> spartan 6, impact, '1': Programming terminated. DONE did not go high.
Alexey_Rostov
сообщение Jun 20 2018, 05:29
Из: Минск, Беларусь
Пользователь №: 77 312
Добрый день! Подскажите пожалуйста, кто какие решения применял для прошивки .bit в Spartan 6 через IMPACT + Platform Cable USB II при возникновении ошибки
Полный лог IMPACT
CODE
PROGRESS_START - Starting Operation.
Maximum TCK operating frequency for this device chain: 25000000.
Validating chain...
Boundary-scan chain validated successfully.
'1': Programming device...
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
'1': Reading status register contents...
[0] CRC ERROR : 0
[1] IDCODE ERROR : 0
[2] DCM LOCK STATUS : 0
[3] GTS_CFG_B STATUS : 0
[4] GWE STATUS : 0
[5] GHIGH STATUS : 0
[6] DECRYPTION ERROR : 0
[7] DECRYPTOR ENABLE : 0
[8] HSWAPEN PIN : 0
[9] MODE PIN M[0] : 0
[10] MODE PIN M[1] : 0
[11] RESERVED : 0
[12] INIT_B PIN : 0
[13] DONE PIN : 0
[14] SUSPEND STATUS : 0
[15] FALLBACK STATUS : 0
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0000 0000 0000 0000
INFO:iMPACT:579 - '1': Completed downloading bit file to device.
INFO:iMPACT:188 - '1': Programming completed successfully.
LCK_cycle = NoWait.
LCK cycle: NoWait
INFO:iMPACT - '1': Checking done pin....done.
PROGRESS_END - End Operation.
Elapsed time = 2 sec.
Отладочная плата Mojo Spartan 6
https://embeddedmicro.com/products/mojo-v3
При этом Get deviceID и Get device Signature выполняются без проблем.
RSS Текстовая версия Сейчас: 22nd August 2025 - 03:00
Страница сгенерированна за 0.01356 секунд с 7
