> ICCAVR 6.31 vs ICCAVR 7.22С, Компилируется в ICCAVR 6.31 не компилируется в ICCAVR 7.22С
Artym
сообщение Apr 18 2014, 06:45
Из: 48°00'N 37°48'E
Пользователь №: 636
Добрый день!
Проект который прекрасно компилируется в ICCAVR 6.31 не компилируется в ICCAVR 7.22С
Вылетает:
CODE
C:\iccv7avr\bin\imakew -f BI_TP.mak
    iccavr -c -e -D__ICC_VERSION=722 -D__BUILD=0 -DATMega128  -l -g -MLongJump -MHasMul -MEnhanced -Wf-use_elpm  System.c
    iccavr -c -e -D__ICC_VERSION=722 -D__BUILD=0 -DATMega128  -l -g -MLongJump -MHasMul -MEnhanced -Wf-use_elpm  display.c
    iccavr -c -e -D__ICC_VERSION=722 -D__BUILD=0 -DATMega128  -l -g -MLongJump -MHasMul -MEnhanced -Wf-use_elpm  IntHandle.c
!W D:\Tp_slave\IntHandle.c(11):[warning] old-style function definition for `T1Hnd'
!W D:\Tp_slave\IntHandle.c(16):[warning] old-style function definition for `T3Hnd'
!W D:\Tp_slave\IntHandle.c(22):[warning] old-style function definition for `RxcHnd'
!W D:\Tp_slave\IntHandle.c(27):[warning] old-style function definition for `TxcHnd'
    iccavr -c -e -D__ICC_VERSION=722 -D__BUILD=0 -DATMega128  -l -g -MLongJump -MHasMul -MEnhanced -Wf-use_elpm  keyboard.c
    iccavr -c -e -D__ICC_VERSION=722 -D__BUILD=0 -DATMega128  -l -g -MLongJump -MHasMul -MEnhanced -Wf-use_elpm  Timers.c
    iccavr -c -e -D__ICC_VERSION=722 -D__BUILD=0 -DATMega128  -l -g -MLongJump -MHasMul -MEnhanced -Wf-use_elpm  UART.c
    iccavr -c -e -D__ICC_VERSION=722 -D__BUILD=0 -DATMega128  -l -g -MLongJump -MHasMul -MEnhanced -Wf-use_elpm  BI06.c
    iccavr -o BI_TP -g -nb:0 -e:0x20000 -ucrtatmega.o -bfunc_lit:0x8c.0x20000 -dram_end:0x10ff -bdata:0x100.0x10ff -dhwstk_size:16 -beeprom:0.4096 -fcoff -S2 @BI_TP.lk   -lcatm128
  ROM 3% full. 4446 out of 131072 bytes used.
  RAM 633 bytes used (does not include stack usage).
can't open input file BI_TP.hex
C:\iccv7avr\bin\imakew.exe: Error code 1
Done: there are error(s). Exit code: 1. Fri Apr 18 08:53:57 2014
Переопределил функции
Warning-и перестали вылазить. Но ошибка вылазит все равно.
CODE
Done: there are error(s). Exit code: 1. Fri Apr 18 09:14:48 2014
В чем может быть проблема? Спасибо.
Прикрепленный файл  modbus_slave.zip ( 13.95 килобайт ) Кол-во скачиваний: 10
RSS Текстовая версия Сейчас: 30th August 2025 - 06:24
Страница сгенерированна за 0.01332 секунд с 7
