SIM18 не могу запустить |
Jan 27 2012, 10:09
Из: Днепр
Пользователь №: 7 988
C какой версией прошивки модуль? Если можно фото стикера. Для тестовой и серийных партий разный алгоритм включения.
Для серийных модулей так:
4.1.2 Starting SIM18 For initial power up, the RTC must start oscillating to sequence the Finite State Machine. RTC startup time may vary.
When power is first applied, SIM18 goes into a low-power mode while RTC starts and FSM sequences though to ”ready-to-start” state.
The host is not required to control nRESET pin since SIM18 internal reset circuitry handles detection of application of power.
While in ”ready-to-start” state, SIM18 awaits a pulse to the ON_OFF input pin to start.
Since RTC startup time varies, detection of the time when SIM18 is ready to accept an ON_OFF pulse requires the host to either wait for a fixed interval, to monitor a pulse on SIM18 WAKEUP output that indicates FSM ”ready-to-start”, or simply to assert a pulse on the ON_OFF input every second until SIM18 starts by indicating a high on WAKEUP or generation of host port messages.
4.1.3 Verification of SIM18 Start
SIM18 WAKEUP pin will go high to indicate the internal processor is started.
System activity indication depends upon the chosen serial interface:
UART with no flow control: When it is activated, SIM18 will output messages at the selected UART speed and message types.
UART with flow control: Host flow control must be released to allow SIM18 to send messages.
I2C multi-master mode with no bus contention: SIM18 will spontaneously send messages at the speed and message types selected.
I2C multi-master mode with bus contention: SIM18 will send messages after the I2C bus contention resolution process allows SIM18 to send.
SPI: Since SIM18’s SPI is slave, there is no possible indication of system ”ready” through SPI interface. The host must initiate SPI connection approximately one second after WAKEUP goes high.
Jan 27 2012, 10:10
Из: Украина. Черкассы
Пользователь №: 49
Добрый день!
Импульс там присутствует. Но если у Вас по какой-то причине не получается его отследить, то можно подождать секунд 5 и подавать импульс включения. После включения на WAKE станет высокий уровень.
Jan 27 2012, 10:50
Пользователь №: 47 838
Понял, буду дальше искать ипульс. Добавил фотку sim18 это тестовый или релизный?
Jan 27 2012, 11:05
Из: Днепр
It is ture, for old SIM18 version, ON_OFF pin is used to let module enter full on mode, and nRESET pin is used to let module sleep . But for new SIM18 module, the ON_OFF pin can be used to let module both into full on and sleep mode by interrupt. The ON_OFF interrupt is generated by rising edge of a low-high-low pulse, which should be longer than 90us and less than 1s (suggestion is about. 100ms pulse length). Do not generate ON_OFF interrupts less than 1 sec intervals. Especially take care that any multiple switch bounce pulses are filtered out.
See red number from below picture of lable on top of module. . 01 is old one, from 02 it is new version.
Те что у нас серийные выглядят так как на втором рисунке.
Jan 31 2012, 12:06
Добрый день еинт не подключен.
Сообщение отредактировал zebrox - Jan 31 2012, 12:31
Jan 31 2012, 13:42
CADiLO, у нас с Вами небольшое недопонимание, на сколько я понял.
У меня проблема в том, что ZDA сообщение, содержащее время и дату выходит из модуля с пустыми параметрами когда модуль не видит спутников. Т.е.
Включили модуль, он обнаружил спутники, в сообщении ZDA время пошло, все ок.
Отлючаем антенну, координат нет, ок. ZDA сообщение продолжает идти, но уже пустое одни запятые.
Подключаем антенну, появляется время и координаты.
Вопрос в том, почему при проадании спутников, модуль не выдает дату и время, если перед этим, он их получил.
С питанием я согласен, обязательно попробую поменятя стабилизатор.
Mar 10 2012, 19:06
Пользователь №: 70 716
Добрый день. Подскажите как быть? Модуль шлет все время вот эти данные, спутники не видит вообще. Код $GPRMC,,*4B $GPGGA,,,,0,00,,,M,0.0,M,,0000*48 $GPGSA,*6E $GPRMC,,*4B Поставили прогу SIRFLive переключаю в BINARY mode, через пару минут находит время, спутники всеравно нет. Антенны пробовали разные, сейчас с GPS навигатора автомобильного выпаяна.. Просадок по питанию нет, смотрели осцилографом, схема подключения взята из даташита. Куда копать уже пару дней не можем понять?? Модуль другого производителя подключается в течении двух минут..
