Пытливый умишко,облучённый постсовковой нищетой,при виде ценника этого продукта, рождает
желание "скомуниздить" эту гуманитарку.Только я не программер и мне это не по-зубам.Может кто
по-зубастее и поближе к програмерству оценит полёт СВЧ-мысли?...
We are pleased to announce that Zeland Evaluation Kit V12 (including IE3D, FIDELITY, MDSPICE, etc.) is available. The Zeland Evaluation Kit includes time-limited full-functional executables. The most significant improvement on the evaluation kit is that the Windows version no longer requires continuous internet connection during the running of the evaluation license. Following is the installation procedure.
1. Please register at the Download of www.zeland.com. You will be issued with some user name and password by e-mail.
2. Using the user name and password, you can access our Download area. Please download the ALL PRODUCTS FOR WINDOWS FROM ZELAND in the EVALAUTION SOFTWARE FOR EVALUATORS section. You can also download the IE3D/AGIF FOR LINUX X32 and IE3D/AGIF FOR LINUX X64. Please note that the use of LINUX versions still require continuous internet access.
3. Unzip the downloaded eval.zip file into a temporary directory. Run the SETUP.EXE to install the evaluation kit.
4. After installation, please run Zeland Program Manager (ZPM or c:\program files\zeland\exe\zeland.exe by default setup). You will see a welcome message from Zeland Products Evaluation. You will be notified that you have 30 days for evaluation.
5. Please select Finish button. You will get the Special Notes from Zeland Software, Inc.
6. Please select I agree to the terms if you want to evaluate the products and you agree to the terms. Select Continue.
7. ZPM will automatically detect your computer's Host ID. It will prompt you to Input License Key which you need to obtain through 2nd registration.
8. Please select OK and you will be prompt to register again. Please register. You will be issued with a License Key by e-mail.
9. When you get the License Key from e-mail, please copy and paste or enter the License Key into the corresponding field on ZPM. You will be granted for the license and ZPM will start the license. Then, you can start using the evaluation kit. In 30-days, you will be able to use the evaluation licenses in the same way as full-functional purchased licenses. In case you require additional time at the end of the evaluation period, you will have one change to extend your evaluation period for another 30-days period.
There are movies on the web on using IE3D for different applications including FastEM Real-Time Full-Wave Tuning, Optimization and Designs.
For technical support or other issues, please feel free to contact us at: support@zeland.com and evaluation@zeland.com.
Thank you very much!
