> Сборка ядра кросс-компилятором GCC под ARM
Impossibility
сообщение Jan 24 2012, 08:20
Пользователь №: 68 176
При сборке ядра кросс-компилятором под ARM выдаются ошибки.
Вот какие команды подавались:
[niagara@stend1-h11 linux-3.2.1]$ make clean
[niagara@stend1-h11 linux-3.2.1]$ make ARCH=arm defconfig
HOSTCC scripts/basic/fixdep
HOSTCC scripts/kconfig/conf.o
HOSTCC scripts/kconfig/zconf.tab.o
HOSTLD scripts/kconfig/conf
*** Default configuration is based on 'versatile_defconfig'
# configuration written to .config
[niagara@stend1-h11 linux-3.2.1]$ make ARCH="arm" CROSS_COMPILE="arm-eabi-" zImage modules
Вот какая ошибка выдается:
Kernel: arch/arm/boot/Image is ready
AS arch/arm/boot/compressed/head.o
GZIP arch/arm/boot/compressed/piggy.gzip
AS arch/arm/boot/compressed/piggy.gzip.o
CC arch/arm/boot/compressed/misc.o
CC arch/arm/boot/compressed/decompress.o
CC arch/arm/boot/compressed/string.o
AS arch/arm/boot/compressed/lib1funcs.o
LD arch/arm/boot/compressed/vmlinux
arm-eabi-ld: ERROR: arch/arm/boot/compressed/misc.o uses VFP instructions, whereas arch/arm/boot/compressed/vmlinux does not
arm-eabi-ld: failed to merge target specific data of file arch/arm/boot/compressed/misc.o
arm-eabi-ld: ERROR: arch/arm/boot/compressed/decompress.o uses VFP instructions, whereas arch/arm/boot/compressed/vmlinux does not
arm-eabi-ld: failed to merge target specific data of file arch/arm/boot/compressed/decompress.o
arm-eabi-ld: ERROR: arch/arm/boot/compressed/string.o uses VFP instructions, whereas arch/arm/boot/compressed/vmlinux does not
arm-eabi-ld: failed to merge target specific data of file arch/arm/boot/compressed/string.o
make[2]: *** [arch/arm/boot/compressed/vmlinux] Error 1
make[1]: *** [arch/arm/boot/compressed/vmlinux] Error 2
make: *** [zImage] Error 2
Компилятор собирал сам с использованием newlib
Конфигурация для сборки компилятора:
$DST/$SRCNAME/$GCC_SRC/configure --target=$TARGET --prefix=$PREFIX --enable-languages=c,c++ --without-fp --with-softfloat-support=internal --enable=multilib --with-float=soft --with-gnu-as --with-gnu-ld --with-newlib --with-gxx-include-dir=$PREFIX/$TARGET/include --with-mpfr-lib=/usr/local/lib --with-gmp-lib=/usr/local/lib
где TARGET=arm-eabi (если в качестве цели выбрать arm-elf ошибка таже)
klen
сообщение Jan 27 2012, 07:44
бессмертным стать можно тремя способами
Пользователь №: 16 912
линкер Вам сообщает что объектники скомпилированы поддержкой инструкций FPU а слинковать образ вы пытаетесь без поддержки оной. Направление решение проблемы - в ключи линкера добавить аналогичные ключи относящиеся к FPU которые проталкиваются при компиляции. По сути линкер в такой ситуации незнает какой набор библиотек линковать с объектниками.
Impossibility
сообщение Jan 30 2012, 05:36
Не могли бы Вы мне еще немного пояснить ситуацию?
Какие ключи, используемые при компиляции, имеются ввиду? Те, что задаются в Makefile при сборке ядра, или те, с кторыми я собирал сам кросс-компилятор (--without-fp --with-softfloat-support=internal, например) ?
И если первый вариант, то ключи к запуску линкера также в Makefile надо добавлять?
Сообщение отредактировал Impossibility - Jan 30 2012, 05:37
klen
сообщение Jan 30 2012, 11:29
чтобы все было бы понятно приведите ключи компиляции с которыми компилируется файл arch/arm/boot/compressed/misc.o
и ключи с которыми линкуется arch/arm/boot/compressed/vmlinux
у меня подозрение что они отличаются в плане использования fpu. отсюда не видно - надо больше информации
полный лог с ключами достигается компиляцие или ликовковкой с дополнительным ключем -v
Impossibility
сообщение Feb 1 2012, 06:15
Ядро собралось... Смешно сказать, но все заработало после выставления параметра CONFIG_AEABI=y в Kernel Features. Что называется - не надо лезть в дебри, надо проверить не дурак ли ты...
klen, хотелось бы все же поднабраться опыта, если Вы, конечно, не против. Не понял куда надо добавить этот самый ключ -v sad.gif Я сделал вот что: в Makefile в строках
# Make variables (CC, etc...)
AS = $(CROSS_COMPILE)as
LD = $(CROSS_COMPILE)ld -v
CC = $(CROSS_COMPILE)gcc -v
Добавил ключ -v (выделено жирным). После запуска процесса сборки стала вроде вываливаться отладочная информация, но команда grep на нее не реагирует...
Я что-то опять не так делаю?
Сообщение отредактировал Impossibility - Feb 1 2012, 06:16
andrew_b
сообщение Feb 1 2012, 07:47
Из: Воронеж
Пользователь №: 1 757
Что именно вы делаете? Выхлоп gcc идёт в stderr, а если вы делаете что-то типа gcc -v | grep , то пайп подключен к stdout, и перенаправлять инфу нужно туда. Попробуйте что-то типа
gcc -v 2>&1 | grep
Impossibility
сообщение Feb 2 2012, 06:28
andrew_b, спасибо, с помощью Вас закрылась еще одна дырка в моей головеsm.gif
А по теме, если кому-то интересно...
Получил логи компиляции и линковки ядра, оказалось, что все дело в ключе -mabi. Он у меня в работающем варианте вот такой: -mabi=aapcs-linux.
Правда я еще не нашел, что же это за магическое сочитание букв - "aapcs-linux", но думаю гугл тут рано или поздно поможетsm.gif
Сообщение отредактировал Impossibility - Feb 2 2012, 06:28
xor.kruger
сообщение Feb 9 2012, 10:54
Из: Чернигов
Пользователь №: 39 647
2 Impossibility:
А каким кросс-компилятором вы пользовались?
Обычно при использовании CodeSourcery или Buildroot'овского КК никаких подобных проблем не возникает.
RSS Текстовая версия Сейчас: 27th August 2025 - 10:58
Страница сгенерированна за 0.02193 секунд с 7
