> Matlab+CodeComposer, Что-то не получается ни как....
Alex-GTU
сообщение Jun 14 2012, 03:47
Пользователь №: 5 318
Пытаюсь простенький проект, сделанный в Матлабе загрузить через КодеКомпозер в СтартерКит на исполнение. Прописал настройки в XMakefile.При выполнении команд Тулс-Код Ген-БилдМодел :
The build failed with the following message: "C:/Program Files/Texas Instruments/ccsv4/tools/compiler/c2000/bin/cl2000.exe" -I"C:\Program Files\MATLAB\R2012a\toolbox\idelink\extensions\ticcs\inc" -I"D:\TimerCheck\TimerCheck_ticcs" -I"D:\TimerCheck" -I"C:\Program Files\MATLAB\R2012a\extern\include" -I"C:\Program Files\MATLAB\R2012a\simulink\include" -I"C:\Program Files\MATLAB\R2012a\rtw\c\src" -I"C:\Program Files\MATLAB\R2012a\rtw\c\src\ext_mode\common" -I"C:\Program Files\MATLAB\R2012a\rtw\c\ert" -D"__TICCSC__" -D"RT" -D"USE_RTMODEL" -ml -v28 --float_support=fpu32 -D"MODEL=TimerCheck" -D"NUMST=1" -D"NCSTATES=0" -D"HAVESTDIO=" -D"ONESTEPFCN=1" -D"TERMFCN=1" -D"MAT_FILE=0" -D"MULTI_INSTANCE_CODE=0" -D"INTEGER_CODE=0" -D"MT=0" -D"TID01EQ=0" -I"C:\Program Files\Texas Instruments\ccsv4\tools\compiler\c2000\include" -fr"./derived/" ./DSP2833x_ADC_cal.asm ./DSP2833x_CodeStartBranch.asm ./DSP2833x_CpuTimers.c ./DSP2833x_DMA.c ./DSP2833x_DefaultIsr.c ./DSP2833x_GlobalVariableDefs.c ./DSP2833x_MemCopy.c ./DSP2833x_PieCtrl.c ./DSP2833x_PieVect.c ./DSP2833x_SysCtrl.c ./DSP2833x_usDelay.asm ./MW_c28xx_board.c ./MW_c28xx_csl.c ./TimerCheck.c ./TimerCheck_data.c ./TimerCheck_main.c
[DSP2833x_ADC_cal.asm]
[DSP2833x_CodeStartBranch.asm]
[DSP2833x_CpuTimers.c]
[DSP2833x_DMA.c]
[DSP2833x_DefaultIsr.c]
[DSP2833x_GlobalVariableDefs.c]
[DSP2833x_MemCopy.c]
[DSP2833x_PieCtrl.c]
[DSP2833x_PieVect.c]
[DSP2833x_SysCtrl.c]
[DSP2833x_usDelay.asm]
[MW_c28xx_board.c]
[MW_c28xx_csl.c]
[TimerCheck.c]
[TimerCheck_data.c]
[TimerCheck_main.c]
"C:/Program Files/Texas Instruments/ccsv4/tools/compiler/c2000/bin/lnk2000.exe" -z -l"rts2800_fpu32.lib" -c -x -m"TimerCheck.map" -stack0x200 -o ./CustomMW/TimerCheck.out ./derived/DSP2833x_ADC_cal.obj ./derived/DSP2833x_CodeStartBranch.obj ./derived/DSP2833x_CpuTimers.obj ./derived/DSP2833x_DMA.obj ./derived/DSP2833x_DefaultIsr.obj ./derived/DSP2833x_GlobalVariableDefs.obj ./derived/DSP2833x_MemCopy.obj ./derived/DSP2833x_PieCtrl.obj ./derived/DSP2833x_PieVect.obj ./derived/DSP2833x_SysCtrl.obj ./derived/DSP2833x_usDelay.obj ./derived/MW_c28xx_board.obj ./derived/MW_c28xx_csl.obj ./derived/TimerCheck.obj ./derived/TimerCheck_data.obj ./derived/TimerCheck_main.obj ./TimerCheck.cmd C:/PROGRA~1/MATLAB/R2012a/toolbox/idelink/EXTENS~1/ticcs/rtlib/IQMATH~1.LIB
fatal error: invalid option: -z
gmake: *** [CustomMW/TimerCheck.out] Error 1
??????????????? А чего не хватает?
В дебрях коры, в мозговой глубине, стремные мысли пригрезились мне.
RSS Текстовая версия Сейчас: 27th July 2025 - 08:18
Страница сгенерированна за 0.01343 секунд с 7
