> Господа, вышел новый 3 Hotfix.
DAV
сообщение Feb 27 2010, 08:37
Пользователь №: 781
Кто- то пробовал лечить.
Alexander E
сообщение Sep 13 2010, 07:44
Пользователь №: 58 959
Вышел новый HOTFIX VERSION: SPB16.30.016
DATE: 09-10-2010 HOTFIX VERSION: 016
CCRID PRODUCT PRODUCTLEVEL2 TITLE
810479 FSP DESIGN_SETTINGS Not able to connect some peripheral signals to FPGA manually
604662 VLS-L VIA When changing Rows/Columns values in Edit Via Properties form, different value are assigned.
747191 PSPICE AA_SENS Pspice crashes when starting Advance Analysis
756103 CONCEPT_HDL ARCHIVER Archiver does not include all the Parts when design blocks are copied from one location to another
758487 APD 3D_VIEWER package substrate (BGA) outline should be on a separate layer, not on bottom conductor layer.
764417 APD EDIT_ETCH Routing with Diagonal entry (45 degree) to Constraint Regions does not work
766409 PSPICE PROBE Copy to Clipboard changes the label text colors
784577 CONCEPT_HDL COMP_BROWSER SingleclickAdd 'true' places does not pick the correct version
784814 SIP_LAYOUT ASSY_RULE_CHECK accuracy of acute angle DRC
792039 CONSTRAINT_MGR OTHER Doing a File->Import->Worksheet Customization from Constraint Manager will change the working directory.
796517 CONCEPT_HDL COMP_BROWSER Component Browser showing wrong symbol
801944 SCM UI SCM dropping terminators and pull-ups when renaming signals (copy - paste special)
804627 PSPICE PROBE Printet text labels have wrong location
810814 CONSTRAINT_MGR OTHER T-point does not create when import DCF file.
811032 ALLEGRO_EDITOR EDIT_ETCH Enable enhanced pad entry to support pads as shapes
812643 SIP_FLOW CONSTRAINT_MGR Physical Constraint values disappear after entering constraint mode
812835 CONSTRAINT_MGR INTERACTIV CM Custom Fomula - "Analyze" on the header of Actual does not analyze pinpairs
813435 SIP_LAYOUT DIE_ABSTRACT_IF Invalid parameter passed to ICP utility API
814060 CONCEPT_HDL CORE Read only library becomes writeable when updated
814347 ALLEGRO_EDITOR ARTWORK It seems like not work ”detailed text checking” on 16.3.
814451 ALLEGRO_EDITOR DATABASE Allegro get crash when run dbdoctor
814496 CAPTURE ANNOTATE Lower level part refdes resets to ?
815150 SIP_RF OTHER sip layout export chips output is not correct
816034 ALLEGRO_EDITOR MANUFACT Backdrill Passes not work from bottom
816065 APD DATABASE Export Libraries with no library dependencies selected creates package symbol without pins.
816426 ALLEGRO_EDITOR SHAPE Dynamic shape not updated when component is unplaced
816616 SCM SYSTEM_OBJECT codesign incorrectly maps primary and secondary codesign object
816686 ALLEGRO_EDITOR TESTPREP Probe Spacing rounds off 3 place decimal to 2 places
816917 SIG_INTEGRITY LIBRARY Issue for loading interconn.iml
816986 ALLEGRO_EDITOR MANUFACT Mfg>NC>Backdrill analysis with passes set at Bottom layer is automatically switching to top, hence failing!
817473 CAPTURE NETLIST_ALLEGRO Backslash (\) is considered as illegal character for netname but it was allow in SPB 16.30.010
817606 SIP_LAYOUT WIREBOND When moving Bondfingers the Via's are sliding too when they should not.
Евграфов Александр/ Alexander Evgraphov
Skype: alexander.evgraphov
- DAV   Господа, вышел новый 3 Hotfix.   Feb 27 2010, 08:37
- - Old1   Цитата(DAV @ Feb 27 2010, 10:37) Кто- то ...   Feb 27 2010, 18:46
|- - rloc   Надеюсь очередной хотфикс не утечет с нашего обмен...   Feb 27 2010, 23:48
|- - tyro   Цитата(rloc @ Feb 28 2010, 02:48) Надеюсь...   Feb 28 2010, 17:42
|- - AlexN   Цитата(tyro @ Mar 1 2010, 00:42) Спасибо,...   Mar 1 2010, 02:51
|- - tyro   Цитата(AlexN @ Mar 1 2010, 05:51) у меня ...   Mar 1 2010, 06:17
|- - rloc   Цитата(tyro @ Mar 1 2010, 09:17) MD5 1094...   Mar 1 2010, 08:17
- - DAV   Могу залить и, если ничего не измениться, и все но...   Feb 28 2010, 17:03
- - rifch   Цитата(DAV @ Feb 27 2010, 11:37) Кто- то ...   Mar 1 2010, 12:57
- - ramm   Уважаемые форумчане нужна помощь После установки ...   Mar 8 2010, 14:26
|- - ramm   Цитата(ramm @ Mar 8 2010, 19:26) Уважаемы...   Mar 8 2010, 20:49
||- - AlexN   Цитата(ramm @ Mar 9 2010, 03:49) этой dll...   Mar 9 2010, 02:51
|- - rifch   Цитата(ramm @ Mar 8 2010, 17:26) Уважаемы...   Mar 9 2010, 17:28
|- - sa_per   Цитата(ramm @ Mar 8 2010, 18:26) Уважаемы...   Mar 17 2010, 01:07
- - ramm   to AlexN библиотеку нашёл там же,но путей решения ...   Mar 9 2010, 18:06
- - rifch   Наверно, можно уже  говорить об установке hotfix 4...   Mar 21 2010, 13:37
- - ramm   Здравствуйте. Снова возникла проблема.Установка пе...   Mar 29 2010, 18:05
|- - One   Цитата(ramm @ Mar 29 2010, 22:05) Здравст...   Mar 30 2010, 05:51
- - ramm   One спасибо за ответ.У меня последний вопрос - при...   Mar 31 2010, 18:54
|- - rifch   Цитата(ramm @ Mar 31 2010, 22:54) One спа...   Apr 1 2010, 05:22
- - ramm   rifch большое спасибо.   Apr 1 2010, 05:59
|- - One   я ставил сразу последний и лечил как описано выше ...   Apr 1 2010, 06:58
- - Designer56   Цитатапосле установки хотфикса SPB16.30.004 Такой ...   Apr 1 2010, 07:39
- - emiq   На одном из сайтов http://www.cadence.dk/dk/teknik...   Apr 11 2010, 14:17
- - OWEN   Спасибо emiq! ..полезная ссылка...   Apr 13 2010, 11:56
- - emiq   На http://www.cadence.dk/dk/teknik__service/d..._o...   Apr 30 2010, 07:37
- - ramm   у братьев наших китайских 11-ый нарыл http://www....   Jul 3 2010, 15:25
|- - ramm   Цитата(ramm @ Jul 3 2010, 21:25) у братье...   Jul 4 2010, 00:53
- - ramm   не работает,в конце установки ему чего то не хвата...   Jul 4 2010, 02:44
|- - AlexN   Цитата(ramm @ Jul 4 2010, 09:44) не работ...   Jul 5 2010, 09:59
- - ramm   он не только ругался,но и распаковываться не хотел...   Jul 5 2010, 16:42
- - ramm   http://downloads.nordcad.dk/Hotfix_SPB16.3...1_win...   Jul 6 2010, 07:44
|- - BSACPLD   Цитата(ramm @ Jul 6 2010, 11:44) http://d...   Jul 6 2010, 09:26
||- - AlexN   Цитата(BSACPLD @ Jul 6 2010, 16:26) Ошибк...   Jul 6 2010, 09:51
||- - BSACPLD   Цитата(AlexN @ Jul 6 2010, 13:51) забавно...   Jul 6 2010, 13:33
||- - AlexN   Цитата(BSACPLD @ Jul 6 2010, 20:33) Нашёл...   Jul 6 2010, 13:44
||- - Victor®   Цитата(AlexN @ Jul 6 2010, 16:44) похоже,...   Jul 6 2010, 16:55
|- - AlexN   Цитата(ramm @ Jul 6 2010, 14:44) http://d...   Jul 11 2010, 08:28
- - ramm   Мир не без добрых людей http://rapidshare.com/f...   Aug 22 2010, 15:55
|- - rloc   Цитата(ramm @ Aug 22 2010, 19:55) Мир не ...   Aug 22 2010, 17:17
- - Alexander E   Hotfix SPB16.30.15 ЦитатаDATE: 08-27-2010 HOTFI...   Aug 31 2010, 11:04
- - ramm   Здравствуйте. Это конечно не плохо,что хотфиксы по...   Aug 31 2010, 17:08
|- - Alexander E   Цитата(ramm @ Aug 31 2010, 21:08) Здравст...   Sep 1 2010, 07:15
|- - vitan   Цитата(Alexander E @ Sep 1 2010, 11:15) З...   Sep 1 2010, 08:09
|- - Alexander E   Цитата(vitan @ Sep 1 2010, 12:09) Раз уж ...   Sep 1 2010, 08:57
- - sergun53   Новый Cadence Hotfix SPB16.30.018 (563Mb) : ...   Oct 15 2010, 06:26
- - vkm   Спасибо, sergun53! Это действительно работающа...   Dec 12 2010, 09:31
- - ramm   Не помню где и когда "откопал" Hotfix_SP...   Dec 12 2010, 13:18
- - Uree   Главное не ставить 20-й хотфикс. Они там порядочны...   Dec 12 2010, 18:17
|- - Old1   Цитата(Uree @ Dec 12 2010, 20:17) Главное...   Dec 12 2010, 19:28
|- - vitan   Цитата(Uree @ Dec 12 2010, 21:17) Главное...   Dec 12 2010, 20:10
- - Uree   ЦитатаЧто за баг? При генерации карты сверловки в...   Dec 12 2010, 22:59
|- - rloc   21-ый уже на саппорте лежит КодDATE: 12-10-20...   Dec 12 2010, 23:02
|- - Old1   Цитата(Uree @ Dec 13 2010, 00:59) При ген...   Dec 13 2010, 06:38
- - Uree   По описанию не похоже, проблема сформулирована как...   Dec 13 2010, 06:36
- - Uree   Вот они интересные... Баг поправили, но в перечень...   Dec 13 2010, 07:37
|- - rloc   Цитата(Uree @ Dec 13 2010, 10:37) Ближе к...   Dec 13 2010, 08:09
- - Uree   Ок. PS А где лежит? Что-то не вижу. ЗЫ Уже вижу....   Dec 13 2010, 08:41
|- - AlexN   Цитата(Uree @ Dec 13 2010, 15:41) Ок. PS...   Dec 13 2010, 10:00
- - leom   Кто-нибудь ставил 21? Баги 20 поправили? Новые ба...   Dec 16 2010, 08:37
- - Uree   Ставили, проверили. Лучше бы не проверяли... Баги ...   Dec 16 2010, 11:17
|- - tyro   Цитата(Uree @ Dec 16 2010, 17:17) Ставили...   Dec 16 2010, 11:37
- - Uree   Похоже на 19. По крайней мере в нем багов нам не п...   Dec 16 2010, 13:37
- - Alexander E   Вышел новый HOTFIX VERSION: SPB16.30.022. ЦитатаDA...   Jan 19 2011, 10:36
|- - vin   Цитата(Alexander E @ Jan 19 2011, 12:36) ...   Jan 25 2011, 11:31
- - Uree   Угу, пока глобальных проблем в этой версии не заме...   Jan 19 2011, 10:38
- - Uree   А что, до сих пор нет? Я думал как и в прошлый раз...   Jan 25 2011, 11:57
|- - rloc   Господин rloc занимался MM$IM101, на остально...   Jan 25 2011, 12:31
- - Uree   Да не вопрос, уже в процессе, через пару часов мож...   Jan 25 2011, 12:58
|- - vin   Цитата(Uree @ Jan 25 2011, 14:58) Да не в...   Jan 26 2011, 11:44
- - Alexander E   Вышел новый HOTFIX VERSION: SPB16.30.023. ЦитатаDA...   Jan 31 2011, 11:51
- - Uree   Что-то они зачастили... Праздники закончились, мож...   Jan 31 2011, 13:25
|- - Alexander E   Цитата(Uree @ Jan 31 2011, 16:25) Что-то ...   Jan 31 2011, 13:51
- - Uree   Спасибо, я в курсе, просто между 21 и 22 достаточн...   Jan 31 2011, 14:09
- - Alexander E   DATE: 02-11-2011 HOTFIX VERSION: 024 Цитата=====...   Feb 14 2011, 07:45
- - Alexander E   DATE: 02-26-2011 HOTFIX VERSION: 025 Цитата=====...   Feb 28 2011, 08:11
- - Ant_m   Кто пробовал 25-й хотфикс? Что нибудь критичное за...   Mar 10 2011, 07:44
- - Uree   В списке поправленных багов очередного хотфикса Ну...   Mar 10 2011, 07:52
|- - rloc   ЦитатаDATE: 03-11-2011 HOTFIX VERSION: 026 =====...   Mar 13 2011, 11:09
|- - vin   ЦитатаDATE: 03-11-2011 HOTFIX VERSION: 026 куда пр...   Mar 14 2011, 10:20
|- - AlexN   Цитата(vin @ Mar 14 2011, 17:20) куда про...   Mar 14 2011, 10:48
|- - vin   Цитата(AlexN @ Mar 14 2011, 12:48) перешл...   Mar 15 2011, 12:44
- - vin   Положил Hotfix_SPB16.30.026 в аплоад. Благодарю rl...   Mar 16 2011, 11:15
|- - rloc   КодDATE: 03-25-2011 HOTFIX VERSION: 027 ...   Mar 25 2011, 12:32
|- - rloc   КодDATE: 04-8-2011 HOTFIX VERSION: 028 ===...   Apr 10 2011, 17:13
- - Alexander E   ЦитатаDATE: 04-22-2011 HOTFIX VERSION: 029 =====...   Apr 25 2011, 08:02
|- - rloc   ЦитатаDATE: 04-22-2011 HOTFIX VERSION: 029 Если я ...   Apr 25 2011, 11:30
|- - Alexander E   Цитата(rloc @ Apr 25 2011, 15:30) Если я ...   Apr 25 2011, 11:47
|- - rloc   Какой смысл тогда писать об обновлениях, если неза...   Apr 25 2011, 11:52
|- - Alexander E   Цитата(rloc @ Apr 25 2011, 15:52) Какой с...   Apr 25 2011, 13:56
|- - rloc   Цитата(Alexander E @ Apr 25 2011, 17:56) ...   Apr 26 2011, 05:48
- - Uree   Ну давайте без наездов. В последнее время хотфиксы...   Apr 26 2011, 07:21
- - xCooLLer   где скачать свежий хотфикс, кроме как cadence.com ...   May 10 2011, 05:09
|- - rloc   http://www.cadence.dk/dk/teknik__service/d..._opda...   May 10 2011, 08:44
|- - AlexN   Цитата(rloc @ May 10 2011, 15:44) http://...   May 11 2011, 10:14
- - ramm   http://rutracker.org/forum/viewtopic.php?t=3507665...   May 11 2011, 13:09
- - Xenia   Люди! Просветите: прикладывать достаточно толь...   May 11 2011, 13:31
- - AlexN   Цитата(Xenia @ May 11 2011, 20:31) Люди...   May 11 2011, 13:36
- - Nixon   Цитата(Xenia @ May 11 2011, 16:31) Люди...   May 11 2011, 14:40
RSS Текстовая версия Сейчас: 28th July 2025 - 04:35
Страница сгенерированна за 0.01526 секунд с 7
