> cross polarization db level
sergei94
сообщение Feb 4 2017, 10:12
Пользователь №: 91 904
"The cross polarization may be specified for an antenna as a power level in negative dB, indicating how many decibels below the desired polarization's power level the x-pol power level is."
db is a ratio of powers,what amplitudes and why its negative ,if you could show an example with numbers showing negative dB.
thanks
semigas
сообщение Feb 4 2017, 14:33
Пользователь №: 87 937
thanks
I don't know any exemple for polarization, but this one about attenuation:
If power level of incident wave of Port 1(a1) is 100 W, and power level of reflected wave of Port 2 (a2) is 1W, it means: |S21|=10log10(1/100)=-20 dB
But I don't know exactly what situation with polarization
sergei94
сообщение Feb 4 2017, 16:24
thank i understand :-)
the thing is the amplitude of the undesired polariZation
RSS Текстовая версия Сейчас: 30th August 2025 - 12:56
Страница сгенерированна за 0.01355 секунд с 7
