> Помогите найти ошибку в коде. UART, ATMega32U4
Буратино
сообщение Apr 12 2011, 06:50
Из: Украина, Киев
Пользователь №: 41 215
main.c
void main (void) {
    InitDevice ();
    while (1) {
        Delay_mSeconds(20);
        UARTTransmitByte(0x55);
UART.c
#include "global.h"
*                             #DEFINE CONSTANTS
#define UART_RX_BUFFER_SIZE 8
#define UART_RX_BUFFER_MASK ( UART_RX_BUFFER_SIZE - 1 )
#define UART_TX_BUFFER_SIZE 8
#define UART_TX_BUFFER_MASK ( UART_TX_BUFFER_SIZE - 1 )
#if ( UART_RX_BUFFER_SIZE & UART_RX_BUFFER_MASK )
#error RX buffer size is not a power of 2
#endif
*                             GLOBAL FUNCTION
INT08U UART_RxBuf[UART_RX_BUFFER_SIZE];
volatile INT08U UART_RxHead;
volatile INT08U UART_RxTail;
INT08U UART_TxBuf[UART_TX_BUFFER_SIZE];
volatile INT08U UART_TxHead;
volatile INT08U UART_TxTail;
INT08U UARTDataInReceiveBuffer (void) {
   INT08U temp1 = UART_RxHead, temp2 = UART_RxTail;
   return (temp1 != temp2);
INT08U UARTReceiveByte (void) {
    INT08U temp1=UART_RxHead, temp2=UART_RxTail;
    INT08U tmptail;
    while (temp1 == temp2) {
    tmptail = ( UART_RxTail + 1 ) & UART_RX_BUFFER_MASK;
    UART_RxTail = tmptail;
    return UART_RxBuf[tmptail];
void UARTTransmitByte (INT08U data ) {
    INT08U tmphead;
    tmphead = ( UART_TxHead + 1 ) & UART_TX_BUFFER_MASK;
    while ( tmphead == UART_TxTail );
    UART_TxBuf[tmphead] = data;
    UART_TxHead = tmphead;
    UCSR1B |= (1<<UDRIE1);
*                              LOCAL FUNCTION
#pragma vector=USART1_RX_vect
__interrupt void USART_Rx_isr(void) {
    INT08U data;
    INT08U tmphead;
    data = UDR1;
    tmphead = ( UART_RxHead + 1 ) & UART_RX_BUFFER_MASK;
    UART_RxHead = tmphead;
    if (tmphead == UART_RxTail) {        }
    UART_RxBuf[tmphead] = data;
#pragma vector=USART1_TX_vect
__interrupt void USART0_Tx_interrupt( void ) {
    INT08U temp1 = UART_TxHead, temp2 = UART_TxTail;
    INT08U tmptail;
    if (temp1 != temp2) {
        tmptail = ( UART_TxTail + 1 ) & UART_TX_BUFFER_MASK;
        UART_TxTail = tmptail;
        UDR1=UART_TxBuf[tmptail];
    else {
        UCSR1B &= ~(1<<UDRIE1);
UART.h
*                             GLOBAL VARIABLE
extern INT08U UART_RxBuf[];
extern volatile INT08U UART_RxHead;
extern volatile INT08U UART_RxTail;
extern INT08U UART_TxBuf[];
extern volatile INT08U UART_TxHead;
extern volatile INT08U UART_TxTail;
*                        GLOBAL FUNCTION PROTOTYPES
INT08U UARTDataInReceiveBuffer (void);
INT08U UARTReceiveByte (void);
void UARTTransmitByte (INT08U);
init.c
void Init_UART (void) {
    UBRR1L = 0x0C;
    UBRR1H = 0x00;
    UCSR1B = (1<<RXEN1)|(1<<TXEN1)|(1<<TXCIE1)|(1<<RXCIE1)|(1<<UDRIE1);
    UCSR1C = (1<<USBS1)|(3<<UCSZ10);
Выполняется несколько итераций (по количеству байт в буфере передатчика), при этом на выводе Тх ничего нет, потом все умирает совсем.
Сообщение отредактировал Буратино - Apr 12 2011, 08:13
Брак - это такой вид отношений, в которых один всегда прав, - а другой - муж.
XVR
сообщение Apr 12 2011, 11:13
Из: Химки
Пользователь №: 26 847
Иззюмительный кусок кода! 1111493779.gif Повесить МК можно и гораздо проще!
Буратино
сообщение Apr 12 2011, 12:36
Из: Украина, Киев
нормально все там, а если че то можно через некоторое время выпрыгивать из этого ожидания. Посмотрите, там даже место оставлено для этих целейsm.gif
XVR
сообщение Apr 12 2011, 12:46
Из: Химки
Да ну? С чего это оно 'выпрыгнет' из while цикла? У вас же там сравниваются локальные копии volatile переменных (из temp1 и temp2). Если они окажутся равными на входе в цикл, то цикл никогда не кончится
Буратино
сообщение Apr 12 2011, 18:50
Из: Украина, Киев
хм, а и правда нехорошо. Я так сделал ибо компилятор ругался на сравнение volatile переменных.
Ну и че делать? Может быть внутри операторного блока цикла ,переменным temp1, temp2 присваивать значения volatile переменных?
RSS Текстовая версия Сейчас: 30th July 2025 - 02:19
Страница сгенерированна за 0.01431 секунд с 7
