Сначала пытал счастье на англоязычном GnuRadio форуме, но пока ответов не получал:
Hi, i work on software T2 decoder. Now decoder can detect and demodulate P1 symbol, and estimate sample rate and carrier offset mostly correctly on gaussian noise channel. (P1 Detection impemented like in "DVB-T2 Implementation Guide", robust estemation goes by correlation beetween two FFT1K parts of P1, (sliced part shifted by 1 sample before correlation whith middle FFT1K part, then S1, S2 indicators detected wihth frequency loop, by minimal hamming distance, beetween received data, and known patterns, after S1 S2 decoded, fine offset estimation performed by comparing phase offsets beetween 2 carriers of recieved, and generated P1 parts). Guard interval detection already works too. I stoped after L1PRE demodulation, my decoder use only BCH, bypassing LDPC step, (cause LDPC/BCH coding in T2 is systematic) It works normaly with syntezited DVB-T2 signals. But not with real world signals. I have a DIY SDR receiver whith quite poor SNR (but it can receive DVB-T 16QAM 3/2 8Mhz from test generator with antennas - in our air is only T2). I try to capture T2 signal from air, but decoder show only S1 S2 (0 10 in my area), but offset estemated incorrectly.
So can anyboby share DVB-T2 samples (1 sec is enough) ??
Thanks !.
Кто может оцифровать кусочек DVB-T2 ? очень надеюсь на вашу помощь --------- Виктор
