> SmartFusion FPGAs from Actel, ProASIC®3 FPGA+hard ARM® Cortex™-M3+programmable analog blocks
maugli
сообщение Mar 5 2010, 02:33
Из: Серпухов
Пользователь №: 39 283
Actel Corporation unveiled SmartFusion™ FPGA
Key components and features of the device are:
Full-Featured FPGA:
SmartFusion devices feature Actel's proven, flash-based ProASIC®3 FPGA architecture. Built on an advanced 130-nm CMOS process, Actel offers densities ranging from 60K to 500K system gates, with 350 MHz performance and up to 204 I/Os. This combination enables the integration of existing functions from other devices, substantially reducing board space and power consumption of the overall system.
Microcontroller Subsystem:
Intelligence is added to the FPGA in the form of a microcontroller subsystem that features a hard ARM Cortex-M3 processor running at 100 MHz. A full complement of standard peripherals and features include:
Multi-layer AHB communications matrix with up to 16 Gbps throughput
10/100 Ethernet MAC with RMII interface
Two of each: SPI, I2C, UART, 32-bit Timers
Up to 512 KB flash memory and 64 KB of SRAM
External memory controller (EMC)
8-channel DMA controller
Programmable Analog:
The innovative and proprietary Analog Compute Engine (ACE) performs sample sequencing and computation, which offloads the ARM Cortex-M3 processor from analog initialization and processing. The programmable analog system features:
ADCs and DACs with 1 percent accuracy.
Up to three 12-bit ADC with up to 600 Ksps sampling rate
Up to three 12-bit first order sigma delta DACs
Up to ten 50 ns high-speed comparators
Multiple integrated temperature, voltage and current monitors
Аматер
сообщение Mar 11 2010, 07:37
Из: Рождественно
Пользователь №: 54 616
Тем не менее Actel делают уникальные вещи. Особенно если места нет на плате.
По моему ни у кого нет fpga или более менее большой CPLD в маленьких корпусах. Поэтому придется пробовать с Actel.
des00
сообщение Mar 11 2010, 09:15
Вечный ламер
Из: Томск
Пользователь №: 3 453
неужто у актела корпуса меньше чем 8х8 мм ?
yes
сообщение Mar 11 2010, 09:25
Пользователь №: 1 640
есть, по моему до 4х4 - но там настолько микроскопическая логика, что только специфические применения
des00
сообщение Mar 11 2010, 09:38
Вечный ламер
Из: Томск
в существовании такого корпуса я и не сомневался, но Аматер упомянул о нормальном по толщине чипе. Я понимаю это так, что у актела есть фпга более чем на 5 килолютов в корпусе меньше чем 8х8мм %)
Аматер
сообщение Mar 11 2010, 10:46
Из: Рождественно
У нас на работе не очень продвинутые технологии. Недавно только на 0306 компоненты перешли. Поставить bga с шагом 0.5 это нечто запредельное, а платы делать маленькие надо. Поэтому и сказал что actel очень хороши своими маленькими и простыми корпусами, которых не у кого больше не видел. У нашей любимой альтеры самый маленький корпус 100 пин и то для устаревшего cyclon. Да еще и загрузочную память надо ставить, разьем для прошивки.
Если вы знаете кто делает fpga в маленьких и не сложных для монтажа корпусах, подскажите пожалуйста. А нормальная толщина чипа для каждого своя, 5 килолютов для нас не мало.
Сообщение отредактировал Аматер - Mar 11 2010, 10:48
des00
сообщение Mar 11 2010, 13:41
Вечный ламер
Из: Томск
сервисмены по мобильникам и снимают и ставят без проблем.
насколько я понимаю речь идет о выводных корпусах QN48/QN68. У большой тройки (xilinx, altera, lattice) средних изделий в таких корпусах действительно нет, есть только в 100 пиновом (maxII, сыклон первый, MachXO). QFN есть у альтернативщиков
если нужен супермини, наши декорпусировали альтеры и распаивали прямо на поликоре. Но ИМХО на вашем месте, я бы задумался о бгашных корпусах.
vadimuzzz
сообщение Mar 11 2010, 13:57
Пользователь №: 6 988
07.gif жесть! а как корпус снимали? фоток нет?
des00
сообщение Mar 11 2010, 14:03
Вечный ламер
Из: Томск
Это еще до меня было, максы 3000 ые декорпусировали и распаивали. Декорпусировали механически, шлифанули по бокам на станке, потом располовинили корпус и распаяли под микроскопом %)
RSS Текстовая версия Сейчас: 28th July 2025 - 23:16
Страница сгенерированна за 0.01495 секунд с 7
