> AVR ADC 10 bit ,help me
vanduongbk
сообщение Apr 2 2011, 03:49
Пользователь №: 61 811
I write program convert adc 10 bit and results to led ,it operates accuracy but i have a problem while simulation by protues ,it appears warning as below ,i dont know it operate or not in real circuit ,please help me
this is warning
and this is code
and I want to ask how I can transfer this 10 bit once time to pc through rs232
Son Of Stone
сообщение Apr 2 2011, 07:35
Пользователь №: 44 106
ATmega's UART allows sending from 5 to 9 data bits at once (in one frame). Best frame format for communication with PC (using hardware RS232 or USB-TO-COM adapter) is 8 data bits and 1 stop bit. You should send ADC conversion result in two frames using "USART Data Register
Empty (UDRE) Interrupt" (Page 150 in datasheet). Example:
Chip type           : ATmega16
Program type        : Application
Clock frequency     : 14,745600 MHz
Memory model        : Small
External SRAM size  : 0
Data Stack size     : 256
#include <mega16.h>
register unsigned char ADCH_, ADCL_; //Plase variables in working registers for fast access to them
// ADC interrupt service routine
interrupt [ADC_INT] void adc_isr(void)
ADCL_ = ADCL;
ADCH_ = ADCH; //Right order to read ADC result!
//Preparing data to transmission
ADCH_<<=3;
ADCH_|=ADCL_>>5;
ADCL_&=0x1F;
//Now we have 5 higher bits of the result in ADCH_ and 5 lower bits of result in ADCL_;
ADCH_|=0x80; //Set MSB in ADCH_ in 1 for correct handling recived data on PC
//Start Transmission!
UDR=ADCH_;
UCSRB=0x28;//UDRE interrupt enabled
// USART Transmitter interrupt service routine
interrupt [USART_DRE] void usart_tx_udre(void)
UDR=ADCL_;
UCSRB=0x08;   //UDRE interrupt disabled
ADCSRA|=0x40; //Start next ADC conversion!!;
void main(void)
// USART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART Receiver: Off
// USART Transmitter: On, UDRE int. On
// USART Mode: Asynchronous
// USART Baud Rate: 57600
UCSRA=0x00;
UCSRB=0x08; //TXEN=1;
UCSRC=0x86; //8-bit frame
UBRRH=0x00;
UBRRL=0x0F;
//ADC initialization
ADMUX=0xC0; // ADC Voltage Reference: Int., cap. on AREF, INPUT=PORTA.0
ADCSRA=0xCF; // ADC Clock frequency: 115,200 kHz, START FIRST CONVERSION
#asm("sei")
while (1);
P. S. Van Duong, are you from Vietnam? I glad to see vietnamese man on this forum!
My e-mail is KT829A[dog]yahoo[dot]com. Also i use YahooMessanger with this Yahoo ID. Any messages welcome!
vanduongbk
сообщение Apr 3 2011, 06:19
thank you very much for your best reply
yes ,i come from vietnamese , your id is KT829A
thank again
Цитата(_Pasha @ Apr 3 2011, 11:38) *
BTW avr DLL is slightly mature in your installation, most recent is 7.7SP0 build 9076.
But, as mentioned before, the key problem is an order of reading ADCL:ADCH
i am using protues 7.5 sp3
i dont know where i can download 7.7 full ,please help me
Сообщение отредактировал IgorKossak - Apr 3 2011, 18:34
Причина редактирования: ridiculous quoting
RSS Текстовая версия Сейчас: 5th August 2025 - 08:40
Страница сгенерированна за 0.0157 секунд с 7
