> Чтение из MAX6956
Jenya7
сообщение Jan 10 2018, 07:30
Пользователь №: 71 075
Может кто работал с этой микросхемой? Сломал уже весь мозг.
Обращаюсь к MAX6956 из Kinetic K70.
Насчет чтения в документации написано так
The MAX6956 is read using the MAX6956’s internally stored command byte as address pointer, the same way the stored command byte is used as address pointer for a write. The pointer generally autoincrements after each data byte is read using the same rules as for a write (Table 4). Thus, a read is initiated by first configuring the MAX6956’s command byte by performing a write (Figure 8). The master can now read n consecutive bytes from the MAX6956, with the first data byte being read from the register addressed by the initialized command byte. When performing read-afterwrite verification, remember to reset the command byte’s address because the stored control byte address generally has been autoincremented after the write.
Чтение
#define MAX6956_SLAVE_ADDR  0x80 //A0,A1-GND
void MAX6956_Read(unsigned char reg_addr, unsigned char *reg_data)
    unsigned char slave_addr = MAX6956_SLAVE_ADDR | 0x01;
    //--------------first - set the address to read from
    //Start
    I2C1_Start()
     /* Send Slave Address  with W/R bit = 1 */
    I2C1_write_byte(slave_addr);
    I2C1_Wait();
    /* Write Register Address */
    I2C1_write_byte(reg_addr);
    I2C1_Wait();
     //-------------second - read from the address
    /* Do a repeated start */
    I2C1_RepeatedStart();  //???
    /* Send Slave Address */
    I2C1_Wait();
    I2C1_Wait();
     /* Put in Rx Mode */
    //I2C1_C1 &= (~I2C_C1_TX_MASK);
    /* Turn off ACK since this is second to last byte being read*/
    //I2C1_C1 |= I2C_C1_TXAK_MASK;
    /* read */
    *reg_data = I2C1_D;
    I2C1_Wait();
    /* Send stop since about to read last byte */
    I2C1_Stop();
Для проверки обращаюсь в регистр с известным значением после рисета.
MAX6956_Read( 0x09, &data);
    if (data != 0xAA)
        return MAX6956_ERROR;
На скопе вижу клок на SCL (400 kHz), вижу правильные адреса на SDA а возвращаемое значение 0х81.
RSS Текстовая версия Сейчас: 31st July 2025 - 13:48
Страница сгенерированна за 0.01371 секунд с 7
