> Седьмая версия прошивки для SIM900.
CADiLO
сообщение Dec 24 2010, 05:41
Из: Днепр
Пользователь №: 7 988
Итак мы получили седьмую версию прошивки.
Порядок получения обычный - письмо мне с ИМЕИ модуля.
Список что нового и исправленого в семерке.
[New Features]
1.
Added the buzzer function to AT command ”AT+SPWM”.
2.
Added the function to disable the ECHO algorithm.
3.
Added AT+CBUZZERRING command, the default value of which is 0. If it is set to 1, the ring of incoming call will be sent out from buzzer, with the frequency of 1HZ, it is valid only when the module has buzzer.
[Improved Features]
4.
Fixed the problem that module could crash when user sets the CLVL continuously.
5.
Fixed the SIM900 problem that the module will reset if user executes ”AT+CFUN=0” or changes the band rate by AT command ”AT+CBAND” at module initiating time.
6.
Modified the ”AT+CENG” command to make it consistent with SIM300 series: 1, enlarged the length of MNC to support 3 bytes; 2, used number ”99” to represent invalid parameter ”rxqulity” instead of ”FF”; 3, added MCC and MNC information of neighborhood cell, 4, changed the show location of LAC which is set to hex mode.
7.
Fixed the problem that self adaptive baud rate was not precise which led to failure of baud rate adaption.
8.
Fixed the problem that the module would not receive any data which were sent immediately after the connection was established successfully if it is set to be a server.
9.
Fixed the problem that the module reported error information of incoming call when user used ”ATH” command to hang up before the ”RING” was reported, and it would ring continuously and keep connected.
10.
Optimized the ATH function to make possible to hang up a call by sending consecutive ATH command when COLP is set to 1.
11.
Fixed the bug that the record of a successful CSD call could not be saved in the phonebook.
12.
Fixed the bug that the out of range hints of dialing record 0 by ”ATD>” command when the current phonebook has no record were different from that when the current phonebook has records.
13.
Optimized the broken transfer resuming function of http.
14.
Fixed the bug that short name display function was not implemented when user queried the network list.
15.
Fixed the problem that module could not search for the network if AT command ”AT+COPS” was set to short alphanumeric format, when executing AT+COPS=1,1,"CMCC".
16.
Fixed the response failure problem when user responds to the ”get input” item of STK with data in UCS2 format.
17.
Fixed the problem that it would fail easily when user activated GPRS context immediately after executing the AT+CIPSHUT command.
18.
Modified the VTS function not to return OK until implementation was executed successfully.
19.
Fixed the problem that some of the CLCC and CLIP URC can not be reported normally in MUX mode.
Aurochs
сообщение Dec 27 2010, 16:57
Ортодокс
Из: Смела, Украина
Пользователь №: 31 775
Цитата(CADiLO @ Dec 27 2010, 10:01) *
Дело не в прошивальщике, а в модуле. В модулях до 6 версии на заводе не прописана одна табличка (копия RF&NUM которая должна служить для восстановления после прошивки), и ее как раз прошивальщик не трогает и записать не может. Ее можно прописать командой (один раз) AT+CBRP=1 , после чего IMEI уже слетать не будет, сколько не перепрошивай. Модули начиная с 6 версии идут уже с исправленой ошибкой и там нет слетания IMEI при обновлении.
А по поводу команды AT+CBRP и ее формата можно немного поподробнее или ссылку на ее описание? Что именно она делает?
Копирует IMEI, чтобы он не затирался при перепрошивке?
Заранее благодарен.
RSS Текстовая версия Сейчас: 28th July 2025 - 16:47
Страница сгенерированна за 0.03391 секунд с 7
