> запись во флеш/чтение на atxmega32d4, +IAR
addi
сообщение Oct 20 2012, 13:36
Пользователь №: 19 422
Здравствуйте
Пытаюсь использовать код от Атмела под ИАР для записи/чения флеш памяти
К сожалению чтото не выходит на этапе загрузчи буфера все виснет
Вот мой код
#include "sp_driver.h"
/* Temporary storage used for NVM-workaround. */
uint8_t sleepCtr;
uint8_t statusStore;
uint8_t pmicStore;
uint8_t globalInt;
uint8_t spmintStore;
unsigned short y;
#pragma vector =  NVM_SPM_vect
__interrupt void NVM_SPM_vectint(void)
    /* Disable the SPM interrupt */
    NVM.INTCTRL = (NVM.INTCTRL & ~NVM_SPMLVL_gm);
    /* Restore sleep settings */
    SLEEP.CTRL = sleepCtr;
    /* Restore PMIC status and control registers */
    PMIC.STATUS = statusStore;
    PMIC.CTRL = pmicStore;
    /* Restore SPM interruptsettings */
    NVM.INTCTRL = spmintStore;
    /* Restore global interrupt settings */
    SREG = globalInt;
    return;
/* Set interrupt vector location to boot section of flash */
void PMIC_SetVectorLocationToBoot( void )
    uint8_t temp = PMIC.CTRL | PMIC_IVSEL_bm;
    CCP = CCP_IOREG_gc;
    PMIC.CTRL = temp;
/*Set interrupt vector location to application section of flash */
void PMIC_SetVectorLocationToApplication( void )
    uint8_t temp = PMIC.CTRL & ~PMIC_IVSEL_bm;
    CCP = CCP_IOREG_gc;
    PMIC.CTRL = temp;
/* Save register settings before entering sleep mode */
void Prepare_to_Sleep( void )
    sleepCtr = SLEEP.CTRL;
    /* Set sleep mode to IDLE */
    SLEEP.CTRL =  0x00;
    /* Save the PMIC Status and control registers */
    statusStore = PMIC.STATUS;
    pmicStore = PMIC.CTRL;
    /* Enable only the highest level of interrupts */
    PMIC.CTRL = (PMIC.CTRL & ~(PMIC_MEDLVLEN_bm | PMIC_LOLVLEN_bm)) | PMIC_HILVLEN_bm;
    /* Save SREG for later use */
    globalInt = SREG;
    /* Enable global interrupts */
    sei();
    /* Save SPM interrupt settings for later */
    spmintStore = NVM.INTCTRL;
/* New function declarations used for the NVM-workaround */
void EraseApplicationPage(uint32_t address)
    /*Set the correct settings and store critical registers before NVM-workaround*/
    Prepare_to_Sleep();
    /*Assembly "function" to preform page erase*/
    SP_EraseApplicationPage(address);
void EraseWriteApplicationPage(uint32_t address)
    Prepare_to_Sleep();
    /*Assembly "function" to preform page erase-write*/
    SP_EraseWriteApplicationPage(address);
void ClearFlashBuffer(void)
    Prepare_to_Sleep();
    /*Assembly "function" to erase flash buffer*/
    SP_EraseFlashBuffer();
void LoadFlashWord(uint32_t address, uint16_t word)
    Prepare_to_Sleep();
    /*Assembly "function" to load flash buffer*/
       SP_LoadFlashWord(address, word);
void main()
  __enable_interrupt();
  PMIC_SetVectorLocationToBoot();
ClearFlashBuffer();
for(y=0;y<(128);y+=2)
  LoadFlashWord(y,0xAAAA);
  SP_WaitForSPM();
EraseWriteApplicationPage(16000);
if(SP_ReadByte(0x3E00)==0x55)
PORTD_OUT |= 0x40;
for(;;)
Прошу подсказать что не так кто уже пользовал иаровский код
Заранее благодарен
RSS Текстовая версия Сейчас: 30th July 2025 - 02:54
Страница сгенерированна за 0.01379 секунд с 7
