> вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 008
rom67
сообщение Nov 2 2016, 21:05
Пользователь №: 88 095
DATE: 10-29-2016   HOTFIX VERSION: 008
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
1644406 ALLEGRO_EDITOR SHAPE            Alternate symbol placement results in illegal parent identifier error
1647098 SIP_LAYOUT     OTHER            SiP crashes on symbol copy and rotate
1647154 APD            OTHER            Disconnected Clines not working
1648817 GRE            IFP_INTERACTIVE  Allegro PCB Editor stops responding on adding netgroups to a nested netgroup
1649829 CONCEPT_HDL    CORE             Project Manager: A delay is observed before the sub menus of the File and Tools menus appear
1652930 ALLEGRO_EDITOR OTHER            Command-line version of switchversion not working
1653109 ASDA           DESIGN_CORRUPTIO SDA not pulling latest library information for part
1655377 FLOWS          PROJMGR          Project Manager crashes on Windows 10
4 страниц V  < 1 2 3 4 >
Ответов (30 - 44)
rom67
сообщение Mar 5 2018, 19:55
Сообщение #31
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 035
rom67
сообщение Mar 7 2018, 17:11
Сообщение #32
Fixed CCRs: SPB 17.2 HF035
02-30-2018
CCRID   Product            ProductLevel2 Title
1873547 ADW                ADW_UPREV     adw_uprev resulted in incomplete footprint XML
1643895 ADW                DBEDITOR      Create Footprint model name is not working properly if footprint exists in local flatlib
1846400 ADW                DBEDITOR      'Copy As' and 'Rename' STEP model options do not work
1868299 ADW                FLOW_MGR      Copy Project fails and makes Flow Manager unresponsive
1872796 ADW                PART_BROWSER  Part/Model Details Attributes are all empty when connected to the EDM DB
1877199 ALLEGRO_EDITOR     DATABASE      Purging backdrill adds bottom filmmask to vias when it is not defined in the padstack
1877219 ALLEGRO_EDITOR     DRC_CONSTR    Allegro Crash at DRC Update
1875528 ALLEGRO_EDITOR     GRAPHICS      Subclasses disappear in partition
1868364 ALLEGRO_EDITOR     OTHER         Translator for Layout to PCB Editor fails in release 17.2-2016 but works in 16.6
1822989 ALLEGRO_EDITOR     UI_GENERAL    Allegro very slow
1855275 ALLEGRO_EDITOR     UI_GENERAL    Allegro becomes slow if OpenGL disabled
1868803 ALLEGRO_EDITOR     UI_GENERAL    Infinite Cursor misbehave
1869523 ALLEGRO_EDITOR     UI_GENERAL    PCB Editor hangs inconsistently on axlOpenDesign
1871409 ALLEGRO_EDITOR     UI_GENERAL    ESC key does not function with Enable_command_window_history set
1812306 ALLEGRO_PROD_TOOLB CORE          Incorrect DIFF result of PCB Design Compare
1872772 ASDA               MISCELLANEOUS SDA pulls a license for 'Allegro_performance'
1877070 CAPTURE            OTHER         Capture redraws icons
1863624 CONCEPT_HDL        CONSTRAINT_MG XNet names are changed in the designs migrated to release 17.2-2016
1866290 CONCEPT_HDL        CORE          variant editor/DE-DHL crashed when changing a component property
1858139 CONCEPT_HDL        OTHER         Slow graphic response in Windows10: Icons redraw
1872703 CONCEPT_HDL        OTHER         Icon and toolbar in DE-HDL keeps on refreshing for every command
1873949 CONCEPT_HDL        OTHER         DE-HDL user interface refreshes frequently
1871542 CONSTRAINT_MGR     INTERACTIV    Extracting object with 'Referenced ECSet' does not inherit T-points from the applied ECSet
1868812 CONSTRAINT_MGR     UI_FORMS      Cannot Save Log File from CM ECSet Audit.
1878574 ECW                PROJECT_MANAG Duplicate entries are created in SharePoint users list while creating project on SSO setup
1878619 ECW                PROJECT_MANAG Too many mails generated on doing create project
1862772 ECW                TDO-SHAREPOIN Logical BOM file name not displayed in Changed Files of Pulse Activity Log.
1860641 INSTALLATION       DOWNLOAD_MGR  Download Manager remembers credential settings
1867195 INSTALLATION       DOWNLOAD_MGR  Download manager crash
1872187 SIP_LAYOUT         DRC_CONSTRAIN Sliding a cline removes DRC markers but updating DRC shows more DRC markers
rom67
сообщение Mar 19 2018, 17:17
Сообщение #33
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 036
Fixed CCRs: SPB 17.2 HF036
03-16-2018
1880209 ADW                DBEDITOR      DBEditor quick search is resetting the check boxes in the Attributes tab
1880376 ADW                DBEDITOR      Allegro EDM Database Editor wildcard search functionality broken after installing hotfix 034.
1855444 ALLEGRO_EDITOR     DATABASE      PCB Editor crashes on creating MDD files after deleting subclasses
1863478 ALLEGRO_EDITOR     DATABASE      PCB Editor crashes on a specific machine when loading any .mdd file
1875544 ALLEGRO_EDITOR     SCHEM_FTB     Constraints are getting removed
1719683 ALLEGRO_EDITOR     UI_GENERAL    Incorrect display when using infinite cursor.
1765989 ALLEGRO_EDITOR     UI_GENERAL    Selection window does not work correctly with infinite cursor option checked
1885667 ALLEGRO_EDITOR     UI_GENERAL    Infinite cursor is not working correctly
1873954 ASDA               IMPORT_DEHDL_ SDA: Inconsistent pin number positions on part in an imported DE-HDL project
1873883 ASDA               NEW_PROJECT   SDA: New project from DE-HDL creates blank Page 1
1852036 ASDA               VARIANT_MANAG Design with variant cannot generate a variant BOM
1875549 CONCEPT_HDL        CORE          Incorrect PART_NUMBER/VALUE properties on schematic
1881848 CONCEPT_HDL        OTHER         License issue: Cannot open Allegro Design Authoring and unable to choose options and features
1872189 CONSTRAINT_MGR     CONCEPT_HDL   Pin-pairs are created for incorrect members of differential pair after ECSet is applied
1880235 CONSTRAINT_MGR     UI_FORMS      Ability to lock auto-generated Constraint Set in UI
1868711 CONSTRAINT_MGR     XNET_DIFFPAIR Nets are dropped from XNets on the BRD file in the front-to-back flow
1879296 ECW                PROJECT_MANAG Mode to remove Uprev Lock from locked webs in admin keys
1881632 PSPICE             SLPS          PSpice creates 'psp_input.log' during co-simulation flow
1879302 SCM                OTHER         SCM crashes when global nets are changed in the Block Packaging Options dialog box
1879580 TDA                SHAREPOINT    GetData error when opening a project in Design Data Management
rom67
сообщение Apr 3 2018, 14:46
Сообщение #34
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 037
Fixed CCRs: SPB 17.2 HF037
03-30-2018
1886573 ALLEGRO_EDITOR     IN_DESIGN_ANA Fail to launch Sigrity executable from release 17.2-2016
1891113 ALLEGRO_EDITOR     NC            Clubbing total backdrill layerwise data
1886085 ALLEGRO_EDITOR     SHAPE         Line to Thru Via DRC is not displayed automatically
1850888 ALLEGRO_PROD_TOOLB CORE          Design Compare crashes immediately after execution
1639079 ALTM_TRANSLATOR    CAPTURE       Title block issues with third-party design
1722577 ALTM_TRANSLATOR    CAPTURE       Third-party translator does not work in Capture in release 17.2-2016 if CDSROOT is not defined
1744697 ALTM_TRANSLATOR    CAPTURE       Third-party translator crashes
1820160 ALTM_TRANSLATOR    CAPTURE       Title block does not show ghost image when selecting it for placement
1628560 ALTM_TRANSLATOR    PCB_EDITOR    Third-party translation to PCB Editor not working properly
1836750 ALTM_TRANSLATOR    PCB_EDITOR    Third-party translator fails to translate a complete design
1844423 ALTM_TRANSLATOR    PCB_EDITOR    Third-party translation takes a long time in release 17.2-2016
1849338 ALTM_TRANSLATOR    PCB_EDITOR    Third-party translated board not correct
1894607 CONCEPT_HDL        CORE          Closing CM during 'Save Hierarchy' crashes DE-HDL
1703351 CONSTRAINT_MGR     CONCEPT_HDL   SigXplorer shows invalid models instead of default models in extracted topology
1868687 CONSTRAINT_MGR     CONCEPT_HDL   DML-independent flow: some pin-pairs missing for Differential Pair XNets when migrating 16.6 design to 17.2
1868747 CONSTRAINT_MGR     CONCEPT_HDL   Additional pin-pairs created on migrating design to release 17.2-2016 DML-Independent flow
1887794 CONSTRAINT_MGR     OTHER         Ability to disable cross-section changes in F2B flow
1859193 MODEL_EDITOR       TRANSLATION   DML provided by Model Integrity has a parsing error: curve must start at time zero
rom67
сообщение May 3 2018, 12:23
Сообщение #35
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 038
Fixed CCRs: SPB 17.2 HF038
04-27-2018
1861616 ADW                TDO-SHAREPOIN Team Design Option requires Allegro_ECAD_Collab_Workbench license feature
1784170 ALLEGRO_EDITOR     3D_CANVAS     Allegro 3D Canvas does not show the flex zone thickness correctly
1801053 ALLEGRO_EDITOR     3D_CANVAS     Moving component in 3D Canvas does not move the pads
1805038 ALLEGRO_EDITOR     3D_CANVAS     Soldermask and drill not refreshed when component is moved in 3D Canvas, or on the board with Canvas open
1808579 ALLEGRO_EDITOR     3D_CANVAS     3D Canvas displays annular ring incorrectly
1816732 ALLEGRO_EDITOR     3D_CANVAS     Mismatch in shape width between board and 3D Canvas
1822778 ALLEGRO_EDITOR     3D_CANVAS     3D Canvas does not display nets when selection is done through click drag
1838129 ALLEGRO_EDITOR     3D_CANVAS     User is not able to create a pastemask layer that is visible in 3D Canvas
1842911 ALLEGRO_EDITOR     3D_CANVAS     Etch shapes not visible in the 3D Canvas when invoked from a symbol drawing
1849380 ALLEGRO_EDITOR     3D_CANVAS     Mirrored components placed in flex zones are not displayed in the 3D Canvas
1851898 ALLEGRO_EDITOR     3D_CANVAS     STL export from 3D Viewer scales it up by 100
1853378 ALLEGRO_EDITOR     3D_CANVAS     The new interactive 3D Canvas has a display issue with the off-centered drills.
1859713 ALLEGRO_EDITOR     3D_CANVAS     PLACE_BOUND shape with package_height_max and package_height_min set displayed incorrectly in 3D Canvas
1880073 ALLEGRO_EDITOR     3D_CANVAS     Design Outline is not displayed correctly in 3D Canvas
1880338 ALLEGRO_EDITOR     3D_CANVAS     Step Model missing in interactive 3D canvas.
1881889 ALLEGRO_EDITOR     3D_CANVAS     Changing the color of STEP model in STEP Mapping Window does not display this color in 3D Canvas.
1889861 ALLEGRO_EDITOR     3D_CANVAS     3D Canvas swaps padstack from Bottom to Top
1830749 ALLEGRO_EDITOR     ARTWORK       Gerber 4x and 6x output do not fill the shape
1848514 ALLEGRO_EDITOR     COLOR         axlVisibleDesign does not interact with wirebonds
1837388 ALLEGRO_EDITOR     CROSS_SECTION Cannot add solder mask to the site layer mask file
1859797 ALLEGRO_EDITOR     CROSS_SECTION The Report only option does not work when choosing Setup - Cross-section - Import - IPC2581
1877858 ALLEGRO_EDITOR     CROSS_SECTION Dynamic Pads Suppression option is not working correctly
1880093 ALLEGRO_EDITOR     CROSS_SECTION Unused Pad Suppression options are not working correctly and are reset on opening cross-section
1886283 ALLEGRO_EDITOR     CROSS_SECTION Unable to turn on 'Dynamic Unused Pads Suppression'
1890959 ALLEGRO_EDITOR     CROSS_SECTION Dynamic Pads Suppression option is not working correctly
1900397 ALLEGRO_EDITOR     CROSS_SECTION Dynamic Unused Pad Suppression option in Cross-section not working at one go.
1905315 ALLEGRO_EDITOR     CROSS_SECTION 'Dynamic Unused Pad Suppression' cannot be turned on.
1861406 ALLEGRO_EDITOR     DATABASE      Refresh symbol for flex zone not mapping padstack layers correctly
1877132 ALLEGRO_EDITOR     DATABASE      Fail to open #Taaaaed17598.tmp file and save database
1883747 ALLEGRO_EDITOR     DATABASE      PCB Editor crashes on stackup modification
1860238 ALLEGRO_EDITOR     DFM           Applying a DFF constraint set closes PCB Editor instantly
1872780 ALLEGRO_EDITOR     DFM           DFF false pin to via DRCs: Copper Spacing, SMD pin Pad to Thru Via pad
1823912 ALLEGRO_EDITOR     DRC_CONSTR    Thru pin to Thru pin DRC between Symbol Pin to Mechanical Hole (with NO regular pad)
1828168 ALLEGRO_EDITOR     DRC_CONSTR    Upgrading from release 16.3 to 17.2-2016: Differences in spacing constraints
1844780 ALLEGRO_EDITOR     DRC_CONSTR    Mechanical Pin to Shape Air Gap value is reduced when updating shape
1845011 ALLEGRO_EDITOR     DRC_CONSTR    When upgrading from 16.6 to 17.2, Spacing constraints for shape to mechanical pin not being resolved properly
1861548 ALLEGRO_EDITOR     DRC_CONSTR    Inconsistent Micro via to Micro via drill to drill overlap DRCs
1862281 ALLEGRO_EDITOR     DRC_CONSTR    Mechanical Pin/hole to Shape spacing too small
1887145 ALLEGRO_EDITOR     DRC_CONSTR    Mechanical pin to conductor spacing setting is overriding constraint region in release 17.2-2016
1893012 ALLEGRO_EDITOR     DRC_CONSTR    Shape voiding not taking the shape to hole spacing rules for NPTH
1906840 ALLEGRO_EDITOR     GRAPHICS      Context menu stays when PCB Editor is minimized.
1738624 ALLEGRO_EDITOR     INTERACTIV    'Invalid Sector' error when saving psm file for symbol that has die pads, which are copied
1800741 ALLEGRO_EDITOR     INTERACTIV    Search in User Preferences Editor is giving incorrect results
1812530 ALLEGRO_EDITOR     INTERACTIV    PCB Editor crashes when opening a file that is in an unsupported format
1812570 ALLEGRO_EDITOR     INTERACTIV    PCB Editor hangs when an invalid pin number value is specified as the rotation point in the symbol preselect mode
1826819 ALLEGRO_EDITOR     INTERACTIV    'Route - Resize/Respace - Align Vias' menu is not available
1842645 ALLEGRO_EDITOR     INTERACTIV    Via align command is missing from the menu path
1845748 ALLEGRO_EDITOR     INTERACTIV    With 'Shape - Change Shape Type' enabled, changing visibility reverts the Shape Fill selection to dynamic copper.
1849700 ALLEGRO_EDITOR     INTERACTIV    Add the reason for generating DBFIX_PAD, to the dbdoctor.log.
1860934 ALLEGRO_EDITOR     INTERACTIV    Auto-Paste environment variable is not working as it should
1861928 ALLEGRO_EDITOR     INTERACTIV    Provide a Persistent snap pick option for Display - Measure
1864238 ALLEGRO_EDITOR     INTERACTIV    Shape place rectangle issue: Dimension of placed rectangle changes on cancelling action
1877026 ALLEGRO_EDITOR     INTERACTIV    Filled rectangles on ETCH/TOP and ETCH/BOTTOM are not getting copied
1881637 ALLEGRO_EDITOR     INTERACTIV    Radius of Shape changes when trying to place circle using Place Circle mode.
1883032 ALLEGRO_EDITOR     INTERACTIV    Find by Query does not find all padstacks in a symbol drawing
1855248 ALLEGRO_EDITOR     INTERFACES    The Technology Dependent Footprint command returns an error
1885716 ALLEGRO_EDITOR     INTERFACES    Increase supported STEP model size to enable the use of models larger then 500MB
1860835 ALLEGRO_EDITOR     MANUFACT      Display a message when backdrill_max_pth_stub is defined for vias or pins only
1869528 ALLEGRO_EDITOR     MANUFACT      Backdrill out of date when deleting Teardrop and Sliding cline with Teardrop
1885672 ALLEGRO_EDITOR     NC            NC drill is creating false backdrills when repeat code is turned on in release 17.2-2016
1895084 ALLEGRO_EDITOR     NC            Padstacks with backdrill data trigger backdrill out-of-date even if the board is not set up for backdrilling
1837514 ALLEGRO_EDITOR     PAD_EDITOR    Offset is not consistent for keepout and mask layers in padstack editor.
1842902 ALLEGRO_EDITOR     PAD_EDITOR    Scrolling through the .pad files in the Library Padstack Browser displays Error(SPMHA1-161)
1846504 ALLEGRO_EDITOR     PAD_EDITOR    COVERLAY_TOP definition lost while opening and saving a 16.6 pad in 17.2 padstack editor
1879453 ALLEGRO_EDITOR     PAD_EDITOR    The 'Y' tolerance in the Padstack Editor does not update when changing the units of the padstack.
1805202 ALLEGRO_EDITOR     PLACEMENT     Place via array adds via on differential pairs incorrectly
1806675 ALLEGRO_EDITOR     PLACEMENT     Place - Manually - Quickview displays the Assembly Top details only
1835177 ALLEGRO_EDITOR     PLACEMENT     Can place symbol even after cancelling copy by choosing 'Oops' from pop-up
1846892 ALLEGRO_EDITOR     PLOTTING      PCB Editor Export PDF does not show lines correct for certain component
1006328 ALLEGRO_EDITOR     SHAPE         Static shapes should void around corners as dynamic shapes do
1033326 ALLEGRO_EDITOR     SHAPE         Cannot compose lines to shape
1045089 ALLEGRO_EDITOR     SHAPE         Dynamic shape voiding is inconsistent for solid and xhatch shape fill type
1069959 ALLEGRO_EDITOR     SHAPE         Compose shape crashes PCB Editor
1085907 ALLEGRO_EDITOR     SHAPE         Pad does not get thermal connections to shape if outside of the shape outline by more than DRC spacing.
1143563 ALLEGRO_EDITOR     SHAPE         The pin void inline clearance does not seem to dynamically update the shape and requires a 'force update'.
1243688 ALLEGRO_EDITOR     SHAPE         shape_rki_autoclip fails to clip shape to route keepin
1269069 ALLEGRO_EDITOR     SHAPE         Shape void not working properly in release 16.5 hotfix 054
1327755 ALLEGRO_EDITOR     SHAPE         Need the ability to nest dynamic shapes on different nets partially or entirely
1417394 ALLEGRO_EDITOR     SHAPE         Shape not updating correctly
1430742 ALLEGRO_EDITOR     SHAPE         When adding fillet to an irregular pad, the fillet might not be added or be strangely shaped
1750760 ALLEGRO_EDITOR     SHAPE         Shape to Route Keepout DRC for a void that meets route keepout
1793898 ALLEGRO_EDITOR     SHAPE         Add teardrops fails to add anything with different settings
1811662 ALLEGRO_EDITOR     SHAPE         'show measure' gives incorrect air gap value between two pins
1820901 ALLEGRO_EDITOR     SHAPE         The pins on adjacent layers are voided as Rounded Rectangle instead of Rectangular as defined in padstacks
1829570 ALLEGRO_EDITOR     SHAPE         Display measure airgap value is very large
1858696 ALLEGRO_EDITOR     SHAPE         The via to the edge of the board is not connecting to shape even with the PAD_SHAPE_TOUCH_CONNECTION property added
1873384 ALLEGRO_EDITOR     SHAPE         Boolean AND operation returning nil
1873860 ALLEGRO_EDITOR     SHAPE         Copper shape does not respect route keepout
1889312 ALLEGRO_EDITOR     SHAPE         Shape voided for net vias on adding 'PAD_SHAPE_TOUCH_CONNECTIONS' when enabling via suppression
1890702 ALLEGRO_EDITOR     SHAPE         Not able to add teardrop in release 17.2-2016
1892692 ALLEGRO_EDITOR     SHAPE         Thermal relief connections being added to static shapes present in the void inside Dynamic Shapes
1893492 ALLEGRO_EDITOR     SHAPE         'merge shapes' results in moved void
1896543 ALLEGRO_EDITOR     SHAPE         Same net pin will not add thermal connection to shape if it is a rotated slot in the symdef
1897645 ALLEGRO_EDITOR     SKILL         axlCNSGetSpacing() returns nil if active class is non-etch.
1822364 ALLEGRO_EDITOR     UI_FORMS      Design Parameters dialog disappears if prmed is called while show measure is active
1834395 ALLEGRO_EDITOR     UI_FORMS      Setup menu of OrCAD PCB Editor is missing the Anchor 3D View command
1838941 ALLEGRO_EDITOR     UI_FORMS      Anchor 3D View command is not available in OrCAD PCB Editor Setup menu
1716433 ALLEGRO_EDITOR     UI_GENERAL    Alias keys do not work until mouse scroll key is activated
1721761 ALLEGRO_EDITOR     UI_GENERAL    During manual placement of symbols, hovering over symbols does not highlight them
1732915 ALLEGRO_EDITOR     UI_GENERAL    Alias does not work in release 17.2-2016 when switching windows
1770723 ALLEGRO_EDITOR     UI_GENERAL    Funckey does not work if focus is not on canvas in release 17.2-2016
1793839 ALLEGRO_EDITOR     UI_GENERAL    Function Key does not work if a form is opened by a previous command
1813961 ALLEGRO_EDITOR     UI_GENERAL    Inconsistent file formats available when saving reports
1816716 ALLEGRO_EDITOR     UI_GENERAL    Shortcut not working when using working layer with 'add connect'
1864321 ALLEGRO_EDITOR     UI_GENERAL    Funckeys not being registered after focus has moved to other window and back again in PCB Editor
1865010 ALLEGRO_EDITOR     UI_GENERAL    PCB Editor does not get focus when clicking shortcut after switching from any other program or application
1868708 ALLEGRO_EDITOR     UI_GENERAL    Allegro PCB Editor, funckeys stop working intermittently in release 17.2-2016, hotfix 032
1869745 ALLEGRO_EDITOR     UI_GENERAL    Allegro 3D Canvas window becomes active on pointing at minimized icon on taskbar
1869860 ALLEGRO_EDITOR     UI_GENERAL    Hotkeys no longer functional on switching from PCB Editor to another application and then back again
1870744 ALLEGRO_EDITOR     UI_GENERAL    Need html extension added to Save pull down menu.
1870996 ALLEGRO_EDITOR     UI_GENERAL    If you switch from one active window to other, hotkeys stop working
1883507 ALLEGRO_EDITOR     UI_GENERAL    Hotkeys stop working after Allegro PCB Editor UI window is opened
1886981 ALLEGRO_EDITOR     UI_GENERAL    Focus lost from layout when switching between PCB Editor and Capture
1887519 ALLEGRO_EDITOR     UI_GENERAL    Release 17.2-2016, hotfix 034: Shortcuts defined using funckeys not working correctly
1887660 ALLEGRO_EDITOR     UI_GENERAL    Alias does not work in release 17.2-2016 when switching windows.
1891204 ALLEGRO_EDITOR     UI_GENERAL    PCB Editor crashes if SKILL form is closed using the Close icon ('X')
1898059 ALLEGRO_EDITOR     UI_GENERAL    Funckey commands are not working consistently in release 17.2-2016
1902322 ALLEGRO_EDITOR     UI_GENERAL    Cannot use funckey commands when cross-probing
1905906 ALLEGRO_EDITOR     UI_GENERAL    Issue with keys and focus when navigating between windows
1913768 ALLEGRO_EDITOR     UI_GENERAL    Uppercase funckey shortcuts do not work
1751586 APD                OTHER         axlGetMetalUsageForLayer() for etch returns value including pins and vias
1863241 APD                SHAPE         Fillet is left on the T-Point without Cline(center) connection.
1894438 APD                STREAM_IF     APD/SiP Layout: Export rounded features as circumscribed and not inscribed polygon in GDS
1812699 ASDA               AUTOMATION    Enhance the performance when extracting data from SDA, using TCL functions
1863436 ASDA               CANVAS_EDIT   alignment guides are not displayed when placing or copy a part, only when moving. They are most needed during placement
1863445 ASDA               CANVAS_EDIT   dark theme blue text in docked CM needs to be a different color. difficult to read
1802111 ASDA               DARK_THEME    Dark theme in SDA should also change the border line color and text color of grid references: they are still black
1869951 ASDA               EXPORT_PCB    File browser button in Export to PCB Layout flashes graphics of the window behind the form
1845831 ASDA               FORMAT_OBJECT Width of the twisted pair of wire should automatically be set to 6, otherwise it is not drawn correctly
1879914 ASDA               INTERNATIONAL Using French Keyboard cannot use the . (point) delimiter to set VOLTAGE property value
1865753 ASDA               MISCELLANEOUS Inconsistent and non-ideal behavior in SDA product choice dialog, small box, hard to check unlike the bottom box
1863457 ASDA               PACKAGER      globaly unset all user assigned references
1889301 ASDA               TDO           SDA TDO Crashes when switching to/from Offline mode
1823203 ASDA               VARIANT_MANAG Variant setting part to not present does not do anything
1823992 ASDA               VARIANT_MANAG Variant Editor fails to read netlist if a net is named NC
1863451 ASDA               VARIANT_MANAG variant mode can select multiple parts to add to variant but can't select multiple parts to hit reset
1863455 ASDA               VARIANT_MANAG Cant resize any panales in variant view mode
1874952 ASDA               VARIANT_MANAG Letter I in the alternate part icons in variant spreadsheet should be  white for readability
1878401 ASDA               VARIANT_MANAG SDA Variant Display - DNI marker color switches between black and red
1877239 ASDA               WORKSPACE     SDA DRC window is hidden if undocked and minimized
1809605 CAPTURE            LIBRARY       Part has pins in the incorrect order in the Connectors library
1638693 CAPTURE            OTHER         Capture Footprint Viewer not showing footprint.
1873612 CONCEPT_HDL        COPY_PROJECT  Copy project causes nets to be added to net groups and ports - fails to package due to mismatch
1779289 CONCEPT_HDL        CORE          Adding a component and wire and saving the design results in a 'Connectivity save failed' error
1878719 CONCEPT_HDL        CORE          Cannot enable or apply block variants at the top-level in a hierarchical design.
1865480 CONCEPT_HDL        OTHER         'partmgr -ptfMode shoppingCart' cannot output cell name with project ptf file into shoppingCart.xml
1829966 CONSTRAINT_MGR     CONCEPT_HDL   DML independent flow: Export Physical audits missing signal models in release 17.2
1904458 CONSTRAINT_MGR     ECS_APPLY     'Audit - ECSets' crashes DE-HDL in release 17.2-2016, Hotfix 037
1798269 CONSTRAINT_MGR     OTHER         Script changes '-' in layer name to '_'
1835520 CONSTRAINT_MGR     OTHER         Cannot add members to netclass name with parenthesis
1896638 CONSTRAINT_MGR     OTHER         Constraint Manager worksheets jump abruptly
1801938 CONSTRAINT_MGR     UI_FORMS      Add To Netclass window: Focus not on ClassSelection
1854060 CONSTRAINT_MGR     UI_FORMS      Using the tab key in the Manufacturing workbook jumps a cell
1881832 ECW                ROLES_PERMISS Adding Users in SSO environment using PS is error prone
1864870 F2B                BOM           Incomplete BOM report generated
1846578 PCB_LIBRARIAN      GRAPHICAL_EDI radio buttons and clickable buttons are hidden in the UI for verify rules
1854080 PCB_LIBRARIAN      METADATA      con2con needs to support special characters in Primitive Name
1796377 PCB_LIBRARIAN      SYMBOL_EDITOR Unable to move pins using arrows when symbol is opened in Symbol Editor
1839692 PCB_LIBRARIAN      SYMBOL_EDITOR Properties tab grayed out in Symbol preview window
1865657 PCB_LIBRARIAN      SYMBOL_EDITOR Cannot change symbol properties using the General tab
1906888 PCB_LIBRARIAN      SYMBOL_EDITOR Properties button in Symbol Pins tab of the Symbols section is inactive.
1891248 PCB_LIBRARIAN      SYMBOL_EDITOR Copy and mirror arc drawing object in the new Symbol Editor results in wrong arc on opening symbol in DE-HDL
1908381 PDN_ANALYSIS       PCB_STATICIRD Allegro PCB PDN Analysis crashes after performing analysis and saving result in release 17.2-2016
1825087 PSPICE             AA_OPT        Graph view menu does not appear when we use 'Curve Fit' in Optimizer.
1808091 PSPICE             ENVIRONMENT   'orSimSetup' crashes when 'Restart Simulation' is selected
1811782 PSPICE             ENVIRONMENT   Setup Simulation Profile no longer enables Advanced Markers when appropriate
1834147 PSPICE             ENVIRONMENT   PSpice Part Search library icons not displayed if product is installed in the Program Files folder in release 17.2-2016
1841992 PSPICE             FRONTENDPLUGI Getting a blank Error dialog while adding a marker
1858574 PSPICE             NETLISTER     PSpice simulation: Some models cannot be used after upgrading to release 17.2-2016
1865022 PSPICE             NETLISTER     The division operator is not recognized by PSpice in DEV expressions in release 17.2-2016
1677119 PSPICE             PROBE         PSpice crashes when plotting simulation message summary
1837046 PSPICE             PROBE         On Windows 10, PSpice crashes on clicking Yes to see message
1879387 PSPICE             PROBE         PSpice crashes when we choose to plot simulation message summary
1842231 PSPICE             SIMULATOR     Wrong results in PSpice Advanced Analysis for DC Sweep Analysis
1843446 PSPICE             SIMULATOR     Distribution type is not showing under Assign Tolerance window for transistor
1872630 RF_PCB             ROUTING       Transition taper length does not work in route- Add RF trace
1872636 RF_PCB             ROUTING       Inherit Width parameter in Route -RF trace only uses width of one side
1872644 RF_PCB             ROUTING       Regression RF trace: change in trace width not retained while routing
1901201 SIP_LAYOUT         EXTRACT       extracta is not retaining custom layer names
1813380 SIP_LAYOUT         OTHER         Layer Compare is not adding the required shapes
1852762 SIP_LAYOUT         OTHER         Error generated in Package Design Integrity Check when adding soldermask to my design
1886847 SIP_LAYOUT         REPORTS       Incorrect metal area in metal usage report
1491315 SIP_LAYOUT         SHAPE         Dynamic shape filling exceeds the shape boundary on running 'create bounding shape' command
1853989 SIP_LAYOUT         SHAPE         'Shape - Select' and then' Move' from pop-up with ix 500 iy 0 moves shape diagonally
1868509 SPECCTRA           PARSER        Autorouter takes long time to invoke
1869317 SYSTEMSI           ENG_PBA       SystemSI PBA does not align correlation waveforms correctly on Linux platform
copov
сообщение May 7 2018, 10:51
Сообщение #36
Пользователь №: 3 012
Очень мощное обновление Cadence Allegro Editor и PSpice и распухло на 300 Мб по сравнению с предыдущим. Нужны ли какие-нибудь дополнительные FEATURE в файл лицензии?
rom67
сообщение May 15 2018, 15:36
Сообщение #37
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 039
Fixed CCRs: SPB 17.2 HF039
05-11-2018
1915149 ADV_PKG_ROUTER     OTHER         Auto-connect fails to initialize when rats are selected, but works with bundle
1870109 ADW                ADW_UPREV     Most mandatory properties turned into optional properties following database uprev
1758396 ADW                CONF          Server Memory setting in setting.ini is lost if server is re-configured using Conf
1911591 ADW                FLOW_MGR      Flow Manager does not start on high latency (> 25ms) networks: displays Java Content Disabled dialog
1887861 ADW                LIBIMPORT     Library Consolidation reports front2back issues but does not provide information about the issues.
1778977 ADW                REPORT_GENERA reportgen memory setting too high in release 17.2-2016 resulting in launch failure
1900422 ADW                REPORT_GENERA Save in reportgen does not save Preferred Part List entry into .rep file
1903888 ADW                REPORT_GENERA Report generator not outputting values as expected for PPL field
1916903 ADW                REPORT_GENERA Reportgen -gui is not producing the expected result
1902184 ALLEGRO_EDITOR     DATABASE      Add connect in package symbol crashes PCB Editor when using the 'clearance_view' variable
1914793 ALLEGRO_EDITOR     DATABASE      Updating shape crashes Allegro PCB Editor
1905138 ALLEGRO_EDITOR     DRC_CONSTR    Max Via count DRC disappears on running DRC update
1848015 ALLEGRO_EDITOR     MANUFACT      Export Creo View cannot find the webpage on the PTC site
1850553 ALLEGRO_EDITOR     MANUFACT      'File - Export - Creo View' is not working
1853960 ALLEGRO_EDITOR     MANUFACT      PTC Creo Interface link is broken
1862305 ALLEGRO_EDITOR     MANUFACT      PTC Creo interface link is not working
1878682 ALLEGRO_EDITOR     MULTI_USER    Delay in Symphony server session when server is started from Allegro PCB Editor
1890108 ALLEGRO_EDITOR     MULTI_USER    Database rejections in Symphony
1887331 ALLEGRO_EDITOR     NC            Milling (NC route) in Gerber tools is not the same as what it is in the board.
1898179 ALLEGRO_EDITOR     RAVEL_CHECKS  PCB High-Speed option required for high-speed rules when Venture license is selected
1461142 ALLEGRO_EDITOR     SHAPE         Pin with nearly-tangent via fails to generate void in dynamic shape, results in short.
1863467 ASDA               CROSSPROBE    Highlighting all parts in PCB Editor does not highlight all parts in SDA
1910974 ASDA               CROSSPROBE    Cross-probing between SDA and PCB Editor does not work
1904440 CONCEPT_HDL        CORE          SPCOCD-577 error on migrating from release 16.6 to release 17.2-2016
1909611 CONCEPT_HDL        CORE          DE-HDL stops responding on running '_movetogrid' and clicking 'No'
1808743 CONCEPT_HDL        PDF           Inconsistent display of Publish PDF hyperlinks
1894868 CONCEPT_HDL        PDF           XREFs getting clipped in the Published PDF
1911676 CONSTRAINT_MGR     CONCEPT_HDL   DE-HDL Constraint Manager crashes on selecting ECSet and then creating pin-pair option
1913968 CONSTRAINT_MGR     CONCEPT_HDL   Match Group pin-pairs are not created on applying ECSet to differential pair
1899638 CONSTRAINT_MGR     XNET_DIFFPAIR Differential pair buffer models are extracted differently in release 17.2-2016 and release 16.6
1914116 ORBITIO            ALLEGRO_SIP_I Unable to import OrbitIO file to SiP Layout
1896487 PCB_LIBRARIAN      GRAPHICAL_EDI Use lower-case characters for notes and pin text in New Symbol Editor
1898008 PCB_LIBRARIAN      SYMBOL_EDITOR Styling is not available for custom shape and pins.
1644787 PSPICE             FRONTENDPLUGI PSpice Model Search window does not show complete library path
1785939 PSPICE             FRONTENDPLUGI PSpice Part Search library browser should display path of the library directories
1855867 PSPICE             FRONTENDPLUGI PSpice Model Search window does not show complete library path
1887016 PSPICE             SIMULATOR     Pseudotran should always be invoked first time in case autoconvergence is ON
1895752 SIG_INTEGRITY      OTHER         Layout Cross Section: Wrong Differential Impedance calculation (0 ohms) in RHEL Linux 7.1 or later versions
1895759 SIG_INTEGRITY      OTHER         Cross Section does not calculate correct differential pair impedance in Linux CENTOS 7 and gives 0 value
1909257 SIP_LAYOUT         INTERACTIVE   Error 'E- (SPMHGE-639): Copying component with bond wire is not allowed' when copying SMD symbols
1900970 SIP_LAYOUT         SHAPE         Shape does not void around SMD Pins and Vias inside pad
1885496 SIP_LAYOUT         SYMB_EDIT_APP Pin Numbering: different results for release 16.6 and 17.2-2016 for the same case.
1907796 SIP_LAYOUT         SYMB_EDIT_APP SKILL commands fail to change pin number in SiP Layout
1887703 SIP_LAYOUT         WIREBOND      On trying to add wire bond to a die, SiP Layout crashes displaying a restart message
1903081 SPECCTRA           LICENSING     PCB Router is failing in Linux 7.1 in release 17.2-2016
1721606 SPECCTRA           ROUTE         PCB Router stops responding on exit if opened in the stand-alone mode
1844366 SPECCTRA           ROUTE         Allegro PCB Router will not exit
1873716 SPECCTRA           ROUTE         PCB Router does not close if opened from Allegro PCB Editor or in the stand-alone mode
1907703 SPIF               OTHER         PCB Editor crashes on choosing 'File - Export - Router' in release 17.2-2016
1889059 VSDP               DIEEXPORT     Incorrect pin location if bump cell origin is not at lower left for rotation other than R0
rom67
сообщение May 29 2018, 21:01
Сообщение #38
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 040
Fixed CCRs: SPB 17.2 HF040
05-27-2018
1924541 ADW                CONF          Designer Server configuration cannot be completed
1906973 ADW                DBEDITOR      Rename attribute fails to preserve values in affected parts
1718524 ADW                FLOW_MGR      FM: Find Projects does not find any projects when Project Path contains a period
1803310 ADW                FLOW_MGR      EDM Find Project no longer supports dot in the project path
1916898 ADW                FLOW_MGR      Flow Manager does not recognize projects with a dot in the path
1887669 ADW                LIBDISTRIBUTI ptfgen displaying Java errors
1897991 ADW                LIBDISTRIBUTI ptfgen fails with error LIBDIST-1062 in library distribution.
1915319 ADW                LIBDISTRIBUTI ptfgen should re-run with the -rewrite2db option automatically
1920309 ADW                LIBDISTRIBUTI Java exceptions in the ptfgen log file
1914706 ALLEGRO_EDITOR     DFM           False Mask to trace DRCs
1912290 ALLEGRO_EDITOR     GRAPHICS      Infinite PCB cursor: symbol move results in symbol trail and disappearance of cursor and symbol
1927425 ALLEGRO_EDITOR     GRAPHICS      Infinite PCB Cursor disappear while moving objects on layout
1908867 ALLEGRO_EDITOR     INTERACTIV    PCB Editor crashes in release 17.2-2016, Hotfix 036 and 037
1906116 ALLEGRO_EDITOR     IN_DESIGN_ANA Allegro Integrated Analysis and Checking: Coupling vision shows the influence of voltage net
1918161 ALLEGRO_EDITOR     MULTI_USER    Symphony crashing and clients disconnecting from server cannot leave session, error applying DBupdate
1919467 ALLEGRO_EDITOR     MULTI_USER    Random crashes while routing design in Symphony
1918702 ALLEGRO_EDITOR     SHAPE         Differential Pair vias not voided in a split plane
1905109 ALLEGRO_EDITOR     UI_GENERAL    PCB Editor randomly stops responding in release 17.2-2016 in Linux
1882365 ASDA               CANVAS_EDIT   SDA - body changes but not properties when changing version of a symbol
1900370 ASDA               CANVAS_EDIT   Version command in SDA should use placeholders from selected version
1901120 ASDA               CANVAS_EDIT   Choosing a different version of a placed component does not use the property placeholders as per the new symbol
1907497 ASDA               GRAPHICS      DNI Cross Mark much larger than Components
1895135 ASDA               MISCELLANEOUS Design created in SDA has the cds.lib containing a pointer to worklib
1895139 ASDA               MISCELLANEOUS Irrelevant warning related to worklib when running checkplus on SDA design
1920753 CAPTURE            LIBRARY       JavaScript exception reported on opening part with name containing '\' in hotfix 038
1925848 CAPTURE            LIBRARY       New (QIR6) Symbol Editor has Script error / SR 600037969
1916991 CAPTURE            NEW_SYM_EDITO New part/symbol editor ignores grid color set in Preferences
1917090 CAPTURE            NEW_SYM_EDITO New symbol editor goes into permanent pan mode on clicking the middle mouse button
1918041 CAPTURE            NEW_SYM_EDITO Saves As for symbol in library from new symbol editor saving 0 byte files
1918497 CAPTURE            NEW_SYM_EDITO Moving multiple items using the arrow keys results in error in new part editor
1918711 CAPTURE            NEW_SYM_EDITO Unable to do a Save As from a Library part to change the name
1920889 CAPTURE            NEW_SYM_EDITO Unable to edit symbol with name containing '/'
1922123 CAPTURE            NEW_SYM_EDITO Save As for symbol in library from new symbol editor saving 0 byte files
1922276 CAPTURE            NEW_SYM_EDITO Space between pin name and pin for names having bar
1922282 CAPTURE            NEW_SYM_EDITO JavaScript exception on closing new part editor window using keyboard shortcuts
1923526 CAPTURE            NEW_SYM_EDITO Unable to "Save As" in new symbol editor.
1927262 CAPTURE            NEW_SYM_EDITO The File > Save As command in version 17.2-s038 differs from earlier versions
1919322 CAPTURE            PART_EDITOR   JavaScript exception on opening parts and creating new part using right-click
1914183 CONSTRAINT_MGR     XNET_DIFFPAIR ECSet fails to map in PCB Editor but maps fine in DE-HDL
1908102 ECW                DASHBOARD     Some lines in Design Dashboard in Pulse are grayed out
1914812 F2B                PACKAGERXL    Hierarchical variable not evaluated
1639231 PSPICE             ENVIRONMENT   Remember last location in simulation settings
1804391 PSPICE             ENVIRONMENT   Libraries with uppercase extension (.LIB) not retained if added using 'Add to Profile'
1879915 PSPICE             ENVIRONMENT   Check points cannot be loaded from a directory with space in its name
1695306 SIP_LAYOUT         STREAM_IF     SiP Layout - Stream out issue: Embedded or stacked components using pad reference in more than one layer
rom67
сообщение Jun 19 2018, 07:33
Сообщение #39
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 041
Fixed CCRs: SPB 17.2 HF041
06-9-2018
1880083 ADW                ADWSERVER     ALM fails to connect and authenticate LDAP server
1922218 ALLEGRO_EDITOR     3D_CANVAS     PCB Editor stops responding when 3D Canvas is opened for a symbol
1915838 ALLEGRO_EDITOR     DFM           Outline to non-signal geometry is not working for non-etch layers in design
1925263 ALLEGRO_EDITOR     DFM           False minimum spoke count DRC
1895486 ALLEGRO_EDITOR     INTERFACES    Importing IPF displays error regarding line being outside drawing extents (SPMHMF-409)
1927266 ALLEGRO_EDITOR     INTERFACES    Miniaturization license required when using enterprise licenses
1912186 ALLEGRO_EDITOR     IN_DESIGN_ANA Coupling analysis on one net takes a long time
1916015 ALLEGRO_EDITOR     NC            Improve the message for reporting unsupported characters in the directory path while generating NC Drill data
1926072 ALLEGRO_EDITOR     SHAPE         Dynamic shape to route keepout not voiding correctly
1903202 ALLEGRO_EDITOR     UI_GENERAL    HTML report dialog does not handle relative links to files correctly
1880684 ALTM_TRANSLATOR    CAPTURE       Importing third-party schematic is not working in Capture
1870218 ALTM_TRANSLATOR    DE_HDL        Unable to translate a third-party design to DE-HDL
1881208 ALTM_TRANSLATOR    DE_HDL        Third-party to DE-HDL translation: schematic symbols missing all pins
1889909 ALTM_TRANSLATOR    DE_HDL        Third-party to DE-HDL and OrCAD Capture translator fails with error message or crash
1924375 ASDA               NEW_PROJECT   SDA new project path truncated at ellipses
1900957 ASI_SI             OTHER         axlLicDefaultVersion() in SKILL console crashes PCB Editor in release 17.2-2016 and works in release 16.6
1918499 CAPTURE            NEW_SYM_EDITO Text in new Part Editor is always left-justified and justification cannot be changed
1921505 CAPTURE            NEW_SYM_EDITO Error if property name starts with the less than character '<'
1924273 CAPTURE            NEW_SYM_EDITO Error if property name starts with the less than character '<'
1924332 CAPTURE            NEW_SYM_EDITO Capture reports an error when editing pin numbers where names contain the less than character '<'
1934655 CAPTURE            NEW_SYM_EDITO Properties populated in older release show up blank in new Symbol Editor
1855851 CAPTURE            OTHER         Crystal Reports not working in release 17.2-2016
1918048 CAPTURE            PART_EDITOR   Unable to modify pin type and shapes for multiple pins simultaneously in new Part Editor
1919459 CAPTURE            PART_EDITOR   Part Editor background display color is not consistent when zoomed out/in
1920078 CAPTURE            PART_EDITOR   Option needed for updating pin type of multiple pins in the 'Edit all pins' menu
1922785 CAPTURE            PART_EDITOR   Cannot place pin array with zero in the suffix in Symbol Editor
1922831 CAPTURE            PART_EDITOR   Symbol Editor redraws when scrolling with non-default background and when zoomed out
1923772 CAPTURE            PART_EDITOR   Placing pin arrays results in error
1888897 CAPTURE            SCHEMATICS    Capture slowly redraws schematic page
1910087 CONCEPT_HDL        CORE          DE-HDL crashes when adding Current Probe to a design
1930364 CONCEPT_HDL        CORE          SIGNAL_MODEL properties not deleted on importing release 16.6 DML design into release 17.2-2016 non-DML design
1920716 CONSTRAINT_MGR     CONCEPT_HDL   Issue with the passing of physical and spacing CSets between Design Entry HDL and PCB Editor
1902591 ECW                OTHER         Flow Manager reports a digital certificate error when launched with Pulse
1926029 PCB_LIBRARIAN      GRAPHICAL_EDI PDV Symbol Editor opens to a blank page in release 17.2-2016
1884694 PSPICE             ENCRYPTION    User-defined library encryption is not working as expected
1927537 SIP_LAYOUT         ASSY_RULE_CHE SiP Layout crashes when running manufacturing checks on specific designs
1878733 SIP_LAYOUT         CROSS_SECTION Layer Function and Manufacture fields in Cross-section Editor are grayed out for soldermask layers in SiP Layout
1900628 SIP_LAYOUT         CROSS_SECTION Board thickness in Cross-section Editor does not change even after soldermask layers are added
copov
сообщение Jun 22 2018, 08:08
Сообщение #40
Подскажите пожалуйста. После установки OrCAD/Allegro 17.2, HOTFIX VERSION: 041 редактор символов в Capture работоспособен или все-также не пригоден?
copov
сообщение Jun 26 2018, 06:03
Сообщение #41
Спасибо, сам отвечу. Косяки в символьном редакторе в Capture не исправили...
P.S. Такая эта ситуация уже становится неприличной.
copov
сообщение Jun 27 2018, 09:23
Сообщение #42
del
En_Serg
сообщение Jul 18 2018, 07:54
Сообщение #43
Пользователь №: 4 775
А в известном месте можно взять Hotfix 42.
Такая же ситуация?
PCBtech
сообщение Jul 18 2018, 19:59
Сообщение #44
Пользователь №: 1 623
А можете перечислить эти косяки?
На правах рекламы:
Для тех, кому нужна современная профессиональная и недорогая САПР печатных плат, взамен P-CAD!
Продлена промо-акция: 19.9 тысяч рублей за годовую сетевую лицензию OrCAD Standard!
В лицензию входит схемный редактор OrCAD Capture, базовый редактор печатных плат на базе Allegro PCB Editor,
с возможностью работы с дифференциальными парами со статическим контролем фазы,
редактор правил и ограничений, 3D-просмотр со STEP-моделями, расчет импеданса, работа с микроотверстиями,
и импорт-экспорт производственных файлов. Прилагается импорт проектов из P-CAD2006.
Все, что нужно для трассировки типовых многослойных плат - всего за 19.9 тыс.рублей в год!
Подробности:
https://www.pcbsoft.ru/orcad-za-19900
rom67
сообщение Jul 18 2018, 21:40
Сообщение #45
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 043
Fixed CCRs: SPB 17.2 HF043
07-13-2018
1935813 ADW                DBEDITOR      Auto merging of DE-HDL and Capture Classifications is not working
1935834 ADW                DBEDITOR      Some DE-HDL only classifications are removed during the CSV merge process of libimport
1941570 ALLEGRO_EDITOR     DATABASE      PCB Editor crashes or stops responding on performing 'Info' or 'edit properties' on select pins
1942536 ALLEGRO_EDITOR     DATABASE      Allegro PCB Editor fails to create backdrill plunges in Zone area
1925899 ALLEGRO_EDITOR     DFM           PCB Editor crashes when placing components in Hotfix 039
1943113 ALLEGRO_EDITOR     DFM           Restore normal move/slide via performance when annular ring checking is enabled.
1940939 ALLEGRO_EDITOR     EDIT_ETCH     PCB Editor crashed on running the Gloss - Line and via cleanup tool
1937754 ALLEGRO_EDITOR     GRAPHICS      Text string disappears when selected during 'Edit - Text' if using PCB_CURSOR
1937056 ALLEGRO_EDITOR     INTERFACES    Cannot import IDX acceptance of third-party change to PCB Editor
1940197 ALLEGRO_EDITOR     INTERFACES    PCB Editor crashes when reading IDX file from third-party
1940232 ALLEGRO_EDITOR     IN_DESIGN_ANA PCB Editor crashes when running Return path DRC
1916921 ALLEGRO_EDITOR     PLACEMENT     Property Pin_Global_Fiducial not inherited from symbol into board
1862241 ALLEGRO_EDITOR     REPORTS       In 'Summary Drawing Report', the listed quantity for HDI vias is incorrect under Drilling Statistics
1935448 ALLEGRO_EDITOR     REPORTS       Etch Detailed Length Report lists only one coordinate pair per trace
1948322 ALLEGRO_EDITOR     SHAPE         Allegro hangs when axlPolyOperation api is called
1795564 ALLEGRO_EDITOR     UI_GENERAL    In release 17.2-2016, focus is lost from command window after right-click
1919247 ALLEGRO_EDITOR     UI_GENERAL    Infinite cursor graphics issues on move: Cursor disappears and symbol image remains at old location till refresh
1919256 ALLEGRO_EDITOR     UI_GENERAL    Infinite cursor graphics issue: Symbol disappears during rotate
1933526 ALLEGRO_EDITOR     UI_GENERAL    Panning is slow in PCB Editor in Hotfix 038
1933530 ALLEGRO_EDITOR     UI_GENERAL    Strokes are slower to respond in release 17.2-2016
1933536 ALLEGRO_EDITOR     UI_GENERAL    Third-party dialog stops responding on running commands
1782227 APD                DIE_GENERATOR Ability to specify rectangular shapes in die text in
1933011 ASDA               PART_MANAGER  Parts changed in library with new pin names are not reported or updated by Part Manager
1924529 CAPTURE            NEW_SYM_EDITO Global colors for pin name and number and part body not allowed in release 17.2-2016, Hotfix 038/039
1925846 CAPTURE            NEW_SYM_EDITO Opening library or component with special characters in path throws JavaScript exception
1928905 CAPTURE            NEW_SYM_EDITO Pin name justification, length, and casing incorrect for generated parts in Hotfix 038
1928965 CAPTURE            NEW_SYM_EDITO Cannot move pins in Capture if Pin Name is missing
1932149 CAPTURE            NEW_SYM_EDITO JavaScript exception if path to part contains special characters in Hotfix 039
1936301 CAPTURE            NEW_SYM_EDITO Cannot edit symbol in new symbol editor: Displays parsing error (SPSMI-1)
1917172 CAPTURE            PART_EDITOR   Pin name rotating on schematic even when pin name rotate is off in symbol editor
1924456 CAPTURE            PART_EDITOR   Color preferences for pin, pin name, and pin number do not apply in part editor but only in schematic
1928872 CAPTURE            PART_EDITOR   Pin name locations are wrong and each needs to be placed manually
1929562 CAPTURE            PART_EDITOR   Changing pin name while adding a pin not intuitive in Symbol Editor
1932732 CAPTURE            PART_EDITOR   Part Editor issue: Pin name selection box too long and text not justified in Hotfix 040
1933523 CAPTURE            PART_EDITOR   Connection box does not appear after changing pin of a placed part in Hotfix 040
1936994 CAPTURE            PART_EDITOR   Error because of illegal characters in pin name and number and net name
1943074 CAPTURE            PART_EDITOR   Pin names rotated in Part Editor not rotated when placed on page
1943078 CAPTURE            PART_EDITOR   Pin name rotate not working.
1945055 CAPTURE            PART_EDITOR   Pin names not rotated in schematic
1925700 CAPTURE            VIEWER        Pin numbers and text not shown during Variant View mode anymore.
1914437 CONSTRAINT_MGR     CONCEPT_HDL   Constraint Difference Report appears even though there is no difference in constraint.
1935152 CONSTRAINT_MGR     CONCEPT_HDL   Match Groups are not formed with the correct pin pairs
1940575 SIP_LAYOUT         ORBITIO_IF    Need new routing flow
1923722 SIP_LAYOUT         STREAM_IF     Use one symbol for all instances of a Via Structure
RSS Текстовая версия Сейчас: 19th July 2025 - 19:48
Страница сгенерированна за 0.016 секунд с 7
