> Новый релиз: Expedition Enterprise 2005, основные нововведения
fill
сообщение Dec 12 2005, 12:42
Из: КП Две Поляны
Пользователь №: 512
В приложении переведенное описание "Что нового в EE2005"
www.megratec.ru
AlexN
сообщение Dec 21 2005, 04:42
Пользователь №: 200
Насчет когда ждать - выдержки из ихнего форума:
11/08/05 ( 8 ноября по-американски)
Dave - The next release was pushed out to the end of December. They are working on making sure it works before it is deployed to everyone. There will be a new and Cool document released at the same time the tools are released.
опять же 11/08/05
Some clarification. EXP2005 could ship sooner than the end of the year. It'll be released when it's released.
David
David Byrd
Mentor Graphics Corp
Customer Services Division
Corporate Applications Engineer
типа, кагда выйдет - тогда и выйдет.
12/6/2005
The release of Expedition Enterprise 2005 looks like it will be the first week in January.
In the upcoming EXP2005 release, CES will be enabled for new DxDesigner and Design Capture/DesignView projects, by default.
When creating new DxD or DC/DV projects, you can keep the default, or choose to not use CES.
If you choose not to use CES in DxD, you will have access to the few net-level constraints that can be edited in DxDesigner's Attribute Editor window.
Note: If you're using the DxDesigner-CDB flow, you must use CES.
If you choose not to use CES in DC/DV, you will have access to the Net Properties and Net Classes & Clearances dialogs.
Existing projects in supported flows can enable CES at any time. Until CES is enabled, the existing projets will continue to use Netclasses and Net Props.
The MGC_ENABLE_CES environment variable will no longer be required.
For those using the keyin netlist, it is not possible to enable CES and you'll have to continue to use Netclasses and Net Properties.
David Byrd
Mentor Graphics Corporation
так что DC не помер.
и жалко, что CES не поддерживается с .kyn нетлстом.
и опять перетусовали все директории установки. Казалось бы, какая разница?
- fill   Новый релиз: Expedition Enterprise 2005   Dec 12 2005, 12:42
- - KA_ru   и когда ожидается это чудо???   Dec 15 2005, 14:09
|- - fill   Цитата(KA_ru @ Dec 15 2005, 17:09) и когд...   Dec 15 2005, 14:23
- - Nixon   Судя по всему логичнее им будет поменять последнюю...   Dec 15 2005, 14:52
|- - fill   Цитата(Nixon @ Dec 15 2005, 17:52) Судя п...   Dec 15 2005, 17:22
- - AlexN   опять все перетусовали, ISD оказывается тоже выйде...   Dec 16 2005, 03:51
|- - fill   Цитата(AlexN @ Dec 16 2005, 06:51) опять ...   Dec 16 2005, 11:01
- - nxn   Судя по ee2005_rus.pdf DC/DV больше развиваться н...   Dec 20 2005, 08:36
|- - fill   Цитата(nxn @ Dec 20 2005, 11:36) Судя по ...   Jan 10 2006, 09:24
- - Dmitrij_80   даже и незнаю, я в DC/DV основные принципы были по...   Dec 21 2005, 07:11
- - Dmitrij_80   интересно в 2005 версии нумерация DC/DV будет итдт...   Dec 28 2005, 15:10
|- - fill   Цитата(Dmitrij_80 @ Dec 28 2005, 18:10) и...   Dec 28 2005, 15:27
- - Dmitrij_80   "доморощенная утилита " идет только под ...   Dec 29 2005, 06:22
|- - fill   Цитата(Dmitrij_80 @ Dec 29 2005, 09:22) ...   Dec 29 2005, 09:11
- - SGP   Хотелось бы узнать поподробнее о работе данного па...   Jan 4 2006, 11:25
RSS Текстовая версия Сейчас: 21st July 2025 - 04:16
