> Расчет таймера для RC5, помогите просчитать таймер
den_sad
сообщение May 30 2011, 10:45
Пользователь №: 45 258
Нужна помошь, никак не могу понять как добиться частоты 38килогерц на выходе.. вот листинг программы
Использую Мега8 на кварце 7.3728Мгц
CODE
This program was produced by the
CodeWizardAVR V1.25.7a Professional
Automatic Program Generator
© Copyright 1998-2007 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 23.05.2011
Author : F4CG
Company : F4CG
Comments:
Chip type : ATmega8
Program type : Application
Clock frequency : 8,000000 MHz
Memory model : Small
External SRAM size : 0
Data Stack size : 256
#include <mega8.h>
// Standard Input/Output functions
#include <stdio.h>
#include <delay.h>
#define RXB8 1
#define TXB8 0
#define UPE 2
#define OVR 3
#define FE 4
#define UDRE 5
#define RXC 7
#define FRAMING_ERROR (1<<FE)
#define PARITY_ERROR (1<<UPE)
#define DATA_OVERRUN (1<<OVR)
#define DATA_REGISTER_EMPTY (1<<UDRE)
#define RX_COMPLETE (1<<RXC)
// USART Receiver buffer
#define RX_BUFFER_SIZE 22
#define PulseON TCCR1B=0x40;TCCR1A=0x05
#define PulseOFF TCCR1B=0;TCCR1A=0
char VOL_UP[6] = {0x50,0x04,0x68,0x32,0x11,0x1F}; // 50 04 68 32 11 1F
char VOL_DN[6] = {0x50,0x04,0x68,0x32,0x10,0x1E};
//char SEEK_UP[6] = {0x50,0x04,0x68,0x3B,0x21,0x26};
char RAD_CDC[5] = {0x68,0x03,0x18,0x01,0x72}; //Ты включен?
//char RAD_CDC_play[7] = {0x68,0x05,0x18,0x38,0x00,0x00,0x4D}; //Ты играешь? 680518380000
char RAD_CDC_play[7] = {0x68,0x05,0x18,0x38,0x01,0x00,0x4C}; //Ты играешь? 68 05 18 38 01 00 4C стоп воспр
char CDC_RAD[6] = {0x18,0x04,0x68,0x02,0x00, 0x76}; //Ответ drk.xty
char CDC_STAT[12] = {0x18,0x0A,0x68,0x39,0x02,0x09,0x00,0x3F,0x00,0x01,0x01,0x77}; //Статус я играю
//39 00 09 00 3F 00 dd tt
int RxRecieveEnable;
int RxCnt;
int RxPacketSize;
int ParseEnable;
char RxBuff[20];
char ch;
int ledON;
// IR JVC
// int start = 320;
// int pause = 160;
// int togle=20;
// END IR JVC
int JVC_VOLUP[16]={1,0,0,0,1,1,1,1,1,0,0,0,0,1,0,0};
// Vol+ 10001111 10000100
void SendHI(void)
ledON=1;
delay_us(400); //********** Здесь задержка должны быть 526vrc но почему то при delay_us(526) задержка по осцилографу больше
ledON=0;
delay_us(1200);
void SendLOW(void)
ledON=1;
delay_us(400);
ledON=0;
delay_us(400);
void SendStart(void)
ledON=1;
delay_us(6400); //********** Здесь задержка должны быть8.4 мс но почему то при delay_ms(8.4) задержка по осцилографу около 12-14 мс
ledON=0;
delay_us(3200);
void SendJVC_volUP(void)
int i;
SendStart();
for (i=0;i<16; i++) {
if (JVC_VOLUP[i]==0) {SendLOW();}
else {SendHI();}
// This flag is set on USART Receiver buffer overflow
// USART Receiver interrupt service routine
interrupt [USART_RXC] void usart_rx_isr(void)
ch = UDR;
if((ch == 0x68 | ch == 0x50 | ch ==0x18) & (RxRecieveEnable == 0))
RxRecieveEnable = 1;
RxCnt = 0;
RxPacketSize = 0;
RxBuff[0] = ch;
else if(RxRecieveEnable==1)
if(RxCnt==0)
if((ch & 0x80) == 0)
RxPacketSize = ch;
RxBuff[1] = RxPacketSize;
RxCnt++;
else if(RxCnt>0) //
RxBuff[RxCnt+1] = ch;
RxCnt++;
if(RxCnt > RxPacketSize) //
RxRecieveEnable = 0;
RxCnt = 0;
RxPacketSize = 0;
ParseEnable = 1; //????? ?????????? ???????? ?????
// Write a character to the USART Transmitter
#ifndef _DEBUG_TERMINAL_IO_
#define _ALTERNATE_PUTCHAR_
#pragma used+
void putchar(char c)
while ((UCSRA & DATA_REGISTER_EMPTY)==0);
UDR=c;
#pragma used-
#endif
int AnalizeMFL(void)
int n;
int razmer;
int volup=0; //?? ??????? ??????????
int voldn=0;
razmer=RxBuff[1]+2;
for (n=0;n<razmer;n++) //??????????? ??????????? ?????
if (RxBuff[n]==VOL_UP[n]) //50 04 68 32 11 1F
volup=volup+1;
if (RxBuff[n]==VOL_DN[n]) //50 04 68 32 10 1E
voldn=voldn+1;
if (volup==razmer)
SendJVC_volUP();
// послать команду громкость +
if (voldn==razmer)
// PORTD.6=!PIND.6;
// послать команду громкость -
return n;
int AnalizeRAD(void)
int n;
int razmer;
int ROLL=0;
int STAT=0;
razmer=RxBuff[1]+2;
if (RxBuff[n]==RAD_CDC[n]) //{0x68,0x03,0x18,0x01,0x72}; ты включен?
ROLL=ROLL+1;
if (RxBuff[n]==RAD_CDC_play[n]) //; что ты играешь? {0x68,0x05,0x18,0x38,0x00,0x00,0x4D};
STAT=STAT+1;
n=0;
if (ROLL==razmer) // я включен
for (n=0;n<6;n++)
putchar(CDC_RAD[n]); //0x18,0x04,0x68,0x02,0x00, 0x76
if (STAT==razmer) // я играю
for (n=0;n<12;n++)
putchar(CDC_STAT[n]); // {0x18,0x0A,0x68,0x39,0x02,0x09,0x00,0x3F,0x00,0x01,0x01,0x77}; //Статус
return n;
// Timer 1 output compare A interrupt service routine
interrupt [TIM1_COMPA] void timer1_compa_isr(void)
// Place your code here
TCNT1H=0;
TCNT1L=0;
{PORTD.6=!PIND.6;} //надо чтобы на PD6 была частота 38 килогерц
if (ledON==1)
{PORTD.7=!PIND.7;}
else {PORTD.7=0;}
// Declare your global variables here
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port B initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=P State6=P State5=P State4=P State3=P State2=P State1=P State0=P
PORTB=0xFF;
DDRB=0x00;
// Port C initialization
// Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State6=P State5=P State4=P State3=P State2=P State1=P State0=P
PORTC=0x7F;
DDRC=0x00;
/// Port D initialization
// Func7=Out Func6=Out Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=0 State6=0 State5=P State4=P State3=P State2=P State1=P State0=P
PORTD=0x3F;
DDRD=0xC0;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
TCCR0=0x00;
TCNT0=0x00;
// Timer/Counter 1 initialization
// Clock value: 921,600 kHz
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x02;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00; ////////////// что надо указать чтобы получить на PD6 была частоту 38 килогерц??
OCR1AH=0x00;
OCR1AL=0x0C;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// Mode: Normal top=FFh
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
MCUCR=0x00;
TIMSK=0x10;
// USART initialization
// Communication Parameters: 8 Data, 1 Stop, Even Parity
// USART Receiver: On
// USART Transmitter: On
// USART Mode: Asynchronous
// USART Baud Rate: 9600
UCSRA=0x00;
UCSRB=0x98;
UCSRC=0xA6;
UBRRH=0x00;
UBRRL=0x2F;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
// Global enable interrupts
#asm("sei")
ledON=0;
while (1)
SendJVC_volUP();
delay_ms(500);
if (ParseEnable==1)
switch (RxBuff[0]) {
case 0x68:
{ ParseEnable=0; AnalizeRAD();}
break;
case 0x50:
ParseEnable=0; AnalizeMFL();}
break;
case 0x18:
ParseEnable=0; }
break;
ParseEnable=0;
}; //while
красным отметил интересующие меня куски кода.. в Итоге 2 вопроса, почему delay.h дает не те задержки что я указываю и как добиться 38 килогерц для модуляции
Сообщение отредактировал IgorKossak - May 30 2011, 10:48
Причина редактирования: [codebox]!!!
Палыч
сообщение May 30 2011, 11:15
Из: г. Новочеркасск
Пользователь №: 16 954
Несоответствие частот:
Для этого желательно использовать выходы таймера OC1A, OC1B или OC2. Как настроить - в DS есть информация и с диаграммами для понимания работы
den_sad
сообщение May 30 2011, 11:20
возможно, вот только отличия с тем коэфициэнтом как 8\7.3728
Читал, нихрена не понял, прошу рабочие куски кода выделеные красным ,мозг уже взрывается
Палыч
сообщение May 30 2011, 11:56
Из: г. Новочеркасск
Сравните частоту Вашего кварца и частоту, установленную в проекте (Menu->Project->Configure->C Compiler->Code Generation->Clock)
den_sad
сообщение May 30 2011, 11:59
Цитата(Палыч @ May 30 2011, 14:56) *
Сравните частоту Вашего кварца и частоту, установленную в проекте (Menu->Project->Configure->C Compiler->Clock)
Все ок, но меня больше волнует какие параметры прописать в таймер чтобы генерить 38 килогерц, delay для меня на данном этапе не критично
RSS Текстовая версия Сейчас: 25th June 2025 - 02:08
Страница сгенерированна за 0.01452 секунд с 7
