> Проблема с Synopsys, vcs
drozel
сообщение Jan 19 2016, 08:27
Пользователь №: 62 650
Пытаюсь скомпилировать исходник для симуляции:
vcs ../src/module.v -sverilog  -full64 +v2k -debug_all
drozel@PC:/media/sf_shareFolder/work/verilog/sim> /vcs ../src/module.v -sverilog  -full64 +v2k -debug_all
Warning-[LNX_OS_VERUN] Unsupported Linux version
  Linux version 'openSUSE 42.1 (x86_64)
  VERSION = 42.1
  CODENAME = Malachite
  # /etc/SuSE-release is deprecated and will be removed in the future, use
  /etc/os-release instead' is not supported on 'x86_64' officially, assuming
  linux compatibility by default. Set VCS_ARCH_OVERRIDE to linux or suse32 to
  override.
  Please refer to release notes for information on supported platforms.
Warning-[LINX_KRNL] Unsupported Linux kernel
  Linux kernel '4.1.13-5-default' is not supported.
  Supported versions are 2.4* or 2.6*.
                         Chronologic VCS (TM)
         Version G-2012.09_Full64 -- Tue Jan 19 14:06:20 2016
               Copyright (c) 1991-2012 by Synopsys Inc.
                         ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
Parsing design file '../src/module.v'
Top Level Modules:
       module
No TimeScale specified
Starting vcs inline pass...
2 modules and 0 UDP read.
    However, due to incremental compilation, no re-compilation is necessary.
Assertion failed "rename(tmp_file, out_file) == 0" at line 833 in file cgmop.c
Command line: /soft/vcs/amd64/bin/cgmop1 -pic -gen_obj rmapats.m rmapats_mop.o
--- Stack trace follows:
sh: 26924: command not found
No context available
filelist.hsopt:2: recipe for target 'rmapats_mop.o' failed
make: *** [rmapats_mop.o] Error 255
Make exited with status 2
CPU time: .080 seconds to compile + 0 seconds to elab + .008 seconds to link
Кто знает, в чем может быть проблема?
OS: OpenSUSE 13.2 x64
Пробовал запускать и 32 и 64-битный vcs - ошибка одна
Сообщение отредактировал drozel - Jan 19 2016, 08:43
RSS Текстовая версия Сейчас: 23rd August 2025 - 14:51
Страница сгенерированна за 0.01371 секунд с 7
