NIOS для начинающих |
Apr 19 2010, 12:49
Из: Earth
Пользователь №: 1 437
Вот отчет компилятора IDE: CODE **** Build of configuration Debug for project test_project ****
make -s all includes Compiling main.c... ../main.c: In function `init_button_pio': ../main.c:34: warning: implicit declaration of function `alt_irq_register' ../main.c: At top level: ../main.c:39: warning: return type of 'main' is not `int' ../main.c: In function `main': ../main.c:41: warning: unused variable `value' Linking test_project.elf... Info: (test_project.elf) 13 KBytes program size (code + initialized data). Info: 3120 Bytes free for stack + heap. Creating generated_app.sh... Post-processing to create ram_memory.hex Hardware simulation is not enabled for the target SOPC Builder system. Skipping creation of hardware simulation model contents and simulation symbol files. (Note: This does not affect the instruction set simulator.) Post-processing to create epcs_flash_controller_boot_rom.flash Build completed in 27.984 seconds Вот простыня исходника: CODE #include "system.h" #include "altera_avalon_pio_regs.h" #include "alt_types.h"
//-------------------------------------------------------------- void delay(value) { int i=0; for(i=0;i<value;i++); }
//-------------------------------------------------------------- static void handle_button_interrupts(void* context, alt_u32 id) { volatile int* edge_capture_ptr = (volatile int*) context; *edge_capture_ptr = IORD_ALTERA_AVALON_PIO_EDGE_CAP(BUTTONS_BASE); IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTONS_BASE,0); IOWR_ALTERA_AVALON_PIO_IRQ_MASK(BUTTONS_BASE,0xF); }
//-------------------------------------------------------------- //-------------------------------------------------------------- //-------------------------------------------------------------- //-------------------------------------------------------------- //-------------------------------------------------------------- volatile int edge_capture;
static void init_button_pio() { void* edge_capture_ptr = (void*) &edge_capture; IOWR_ALTERA_AVALON_PIO_IRQ_MASK(BUTTONS_BASE,0xF); IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTONS_BASE,0); alt_irq_register(BUTTONS_IRQ,edge_capture_ptr,handle_button_interrupts); }
//-------------------------------------------------------------- void main(void) { int value = 0x00000001; init_button_pio(); while (1) { if(edge_capture!=0) { switch(edge_capture) { case 0x1: IOWR_ALTERA_AVALON_PIO_DATA(LEDS_BASE , 0x1); break;
case 0x2: IOWR_ALTERA_AVALON_PIO_DATA(LEDS_BASE , 0x2); break;
case 0x4: IOWR_ALTERA_AVALON_PIO_DATA(LEDS_BASE , 0x4); break;
case 0x8: IOWR_ALTERA_AVALON_PIO_DATA(LEDS_BASE , 0x8); break; default: break; } } } Если это важно: в свойствах системной библиотеки параметры Program Memory и ReadOnly Memory установлены на On-Chip память. Еще одно уточнение - процессор по сбросу и исключению уходит в память EPCS. Но в системной библиотеке, как я уже писал выше память программ и ROM-память указывают на OnChip-память. Может из-за этого косячить? Во! Когда я изменил в свойствах системной библиотеки указание памяти программ и ROM с OnChip на EPCS, то компилятор выдал-таки ошибку, причем как раз с теми адресами, которые он выдавал при верификации: Код **** Build of configuration Debug for project test_project ****
make -s all includes Compiling main.c... ../main.c: In function `init_button_pio': ../main.c:34: warning: implicit declaration of function `alt_irq_register' ../main.c: At top level: ../main.c:39: warning: return type of 'main' is not `int' ../main.c: In function `main': ../main.c:41: warning: unused variable `value' Linking test_project.elf... /cygdrive/c/altera/81/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: region epcs_flash_controller is full (test_project.elf section .text). Region needs to be 8908 bytes larger. /cygdrive/c/altera/81/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: address 0xa2b4 of test_project.elf section .epcs_flash_controller is not within region epcs_flash_controller /cygdrive/c/altera/81/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .rodata [00009820 -> 0000984b] overlaps section .exceptions [00009820 -> 000099c7] /cygdrive/c/altera/81/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .rwdata [0000984c -> 0000a2b3] overlaps section .exceptions [00009820 -> 000099c7] collect2: ld returned 1 exit status make: *** [test_project.elf] Error 1 Build completed in 13.921 seconds Похоже что ему мало памяти...
Сообщение отредактировал Omen_13 - May 13 2010, 15:50
Причина редактирования: Оформление кода.
AlexBel NIOS для начинающих Oct 12 2009, 17:47 Full41 Материала на русском языке мало, я бы даже сказал ... Oct 12 2009, 18:00 AlexBel Цитата(Full41 @ Oct 12 2009, 22:00) Если ... Oct 12 2009, 18:39 sysel Цитата(Full41 @ Oct 12 2009, 22:00) Если ... Oct 13 2009, 05:47 Full41 У тебя проблемы с ящиком не чего не отправляется... Oct 12 2009, 18:46 AlexBel Цитата(Full41 @ Oct 12 2009, 22:46) У теб... Oct 12 2009, 19:22  Full41 Цитата(AlexBel @ Oct 12 2009, 23:22) alex... Oct 12 2009, 19:28   AlexBel Цитата(Full41 @ Oct 12 2009, 23:28) Все о... Oct 12 2009, 20:09 iosifk Цитата(AlexBel @ Oct 12 2009, 21:47) Имею... Oct 13 2009, 04:50 Full41 Да нет нормальный сайт, там просто в кратце на рус... Oct 13 2009, 06:01 Stewart Little Цитата(AlexBel @ Oct 12 2009, 21:47) Имею... Oct 13 2009, 13:01 AlexBel Цитата(Stewart Little @ Oct 13 2009, 17:0... Oct 13 2009, 16:31 Kuzmi4 Может тему в шапку вынести , а то вопросы по ниосу... Oct 13 2009, 18:13 Full41 Цитата(Kuzmi4 @ Oct 13 2009, 22:13) Может... Oct 14 2009, 05:20  Omen_13 Сделано по просьбе трудящихся...
С уважением, мод... Oct 18 2009, 18:45 Reanimator++ AlexBel
Леш, я запустил ниос пройдя "Nios II ... Oct 27 2009, 11:28 AlexBel Reanimator++
Рома, спасибо, извини, что не отреаги... Dec 12 2009, 18:05 Full41 Хотел узнать, можно ли использовать переферийные у... Nov 17 2009, 13:28 Kuzmi4 2 Full41 - можно, только вам тогда нужно будет нап... Nov 17 2009, 13:50 Full41 Цитата(Kuzmi4 @ Nov 17 2009, 16:50) 2 Ful... Nov 17 2009, 13:58  Stewart Little Цитата(Full41 @ Nov 17 2009, 16:58) То ес... Nov 17 2009, 14:06 Full41 Все понял!! Буду пробовать!! Спаси... Nov 17 2009, 14:13 Евгений Николаев Уважаемые гуру, подскажите - как "объяснить... Dec 9 2009, 17:21 inco Евгений Николаев
В 9.1 в этом плане сильно всё пом... Dec 9 2009, 19:59 Евгений Николаев inco, спасибо!
Сегодня попробую. Честно говор... Dec 10 2009, 04:37 barabek Подскажите. Есть система, картинка во вложении. Me... Dec 20 2009, 02:30 vadimuzzz Цитата(barabek @ Dec 20 2009, 08:30) Если... Dec 20 2009, 03:23  barabek Цитата(vadimuzzz @ Dec 20 2009, 14:23) по... Dec 20 2009, 03:38 vadimuzzz можно погонять контроллер на тестах, что генерит м... Dec 20 2009, 06:42 barabek Цитата(vadimuzzz @ Dec 20 2009, 16:42) мо... Dec 20 2009, 11:28  barabek Переделал тест. Теперь он пишет сперва 5 ячеек под... Dec 21 2009, 08:48 Kuzmi4 2 barabek
когда у меня возникают проблемы похожего... Dec 21 2009, 08:57 barabek Kuzmi4
По поводу сигналтаба идея хорошая, но боюсь... Dec 21 2009, 09:28  vadimuzzz Цитата(barabek @ Dec 21 2009, 15:28) А кт... Dec 21 2009, 09:36 Kuzmi4 Разъясняю - пишем прогу для ниоса2, компилим, расп... Dec 21 2009, 10:12 vadimuzzz кстати, как-то упустили из виду. а какого рода сбо... Dec 21 2009, 10:40 barabek Цитата(vadimuzzz @ Dec 21 2009, 20:40) кс... Dec 22 2009, 03:58 vadimuzzz ЦитатаА можно ли будет одновременно работать и в д... Dec 22 2009, 07:00 barabek vadimuzzz и Kuzmi4, спасибо! Действительно пол... Dec 23 2009, 13:42 barabek Не знаю точно, сюда нужно постить, или в раздел gc... Jan 24 2010, 07:28 vadimuzzz посмотрите тут http://porn.quiteajolt.com/2007/11/... Jan 25 2010, 01:39 Serg_Sm Здравствуйте. Начинаю разбираться с ниосом, при эт... Feb 10 2010, 10:07 barabek Цитата(Serg_Sm @ Feb 10 2010, 21:07) Доку... Feb 11 2010, 05:43 Serg_Sm Большое спасибо за ответ.
Сейчас платы с разведенн... Feb 11 2010, 06:53 S_Lee Доброго времени суток. Я начал работать в SOPC Bui... Feb 22 2010, 20:45 barabek Цитата(S_Lee @ Feb 23 2010, 06:45) Как пр... Feb 23 2010, 02:36 Kuzmi4 Цитата(S_Lee @ Feb 22 2010, 22:45) ...а т... Feb 23 2010, 08:43 styuf Здравствуйте.
Я сделал проектик, с использование... Mar 9 2010, 10:22 vadimuzzz Цитата(styuf @ Mar 9 2010, 16:22) Но при ... Mar 9 2010, 10:44 styuf Жалко, что плохо развит
По порядку:
- плата с... Mar 12 2010, 09:23 vadimuzzz это spansion. сама микросхема, видимо, снята с про... Mar 13 2010, 10:57 S_Lee Кто-то может подсказать как можно создать блок, да... Mar 14 2010, 14:37 barabek Цитата(S_Lee @ Mar 15 2010, 00:37) Кто-то... Mar 15 2010, 01:03 S_Lee как счетчик может дать 1КГц из 50МГц??? 16ти разр... Mar 20 2010, 09:40 des00 Цитата(S_Lee @ Mar 20 2010, 03:40) как сч... Mar 20 2010, 09:56 barabek Цитата(S_Lee @ Mar 20 2010, 19:40) как сч... Mar 21 2010, 22:07 styuf Вечер добрый)
Вопросы собственно такие:
-Научи... Mar 22 2010, 07:20 vadimuzzz Цитата(styuf @ Mar 22 2010, 13:20) - Чем ... Mar 22 2010, 07:52 styuf Цитатаво флеш-программере, пожалуй, ничем
Эти пара... Mar 22 2010, 08:10 vadimuzzz Цитата(styuf @ Mar 22 2010, 14:10) Судя п... Mar 22 2010, 08:26 spectr Только начал осваивать Nios, поэтому сразу начали ... Apr 13 2010, 18:17 barabek Цитата(spectr @ Apr 14 2010, 05:32) Собст... Apr 13 2010, 23:29 vadimuzzz ЦитатаТо есть, что получается при запуске программ... Apr 14 2010, 00:37 spectr Цитатапопробуйте в строке "Additional nios2-d... Apr 15 2010, 06:33 barabek По второй ошибке. Вообще-то тут у уважаемого vadi... Apr 15 2010, 06:49  Аматер Цитата(barabek @ Apr 15 2010, 11:04) По ... Apr 15 2010, 07:07   vadimuzzz да, это я неудачно скопипастил, правильный код так... Apr 15 2010, 08:21 spectr Все заработало!
Ошибка была в том, что я испол... Apr 15 2010, 09:09 spectr Что-то аццкий Flash programmer (из IDE) орет на ме... Apr 15 2010, 13:25 vadimuzzz да, нужна лицензия Apr 15 2010, 14:20 spectr Я проверил в Quartus->Tools->License Setup ... Apr 15 2010, 14:24 vadimuzzz в логах компиляции поищите "Opencores-бла-бла... Apr 15 2010, 15:29 spectr Да, есть такое. Курю форум, понимаю что надо пофик... Apr 15 2010, 15:33 vadimuzzz способа 2 - буржуйский и народный ) если интересуе... Apr 15 2010, 15:46 spectr ilkz (at) yandex.ru Apr 15 2010, 15:47 vadimuzzz выслал Apr 15 2010, 15:54 spectr Все получил.
Компиляция прошла без упоминаний о т... Apr 15 2010, 18:13 spectr Итак, все заработало как я и ожидал. Программка и ... Apr 19 2010, 11:59 vadimuzzz такое впечатление, что либо бинарник большой, либо... Apr 19 2010, 12:10 vadimuzzz ЦитатаЕсли это важно: в свойствах системной библио... Apr 19 2010, 14:21  barabek кроме всего вышесказанного предыдущими, при испол... Apr 19 2010, 21:37 Sergey'F Я немного не понял, что Вы делаете
Когда при запу... Apr 19 2010, 13:26 Porty Добрый день,
возникла проблема с средой Eclipse:
... Apr 30 2010, 07:45 vadimuzzz Цитата(Porty @ Apr 30 2010, 14:45) Как ег... Apr 30 2010, 07:49 Porty спасибо, запустил, но почему во время отладки при ... May 4 2010, 05:48 vadimuzzz Цитата(Porty @ May 4 2010, 12:48) спасибо... May 4 2010, 12:47 Porty спасибо, ещё вопрос: как освободить усб бластер за... May 6 2010, 06:25 vadimuzzz Цитата(Porty @ May 6 2010, 13:25) как осв... May 6 2010, 07:33 Porty win7 64bit May 6 2010, 08:01 vadimuzzz Цитата(Porty @ May 6 2010, 15:01) win7
не... May 6 2010, 08:17 Porty запустил один чип sdram памяти 256мегабит, 16 бит ... May 7 2010, 07:14 Kuzmi4 2 Porty
если у вас Cyclone II FPGA Starter Develop... May 7 2010, 07:30 Porty у меня своя плата, точнее набор. поспешили и сдела... May 7 2010, 07:35 Kuzmi4 2 Porty
Тогда, наверно, дорога вам ковыряйть альте... May 7 2010, 07:37 Porty хочу сделать согласно этому рисунку (т.е. все сигн... May 7 2010, 14:10 vadimuzzz а что мешает взять custom memory и скоммутировать ... May 7 2010, 14:23 Porty чтение понятно как можно скомутировать, а вот чтоб... May 7 2010, 16:39 vadimuzzz Цитата(Porty @ May 7 2010, 23:39) чтение ... May 8 2010, 05:42 vetal Вы сигналы маскирования объединили или нет? May 7 2010, 18:02
