> Проблема с Ring Buffer.
Jenya7
сообщение Aug 31 2016, 08:46
Пользователь №: 71 075
Я сделал такую реализацию.
CODE
typedef enum CycBuffState {cbsOk = 0, cbsOverwrite = 1, cbsBuffFull = 2, cbsBuffEmpty = 3, cbsError = 4} enCycBuffState;
typedef struct
uint32_t MaxBufSize,
HeadIdx,
TailIdx;
enCycBuffState State;
uint8_t *Buffer;
} stRingBuffer;
void RingBuf_Init (stRingBuffer *ring_buf, uint8_t *buf, uint32_t max_size)
ring_buf->Buffer = buf;
ring_buf->MaxBufSize = max_size;
ring_buf->HeadIdx = ring_buf->TailIdx = 0;
ring_buf->State = cbsBuffEmpty;
enCycBuffState RingBuf_PushByte(stRingBuffer *ring_buf, uint8_t val, uint8_t allow_overwrite)
if ((ring_buf->HeadIdx+1) == ring_buf->TailIdx)
if (!allow_overwrite)
return cbsBuffFull;
ring_buf->Buffer[ring_buf->HeadIdx] = val;
ring_buf->HeadIdx++;
if (ring_buf->HeadIdx >= ring_buf->MaxBufSize)
ring_buf->HeadIdx = 0;
return cbsOk;
enCycBuffState RingBuf_PushBytes(stRingBuffer *ring_buf, uint8_t len, uint8_t *buf, uint8_t allow_overwrite)
uint32_t free_space;
if (ring_buf->HeadIdx == ring_buf->TailIdx)
free_space = ring_buf->MaxBufSize;
else
if (ring_buf->HeadIdx >= ring_buf->TailIdx)
free_space = ring_buf->HeadIdx - ring_buf->TailIdx;
else
free_space = (ring_buf->MaxBufSize - ring_buf->TailIdx) + ring_buf->HeadIdx;
if (free_space < len)
return cbsBuffFull;
while (len)
RingBuf_PushByte(ring_buf, *buf, allow_overwrite);
buf++;
len--;
return cbsOk;
enCycBuffState RingBuf_PopByte(stRingBuffer *ring_buf, uint8_t *val)
return cbsError;
*val = ring_buf->Buffer[ring_buf->TailIdx];
ring_buf->Buffer[ring_buf->TailIdx] = 0;
ring_buf->TailIdx++;
if (ring_buf->TailIdx >= ring_buf->MaxBufSize)
return cbsOk;
enCycBuffState RingBuf_PopBytes(stRingBuffer *ring_buf, uint8_t len, uint8_t *val)
while (len)
RingBuf_PopByte(ring_buf, val);
val++;
len--;
return cbsOk;
И потом проверяю (в IAR, в симуляторе)
#include <string.h>
#include "ringbuf.h"
stRingBuffer ring_buf;
uint8_t *temp_buff;
uint8_t *test_buff = "Hello World";
uint8_t *read_buff;
int main()
  RingBuf_Init (&ring_buf, temp_buff, 32);
  while (1)
     RingBuf_PushBytes(&ring_buf, strlen(test_buff), test_buff, 0);
     RingBuf_PopBytes(&ring_buf, strlen(test_buff), read_buff);
Но несмотря на то что я отслеживаю наличие свободного места.
  else
     else
      return cbsBuffFull;
В отладчике я вижу перезапись буфера. Что я упустил?
Сообщение отредактировал Jenya7 - Aug 31 2016, 08:51
smalcom
сообщение Aug 31 2016, 09:17
Пользователь №: 28 718
Много чего, там и переполнение и... проще показать. Вот вам пример снизу, немного адаптировал из другой программы. Самая высокоуровневая функция - это Write.
CODE
uint32_t BufferFreeSize()
if(RdIdx > WrIdx)
return RdIdx - WrIdx;
else
return (BUFFER_SIZE - WrIdx) + RdIdx;
bool CheckOverEndIdx(uint32_t& pIdx)
if(pIdx > BUFFER_SIZE)
pIdx -= (BUFFER_SIZE - 1);
return true;
else
return false;
void PushBytes_Internal(const uint8_t* const pDataBlock, const uint16_t pBlockSize)
uint16_t bw = 0;// количество записанных байт
uint32_t TempWrIdx = WrIdx;// берём текущее значение индекса записи
Service::RetVal rv;
do
uint16_t btw;// количество байт, которые необходимо записать
CheckOverEndIdx(TempWrIdx);
if((TempWrIdx + pBlockSize - bw) > BUFFER_SIZE)
btw = BUFFER_SIZE - TempWrIdx + 1;
else
btw = pBlockSize - bw;
for(uint32_t idx = TempWrIdx, idx_end = idx + btw; idx < idx_end; idx++) BufferData[idx] = pDataBlock[bw++];
TempWrIdx += btw;
} while(bw < pBlockSize);
WrIdx = TempWrIdx;
bool Write(const uint8_t* const pDataBlock, const uint16_t pBlockSize)
if(pBlockSize > BUFFER_SIZE) return false;
if(BufferFreeSize() < (pBlockSize + 1))
RdIdx += pBlockSize;
CheckOverEndIdx(RdIdx);
// записываем блок данных
PushBytes_Internal(WrIdx, mNPQPack, pBlockSize, &WrIdx);
return false;
Jenya7
сообщение Aug 31 2016, 10:23
Но вы все таки разрешаете запись, освобождая место. А я думаю блокировать запись пока данные не будут считаны.
XVR
сообщение Aug 31 2016, 12:41
Из: Химки
Пользователь №: 26 847
uint8_t *temp_buff;
uint8_t *read_buff;
Ну и куда они в результате смотрят?
Сделайте так -
uint8_t temp_buff[32];
uint8_t read_buff[32];
Jenya7
сообщение Aug 31 2016, 14:13
Цитата(XVR @ Aug 31 2016, 18:41) *
uint8_t *temp_buff;
uint8_t *read_buff;
Сделайте так -
да. спасибо. указатели нужно конечно инициализировать.
smalcom
сообщение Aug 31 2016, 14:14
заменить на
if(BufferFreeSize() < (pBlockSize + 1)) return;
Jenya7
сообщение Aug 31 2016, 14:28
Цитата(smalcom @ Aug 31 2016, 20:14) *
заменить на
спасибо.
DASM
сообщение Aug 31 2016, 14:53
Пользователь №: 5 493
Чет мудреные какие-то реализации. Так не проще?
CODE
template <class T>
class RingBuf
public:
RingBuf (unsigned int size) : buf(new T[size]), head(0), sz_contains(0), SZ_MAX(size){};
~RingBuf() {
delete [] buf;
bool Pop (T &val)
if (sz_contains == 0)
return false;
else
val = buf[head++]; head %= SZ_MAX; sz_contains--;
return true;
bool Push (T val)
if (!GetFree())
return false;
else
buf[(head + sz_contains++) % SZ_MAX] = val;
return true;
bool Push (T val[] , unsigned int count)
if (count > GetFree())
return false;
for (unsigned int i = 0; i < count; i++)
Push(val[i]);
return true;
void Clear() {sz_contains = 0;}
unsigned int GetFree () {return SZ_MAX - sz_contains;}
private:
unsigned int sz_contains;
const unsigned int SZ_MAX;
T *buf;
unsigned int head;
Jenya7
сообщение Aug 31 2016, 15:05
Нет проверки влезет ли записываемый кусок в свободное место.
DASM
сообщение Aug 31 2016, 15:09
У меня поэлементый метод только накидал, счас блок сделаем
Вот
CODE
return false;
Push(val[i]);
return true;
Использование тривиально
CODE
const int SZ = 4;
RingBuf<int> r(SZ);
int ar[] = {1,2,3};
bool mres = r.Push(ar, sizeof(ar)/sizeof(ar[0])); // несколько элементов
printf ("push %s \n", mres ? "OK ": "FULL ");
r.Push(val); // один элемент
Pop для нескольких элементов - аналогично
smalcom
сообщение Aug 31 2016, 18:03
угроза переполнения "sz_contains".
DASM
сообщение Aug 31 2016, 18:12
Откуда ? После 2^32 push??
smalcom
сообщение Aug 31 2016, 19:24
После 2^32 push?
я так на волне паранойи и подумал. Но при внимательном рассмотрении - SZ_MAX имеет такой же тип, что и sz_contains.
brag
сообщение Sep 7 2016, 08:48
Из: Kyiv, Ukraine
Пользователь №: 23 046
Хм. Зачем все так сложно мудрить, если есть уже давно простейшая рабочая реализация прописанная в букварях по программированию, остается ее только портировать на свой язык.
При чем тут еще от задачи зависит. Если это SPSC, тогда вообще все просто и без блокировок. Если MPSC/MPMC/SPMC - нужны уже блокировки.
Приведу простейший пример SPSC, написан был мной лет 8 назад(то есть просто реализован на ц++ алгоритм из букваря) и очень часто используется по сей день везде(драйверы, очередя сообщений, итд итп)
CODE
template<class T, int Size> class Fifo_spsc{
public:
static_assert((Size&(Size-1)) == 0, "Size must be power of 2");
Fifo_spsc(){
rx = 0;
wx = 0;
// Producer
bool push(const T &v){
uint32_t w = (wx+1)&(Size-1);
if(w==rx)return false; //ERR_FIFO_FULL;
data[wx] = v;
__DMB(); // just a memory barrier - ensure data has been completely stored
wx = w; // make item available for reading
return true;
// Consumer
bool pop(T *v){
uint32_t r = rx;
if(r==wx)return false; //ERR_FIFO_EMPTY;
*v = data[r];
__DMB(); // ensure data has been completely loaded
rx = (r+1)&(Size-1); // make item available for writing
return true;
// Consumer
void flush(){
__DMB();
rx = wx;
protected:
uint16_t rx, wx;
T data[Size];
Памяти занимает - собственно сами данные + 2 16-битных слова.
Хоть и c++, что позволяет использовать этот буфер для любых типов - как простого uint_8t, так и для сложных обьектов. Это базовая реализация для практически всех других более сложных очередей.
Один элемент всегда пустой - это делает код гораздо проще и быстрее, и как ни странно зачастую - меньше требовательным к памяти sm.gif
Также, если у нас строго один писатель и один читатель, то можно сделать и чтение не по одному элементу, а сразу массивом.
CODE
// Consumer, use with caution
const T* getConsecutiveData_ptr()const{
if(rx==wx)return 0; // empty
return &data[rx];
int getConsecutiveData_len()const{
if(wx>rx)return wx-rx;
else return Size-rx;
void popConsecutiveData(unsigned n){
__DMB();
rx = (rx+n)&(Size-1);
Важно понимать, что связь между producer и consumer должна быть только через функции этого буфера, без каких либо других переменных, вызовов функций итд в обход этого FIFO. Иначе однозначно рано или поздно схватите гонку.
То есть он подходит, например когда producer - это прерывание, а consumer - вечный цикл. Что для большинства задач достаточно.
Если у нас еvent-driven-движок (то есть без вечных циклов, все на событиях) - тогда нужна более сложная реализация. Но использовать нужно опять же только ее, без всяких сторонних связей.
Если интересно - расскажу и покажу как, я на этих циклических буферах(в том числе с обьектами не фиксированного размера) уже собаку сьел за много лет, и в своих программах использую только их - как самый простой, эффективный и безопасный интерфейс для связи между обьектами.
Но это все C++, зато позволяет эффективно и безопасно работать и писать очень простой код.
Например. Прерывание uart
void U0RxCbk::readyRead(LPC_UART_TypeDef *uart){ // interrupt
    while(Uart::isCharAvailable(uart)){
        bool r = rxfifo.push(Uart::read_char(uart));
        if(!r){
            printf("U0RxCbk::readyRead(): rxfifo full!\n");
Приемник - просто функция, которая будет вызвана, когда на это появится время(в порядке приоритета и очереди).
Которая в свою очередь принимает текст NMEA и дальше парсит его.
void Gps::start_receiver(){
    // Устанавливаем обработчик события
    rxfifo.set_onReadyRead([this](){ // собственно сам обработчик
        uint8_t ch;
        while(true){
            bool r = rxfifo.pop(&ch); // читаем из очереди
            parse(ch); // парсим
            if(!r)break; // если очередь стала пустой - выходим
    }, GPS_TASK_PRIORITY); // приоритет обработчика
Это более старый вариант, привел, чтобы понять как оно работает, скажем так, внутри.
Сейчас я пользуюсь в основном таким:
class GpsReceiver : public UmFifoSingleReceiver<uint8_t, GpsReceiver, GPS_TASK_PRIORITY>{
protected:
    void onItemReceived(uint8_t ch){
        parse(ch);
То есть вся логика чтения из буфера реализована один раз отдельно и используется повторно сколько угодно раз.
Так же есть аналогичные реализации, когда приемник может обрабатывать не один элемент - а массив из нескольких(например отправка через DMA), физически - подряд лежащих в нашем ring-buffere.
Overhed-a нет, наоборот такая реализация на шаблонах работает быстрее, чем обычные сишные sm.gif Большинство работы делает компилятор, там даже вызова функции не будет - компилятор функцию parse встроит в недра самой очереди.
smalcom
сообщение Sep 7 2016, 17:47
самое первое (а там и дальше так)
это не кольцевой буфер, а обычный.
RSS Текстовая версия Сейчас: 30th August 2025 - 03:40
Страница сгенерированна за 0.02321 секунд с 7
