> Qemu :: Raspberry PI, выбрасывает после логина
_Pasha
сообщение Oct 30 2013, 21:12
Пользователь №: 29 509
Привет.
Кто игрался с сабжем?
CODE
pasha@Nbook248P:~/NewDesk/Raspbian$ qemu-system-arm -kernel kernel-qemu -cpu arm1176 -m 256 -M versatilepb -no-reboot -serial stdio -append "root=/dev/sda2 panic=1" -hda 2013-09-25-wheezy-raspbian.img
/usr/bin/pulseaudio: error while loading shared libraries: libpulsecommon-1.1.so: cannot open shared object file: No such file or directory
pulseaudio: pa_context_connect() failed
pulseaudio: Reason: Connection refused
pulseaudio: Failed to initialize PA contextaudio: Could not init `pa' audio driver
Uncompressing Linux... done, booting the kernel.
pflash_write: Unimplemented flash cmd sequence (offset 0000000000000000, wcycle 0x0 cmd 0x0 value 0xf000f0)
pflash_write: Unimplemented flash cmd sequence (offset 0000000000000000, wcycle 0x0 cmd 0x0 value 0xf0)
Raspbian GNU/Linux 7 (none) ttyAMA0
(none) login: pi
Password:
Linux (none) 3.2.0 #1 Sun Jan 29 03:14:15 CST 2012 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
NOTICE: the software on this Raspberry Pi has not been fully configured. Please run 'sudo raspi-config'
(none) login:
и всё! shell не запускается "искаропки". Что делать?
RSS Текстовая версия Сейчас: 28th August 2025 - 22:31
Страница сгенерированна за 0.01344 секунд с 7
