> IAR выдает предупреждение о стеке при загрузке J-Link ARM, Stack pointer is setup to incorrect alignment. Stack addr = 0x030000B9
M0HAX
сообщение Nov 28 2014, 12:41
Пользователь №: 40 378
Имеется iar 7.20. Взял пример для Cortex LPC1549 из iar 7.30. Загрузил проект в iar 7.20. Отладчик J-Link ARM v8 (версия драйвера v4.94g). В проекте указал, что отладчиком явлется J-Link. При загрузке выдается предупреждение
Driver
Warning: Stack pointer is setup to incorrect alignment. Stack addr = 0x030000B9
ОК
При этом подцеплен правильный icf-файл для LPC1549
/*###ICF### Section handled by ICF editor, don't touch! ****/
/*-Editor annotation file-*/
/* IcfEditorFile="$TOOLKIT_DIR$\config\ide\IcfEditor\cortex_v1_0.xml" */
/*-Specials-*/
define symbol __ICFEDIT_intvec_start__ = 0x00000000;
/*-Memory Regions-*/
define symbol __ICFEDIT_region_ROM_start__   = 0x00000000;
define symbol __ICFEDIT_region_ROM_end__     = 0x0003FFFF;
define symbol __ICFEDIT_region_RAM_start__   = 0x02000000;
define symbol __ICFEDIT_region_RAM_end__     = 0x02008FDF;
/*-Sizes-*/
define symbol __ICFEDIT_size_cstack__   = 0x1000;
define symbol __ICFEDIT_size_heap__     = 0x2000;
/**** End of ICF editor section. ###ICF###*/
define symbol __CRP_start__   = 0x000002FC;
define symbol __CRP_end__     = 0x000002FF;
define memory mem with size = 4G;
define region ROM_region   = mem:[from __ICFEDIT_region_ROM_start__   to __ICFEDIT_region_ROM_end__] -  mem:[from  __CRP_start__ to __CRP_end__];
define region RAM_region   = mem:[from __ICFEDIT_region_RAM_start__   to __ICFEDIT_region_RAM_end__];
define region CRP_region   = mem:[from  __CRP_start__ to __CRP_end__];
define block CSTACK    with alignment = 8, size = __ICFEDIT_size_cstack__   { };
define block HEAP      with alignment = 8, size = __ICFEDIT_size_heap__     { };
initialize by copy { readwrite };
do not initialize  { section .noinit };
place at address mem:__ICFEDIT_intvec_start__ { readonly section .intvec };
place in ROM_region   { readonly };
place in RAM_region   { readwrite,
                        block CSTACK, block HEAP };
place in CRP_region      { section .crp };
Т.е. CSTACK находится в диапазоне адресов [0x02000000 - 0x02008FDF]. А при загрузке вдруг SP получает значение 0x030000B9, а диапазон адресов [0x03000000 - 0x03008000] принадлежит 32kB boot
ROM согласно даташиту.
Отладчик затем догружается, но указатель отладчика встает на некий адрес программы и стоит там, не реагируя на пошаговые инструкции.
В чем может быть дело? До этого работал с АРМ7 и iar 5.41, там немного по-другому, а тут столкнулся с этой проблемой. FLASH проца до этого стирал с помощью отдельного запуска j-link.
RSS Текстовая версия Сейчас: 9th August 2025 - 09:50
Страница сгенерированна за 0.0135 секунд с 7
