Попробовал. Удалось достучаться до памяти, она корректно определяется, но не программруется
target state: halted
target halted in ARM state due to debug-request, current mode: Supervisor
cpsr: 0x000000d3 pc: 0x00000000
MMU: disabled, D-Cache: disabled, I-Cache: disabled
(processor reset)
Info : Flash Manufacturer/Device: 0x0089 0x8816
Warn : expected one protection register field, but found 2
Warn : configuration specifies 0x2000000 size, but a 0x2000000 size flash was found
flash 'cfi' found at 0x00000000
> flash write_image 1.2.5-hp.rom 0x0 bin
Using target buffer at 0x5c000038 and of size 0x8000
Write 0x8000 bytes to flash at 0x00000000
status register: 0x98
Low Programming Voltage Detected, Operation Aborted
Program Error / Error in Setting Lock-Bit
error writing to flash at address 0x00000000 at offset 0x00000000 (-902)
Command handler execution failed
in procedure 'flash' called at file "command.c", line 650
called at file "command.c", line 361
