> Как подключить *.s файл, Компилятор ICC
$ilent
сообщение Sep 28 2006, 12:46
Из: Москва. Перово
Пользователь №: 14 296
есть у меня файл написаный не знаю на чём, необходимо подключить его к ICC проекту или превратить в Си. При попытке подключения ругань на всё... АСМ не знаю вообще... Помогите советом...
## File        : asm_codec.s
## Version     : 1.0
## Written by  : Chaouki ROUAISSIA
## Date        : 02-08-2004
## Project     : -
## Changes     :
## Description : Reads and writes a sample
##  Connections between the CODEC and the LC07A :
##                                   MCLK  -->  PB(2)
##                                   FSYNC -->  PB(0)
##                                   BCLK  -->  PB(1)
##                                   SDI   -->  PB(6)
##                                   SDO   -->  PA(6)
  .altregsyn  0
  .global Asm_Send_Receive_Sample ;; Function declared in this file
  .text
;* FUNCTION: 'Asm_Send_Receive_Sample'                            *;
;* INPUT: sample to be sent in r3 and r2                          *;
;* OUTPUT: received sample in r3 and r2                           *;
;* DESCRIPTION:                                                   *;
;*  This function sends a 16 bits sample on SDI                   *;
;*  and receives in the mean time a 16 bits sample on SDO         *;
Asm_Send_Receive_Sample:
  move    -(i3), ipl
  move    -(i3), iph
loop_wait_sampling_event:       ;;
  move  a,RegEvnEvn              ;
  jzs   loop_wait_sampling_event ; Wait for the sampling event
  move  RegEvn,#0x80            ;;
; the value we want to send is stored in the i1 register
  move  i1l, r2
  move  i1h, r3
  move  r0, RegPBOut   ; Read the status of the Port B
  or    r0, #0x03
  move  RegPBOut,r0    ; Set BCLK and FSYNC
  clrb  r0,#1
  move  RegPBOut,r0    ; Keep FSYNC set and clear BCLK
  clrb  r0,#0
  setb  r0,#1
  move  RegPBOut,r0    ; Clear FSYNC and set BCLK
; in the following loop: first we send and receive the 8 bits of the MSB
;                        then we send and receive the 8 bits of the LSB
  move  i0h,#2   ; Initialize byte counter
loop_msb_lsb:
  move  r2,#0x00 ; By default, the word received on SDO is 00000000
;*****************  Read / Write bit 15 then bit 7 *****************;
  or    r0, #0x42                                ;;
  tstb  i1h,#7                                    ;
  jzc   _write_bit_15                             ;
  clrb  r0,#6                                     ;;  write bit on SDI
_write_bit_15:                                    ;
  move  RegPBOut,r0; update SDI and set BCLK     ;
  move  a,RegPAIn                                ;;
  tstb  a,#6                                      ;
  jzs   bit_15_zero                               ;; read bit on SDO
  setb  r2,#7                                     ;
bit_15_zero:                                     ;;
  clrb  r0, #1    ; clear BCLK
  move  RegPBOut,r0
;*****************  Read / Write bit 14 then bit 6 *****************;
  or    r0, #0x42                                ;;
  tstb  i1h,#6                                    ;
  jzc   _write_bit_14                             ;
_write_bit_14:                                    ;
  move  a,RegPAIn                                ;;
  tstb  a,#6                                      ;
  jzs   bit_14_zero                               ;;  read bit on SDO
  setb  r2,#6                                     ;
bit_14_zero:                                     ;;
  move  RegPBOut,r0
;*****************  Read / Write bit 13 then bit 5 *****************;
  or    r0, #0x42                                ;;
  tstb  i1h,#5                                    ;
  jzc   _write_bit_13                             ;
_write_bit_13:                                    ;
  move  a,RegPAIn                                ;;
  tstb  a,#6                                      ;
  jzs   bit_13_zero                               ;; read bit on SDO
  setb  r2,#5                                     ;
bit_13_zero:                                     ;;
  move  RegPBOut,r0
;*****************  Read / Write bit 12 then bit 4 *****************;
  or    r0, #0x42                                ;;
  tstb  i1h,#4                                    ;
  jzc   _write_bit_12                             ;
_write_bit_12:                                    ;
  move  a,RegPAIn                                ;;
  tstb  a,#6                                      ;
  jzs   bit_12_zero                               ;; read bit on SDO
  setb  r2,#4                                     ;
bit_12_zero:                                     ;;
  move  RegPBOut,r0
;*****************  Read / Write bit 11 then bit 3 *****************;
  or    r0, #0x42                                ;;
  tstb  i1h,#3                                    ;
  jzc   _write_bit_11                             ;
_write_bit_11:                                    ;
  move  a,RegPAIn                                ;;
  tstb  a,#6                                      ;
  jzs   bit_11_zero                               ;; read bit on SDO
  setb  r2,#3                                     ;
bit_11_zero:                                     ;;
  move  RegPBOut,r0
;*****************  Read / Write bit 10 then bit 2 *****************;
  or    r0, #0x42                                ;;
  tstb  i1h,#2                                    ;
  jzc   _write_bit_10                             ;
_write_bit_10:                                    ;
  move  a,RegPAIn                                ;;
  tstb  a,#6                                      ;
  jzs   bit_10_zero                               ;; read bit on SDO
  setb  r2,#2                                     ;
bit_10_zero:                                     ;;
  move  RegPBOut,r0
;*****************  Read / Write bit 9 then bit 1 *****************;
  or    r0, #0x42                                ;;
  tstb  i1h,#1                                    ;
  jzc   _write_bit_9                              ;
_write_bit_9:                                     ;
  move  a,RegPAIn                                ;;
  tstb  a,#6                                      ;
  jzs   bit_9_zero                                ;; read bit on SDO
  setb  r2,#1                                     ;
bit_9_zero:                                      ;;
  move  RegPBOut,r0
;*****************  Read / Write bit 8 then bit 0 *****************;
  or    r0, #0x42                                ;;
  tstb  i1h,#0                                    ;
  jzc   _write_bit_8                              ;
_write_bit_8:                                     ;
  move  a,RegPAIn                                ;;
  tstb  a,#6                                      ;
  jzs   bit_8_zero                                ;; read bit on SDO
  setb  r2,#0                                     ;
bit_8_zero:                                      ;;
  move  RegPBOut,r0
; Test to check if we have to send the LSB
  dec   i0h
  jzs   end
  move  r3,r2   ; Rotate SDI and SDO registers
  move  i1h,i1l ;
  jump  loop_msb_lsb
  end:
  move  iph, (i3)+
  move  ipl, (i3)+
  jump  ip
;*              END OF 'Asm_Send_Receive_Sample' FUNCTION            *;
RSS Текстовая версия Сейчас: 21st July 2025 - 21:07
Страница сгенерированна за 0.01433 секунд с 7
