> Вопрос по LPC11xx, реагирование на изменения уровня на входе
_Артём_
сообщение Oct 13 2011, 23:19
Пользователь №: 17 322
Пытаюсь заставить LPC1114 реагировать на измение состояния на входе (на фронт).
Вот код:
#include "driver_config.h"
#include "target_config.h"
volatile unsigned short LedTimer;
void SysTick_Handler(void)
    if (LPC_GPIO[0]->DATA&(1<<7)) {
        if (++LedTimer>=100) {
            LPC_GPIO[0]->DATA&=~(1<<7);
void GPIOInit( void )
  /* Enable AHB clock to the GPIO domain. */
  LPC_SYSCON->SYSAHBCLKCTRL |= (1<<6);
#ifdef __JTAG_DISABLED
  LPC_IOCON->R_PIO1_1  &= ~0x07;
  LPC_IOCON->R_PIO1_1  |= 0x01;
#endif
  /* Set up NVIC when I/O pins are configured as external interrupts. */
#if CONFIG_GPIO_DEFAULT_PIOINT0_IRQHANDLER==1
  NVIC_EnableIRQ(EINT0_IRQn);
#endif
#if CONFIG_GPIO_DEFAULT_PIOINT1_IRQHANDLER==1
  NVIC_EnableIRQ(EINT1_IRQn);
#endif
#if CONFIG_GPIO_DEFAULT_PIOINT2_IRQHANDLER==1
  NVIC_EnableIRQ(EINT2_IRQn);
#endif
#if CONFIG_GPIO_DEFAULT_PIOINT3_IRQHANDLER==1
  NVIC_EnableIRQ(EINT3_IRQn);
#endif
  return;
** Function name:        GPIOSetInterrupt
** Descriptions:        Set interrupt sense, event, etc.
**                        edge or level, 0 is edge, 1 is level
**                        single or double edge, 0 is single, 1 is double
**                        active high or low, etc.
** parameters:            port num, bit position, sense, single/doube, polarity
** Returned value:        None
void GPIOSetInterrupt( uint32_t portNum, uint32_t bitPosi, uint32_t sense,
            uint32_t single, uint32_t event )
  switch ( portNum )
    case PORT0:
      if ( sense == 0 )
        LPC_GPIO0->IS &= ~(0x1<<bitPosi);
        /* single or double only applies when sense is 0(edge trigger). */
        if ( single == 0 )
          LPC_GPIO0->IBE &= ~(0x1<<bitPosi);
        else
          LPC_GPIO0->IBE |= (0x1<<bitPosi);
      else
          LPC_GPIO0->IS |= (0x1<<bitPosi);
      if ( event == 0 )
        LPC_GPIO0->IEV &= ~(0x1<<bitPosi);
      else
        LPC_GPIO0->IEV |= (0x1<<bitPosi);
    break;
    case PORT1:
      if ( sense == 0 )
        LPC_GPIO1->IS &= ~(0x1<<bitPosi);
        if ( single == 0 )
          LPC_GPIO1->IBE &= ~(0x1<<bitPosi);
        else
          LPC_GPIO1->IBE |= (0x1<<bitPosi);
      else
          LPC_GPIO1->IS |= (0x1<<bitPosi);
      if ( event == 0 )
        LPC_GPIO1->IEV &= ~(0x1<<bitPosi);
      else
        LPC_GPIO1->IEV |= (0x1<<bitPosi);
    break;
    case PORT2:
      if ( sense == 0 )
        LPC_GPIO2->IS &= ~(0x1<<bitPosi);
        if ( single == 0 )
          LPC_GPIO2->IBE &= ~(0x1<<bitPosi);
        else
          LPC_GPIO2->IBE |= (0x1<<bitPosi);
      else
          LPC_GPIO2->IS |= (0x1<<bitPosi);
      if ( event == 0 )
        LPC_GPIO2->IEV &= ~(0x1<<bitPosi);
      else
        LPC_GPIO2->IEV |= (0x1<<bitPosi);
    break;
    case PORT3:
      if ( sense == 0 )
        LPC_GPIO3->IS &= ~(0x1<<bitPosi);
        if ( single == 0 )
          LPC_GPIO3->IBE &= ~(0x1<<bitPosi);
        else
          LPC_GPIO3->IBE |= (0x1<<bitPosi);
      else
          LPC_GPIO3->IS |= (0x1<<bitPosi);
      if ( event == 0 )
        LPC_GPIO3->IEV &= ~(0x1<<bitPosi);
      else
        LPC_GPIO3->IEV |= (0x1<<bitPosi);
    break;
    default:
      break;
  return;
uint32_t GPIOIntStatus( uint32_t portNum, uint32_t bitPosi )
  uint32_t regVal = 0;
  switch ( portNum )
    case PORT0:
      if ( LPC_GPIO0->MIS & (0x1<<bitPosi) )
        regVal = 1;
    break;
    case PORT1:
      if ( LPC_GPIO1->MIS & (0x1<<bitPosi) )
        regVal = 1;
    break;
    case PORT2:
      if ( LPC_GPIO2->MIS & (0x1<<bitPosi) )
        regVal = 1;
    break;
    case PORT3:
      if ( LPC_GPIO3->MIS & (0x1<<bitPosi) )
        regVal = 1;
    break;
    default:
      break;
  return ( regVal );
void GPIOIntClear( uint32_t portNum, uint32_t bitPosi )
  switch ( portNum )
    case PORT0:
      LPC_GPIO0->IC |= (0x1<<bitPosi);
    break;
    case PORT1:
      LPC_GPIO1->IC |= (0x1<<bitPosi);
    break;
    case PORT2:
      LPC_GPIO2->IC |= (0x1<<bitPosi);
    break;
    case PORT3:
      LPC_GPIO3->IC |= (0x1<<bitPosi);
    break;
    default:
      break;
  return;
int main (void)
    // настройка реакции на фронт
    GPIOSetInterrupt(PORT1, 6, 0, 0, 1);
    SysTick_Config( SystemCoreClock/1000);
    while( 1 ) {
        if (GPIOIntStatus(PORT1, 6)) {
            GPIOIntClear(PORT1, 6);
            LedTimer=100;
            LPC_GPIO[0]->DATA|=(1<<7);
**                            End Of File
Сигнал на входе меняется от кнопки (также видно по значению LPC_GPIO[0]->DATA), но в
внутрь if (GPIOIntStatus(PORT1, 6)) {...} программа не попадает.
Подскажите, что делаю не так?
Если не те регистры опрашиваю, то какие нужно?
Alex19
сообщение Oct 14 2011, 04:15
Из: Тула
Пользователь №: 49 063
У Вас тактирование портов не включено - необходимо в main перед настройкой реакции на фронт добавить - GPIOInit( );
_Артём_
сообщение Oct 14 2011, 19:01
Да, про тактирование забыл.
Но всё равно нет реакции.
Или не там смотрю.
RSS Текстовая версия Сейчас: 22nd July 2025 - 23:25
Страница сгенерированна за 0.01394 секунд с 7
