Configures the different GPIO ports.
* @param None
* @retval : None
GPIO_InitTypeDef GPIO_InitStructure;
/* Configure USART1 Rx (PA.10) as input floating */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* Configure USART1 Tx (PA.09) as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
* @brief Configures the nested vectored interrupt controller.
* @param None
* @retval : None
NVIC_InitTypeDef NVIC_InitStructure;
/* Enable the USART1 Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
Код обработчика прерывания
void USART1_IRQHandler(void)
extern vu8 RxBuffer[];
extern vu8 RxCounter;
if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
/* Read one byte from the receive data register */
RxBuffer[RxCounter++] = USART_ReceiveData(USART1);
USART_SendData(USART1, RxBuffer[RxCounter - 1]);
while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET)
Просто я подумал, что код почти такой же, как в примере... Видно, мне надо меньше думать
Сообщение отредактировал Rosso - Mar 2 2010, 13:52
