> CDC драйвер виртуального COM порта под Window XP - Windows 7, 32 и 64 бит, для процессоров AT91SAM (VID_03EB&PID_6124)
Pasha 111
сообщение Sep 24 2009, 23:22
Пользователь №: 10 515
Установил себе Windows 7 64 бит и не смог поставить драйвер из sam-ba_2.9_cdc_xp_vista.zip - atm6124_cdc.inf
Искал по форуму и интернету минут 30, в итоге решил изменить существующий, чтобы везде работал. Вот мой вариант драйвера
atm6124_cdc_win2k-win7_x86-x64.inf
; Windows USB CDC Driver Setup File for ATMEL AT91SAM products
; Improved by Pavel K, pasha_nik@mail.ru
[Version]
Signature=        "$Windows NT$"; Windows 200 and later versions
Class=            Ports; This is a serial port driver
ClassGuid=        {4D36E978-E325-11CE-BFC1-08002BE10318}
Provider=        %DriverProvider%
DriverVer=        09/25/2009,1.0.0.0; Driver version 1.0.0.0 published on 25 September 2009
[Manufacturer]
%DriverProvider%=    DeviceList, NT, NTia64, NTamd64
[DestinationDirs]
DefaultDestDir=        12; Default install directory is \drivers or \IOSubSys
[DeviceList.NT]
%DeviceDescription%=    DriverInstall,USB\VID_03EB&PID_6124
[DeviceList.NTia64]
[DeviceList.NTamd64]
; 32 bit section for Windows 2000/2003/XP/Vista/7
[DriverInstall.NT]
include=        mdmcpq.inf
CopyFiles=        DriverInstall.NT.Files
AddReg=            DriverInstall.NT.AddReg
[DriverInstall.NT.Files]
usbser.sys,,,0x20
[DriverInstall.NT.AddReg]
HKR,,DevLoader,,*ntkern
HKR,,NTMPDriver,,usbser.sys
HKR,,EnumPropPages32,,"MsPorts.dll,SerialPortPropPageProvider"
[DriverInstall.NT.Services]
AddService=usbser,0x00000002,usbser_sys_service
; 64 bit section for Intel Itanium based systems
[DriverInstall.NTia64]
include=        mdmcpq.inf
CopyFiles=        DriverInstall.NTia64.Files
AddReg=            DriverInstall.NTia64.AddReg
[DriverInstall.NTia64.Files]
usbser.sys,,,0x20
[DriverInstall.NTia64.AddReg]
[DriverInstall.NTia64.Services]
; 64 bit section for AMD64 and Intel EM64T based systems
[DriverInstall.NTamd64]
include=        mdmcpq.inf
CopyFiles=        DriverInstall.NTamd64.Files
AddReg=            DriverInstall.NTamd64.AddReg
[DriverInstall.NTamd64.Files]
usbser.sys,,,0x20
[DriverInstall.NTamd64.AddReg]
[DriverInstall.NTamd64.Services]
AddService=        usbser,0x00000002,usbser_sys_service
; usbser.sys service
[usbser_sys_service]
DisplayName=        %ServiceDescription%
ServiceType=        1; SERVICE_KERNEL_DRIVER, Service kernel driver
StartType=        3; SERVICE_DEMAND_START, Driver is started by the PnP manager
ErrorControl=        1; SERVICE_ERROR_NORMAL, Warn about errors
ServiceBinary=        %12%\usbser.sys
LoadOrderGroup =    Base
; strings
[Strings]
DriverProvider=        "Microsoft"
DeviceDescription=    "Виртуальный COM порт (AT91SAM)"
ServiceDescription=    "USB To Serial Driver"
Проверил - ставится и работает. Буду рад, если кому-то понадобится.
Прикрепленный файл  atm6124_cdc_win2k_win7_x86_x64.zip ( 1.17 килобайт ) Кол-во скачиваний: 641
prottoss
сообщение Apr 3 2011, 20:31
Пользователь №: 3 659
Интересная получается ситуевина...
В WinXP-32 запрос SET_LINE_CODING отрабатывается нормально. Принимает от устройства пакет нулевой длины (ACK).
Ну и далее, еще через несколько контрольных запросов, обмен данными с приложением.
В Win7-64 запрос SET_LINE_CODING. 30 секунд ожидания. Затем драйвер сообщает статус STATUS_CANCELLED. За тем несколько контрольных запросов и сообщение STATUS_IO_TIMEOUT. Все, приложение закрыло порт.
Все. Разобрался. Баг был все таки в моем девайсе похоже... После приема запроса SET_LINE_CODING необходимо посылать уведомление (Notification) SERIAL_STATE. Причем до того, как посылаем ACK через контрольную точку.
Все спасибо, особенно sergeeff за сниффер cheers.gif . Прикольная, однако, штучка.
- Pasha 111   CDC драйвер виртуального COM порта под Window XP - Windows 7, 32 и 64 бит   Sep 24 2009, 23:22
- - VAI   Спасибо, сейчас попробуем.   Sep 25 2009, 03:06
- - Gorobey   Спасибо ОГРОМНОЕ ! Только вот че-то делаю не ...   Oct 22 2009, 18:06
- - Pasha 111   Gorobey Бывают иногда глюки, что файл usbser.sys н...   Nov 6 2009, 23:19
|- - Chameleon   Разобрался. Все работает. Мой косяк был. Я в дескр...   Dec 5 2009, 10:26
- - newsip   Добрый день Помогите чайнику....не могу найти драй...   Nov 25 2010, 14:20
- - prottoss   Цитата(Pasha 111 @ Sep 25 2009, 06:22) Пр...   Apr 2 2011, 19:47
|- - sergeeff   Цитата(prottoss @ Apr 2 2011, 23:47) Мож ...   Apr 2 2011, 23:37
|- - prottoss   Цитата(sergeeff @ Apr 3 2011, 06:37) cat ...   Apr 3 2011, 10:37
|- - sergeeff   ЦитатаЗначит драйвер обязан корректно работать с м...   Apr 3 2011, 12:17
|- - prottoss   Цитата(sergeeff @ Apr 3 2011, 19:17) ...Ч...   Apr 3 2011, 12:22
|- - sergeeff   Цитата(prottoss @ Apr 3 2011, 15:22) То ч...   Apr 3 2011, 16:44
|- - prottoss   Цитата(sergeeff @ Apr 3 2011, 23:44) С эт...   Apr 3 2011, 17:14
|- - Dir   Цитата(sergeeff @ Apr 3 2011, 18:44) С эт...   Apr 3 2011, 17:22
|- - halfdoom   Цитата(sergeeff @ Apr 3 2011, 19:44) Тут ...   Apr 4 2011, 06:28
|- - sergeeff   Цитата(halfdoom @ Apr 4 2011, 09:28) Ссыл...   Apr 4 2011, 09:49
- - sergeeff   Могу поделится наблюдением. Процесс enumeration до...   Apr 3 2011, 17:29
|- - prottoss   Цитата(sergeeff @ Apr 4 2011, 00:29) Могу...   Apr 3 2011, 17:46
|- - sergeeff   Цитата(prottoss @ Apr 3 2011, 20:46) Это ...   Apr 3 2011, 18:23
|- - prottoss   Цитата(sergeeff @ Apr 4 2011, 01:23) Есть...   Apr 3 2011, 18:39
- - prottoss   Цитата(Pasha 111 @ Sep 25 2009, 06:22) Во...   May 21 2011, 05:25
- - sonycman   Не пойму, а зачем ставить драйвер для стандартного...   Jun 4 2011, 05:04
- - athlon64   Цитата(Pasha 111 @ Sep 25 2009, 05:22) . ...   Sep 21 2011, 11:21
|- - danila777   всем доброго дня! Я в программировании не ...   Mar 21 2013, 20:08
|- - Xenia   Цитата(danila777 @ Mar 22 2013, 00:08) с ...   Mar 21 2013, 20:54
|- - danila777   Цитата(Xenia @ Mar 22 2013, 00:54) Возьми...   Mar 25 2013, 04:47
|- - Xenia   Цитата(danila777 @ Mar 25 2013, 08:47) я ...   Mar 25 2013, 08:37
|- - danila777   Цитата(Xenia @ Mar 25 2013, 12:37) Мне пр...   Mar 25 2013, 18:30
|- - SavageForest   Цитата(danila777 @ Mar 25 2013, 22:30) .....   Jul 18 2013, 08:35
- - SavageForest   вот собственно ссылка на обновление с сайта мелком...   Oct 16 2013, 05:46
RSS Текстовая версия Сейчас: 30th July 2025 - 10:31
Страница сгенерированна за 0.01406 секунд с 7
