> Модули ZigBee от MaxStream, Кто нить имел с ними дело
at90
сообщение Feb 8 2006, 10:20
Из: Краснодар
Пользователь №: 3 814
Вот нашел недорогие ZigBee модули от Maxsteram -Xbee.
http://www.maxstream.net/products/
Кто нить с ними работал? Поделитесь впечатлениями!
<<Первая производная от чужой идеи - уже твоя идея.>>
OPM
сообщение Mar 30 2006, 17:19
Пользователь №: 14 236
Вот, получил ответы от Maxstream (работает техподдержка!)
Файл прислали v1.08
Hello,
Below is the complete transcript of your chat session:
Company:
Department: Support
Email: reubenb@maxstream.net
Day: Thu 03/30/06 09:47 am
"Does RF speed changes if I change UART baud rate (9600,19200,...etc)
** You are now speaking with Travis H., Support. **
Travis H. : Hello, how are you today?
Petr : Fine, What's about RF speed. Is it the same regardless UART
speed? I mean XBee 802.15.4. products
Travis H. : The RF data rate is 250Kbps irregardsless of interface
data rate.
Petr : Thank you. And another question. How can I get information if
my packet was received by another Xbee module?
Travis H. : What sort of information were you looking for... Addressing info? Or reception info?
Petr : Just confirmation of success delivery of packet. As far as I
understand XBee will try to send packet 3 times. And if it fail, how
can I get information about this?
Travis H. : If you are looking for reception info (or addressing info
for that matter) you can use the API... The API gives you a response frame telling you the status
of your packet (success, ACK failure, CCA failure, or purged).
Petr : What command?
Travis H. : ATAP, but you must have firmware v108.
Travis H. : Do you have firmware v108?
Petr : I really have 1.06 and XCTU said me - nothing to update! Where
I am wrong?
Travis H. : Did you just click the "Download new firmware" button in
CTU?
Travis H. : (then select web)
Petr : Yes I did
Travis H. : What response did the popup window give you?
Petr : XCTU try to connect some time, then I get information -
something like - there are nothing new for you.
Travis H. : I can send it to you, what is your email address?
Petr : It's fine! Please: rrr2000@rambler.ru
Travis H. : I just sent it...
Travis H. : You should recieve it in a few moments.
Petr : Thanks a lot. Generally XBee is amazing module.
Petr : By!
Travis H. : Bye
- at90   Модули ZigBee от MaxStream   Feb 8 2006, 10:20
- - OPM   Отличные модули! На практике передавал 115 кБи...   Feb 11 2006, 21:18
|- - =AK=   Цитата(OPM @ Feb 12 2006, 06:48) Отличные...   Feb 17 2006, 04:04
- - Dr.NoA   Цитата(OPM @ Feb 12 2006, 00:18) Отличны...   Feb 12 2006, 09:47
|- - vm1   А как с легальностью? Требуется - Разрешение на пр...   Feb 12 2006, 10:46
- - OPM   115 - была реальная скорость передачи при 1 мВт на...   Feb 12 2006, 15:48
- - at90   OPM: А как там передвать. Чё за AT комманда? Чё то...   Feb 13 2006, 14:15
|- - acex2   Цитата(at90 @ Feb 13 2006, 11:15) OPM: А ...   Feb 13 2006, 14:41
- - OPM   Эти модули не сыроваты, а "имеющие большой по...   Feb 13 2006, 18:39
- - at90   Так как передавать через модули? Так как передава...   Feb 16 2006, 12:39
- - OPM   Подключаешь питание +3,3 и землю. На вход UART под...   Feb 16 2006, 19:40
|- - acex2   Цитата(OPM @ Feb 16 2006, 16:40) Подключа...   Feb 16 2006, 23:11
- - at90   Может кто нить знает на каких чипах они сделаны?   Feb 17 2006, 07:37
|- - acex2   Цитата(at90 @ Feb 17 2006, 04:37) Может к...   Feb 17 2006, 10:18
- - OPM   Я не знаю откуда у кого руки растут, но я пишу тол...   Feb 17 2006, 18:49
|- - acex2   Цитата(OPM @ Feb 17 2006, 15:49) Я не зна...   Feb 17 2006, 20:31
|- - BoolAB   Цитата(OPM @ Feb 17 2006, 22:49) Повторяю...   Mar 30 2006, 05:15
- - OPM   Вот смотри - прилагаю копию окошка программы. Непр...   Feb 18 2006, 09:44
- - OPM   Вот еще пример нашел - передовал из X-CTU в термин...   Feb 18 2006, 10:02
- - at90   Значь тогда будем Ember копать. Пока лучьше ничего...   Feb 22 2006, 06:40
- - tag   Вроде техподдержка Эфо сообщила что чипы EM250 ско...   Mar 7 2006, 06:39
- - OPM   На сайте САХАРЫ есть статейка про дальность действ...   Mar 7 2006, 15:57
- - at90   >Все производители предлагают одночиповые решен...   Mar 9 2006, 07:48
- - at90   короче с EM250 полная жопа. Стэк Ембер как всегда ...   Mar 15 2006, 08:36
- - OPM   А для тестовых целей можно получить пробную версию...   Mar 15 2006, 17:39
|- - Gulf   Софт под XAP2 (основа EM250) разрабатывался еще 5 ...   Mar 15 2006, 20:16
- - at90   Да Эфо предлагала вариант с прошиванием чипов у ни...   Mar 16 2006, 06:35
- - OPM   GULF: Не понимаю, как можно разрабатывать софть 5...   Mar 16 2006, 18:15
|- - acex2   Цитата(OPM @ Mar 16 2006, 15:15) Не поним...   Mar 16 2006, 23:11
- - at90   Стэк от Ембера можно поробоавать бесплатно на чипа...   Mar 17 2006, 10:50
- - OPM   Скорость в радиоканале, вероятно, 250 кБит/сек (ма...   Mar 30 2006, 16:22
|- - Gulf   Цитата(OPM @ Mar 30 2006, 20:22) Кстати, ...   Mar 30 2006, 16:51
|- - BoolAB   Огромное спасибо OPM! Ну и всем остальным :-)   Apr 1 2006, 06:29
|- - BoolAB   Господа! Ещё вопрос. Какое же напряжение питан...   Apr 11 2006, 08:29
- - OPM   Аккумуляторы ведут себя хорошо, хотя это древние N...   Mar 30 2006, 17:04
|- - Gulf   Выложите пожалуйста здесь новую прошивку для всех,...   Mar 30 2006, 20:21
- - OPM   Вот, что мне прислал MaxStream. Описание лежит зд...   Mar 31 2006, 17:02
- - OPM   Любителям модулей MaxStream - теперь все в ваших р...   May 24 2006, 17:48
- - George!   Прошло больше года с момента написания последнего ...   Sep 11 2007, 04:57
|- - OPM   Цитата(George! @ Sep 11 2007, 07:57) ...   Sep 12 2007, 17:00
- - George!   Спасибо. Я просто не до конца был уверен что это в...   Sep 13 2007, 09:31
- - Velund   Хотелось бы поднять тему... Читаю сейчас сайт мак...   Oct 8 2007, 16:16
|- - plan   Цитата(Velund @ Oct 8 2007, 19:16) Хотело...   Oct 9 2007, 05:25
- - Velund   Глючит - это не то слово. Скорее - не работает над...   Oct 9 2007, 09:02
|- - plan   Цитата(Velund @ Oct 9 2007, 12:02) Глючит...   Oct 9 2007, 12:16
- - Velund   Ну они с выходом XB Series 2 и спозиционировали......   Oct 9 2007, 17:08
|- - OPM   Цитата(Velund @ Oct 9 2007, 21:08) Ну они...   Oct 9 2007, 17:21
|- - Velund   Цитата(OPM @ Oct 9 2007, 21:21) Series 2 ...   Oct 9 2007, 18:40
- - andrewlekar   Ну так что, у кого-нибудь есть xIDE для XAP2? Хотя...   Nov 8 2007, 11:47
- - at90   Обратитесь в компанию эфо. Возможно там помогут с ...   Nov 8 2007, 13:10
|- - andrewlekar   В Эфо уже спросил. Жду ответа. А вообще, теоретич...   Nov 9 2007, 06:29
- - at90   А стэком уже разжились? Cтэк от EMBER поставляетс...   Nov 9 2007, 08:21
|- - andrewlekar   Цитата(at90 @ Nov 9 2007, 13:21) А стэком...   Nov 9 2007, 08:29
- - at90   Ну стэк дают если купите хотябы чипы.   Nov 9 2007, 09:00
|- - andrewlekar   Ну а мы купили. Тут скорее видится проблема в то...   Nov 9 2007, 09:08
- - at90   Я как то пробовал компилятор от CSR. Не подошел...   Nov 9 2007, 09:20
|- - andrewlekar   Цитата(at90 @ Nov 9 2007, 14:20) Я как то...   Nov 9 2007, 09:30
- - at90   Не помню, давно уже было. Мы купили их кит я являе...   Nov 9 2007, 09:36
|- - andrewlekar   Цитата(at90 @ Nov 9 2007, 14:36) Не помню...   Nov 9 2007, 11:02
- - at90   А нету там такого файла.   Nov 9 2007, 12:42
|- - andrewlekar   Цитата(at90 @ Nov 9 2007, 17:42) А нету т...   Nov 12 2007, 05:32
|- - andrewlekar   А просто в папке bin кроме xIDE.exe какие экзешник...   Nov 12 2007, 06:59
- - at90   Там есть только: xaprun.exe xipbuild.exe   Nov 12 2007, 07:03
- - andrewlekar   Вот блин, зашифровались. Ну будем искать тогда св...   Nov 12 2007, 07:24
RSS Текстовая версия Сейчас: 21st July 2025 - 00:56
Страница сгенерированна за 0.01422 секунд с 7
