> Новая рассылка от _з*е-л*_а*н_д*а наводит на мысли...
roman_uhf
сообщение Nov 7 2006, 07:30
Из: Одесса
Пользователь №: 13 746
Пытливый умишко,облучённый постсовковой нищетой,при виде ценника этого продукта, рождает
желание "скомуниздить" эту гуманитарку.Только я не программер и мне это не по-зубам.Может кто
по-зубастее и поближе к програмерству оценит полёт СВЧ-мысли?... ninja.gif .
We are pleased to announce that Zeland Evaluation Kit V12 (including IE3D, FIDELITY, MDSPICE, etc.) is available. The Zeland Evaluation Kit includes time-limited full-functional executables. The most significant improvement on the evaluation kit is that the Windows version no longer requires continuous internet connection during the running of the evaluation license. Following is the installation procedure.
1. Please register at the Download of www.zeland.com. You will be issued with some user name and password by e-mail.
2. Using the user name and password, you can access our Download area. Please download the ALL PRODUCTS FOR WINDOWS FROM ZELAND in the EVALAUTION SOFTWARE FOR EVALUATORS section. You can also download the IE3D/AGIF FOR LINUX X32 and IE3D/AGIF FOR LINUX X64. Please note that the use of LINUX versions still require continuous internet access.
3. Unzip the downloaded eval.zip file into a temporary directory. Run the SETUP.EXE to install the evaluation kit.
4. After installation, please run Zeland Program Manager (ZPM or c:\program files\zeland\exe\zeland.exe by default setup). You will see a welcome message from Zeland Products Evaluation. You will be notified that you have 30 days for evaluation.
5. Please select Finish button. You will get the Special Notes from Zeland Software, Inc.
6. Please select I agree to the terms if you want to evaluate the products and you agree to the terms. Select Continue.
7. ZPM will automatically detect your computer's Host ID. It will prompt you to Input License Key which you need to obtain through 2nd registration.
8. Please select OK and you will be prompt to register again. Please register. You will be issued with a License Key by e-mail.
9. When you get the License Key from e-mail, please copy and paste or enter the License Key into the corresponding field on ZPM. You will be granted for the license and ZPM will start the license. Then, you can start using the evaluation kit. In 30-days, you will be able to use the evaluation licenses in the same way as full-functional purchased licenses. In case you require additional time at the end of the evaluation period, you will have one change to extend your evaluation period for another 30-days period.
There are movies on the web on using IE3D for different applications including FastEM Real-Time Full-Wave Tuning, Optimization and Designs.
For technical support or other issues, please feel free to contact us at: support@zeland.com and evaluation@zeland.com.
Thank you very much!
Lonesome Wolf
сообщение Nov 7 2006, 11:47
Из: Украина
Пользователь №: 2 805
А что Вы удивляетесь? Так всегда было у них, по крайней мере, уже с того момента, как к ним на сайт заглянул в первый раз - лет 6. Да и цены впечатлили...
А десятка ломанная у меня есть...
roman_uhf
сообщение Nov 7 2006, 12:47
Из: Одесса
Да тут ведь такой случай замечательный - автономная 30-дневная
триалка (полнофункциональная !!!!) -за ними такого ранее не наблюдалось.Всё через инет рулилось и в руки не давалось.А тут
Lonesome Wolf
сообщение Nov 7 2006, 13:30
Из: Украина
Ja by ne skazal... Vse taki plokho, chto kakaja-to programulina lezet naruzhu bez moego vedoma. Po krainej mer, mogli by davat' oznakomitsja s tem-chto posylaetsja - eto vsego lish' host_id. Ili eto tak i est'?
Ved' sushestvujut sredstva menjat' etot samyj host_id.
roman_uhf
сообщение Nov 7 2006, 14:51
Из: Одесса
Тут вот какая штука - можно прогнать пургу не со своего,а с совершенно левого железа на момент активации и промониторить
на совесть.Ведь в этот раз триальный ключик они дают для
АВТОНОМНОЙ триалки с таймером на месяц (впервые на моей памяти).Но повторюсь :для меня всё это -"фантазии Веснухина".
Сдесь нужен Штырлиц с очень неслабой подготовкой как по железу
(ана-слизаторы),так и с опытом "чукотского шамана". smile3046.gif ph34r.gif help.gif cool.gif
TimJet
сообщение Nov 7 2006, 16:07
Пользователь №: 20 995
Может быть, частично решить проблему можно с помощью программы Hall of the Mountain King.
Из описания:
Hall of the Mountain King - может останавливать время для отдельно взятых системных процессов. Достаточно в списке Process Selector выбрать интересующее вас приложение, указать требуемое время и занести в Frosted Process List. Время можно останавливать полностью, а можно частично, например, часы, минуты, секунды будут идти, но следующий день так и не наступит. Только нужно помнить, что нужное приложение следует поместить в Frosted Process List сразу же, не дожидаясь окончания триального периода, чтобы не было лишних проблем.
Среди программ своего класса: SlyASW, Data Fuck, Trial Freezer, TimeBack Hall of the Mountain King-лучшая - с "умными" shareware часто только она одна и справляется.
http://www.angelfire.com/rpg2/e_grig/About.html
roman_uhf
сообщение Nov 7 2006, 18:40
Из: Одесса
2 TimJet: Спасибо за инфу ! Возможно попробую скачать и потриалить годик-другой,пока какой-нибудь толковый
"чукотский юнош" не подарит нам радость "властелина зЕлы".
EVS
сообщение Nov 13 2006, 03:08
Евгений
Из: С.-Петербург
Пользователь №: 2 115
Да, это новость...
В свое время с тогда еще доброй AWR (вроде, еще с версией 3.22) катила такая фишка:
Создал маленький (около 80 Мб) раздел на диске, проинсталлировал туда Офис и после выдачи длинного номера и просьбы ввести ответный кей сохранил образ диска. С тех пор ежемесячно восстанавливал образ из файла, вводил вполне легально присланный ключ и, достаточно законопослушно, продолжал evaluation period.
Интересно, покатит ли с Zeland?
Proton
сообщение Nov 13 2006, 11:08
Из: Новосибирск
Пользователь №: 7 334
Проблема триала обычно решается довольно просто: подопытная прога загоняется в отладчик и ставится брейкпойнт на API получения текущей даты. Дальше правиться несколько байт и получаем вечный триал. Этот фокус у меня проходит с большинством программ, хотя встречаюстся довольно мощные защиты.
Всяк хорошая мысля к нам приходит опосля.
EVS
сообщение Nov 13 2006, 18:54
Евгений
Из: С.-Петербург
Хм...
EVS
сообщение Nov 15 2006, 22:29
Евгений
Из: С.-Петербург
Полный облом-с.....
Скачал поставить на комп домой. Ставится только на с:/Program files по умолчанию, изменить не дает.
Попросила Key, предложила его получить на мыло с привязкой по HostId. Ну тут я и сморозил. Думаю, дай сначала проверю, как она к переводу даты отнесется. Перевел на десять вперед, отнеслась адекватно, сказала, что осталось только двадцать. Перевел обратно чтобы, наконец, ключ по инету попросить. Ну и все... Срок эвуляции истек. Думал, я хитрый, восстановил весь раздел с: из образа, снова поставил - все равно истек. Куда она это записала - не знаю, да и не понимаю в этоих сентинелах ни фига. Жаль. Понял в который раз: реверсивный инжинеринг - не мой конек. Где ты, "чукотский юнош" sad.gif ...
roman_uhf
сообщение Nov 18 2006, 08:41
Из: Одесса
----Где Вы? Кудесники шаловливых програмерских ручек ?
Vasiliy
сообщение Nov 18 2006, 20:16
Группа: Banned
Пользователь №: 50
Установить софтваре
Не проводить updates!!!
Можно попробовать поменять zeland.cfg ,zeland.exe
Для новой версии - не уверен
11-11.18 работают
roman_uhf
сообщение Nov 18 2006, 22:42
Из: Одесса
Скачать-скачал,но пока не устанавливал-ибо опасаюсь,что своей програмерской малограмотностью загублю зЭленький цвяточек.А
второй шенс уже не будет таким удобным.А пареставлять свою
рабочую лошадку из-за собственной криворукости не охота.Вот
жду и надеюсь на то,что кто-нибудь грамотный выложит пошаговую
Vasiliy
сообщение Nov 19 2006, 00:00
Группа: Banned
Пользователь №: 50
30-days FREE TRIAL + 30-days
Имеет смысл поработать с триалом
RSS Текстовая версия Сейчас: 28th August 2025 - 22:52
Страница сгенерированна за 0.01486 секунд с 7
