> программа упр. светодиодами, нужно небольшое изменение кода пр-ммы
poke
сообщение Feb 8 2007, 01:20
Пользователь №: 25 153
Братцы, звиняйте за длинный листинг
это прога для 16ф84, который управляет мерцанием 8 светодиодов. треба понизить скорость мерцания.
отблагодарю пивом или например денег на сотовый подброшу. надо для одного проекта. все работает, но надо помедленнее.
CODE
title "flash" ; Program title June 2002
W equ 00H ; Destination is W-Register
F equ 01H ; Destination is F-Register
; Operational Register File
INDF equ 00H ; indf Data addressing
TMR0 equ 01H ; Real Time Clock/Counter Register
PCL equ 02H ; Program counter
STATUS equ 03H ; Status Word Register
FSR equ 04H ; File Select Register
PORTA equ 05H ;inputs
PORTB equ 06H ;outputs
PCLATH equ 0AH
INTCON equ 0BH ;gp files from 0Ch (68 files)
OPTION_REG equ 081H
TRISA equ 085H
TRISB equ 086H
PERIOD equ 0CH
HOLD equ 0DH
SHIFT equ 0EH
TEMP1 equ 0FH
TEMP2 equ 010H
STORE equ 011H
TEMPLIM equ 012H
MODFAC equ 013H ;
STORE2 equ 014H
WREG equ 020H ;8 working regs
INDX equ 030H ;array index (8locs)
INPUT equ PORTA
OUTPUT equ PORTB
;Subroutines
org 00H
goto main_start ;start of main program
getmark btfsc input,4 ;check which array
goto otherone
clrf pclath
movf indf,W
addwf PCL, F
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H ;10
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H ;20
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H ;30
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 02H
retlw 02H
retlw 02H
retlw 02H
retlw 02H ;40
retlw 03H
retlw 03H
retlw 03H
retlw 03H
retlw 04H
retlw 04H
retlw 04H
retlw 05H
retlw 05H
retlw 06H
retlw 06H
retlw 07H ;50
retlw 07H
retlw 08H
retlw 08H
retlw 09H
retlw 09H
retlw 0AH
retlw 0AH
retlw 0BH
retlw 0BH
retlw 0CH ;60
retlw 0CH
retlw 0DH
retlw 0DH
retlw 0EH
retlw 0EH
retlw 0FH
retlw 0FH
retlw 010H
retlw 011H
retlw 012H ;70
retlw 013H
retlw 014H
retlw 016H
retlw 018H
retlw 01AH
retlw 01CH
retlw 01EH
retlw 020H
retlw 024H
retlw 028H ;80
retlw 02CH
retlw 030H
retlw 038H
retlw 040H
retlw 048H
retlw 050H
retlw 058H
retlw 060H
retlw 068H
retlw 070H ;90
retlw 080H
retlw 090H
retlw 0A0H
retlw 0B0H
retlw 0C0H
retlw 0D0H
retlw 0F0H
retlw 0FFH ;100
retlw 0F0H
retlw 0D0H
retlw 0C0H
retlw 0B0H
retlw 0A0H
retlw 090H
retlw 080H
retlw 070H ;110
retlw 068H
retlw 060H
retlw 058H
retlw 050H
retlw 048H
retlw 040H
retlw 038H
retlw 030H
retlw 02CH
retlw 028H ;120
retlw 024H
retlw 020H
retlw 01EH
retlw 01CH
retlw 01AH
retlw 018H
retlw 016H
retlw 014H
retlw 012H
retlw 010H ;130
retlw 0FH
retlw 0FH
retlw 0EH
retlw 0EH
retlw 0DH
retlw 0DH
retlw 0CH
retlw 0CH
retlw 0BH
retlw 0BH ;140
retlw 0AH
retlw 0AH
retlw 09H
retlw 09H
retlw 08H
retlw 08H
retlw 07H
retlw 07H
retlw 06H
retlw 06H ;150
retlw 05H
retlw 05H
retlw 04H
retlw 04H
retlw 04H
retlw 03H
retlw 03H
retlw 03H
retlw 03H
retlw 02H
retlw 02H
retlw 02H ;160
retlw 02H
retlw 02H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H ;170
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H ;180
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H ;190
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H ;200
retlw 01H
retlw 01H
getlim clrf pclath ;get index limit and modofy
call lim ;accordong to modfac.This gives
movwf store ;the number of /2's
movf modfac,W ;div factor (+1)
movwf store2
bcf status,0 ;clear carry
rlf store,F ;limit *2
divlim rrf store,F ;index lim /2
decfsz store2,F ;this determines the no of div by 2's
goto divlim
movf store,W ;modified index limit
movwf templim ;save for lower limit
addlw D'100'
return
lim addwf PCL, F ;index limits
retlw D'76'
retlw D'80'
retlw D'84'
retlw D'88'
retlw D'92'
retlw D'96'
retlw D'100'
retlw D'72'
resetlim movf templim,W
sublw D'99' ;w = 100 - lim
movwf indf
return ;with start value in W
speed clrf pclath
addwf PCL,F
retlw 01H ;for 00 switch setting, port a b0,b1
retlw 04H ; 10
retlw 02H ; 01
retlw 08H ; 11
getmod clrf pclath
addwf PCL,F
retlw 08H
retlw 010H
retlw 018H
retlw 020H
org 0100H
;Main programme
main_start clrf output
clrf input
bsf status, 5
clrf TRISB ;set port b to o/p
movlw 0FFH
movwf TRISA ;set port a to i/p
movlw 080H
movwf option_reg
bcf status, 5
movlw 08H ;set all array indexes to 0
movwf temp2
movlw indx
movwf FSR
clearindx clrf indf
incf FSR,F
decfsz temp2,F
goto clearindx
outer movlw 03H ;read speed switches
andwf input,W ;mask off other switches
call speed ;repititions of mark/space
movwf hold ;for each array value
btfsc input,4
incf hold,F
movlw B'00001100' ;get modulation factor
andwf input,W
movwf modfac
rrf modfac,F
rrf modfac,F ;shift mod to ls bits
movf modfac,W
addwf hold,F ;modify speed if <100% mod
incf modfac,F ;1=/1div, 2=/2, etc
;Put array values into working regs
opmark movlw 01H ;counter for 8 values
movwf shift
movlw wreg ;working reg
movwf temp1 ;save address
movlw indx ;index
movwf temp2 ;save address
loadmark movf temp2, W ;index addr
movwf FSR
call getmark ;get mark from array
movwf store
movf temp1, W ;addr for wreg
movwf FSR
movf store, W
movwf indf
incf temp1, F ;next working reg
incf temp2, F ;next array index
rlf shift, F ;b7 into carry ?
btfss status, 0 ;temp1,2 set to 9th loc on exit
goto loadmark ;but lost anyway
;exit with c=1
;Output one mark/space for all 8 outputs
movlw 0FFH ;inner loop. Mark is already
movwf period ;loaded into work reg
domark movlw wreg ;space is 255-mark
movwf FSR ;base address
movlw 01H ;keeps track of 8 working regs
movwf shift ;and use to set/clear o/p bits
opbits decfsz indf, F ;decrement mark
goto setbit ;if >0
comf shift, W ;space if 0
andwf output, F ;set output pin lo
incf indf, F ;restore to 1 for next loop
goto nextbit
setbit movf shift, W
iorwf output, F ;set pin hi
nextbit incf FSR, F ;next working reg
rlf shift, F ;working reg tracker
btfss status, 0 ;all 8 wregs done if c=1
goto opbits ;care! 9th indirect reg has been
;incremented
decfsz period, F
goto domark
;exit with c=1
;Repeat to control speed
decfsz hold, F ;repeat mark/space o/p
goto opmark ;to control speed
;Check the size of indexes
movlw 01H ;check if indexes have reached
movwf shift ;their limits
clrf temp1 ;no. of index, 0-7
movlw indx ;index base address
movwf FSR
indlim movf temp1, W ;offset
call getlim ;limit for this offset
subwf indf, W ;W = indf-W
btfsc status, 0 ;c=1 for 0 or +ve result
call resetlim ;i.e. limit reached
incf indf, F ;increment current index
incf temp1, F ;o/s for next limit
incf FSR, F ;next array index
rlf shift, F ;8 indexes done ?
btfss status,0
goto indlim ;exit with c=1
;indx value set to 1 if cleared
goto outer ;next mark/space
org 0200H
otherone movlw 02H
movwf pclath
movf indf,W
addwf PCL, F
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H ;10
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H ;20
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H ;30
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H ;40
retlw 01H
retlw 01H
retlw 01H
retlw 02H
retlw 02H
retlw 01H
retlw 01H
retlw 03H
retlw 03H
retlw 01H
retlw 01H
retlw 04H ;50
retlw 06H
retlw 01H
retlw 01H
retlw 08H
retlw 0AH
retlw 01H
retlw 01H
retlw 0EH
retlw 010H
retlw 01H ;60
retlw 01H
retlw 012H
retlw 014H
retlw 01H
retlw 01H
retlw 016H
retlw 018H
retlw 01H
retlw 01H
retlw 01AH ;70
retlw 01CH
retlw 01H
retlw 01H
retlw 020H
retlw 024H
retlw 01H
retlw 01H
retlw 028H
retlw 030H
retlw 01H ;80
retlw 01H
retlw 038H
retlw 040H
retlw 01H
retlw 01H
retlw 060H
retlw 080H
retlw 01H
retlw 01H
retlw 0A0H ;90
retlw 0C0H
retlw 01H
retlw 01H
retlw 0D0H
retlw 0E0H
retlw 01H
retlw 01H
retlw 0FFH ;100
retlw 0FFH
retlw 01H
retlw 01H
retlw 0E0H
retlw 0D0H
retlw 01H
retlw 01H
retlw 0C0H ;110
retlw 0A0H
retlw 01H
retlw 01H
retlw 080H
retlw 060H
retlw 01H
retlw 01H
retlw 040H
retlw 038H
retlw 01H ;120
retlw 01H
retlw 030H
retlw 028H
retlw 01H
retlw 01H
retlw 024H
retlw 020H
retlw 01H
retlw 01H
retlw 01CH ;130
retlw 01AH
retlw 01H
retlw 01H
retlw 018H
retlw 014H
retlw 01H
retlw 01H
retlw 012H
retlw 010H
retlw 01H ;140
retlw 01H
retlw 0EH
retlw 0CH
retlw 01H
retlw 01H
retlw 0AH
retlw 08H
retlw 01H
retlw 01H
retlw 06H ;150
retlw 04H
retlw 01H
retlw 01H
retlw 03H
retlw 03H
retlw 01H
retlw 01H
retlw 02H
retlw 02H
retlw 01H
retlw 01H
retlw 01H ;160
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H ;170
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H ;180
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H ;190
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H
retlw 01H ;200
retlw 01H
retlw 01H
end
Сообщение отредактировал Doka - Feb 10 2007, 12:18
urry1
сообщение Feb 9 2007, 23:00
Пользователь №: 23 498
млин, стока читать... проще написать по - новой на 628 .. смени кварц... smile.gif
poke
сообщение Feb 9 2007, 23:40
censored... а че, на пониженной будет работать? там на 20мгц кварц стоит..
Сообщение отредактировал Doka - Feb 10 2007, 12:19
urry1
сообщение Feb 10 2007, 10:57
хуивознаит... а че, на пониженной будет работать? там на 20мгц кварц стоит..
будет
DL36
сообщение Feb 10 2007, 11:43
Из: Херсон
Пользователь №: 21 006
Не ругался бы.
Да переписал по быстрому.
poke
сообщение Feb 10 2007, 11:49
не пойму, как предыдущий пост редактировать. за выражение извините.
с кварцем - это вариант. А емкости менять не надо? тайминги пика или как их там, не изменятся? я в этом не силен.
Сообщение отредактировал poke - Feb 10 2007, 11:54
VXDRV
сообщение Feb 10 2007, 12:08
Пользователь №: 25 074
Конфиг не забудте поменять с HS на XT при смене кварца. Кстати в 628 есть внутренний генератор на 4МГц.
Doka
сообщение Feb 10 2007, 12:20
Electrical Engineer
Группа: СуперМодераторы
Пользователь №: 778
hint: для длинных листингов не забываем юзать таги:
[codebox]
    тут код
[/codebox]
Блог iDoka.ru
CV linkedin.com/in/iDoka
Sources github.com/iDoka
Never stop thinking...........................
poke
сообщение Feb 10 2007, 12:36
понял. спасибо. да, про хт забыл.
про 628 с 4мгц-это у меня "звездное небо" в 5 раз медленнее мерцать будет? sad.gif
Сообщение отредактировал poke - Feb 10 2007, 12:40
VXDRV
сообщение Feb 10 2007, 14:54
Да в пять раз медленнее.
usawal
сообщение Feb 20 2007, 02:07
Пользователь №: 13 021
Есть способ с программной задержкой.
Из себя это представляет программный счётчик с вложенными циклами.
Как-то для вычисления значений количества рекурсий написал прогу.
Она высчитывает, но выглядит сыро.
poke
сообщение Feb 20 2007, 10:33
С кварцем на десять мгц нормально работает, частота мерцания в самый раз. Конфигурацию не менял, оставил HS-PWRT. Такой вопрос, надо ли ставить XT вместо HS?
urry1
сообщение Feb 20 2007, 10:36
не надо. НS это для режима больше 4 мегагерц.
RSS Текстовая версия Сейчас: 31st August 2025 - 16:52
Страница сгенерированна за 0.015 секунд с 7
