Исправления которые войдут в 8 версию для 900-ки |
Mar 10 2011, 07:25
Из: Днепр
Пользователь №: 7 988
Кстати по просьбе товарищей которые хотели переключаемый режим RI - обратите внимание на пункт 29 - команда CRIPULSE
Есть и не очень хорошая новость - в связи с обнаруженой критической ошибкой в приеме DTMF, будет выпущена дополнительная сборка 8 версии после устранения данной ошибки. SIMCOM извиняется и постарается сделать это как можно скорее.
Обновленые даташиты выложу на сайт сразу по получению.
НОВОЕ 1. Added "AT+SLEDS" command to configure the flicker frequency of network lights in the status of unregistered, registered or PPP. 2. Added the value "UR" to the parameter <exunsol> of "AT+EXUNSOL" command to support unsolicited result code.
ИСПРАВЛЕНИЯ 1. Solved the problem of not reporting "NO ANSWER" in the case of calling the other side who was busy when user set ATS7=15. 2. Solved the problem that voltage alarm urc was only reported in a logical serial port in MUX mode. 3. Modified the format of returning information when setting "AT+CENG=3". 4. Solved the reset problem when user input wrong value of parameter to change the frequency band. 5. Added AT+CGAS command to increase the speed of GPRS attachment since it is not necessary to re-attach each time. 6. Fixed the bug that executing ATA command can not pull RI to high level in MUX mode. 7. Solved the problem that USSD information reported was incorrect found by Indian customer. 8. Fixed the bug that the local time converted by the time NITZ reported was wrong and ”CI” of operator’s name was wrong. 9. Optimized the SIDETONE function. 10. Solved the problem that it would take a long time for network indicator light to flash for some SIM cards when user powered on the module in roaming status. 11. Solved the problem that unrecognizable code would be reported when user executed the CLCC or CLIP command to get information of an incoming call whose name was saved in the phonebook in UCS2 mode previously. 12. Solved the problem that there is no response returned from serial port if user executes the following steps: 1. Plug out the SIM card and then dial emergency number. 2. Plug in the SIM card then execute "AT+CFUN=0" command. 13. Limited the scope of input parameters of "AT+CRLP" command. 14. Fixed the bug of CLCC, CLIP, CMGR command that Chinese name and English name could not display in UCS2 mode if user sets CSCS to UCS2 mode. 15. Modified the CPBW command when CSCS was set to HEX mode, the name could be written up to 28 characters. 16. Limited the scope of input parameters of AT+CALD command. 17. Modified the error response of AT command "AT+CSTA=", the error response should be "ERROR" instead of "OK". 18. Solved the problem that the responses of reading empty record in phone book via CPBR command were not consistent. 19. Modified the response of test command of EXUNSOL by adding the parameter value "UR". 20. Solved the problem that the module can not register to the network successfully with SIM card of Orange operator when user sets "AT+CBAND="ALL_BAND"" 21. Added the content "resource limitation" of error code 99. 22. Solved the problem that the calling record of some special number can not be saved in recent call lists. 23. Solved the problem that the CSD connection can not be established successfully anymore after user dials a number in call record list in CSD mode. 24. Solved the problem that "CALL READY" will not report in some special conditions when URC presentation was enabled by executing CIURC command. 25. Исправления касаются служебной команды - информация NDA 26. Solved the problem that CTS varied when user sent or received AT command with no flow control. 27. Limited the scope of inputting parameter when executing HTTPREAD and HTTPDATA command in writing mode. 28. Solved the problem that Shenzhen customer can not originate a phone call or send SMS after a successful call. 29. Altered the RI pin status when the module reported "RING" of incoming CSD call. If CRIPULSE is set to 1, it presents RI pulse otherwise it is continuously in high level. 30. Solved the problem that there was no ring back tone if user dialed a number of MAXIS sim card through the CELECOM sim card in Malaysia. 31. Solved the problem which happened after user sent a sms via AT command accidentally that the module would "freeze" for about 50 seconds before it replied, during that time, the module did not respond to any commands. 32. Supported GPRS multislot class 2, user is allowed to set class 2 by executing CGMSCLASS command. 33. Solved the problem that SIM PIN2 couldn’t be modified. 34. Solved the problem that the module couldn’t attach to the GPRS network if it had activated GPRS previously and then restarted manually. 35. Solved the problem raised by Shenzhen customer that some special SIM card could not be recognized by the module. 36. Improved the CENG function to show more neighbor cells.
Mar 10 2011, 09:12
Из: Днепр
Нет, я сейчас с ними активно общаюсь на эту тему и тестирую то что они просят. Думаю это будет гораздо быстрее. вот еще информация кому интересно 1. Jamming detection won't be standard version, but special version. You have test JD version, if you say ok, we can make a special version bansed on B08 for you. 2. DTMF version will be STANDART version for east europe. 1137B08SIM900M64_ST доступна, получение как обычно Выложил обновленную RC1 с DTMF - тестируем. http://microchip.ua/temp/TEST_DTMF_0310V2.RAR
CADiLO Исправления которые войдут в 8 версию для 900-ки Mar 10 2011, 07:25 ssokol Цитата(CADiLO @ Mar 10 2011, 10:25) Есть ... Mar 10 2011, 08:38 ssokol Цитата(CADiLO @ Mar 10 2011, 12:12) 1137B... Mar 10 2011, 10:18 Aurochs Цитата(CADiLO @ Mar 10 2011, 09:25) Кстат... Mar 10 2011, 09:59 CADiLO замечание принято - напишу производителю Mar 10 2011, 10:12 CADiLO S2-1040S-Z090C это 1137B04SIM900M64_ST
У меня ест... Mar 10 2011, 10:32 Velund QUOTE (CADiLO @ Mar 10 2011, 13:32) Но ко... Mar 10 2011, 11:16 ssokol Цитата(CADiLO @ Mar 10 2011, 13:32) DTMF ... Mar 10 2011, 19:15  emolonza Прошивка, пожалуйста, сообщите мне sim900 DTMF?
cy... Mar 29 2011, 20:18 CADiLO S2-1040S-Z090M = 1137B06SIM900M64_ST Mar 10 2011, 11:17 Velund QUOTE (CADiLO @ Mar 10 2011, 14:17) S2-10... Mar 10 2011, 11:33 CADiLO Да - определение должно включаться только на нужну... Mar 11 2011, 06:38 ssokol Цитата(CADiLO @ Mar 11 2011, 09:38) По по... Mar 11 2011, 08:20 CADiLO Я описал проблему полностью и подтвердил ее от себ... Mar 11 2011, 09:06 ssokol Цитата(CADiLO @ Mar 11 2011, 12:06) пришл... Mar 11 2011, 18:59 CADiLO Спасибо. Я тоже заметил нечеткое определение при в... Mar 12 2011, 08:47 ssokol Цитата(CADiLO @ Mar 12 2011, 11:47) Спаси... Mar 12 2011, 10:36  ssokol Цитата(ssokol @ Mar 12 2011, 13:36) Уточн... Mar 14 2011, 15:46   ssokol Похоже после Нового Года, вместо того, чтоб работа... Mar 16 2011, 12:46 Slonofil А вы чё хотели! У нас люди вообще почти месяц ... Mar 16 2011, 12:48 sobr Цитата(Slonofil @ Mar 16 2011, 18:48) А в... Mar 16 2011, 14:41  ssokol Похоже , китайцы уже про дтмф забыли... или забил... Mar 18 2011, 12:02 Samodelkin А для DTMF декодирования, у SIM900, есть какие то ... Mar 21 2011, 22:07 ssokol Цитата(Samodelkin @ Mar 22 2011, 01:07) т... Mar 22 2011, 05:47 CADiLO Процесс идет. Просто мне не каждый день получается... Mar 22 2011, 07:37 Samodelkin Цитата(CADiLO @ Mar 22 2011, 09:37) Ну и ... Mar 22 2011, 09:14  ssokol Цитата(Samodelkin @ Mar 22 2011, 12:14) О... Mar 22 2011, 12:20 av-master CADiLO
Семинар OnLine будет ? Mar 22 2011, 07:50 CADiLO 31 марта в городе Киеве будет проводиться весенний... Mar 22 2011, 10:13 ssokol Цитата(CADiLO @ Mar 22 2011, 13:13) Так ж... Mar 22 2011, 12:06 sobr Цитата(CADiLO @ Mar 22 2011, 16:13) 31 ма... Mar 22 2011, 14:42 CADiLO Не спорю - бум разбираться.... Mar 22 2011, 12:09 CADiLO Для тех кто GSM мосты делает - слушать городскую л... Mar 22 2011, 12:25 ssokol Цитата(CADiLO @ Mar 22 2011, 15:25) Для т... Mar 22 2011, 12:41 Lexi Да хотя бы сделать стабильный такой как есть. А вы... Mar 22 2011, 13:28 CADiLO Подпишитесь на нашу рассылку - первое сообщение о ... Mar 22 2011, 14:53 sobr Цитата(CADiLO @ Mar 22 2011, 20:53) Подпи... Mar 22 2011, 14:58 CADiLO Привычка Mar 22 2011, 15:14 Lexi Семинар это здорово, НО давайте вернемся к ДТМФу. Mar 22 2011, 17:23 av-master ЦитатаСеминар это здорово, НО давайте вернемся к Д... Mar 22 2011, 17:44 CADiLO С онлайном вопрос отложен в связи с качеством лини... Mar 23 2011, 08:05 av-master ЦитатаС онлайном вопрос отложен в связи с качество... Mar 23 2011, 08:15 13amator Цитата(av-master @ Mar 23 2011, 11:1... Mar 23 2011, 08:57 =F8= Проблему с DCD и закрытием сессии чинить не собира... Mar 23 2011, 16:05 sobr Цитата(=F8= @ Mar 23 2011, 22:05) Проблем... Mar 23 2011, 16:38 Lexi Цитата(=F8= @ Mar 23 2011, 19:05) Проблем... Mar 24 2011, 15:26  sobr Цитата(Lexi @ Mar 24 2011, 21:26) Кому не... Mar 24 2011, 16:23  =F8= Цитата(Lexi @ Mar 24 2011, 19:26) Кому не... Mar 25 2011, 09:47   ssokol Цитата(=F8= @ Mar 25 2011, 12:47) Мне воо... Mar 26 2011, 12:14    =F8= Цитата(ssokol @ Mar 26 2011, 16:14) А что... Mar 27 2011, 11:44 CADiLO Напомните пожалуйста - что там с DCD ? Mar 24 2011, 07:33 =F8= Цитата(CADiLO @ Mar 24 2011, 10:33) Напом... Mar 24 2011, 14:10 CADiLO Отписался китайцам в багрепорте. Mar 24 2011, 14:20 Lexi sobr, Что Вы курите? Mar 24 2011, 19:30 sobr Цитата(Lexi @ Mar 25 2011, 01:30) sobr, Ч... Mar 25 2011, 00:25 CADiLO Итак тестирование закончили - собираем все в кучу... Mar 28 2011, 07:49 ssokol Цитата(CADiLO @ Mar 28 2011, 10:49) Итак ... Mar 28 2011, 18:15 Transistor CADiLO, так как насчёт записать видео семинара и в... Mar 28 2011, 10:41 =F8= Цитата(Transistor @ Mar 28 2011, 13:41) C... Mar 29 2011, 08:52 CADiLO Ну разве что кто-то из посетителей займется записа... Mar 28 2011, 10:54 13amator Цитата(CADiLO @ Mar 28 2011, 13:54) Ну ра... Mar 28 2011, 11:07 CADiLO Надежда есть всегда.
Законы Мерфи помните?
- Ес... Mar 29 2011, 06:05 sobr Цитата(CADiLO @ Mar 29 2011, 12:05) 19 ап... Mar 29 2011, 14:22  Telit Цитата(sobr @ Mar 29 2011, 18:22) 19 апре... Mar 29 2011, 19:49 CADiLO Материалы после семинара я выложу на сайт. А вопр... Mar 29 2011, 09:30 Transistor Цитата(CADiLO @ Mar 29 2011, 12:30) Матер... Apr 6 2011, 11:43  ssokol Цитата(Transistor @ Apr 6 2011, 14:43) Вы... Apr 6 2011, 17:51   Transistor Цитата(ssokol @ Apr 6 2011, 20:51) ... я ... Apr 6 2011, 18:22    ssokol Цитата(Transistor @ Apr 6 2011, 21:22) чт... Apr 7 2011, 05:02 CADiLO Дожились - быстрее в форуме спросить чем на сайт о... Mar 30 2011, 06:10 ssokol Цитата(CADiLO @ Mar 30 2011, 09:10) И ест... Mar 31 2011, 10:56 CADiLO из глобального - что уже анонсировано
Assisted-GP... Apr 1 2011, 08:16 CADiLO Все правильно. В Киеве уже состоялся 31 марта. В ... Apr 7 2011, 06:25 Transistor Цитата(CADiLO @ Apr 7 2011, 09:25) ...Мат... May 11 2011, 09:42
