нашёл интересный код по теме поста:
CODE
// This routine makes the flash looks like EEPROM. It will erase and
// replace just one word
// This routine copies will erase SEGA and then image SEGB to SEGA
// It will then erase SEGB and copy from SEGA back to SEGB all 128 bytes
// except the one to be replaced.
void flash_replace16(int16_t *ptr, int16_t word)
int *read_ptr;
int *write_ptr;
int w;
//Optimise the case where the new and old values are the same
if (*ptr == word)
return;
flash_clr((int *) FSEG_A);
_DINT();
//Set to write mode to prepare for copy
FCTL3 = FWKEY; /* Lock = 0 */
FCTL1 = FWKEY | WRT;
//Copy block B to A
read_ptr = (int *) FSEG_B;
write_ptr = (int *) FSEG_A;
for (w = 0; w < 64; w++)
*write_ptr++ = *read_ptr++;
flash_clr((int *) FSEG_B);
//Copy block A to B, slipping in the new value at the right location
read_ptr = (int *) FSEG_A;
write_ptr = (int *) FSEG_B;
for (w = 0; w < 64; w++, read_ptr++, write_ptr++)
if (write_ptr == ptr)
*write_ptr = word;
else
*write_ptr = *read_ptr;
flash_secure();
_EINT();
как я понял, эта функция то, что мне нужно
Прошу прокоментировать
Сообщение отредактировал Zelepuk - Nov 21 2011, 11:32
