> Проблема с прошивкой fuse-bit в ATmega32U4, avrdude
Doka
сообщение Feb 9 2016, 12:15
Electrical Engineer
Группа: СуперМодераторы
Пользователь №: 778
возникла проблема с atmega32u4 (китайский клон Arduino Pro Micro) - прошивается всё, кроме фьюзов:
sudo /usr/bin/avrdude -C /etc/avrdude/avrdude.conf -p atmega32u4 -c avr109 -P /dev/ttyACM0 -b 19200 -U lfuse:w:0x90:m -U hfuse:w:0xd9:m
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
    Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
    Device code: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587
avrdude: reading input file "0x90"
avrdude: writing lfuse (1 bytes):
Writing |                                                    | 0% 0.00s ***failed;
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0x90:
avrdude: load data lfuse data from input file 0x90:
avrdude: input file 0x90 contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0x90 != 0xff
avrdude: verification error; content mismatch
avrdude: safemode: lfuse changed! Was 90, and is now ff
Would you like this fuse to be changed back? [y/n]
все секции memory присутствуют в /etc/avrdude/avrdude.conf и соответствуют даташиту
расширенная диагностика при чтении фьюзов:
sudo /usr/bin/avrdude -C /etc/avrdude/avrdude.conf -p atmega32u4 -c avr109 -P /dev/ttyACM0 -b 19200 -U lfuse:r:-:i -U hfuse:r:-:i -v
avrdude: Version 5.10, compiled on Oct 22 2010 at 08:16:12
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/etc/avrdude/avrdude.conf"
         User configuration file is "/root/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyACM0
         Using Programmer              : avr109
         avr910_devcode (avrdude.conf) : none
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       1024    8      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : avr910
         Description     : Atmel AppNote AVR109 Boot Loader
    Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: safemode: lfuse reads as FF
avrdude: safemode: hfuse reads as D8
avrdude: safemode: efuse reads as CB
avrdude: reading lfuse memory:
avrdude: writing output file "<stdout>"
0xff
avrdude: reading hfuse memory:
0xd8
avrdude: reading lock memory:
0xef
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
any ideas?
smalcom
сообщение Feb 9 2016, 18:03
Пользователь №: 28 718
проверьте качество питания МК. Бывает фантомной запитки хватает при потоке данных, а вот с фьюзами начинаются проблемы.
Doka
сообщение Feb 9 2016, 21:28
Electrical Engineer
Пользователь №: 778
проверил - эффекта не дало.
PS: на Arduino Pro Micro стоят танталы на 10мкФ до и после LDO + керамика
пробовал подключать коротким качественным кабелем microUSB (20cm) на заднюю панель.
Блог iDoka.ru
CV linkedin.com/in/iDoka
Sources github.com/iDoka
Never stop thinking...........................
smalcom
сообщение Feb 9 2016, 22:15
плохо вижу или вы не указали "-e". Попробуйте этот ключ.
Doka
сообщение Feb 10 2016, 16:51
Electrical Engineer
Пользователь №: 778
$ sudo /usr/bin/avrdude -C /etc/avrdude/avrdude.conf -p atmega32u4 -c avr109 -P /dev/ttyACM0 -b 19200 -e
    Device code: 0x44
avrdude: erasing chip
$ sudo /usr/bin/avrdude -C /etc/avrdude/avrdude.conf -p atmega32u4 -c avr109 -P /dev/ttyACM0 -b 19200 -e -U lfuse:w:0x90:m -U hfuse:w:0xd9:m
    Device code: 0x44
         0x90 != 0xff
Блог iDoka.ru
smalcom
сообщение Feb 10 2016, 20:38
Ну у меня последняя идея - притормозить всё как следует
$ sudo /usr/bin/avrdude -C /etc/avrdude/avrdude.conf -p atmega32u4 -c avr109 -i 1000 -B 1000 -P /dev/ttyACM0 -b 19200 -e -U lfuse:w:0x90:m -U hfuse:w:0xd9:m
Эммм, а avr109 - это вы не системный загрузчик(SPI) используете, а свой? Может в этом проблема?
Doka
сообщение Feb 11 2016, 06:21
Electrical Engineer
Пользователь №: 778
да, шью встроенным бутлодером. он не умеет прошивать фьюзы?
могу для чистоты эксперимента попробовать avrisp, но надо будет подпаяться.
Блог iDoka.ru
smalcom
сообщение Feb 11 2016, 06:25
если честно, то не в курсе. всегда ISP использовал.
Doka
сообщение Feb 12 2016, 15:45
Electrical Engineer
Пользователь №: 778
не очень помогло притормозить((
$ sudo /usr/local/bin/avrdude -C /etc/avrdude/avrdude.conf -p atmega32u4 -c avr109 -P /dev/ttyACM0 -i 1000 -B 1000 -b 9600 -U lfuse:w:0x90:m -U hfuse:w:0xd9:m
    Device code: 0x44
avrdude: Device signature = 0x1e9587 (probably m32u4)
         0xff != 0x90
Блог iDoka.ru
smalcom
сообщение Feb 12 2016, 15:56
Что-то я совсем того... http://microsin.net/programming/AVR/avr109...rogramming.html
Этот загрузчик не умеет записывать fuse-биты. По простой причине: программа МК не имеет никакой возможности менять fuse-биты. Собственно от них[fuses] зависит её[программы] работа )))
Alternatively,
the Boot Reset Fuse can be programmed so that the Reset Vector is pointing to the Boot Flash
start address after a reset. In this case, the Boot Loader is started after a reset. After the applica-
tion code is loaded, the program can start executing the application code. [b]Note that the fuses
cannot be changed by the MCU itself.[/b] This means that once the Boot Reset Fuse is pro-
grammed, the Reset Vector will always point to the Boot Loader Reset and the fuse can only be
changed through the serial or parallel programming interface.
Doka
сообщение Feb 14 2016, 20:20
Electrical Engineer
Пользователь №: 778
однако успех через внешний прошивальщик. какая-то загадка со встроенным..
avrdude -p atmega32u4 -c arduino-ft232r -P ft0 -U lfuse:w:0x90:m -U hfuse:w:0xd9:m
Reading | ################################################## | 100% 0.01s
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0xd9"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xd9:
avrdude: load data hfuse data from input file 0xd9:
avrdude: input file 0xd9 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: safemode: Fuses OK (E:CB, H:D9, L:90)
нда.. рано радовался.. теперь выдает такое после первой перешивки фьюзов:
avrdude -F -p atmega32u4 -c arduino-ft232r -P ft0 -U lfuse:w:0x90:m -U hfuse:w:0xd9:m
avrdude: Device is not responding to program enable. Check connection.
avrdude: initialization failed, rc=-1
avrdude: Device signature = 0xe80ed1
avrdude: Expected signature for ATmega32U4 is 1E 95 87
не понимаю - как вообще Device signature могла смениться??
Блог iDoka.ru
smalcom
сообщение Feb 14 2016, 21:02
встроенный - это тот, который SPI использует.
сигнатура не менялась. просто МК не отвечает.
Там фьюзами случайно SPI не был выключен?
Ещё может быть установлен тип генератора не тот.
Doka
сообщение Feb 15 2016, 21:04
Electrical Engineer
Пользователь №: 778
разобрался в чем накосячил - выключил кварцевый генератор - настроил на внешний клок, вот он и затих...
теперь вот какая непонятка: не могу снять защиту с бутсектора.
фьюз LOCK=0x2F а я хочу туда залить 0xFF - как?
$ sudo avrdude -p atmega32u4 -c usbasp  -U lock:w:0xFF:m
avrdude: reading input file "0xFF"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.06s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0xFF:
avrdude: load data lock data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lock data:
         0x2f != 0xff
avrdude: safemode: Fuses OK (E:CB, H:D9, L:BF)
остальные фьюзы прошились как мне надо
Блог iDoka.ru
RSS Текстовая версия Сейчас: 30th August 2025 - 19:36
Страница сгенерированна за 0.02911 секунд с 7
