> [МСК] Продам Friendly Arm development kit Samsung S3C2440 ARM9 400 MHz + 3,5" touchscreen, Mini USB & Bluetooth Interface GPS Module Demo Board
mulliok
сообщение Sep 27 2010, 09:57
Пользователь №: 57 864
Новый полный комплект, брался под стационарную установку навигации в машину.
Specification:
Dimension: 100 x 100 mm
CPU: 400 MHz Samsung S3C2440A ARM920T (Max freq. 533 MHz)
RAM: 64 MB SDRAM, 32 bit 100 MHz Bus
Flash: 64 MB NAND Flash and 2 MB NOR Flash with BIOS
EEPROM: 1024 Byte 24C08 (I2C)
Ext. Memory: SD-Card socket
Serial Ports: 1x DB9 connector (RS232), total: 3x serial ports on the PCB
USB: 1x USB Host, 1x USB Device
Audio Output: 3.5 mm stereo jack
Audio Input: on PCB + condenser microphone
Ethernet: RJ-45 10/100M (DM9000)
RTC: Built in Real Time Clock with battery
Beeper: On board PWM buzzer
Camera: 20 pin Camera interface
LCD Interface:
STN Displays:
4 bit dual scan, 4 bit single scan or 8 bit single scan display type
monochrome, 4 gray levels, 16 gray levels, 256 colors or 4096 colors
Max: 1024x768, 4096 colors
TFT Displays:
1, 2, 4 or 8 bpp palletized color displays
16 or 24 bpp non-palletized true-color displays
Max: 1024x768, 64k colors
Touch Panel: 4 wire resistive
User Inputs: 6x push buttons and A/D pot
User Outputs: 4x LEDs
Expansion: 40 pin System Bus, 34 pin GPIO (2.0mm)
Debug: 10 pin JTAG (2.0mm)
Power Connector: 5V with switch and LED
OS Support
Linux 2.6
Windows CE 5, 6
В комплекте плата, 3,5" TFT экран, комплект кабелей, блок питания, DVD диск, LPT J-Tag интерфейс, все в родной коробке.
Цена 3500 руб.
Так же есть к нему плата GPS, подключается по USB, RS232 или bluetooth
Features:
Low Power consumption
Powered by USB port, no need to feed with DC power supply
RF Receiver of Noise Figure is at 2.5 dB
High Sensitivity -161 dBm( indoor)
Seamless Outdoor/Indoor Operation
Support standard NMEA-0183 V 3.01
Graphic GPS testing software is provided for free
Software for modifying baud rate is provided for free
Interfaces: USB Mini-B and USB B interface, RS232 Female Interface, bluetooth
В комплекте плата, внешняя антенна, кабель USB
Цена 1200 руб.
RSS Текстовая версия Сейчас: 30th July 2025 - 02:22
Страница сгенерированна за 0.01369 секунд с 7
