> Samsung S3C2440 ARM9 Board + 3.5" TFT LCD Touch Screen
SL555
сообщение Oct 12 2009, 08:16
Пользователь №: 5 580
нашел на ebay такой кид:
CPU
- Samsung S3C2440A 400MHz, Max freq. 533Mhz
SDRAM
- 64MB SDRAM
- 32bits Data Bus width
- 100MHz Clock
Flash
- 64MB Nand Flash,
- 2MB Nor Flash, BIOS installed
LCD
- 4 wire resistive touch screen interface
- Up to 4096 color STN, 3.5 inches to12.1 inches, up to 1024x768 pixels
- Up to 64K color TFT, 3.5 inches to 12.1 inches, up to1024x768 pixels
- In box NEC 256K color 240x320/3.5 inches TFT screen, with touch screen
Interface and Resource
- 1 10/100M Ethernet RJ-45(DM9000)
- 3 Serial Ports(1 RS232 with CTS and RTS)
- 1 USB Host
- 1 USB Slave Type B
- 1 SD Card Interface
- 1 Stereo audio out, 1 Micro In
- 1 10-Pin JTAG
- 4 USER LEDs
- 6 USER buttons
- 1 PWM Beeper
- 1 POT can be used for A/D converter adjust
- 1 AT24C08 for I2C test
- 1 20-Pin Camera Interface
- 1 Battery for RTC
- Power In(5V), with switch and lamp
Oscillator Freq.
- 12MHz
RTC
- Internal
Expand Interface
- 1 34-Pin 2.0mm GPIO
- 1 40-Pin 2.0mm System Bus
Dimension
- 100 x 100(mm)
OS Support
- Linux 2.6.13
- Windows CE.Net 5.0
2. Content List:
(1) 1 S3C2440 board (Preload with Linux)
(2) 1 Serial cable
(3) 1 Net cable
(4) 1 USB cable
(5) 5V power adapter
(6) 1 JTAG board(for H-JTAG)
(7) 1 DVD-ROM with product reference
(8) 1 NEC LCD: 3.5", 240x320, with touch panel
3. Material list on DVD-ROM
(1) H-JTAG Debugger
(2) Windows Flash Programmer SJF2440
(3) Linux Nand Flash Programmer Jflash-2440(source code included)
(4) Serial tool CRT, dnw
(5) Bitmap to C Language transfer tool
(6) USB Driver(WindowXP/2000)
(7) vivi source code(linux bootloader)
(8) LED test program(ADS1.20 project)
(9) 2440test program(ADS1.20 project), include :
key test, RTC test, ADC test, IIS Audio play(wav), IIS Audio record,
touch screen test, I2C test, Samsung 3.5"LCD, 640x480 TFT test
(10) WindowsCE BSP and sample project files.
(11) Pre-compiled Win CE image for evaluation
(12) Linux tool and kernel source codes
- arm-linux-gcc-3.3.2 to compile Qtopia
- arm-linux-gcc-3.4.1 to compile kernel
- arm-linux-gcc-2.95.3 to compile vivi
- yaffs file system image maker -mkyaffsimage
- linux-2.6.13 for S3C2440 kernel source code(include DM9000, LCD driver, Audio,
Touch screen, YAFFS Source code, SD Card, RTC, Expand serial driver,
USB Camera,USB Mouse and Keyboard, U-Disk)
(13) Pre-compiled Linux image for evaluation
(14) Qtopia source codes, web browser source codes
(15) Schematics(Protel99SE/PDF)
http://cgi.ebay.com/Samsung-S3C2440-ARM9-B...=item27aa521a12
за 88 $,
Кто ни будь побывал данный девайс ?
Что то слишком дешево они стоят :
http://shop.ebay.com/i.html?_trkparms=65%2...br=1&_pgn=1
Сообщение отредактировал SL555 - Oct 12 2009, 08:25
BCluster
сообщение Dec 29 2010, 09:22
Пользователь №: 32 111
Да в 2440 хост 1.1. USB трансмиттер от TI (usb-> 4 i2s, TUSB3200A) тоже 1.1. Да и на 8 каналов нужна скорость в 6 мбит, если 44.1кгц 16 бит. Не так уж много. Запас в половину ширины канала. Насчет декодирования - почему нет, у меня там wav файлы без всяких наворотов. Что скажете?
Про McASP читал, знаю, это вообще идеальный вариант, но там дебри в которые лезть хочется в последнюю очередь. Плюс мне ОЧЕНЬ нравится что эта плата готовая и не надо тратить время и средства на разработку и изготовление прототипа на данном этапе.
- SL555   Samsung S3C2440 ARM9 Board + 3.5" TFT LCD Touch Screen   Oct 12 2009, 08:16
- - HARMHARM   Может быть дешево, но не слишком. Я брал какой-то ...   Oct 12 2009, 11:16
- - Dron_Gus   Я пробовал. Хороший девайс. Все, что написано прав...   Oct 16 2009, 10:25
|- - Сергей Борщ   Цитата(Dron_Gus @ Oct 16 2009, 12:25) Я п...   Jan 8 2010, 15:39
|- - Itch   Цитата(Сергей Борщ @ Jan 8 2010, 21:39) Н...   Jan 10 2010, 14:59
||- - Marat_MMX   Цитата(Itch @ Jan 10 2010, 18:59) Где-то ...   Feb 11 2010, 14:16
|- - ArtemDement   Цитата(Сергей Борщ @ Jan 8 2010, 18:39) Н...   Nov 27 2010, 15:17
- - DRUID3   Нифига себе! За ~90$ это просто мечта. Бе...   Oct 16 2009, 10:34
- - RobFPGA   Приветствую! А как такая плата (и аналогичная...   Jan 9 2010, 01:45
- - Itch   Плата 3.5LCD + камера+WiFi в 139$ с доставкой...   Feb 12 2010, 05:23
|- - Vasily_A   а qtopia некитайская под эту плату есть, так чтоб ...   Feb 13 2010, 19:54
- - Itch   У меня Qtopia как раз английская, а вот образ CE5....   Feb 15 2010, 05:22
|- - Vasily_A   Цитата(Itch @ Feb 15 2010, 08:22) У меня ...   Feb 16 2010, 13:06
- - BlackHead   Хочу узнать, нужен ли дополнительно программатор д...   May 4 2010, 06:25
- - MAXXXX   Я тоже купил подобный девайс. Установлена Windows ...   May 26 2010, 08:25
- - kalipso   Тоже приобрел этот девайс. Покрутил в руках и попр...   May 31 2010, 10:37
- - BCluster   Что-то не вижу в описании, у нее есть i2s? Мне нуж...   Dec 26 2010, 05:12
- - Dron_Gus   Есть. Но наружу, насколько помню, не выведен. Плюс...   Dec 27 2010, 07:40
- - BCluster   Меня и DSP устраивает по большому счету все равно....   Dec 27 2010, 13:50
- - Dron_Gus   DSP режим умеют кодеки от TI, а вот самсунг, похож...   Dec 28 2010, 08:20
- - Dron_Gus   Я скажу - пробуйте. Такие вещи уже сложно просчит...   Dec 29 2010, 09:32
|- - BCluster   Цитата(Dron_Gus @ Dec 29 2010, 16:32) Я с...   Dec 29 2010, 10:27
- - Dron_Gus   Я читал эту http://www.amazon.com/Embedded-Linux-P...   Dec 29 2010, 10:51
|- - BCluster   Цитата(Dron_Gus @ Dec 29 2010, 17:51) Я ч...   Dec 29 2010, 13:05
- - Dron_Gus   Не видел. На русском читать не имеет смысла - наши...   Dec 29 2010, 13:34
|- - BCluster   Цитата(Dron_Gus @ Dec 29 2010, 20:34) Не ...   Dec 29 2010, 14:41
- - ArtemDement   Купил у Starnewtech, примерно в 100$ обошелся...   Jan 18 2011, 17:50
- - Dron_Gus   Любая будет адски тормозить. Андроиду надо >190...   Jan 19 2011, 17:14
- - ArtemDement   А что тогда лучше поставить ?   Jan 19 2011, 17:58
- - Dron_Gus   Angstrom, gpe-image или xfce-image.   Jan 19 2011, 18:30
- - ArtemDement   А приложения разработанные на Qt от Nokia кто-то п...   Jan 23 2011, 19:29
- - ArtemDement   Еще вопрос - где купить ответные части к разъемам ...   Jan 24 2011, 19:34
|- - (vS)   Цитата(ArtemDement @ Jan 25 2011, 02:34) ...   Mar 23 2011, 12:55
- - Dron_Gus   В магазине? Например в буром медведе.   Jan 24 2011, 20:04
- - zheka   Господа, кто пользовал эту плату - она потянет вид...   Jul 25 2011, 16:49
- - mantech   А кто-нить программировал этот проц (2442) на обыч...   Dec 8 2012, 20:34
RSS Текстовая версия Сейчас: 4th August 2025 - 06:49
Страница сгенерированна за 0.01317 секунд с 7
