> SIM900R - изменения и дополнения.
CADiLO
сообщение Apr 10 2012, 09:11
Из: Днепр
Пользователь №: 7 988
Вышла новая версия фирмваре для модуля SIM900R. B04
Самым главным нововведением является то что модуль начиная с этой версии не будет иметь залочки по странам
и сможет работать с операторами любой страны. При этом цена модуля будет оставлена на прежнем уровне.
Запрос на обновление прошивки направляем почтой региональным дистрибьюторам.
Ну и список прочих изменений в новой версии:
[New Features]
1.
Added "AT+CWHITELIST" command to support white list function, only the number from the list is allowed to access, other numbers will be rejected directly without incoming call ring and any hints. It can set 30 numbers at most.
2.
Added "AT+CNETLIGHT" command to close/open network light. "0" means close, "1" means open.
3.
Added a new command "AT+SRSPT" to reduce the response time of SMS. It can be set as 0 or 1. The default value is 0 which means not to enable this function. "1" means enable this function.
4.
Added three parameters of "AT+CIPCCFG" command: (Rxmode:0,1),(RxSize:50-1460),(Rxtimer:20-1000). If "Rxmode" is set to 1, the function is enabled that the data received from network in transparent mode will be partitioned into small blocks then sent to serial port by time sharing processing.
[Improved Features]
1.
Further improved the command "AT+CIPTXISS=1" to prevent the response of AT command mix in TCP data.
2.
Under the condition that the module is in sleep mode and the RF is closed, the module will enter into super sleep mode, the net-light will be turned off for decreasing the decreasing the current consumption until the module exit the super sleep mode.
3.
Modified some URC errors of CSD call in MUX mode.
4.
Solved the problem that the module would reset if user input "AT+COPS=?" command continuously in some special case.
5.
Solved the problem that the voltage of 1.8v SIM card is still 3v after operating "AT+CFUN=1" operation in some special cases.
6.
Changed the initial return value of "*CELLLOCK" reading command from 255 to 0.
7.
Solved the problem that no response would return from serial port when SHUTDOWN the TCP/UDP connection immediately after it was established.
8.
Optimized the command "AT+EXUNSOL="UR",1".
9.
Solved the problem that plugging out the antenna may cause false reports of jamming detection.
10.
Solved the problem if the module was reset by key depression, the information "SIM PUK2 required" will be shown when unlocking the pin after "AT+CFUN=1" operation.
11.
Solved the problem of Ukrainian customer: Set up a call connection between module and mobile phone, and the mobile phone was set to call hold, then it reconnect this call, after which user cannot make the microphone of SIM900 mute by setting “AT+CMUT=1".
12.
Solved the problem that MIDI interval was not precise.
13.
Extend the function of "AT+CLDTMF" command that user can generate square-wave by setting an extra optional parameter which is newly added to the end of the command.
14.
Solved the problem that SMS process could not exit if the module enters into transparent mode during its editing process, it would cause the serial port impassable.
andrewlekar
сообщение Apr 11 2012, 04:47
Пользователь №: 25 163
CADiLO
сообщение Apr 11 2012, 05:34
Из: Днепр
На те же хрена что залочили некоторые модели и Телит с Синтерионом.....
Теперь есть изменения в ситуации, дополнительные поборы оплачены, можно модуль и в Европу выпускать.....
RSS Текстовая версия Сейчас: 29th August 2025 - 03:31
Страница сгенерированна за 0.014 секунд с 7
