> Помогите откомпилировать пример в avr-gcc (GCC) 3.4.6.
ShuraM
сообщение Nov 14 2006, 11:05
Пользователь №: 22 299
При попытке окомпилировать пример avr-gcc (GCC) 3.4.6 выдаёт кучу варнингов и ошибки, подкажите плз. как это исправить.
Версия WinAvr 20060421
-------- begin --------
avr-gcc (GCC) 3.4.6
Copyright © 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Compiling: main.c
In file included from main.c:16:
symbol_tbl.h:5: warning: missing braces around initializer
symbol_tbl.h:5: warning: (near initialization for `symbol[0]')
main.c: In function `__vector_9':
main.c:132: warning: implicit declaration of function `sbi'
main.c: In function `spi_init':
main.c:184: warning: implicit declaration of function `cbi'
main.c: In function `adc_init':
main.c:201: error: `ADHSM' undeclared (first use in this function)
main.c:201: error: (Each undeclared identifier is reported only once
main.c:201: error: for each function it appears in.)
main.c: In function `main':
main.c:214: warning: passing arg 1 of `strcpy_P' discards qualifiers from pointer target type
main.c:215: warning: passing arg 1 of `strcpy_P' discards qualifiers from pointer target type
main.c:216: warning: passing arg 1 of `strcpy_P' discards qualifiers from pointer target type
main.c:217: warning: passing arg 1 of `strcpy_P' discards qualifiers from pointer target type
main.c:218: warning: passing arg 1 of `strcpy_P' discards qualifiers from pointer target type
main.c:233: warning: assignment discards qualifiers from pointer target type
main.c:242: warning: implicit declaration of function `PRG_RDB'
make: *** [main.o] Error 1
Build failed with 3 errors and 11 warnings...
В проиложении файл проекта.
Пример взят отсюда:
http://www.vga-avr.narod.ru/main_rus.html
Laksus
сообщение Nov 15 2006, 04:41
Пользователь №: 5 069
Посмотрите в своем файле ..\WinAVR\avr\include\avr\iom16.h
определение битов регистра SFIOR.
Если iom16.h очень древний (WinAVR20040404), то увидите:
/* SFIOR */
#define ADTS2 7
#define ADTS1 6
#define ADTS0 5
#define ADHSM 4
#define ACME 3
#define PUD 2
#define PSR2 1
#define PSR10 0
А если поновее:
The ADHSM bit has been removed from all documentation,
as being not needed at all since the comparator has proven
to be fast enough even without feeding it more power.
#define SFIOR _SFR_IO8(0x30)
#define PSR10 0
#define PSR2 1
#define PUD 2
#define ACME 3
#define ADTS0 5
#define ADTS1 6
#define ADTS2 7
То есть, насколько я понимаю, надо просто закомментировать строку:
// SFIOR = 1<<ADHSM;// High speed conversion mode
_______________
Александр
2006 11 15
ShuraM
сообщение Nov 16 2006, 18:18
Спасибо, попробую. Подскажите плз. с чем связано предупреждение, компилятора.
warning: passing arg 1 of `strcpy_P' discards qualifiers from pointer target type.
ReAl
сообщение Nov 16 2006, 20:19
Нечётный пользователь.
Из: Бровари, Україна
Пользователь №: 5 417
Похоже, не понравился модификатор типа volatile первого аргумента (выборка из str_array, который volatile). Неполное совпадение типов.
Или игнорировать, или, если хочется довести до полного отсутствия предупреждений, поставить явное приведение типа первого аргумента к (char *).
lech196
сообщение Apr 26 2007, 14:02
Пользователь №: 25 110
AVR Studio 4.12 build 460
WinAVR 20070122
ATmega32
В разделе объявления глобальных переменных объявлено:
const char com_readsms[]   = "AT+CMGR=";
Существует следующая функция отправляющая строку по USART:
void USART_sendtext(char *buff)
    for(;*buff;)
            while(!(UCSRA & (1<<UDRE)));
            UDR = *buff++;
Вызываю её:
USART_sendtext(com_readsms);
При этом компилятор выдаёт warning:
../i2c_master_gsm.c:487: warning: passing argument 1 of 'USART_sendtext' discards qualifiers from pointer target type
В принципе данная конструкция работает, однако таких варнингов набралось уже около 200, что немного напрягает. Подскажите пожалуйста как обыграть данную ситуацию? т.е. сделать всё правильно
Заранее спасибо за ответ!
Сообщение отредактировал lech196 - Apr 26 2007, 14:03
beer_warrior
сообщение Apr 26 2007, 14:28
Из: Kiev, UA
Пользователь №: 9 380
gcc весьма придирчив к небрежному написанию, иногда пожалуй чересчур.
Выхода два
1. либо снизить warning level, что не очень хорошо.
2. либо быть педантичным и четко прописывать типы или приводить их к требуемым.
void USART_sendtext(const char *buff)
void USART_sendtext((char*)&buff) // (тут не уверен)
Вони шукають те, чого нема,
Щоб довести, що його не існує.
forever failure
сообщение Apr 26 2007, 14:44
Из: Екатеринбург
Пользователь №: 3 112
Вообще лучшее решение - чётко прописывать типы в аргументах функций.
В даном случае лучше было бы объявить
void USART_sendtext(const char *buff), т.к. функция не меняет данные, адресуемые указателем.
RSS Текстовая версия Сейчас: 20th August 2025 - 16:14
Страница сгенерированна за 0.01415 секунд с 7
