> Как добавить...
kkosik
сообщение Sep 18 2012, 08:28
Пользователь №: 73 445
Был проект:
LIBRARY IEEE;
USE IEEE.std_logic_1164.all;
LIBRARY IEEE;
USE IEEE.std_logic_unsigned.all;
ENTITY SinTR IS
    PORT (
        TAKT: in std_logic;
        dfm: out std_logic;
        vihod: out std_logic_vector( 9 DOWNTO 0 );
--        strob: in std_logic;
--        sdvig: in std_logic;
      perep_out: out std_logic;
        f256: out std_logic;
        takt_out: out std_logic;
        clr : in std_logic;
--        data_serial: in std_logic;
    kod: in std_logic_vector( 11 DOWNTO 0 );
    otklmod: in std_logic;
    rlp: in std_logic;
--    t1out: out std_logic;
--   t2out: out std_logic;
--    t3out: out std_logic;
--    t4out: out std_logic;
    dataout: out  std_logic_vector( 31 DOWNTO 0 );
    sumout: out  std_logic_vector( 31 DOWNTO 0 );
    write : out std_logic
END SinTR;
ARCHITECTURE beh OF SinTR IS
--   port( DataA : in std_logic_vector(31 downto 0); Aclr : inout
--        std_logic := 'Z'; Clock : in std_logic; Sum : out
--       std_logic_vector(31 downto 0));
    component accumhs323
       port( DataA : in std_logic_vector(31 downto 0); Aclr : in  std_logic;
      Clock : in std_logic; Sum : out std_logic_vector(31 downto
       0); Cout: out std_logic);
     end component;
  CONSTANT kodotklmod : std_logic_vector( 19 DOWNTO 0 ) := "00100001101011111100";
  CONSTANT kodrlp1 : std_logic_vector( 19 DOWNTO 0 ) := "00100001101100001001";
  CONSTANT kodrlp2 : std_logic_vector( 19 DOWNTO 0 ) := "00100001101011101111";
  CONSTANT kod1 : std_logic_vector( 19 DOWNTO 0 ) := "00100001101100001001";
  CONSTANT kod2 : std_logic_vector( 19 DOWNTO 0 ) := "00100001101011110001";
  CONSTANT kodtest : std_logic_vector( 31 DOWNTO 0 ) := "00101000011011100101000110100101";
  CONSTANT Cin1 : std_logic := '0';
    SIGNAL q1, f2, f3, fm, strob_t : std_logic  := '0';
    SIGNAL r1, r0, data, S_out2 : std_logic_vector( 31 DOWNTO 0 )  := ( others => '0' );
    SIGNAL rs : std_logic_vector( 31 DOWNTO 0 )  ;
    SIGNAL   perep, perep_in,  wr0, del, tiktak1, tiktak2, tiktak3, tiktak4,sdvig_t, takt_out1, write1 : std_logic := '0';
    SIGNAL sOut : std_logic_vector( 9 DOWNTO 0 )  ;
-- 00111100100111101110110010111111
BEGIN
--                <<  TAKT  >>  == 20 MHz
Ниже еще идет port map к accumhs323.
В нем отдельно был сгенерирован и присоединен компонент accumhs323. Но теперь мне необходимо этот компонент удалить и написать его вручную. Как это сделать? Нужно добавлять source-файл, подключать и в нем всё прописывать? или же как-то в этом vhd-файле можно дописать?
В книгах не могу найти, как это делается...
Closed TopicStart new topic
RSS Текстовая версия Сейчас: 1st August 2025 - 17:25
Страница сгенерированна за 0.01343 секунд с 7
