> Рабочий пример работы SL811 в режиме host'a
Hexxx
сообщение Apr 10 2007, 15:14
Пользователь №: 15 592
Тема поднималась милион раз, но никто так и не удосужился запостить пример. Значит буду первым:
#define MASTER_MODE             0x80
void SL811_Init(void)
    SL811Write(cDATASet, 0xe0); //SOF Timeout Value
    SL811Write(cSOFcnt, 0x2e | MASTER_MODE);
    SL811Write(CtrlReg, 0x5);
    SL811Write(EP0Status, PID_SOF);
    SL811Write(EP0Counter, 0);              //Set Endpoint Zero
    SL811Write(EP0Control, 0x01);            //Start the SOF
    SL811Write(IntEna, INSERT_REMOVE);      //USB-A, Insert/Remove, USB_Resume.
    SL811Write(IntStatus, INT_CLEAR);    //Clear Interrupt enable status
#define NO_ERROR 0
#define ERROR_TIMEOUT 1
#define ERROR_STALL 2
#define ERROR_OVERFLOW 3
#define ERROR_EP0_ERROR 4
#define ERROR_UNKNOWN 5
int SendData(void * pData, int DataSize)
  unsigned char result, intr, remainder,timeout;
  SL811BufWrite(EP0_Buf,pData,DataSize);
  SL811Write(EP0Status,(PID_SETUP | 0));  // PID + EP address
  SL811Write(EP0Counter,0);               // USB address
  SL811Write(EP0Address,EP0_Buf);         // buffer address, start with "data0"
  SL811Write(EP0XferLen,DataSize);        // data transfer length
  SL811Write(IntStatus,INT_CLEAR);        // clear interrupt status
  SL811Write(EP0Control,DATA0_WR);
  timeout=10;
  while(1)
    do
      intr = SL811Read(IntStatus);          // wait for interrupt to be done
      if((intr & USB_RESET) || (intr & INSERT_REMOVE))  //leave if device is removed
        return 1;
    } while (!(intr & USB_A_DONE)); // interrupt done !!!
    result = SL811Read(EP0Status);           // read EP0status register
    remainder = SL811Read(EP0Counter);       // remainder value in last pkt xfer
    if (result & EP0_ACK)
      return 0;
    if (result & EP0_NAK)                  // NAK Detected
        SL811Write(IntStatus,INT_CLEAR);        // clear interrupt status, need to
        SL811Write(EP0Control,DATA0_WR);            // re-arm and request for last cmd, IN token
        result = 0;                                     // respond to NAK status only
    if (result & EP0_TIMEOUT)                // TIMEOUT Detected
        if(timeout)
            timeout--;
        else
          return ERROR_TIMEOUT;                    // exit on the timeout detected
        SL811Write(EP0Control,DATA0_WR);            // re-arm and request for last cmd again
    if (result & EP0_STALL)                  // STALL detected
      return ERROR_STALL;                    // for unsupported request.
    if (result & EP0_OVERFLOW)                // OVERFLOW detected
      return ERROR_OVERFLOW;
    if (result & EP0_ERROR)                  // ERROR detected
      return ERROR_EP0_ERROR;
  return ERROR_UNKNOWN;
int GetReply(void * pData, int DataSize)
  SL811Write(EP0Status,(PID_IN | 0));  // PID + EP address
  SL811Write(EP0Control,DATA0_RD);
  timeout=10;
  while(1)
    do
        return 1;
      if(remainder!=DataSize)
        SL811BufRead(EP0_Buf, pData, DataSize);
        return 0;
        if(timeout)
            timeout--;
        else
unsigned char Buffer[0x64];
void testSL811(void)
  int error;
  SetupPKG pkg;
  pkg.bmRequest=0x80;
  pkg.bRequest=0x06;
  pkg.wValue=0x200;
  pkg.wIndex=0x00;
  pkg.wLength=0xFF00;
  SL811ClockInit();
  SL811_Init();
  error=SendData(&pkg,sizeof(pkg));
  if (!error)
    error=GetReply(Buffer,0x9);
Код не идеальный, надо доделывать функцию чтения. Он инитит хост в режиме low-speed и позволяет вам послать SETUP пакет GET_DESCRIPTOR и вычитать 9-байтов ответа от Slave устройства. Все нехватающие функции и define есть в cy3662/EZ811 development kit'e. Его можно взять вот тут
- Hexxx   Рабочий пример работы SL811 в режиме host'a   Apr 10 2007, 15:14
- - Hexxx   Я понял как заставить работать пример из EZ811 DK...   Apr 18 2007, 17:28
- - Hexxx   И все таки он глючит на чтении. Люди помогите, уже...   Apr 19 2007, 14:59
- - Hexxx   Так странно, куча людей. У многих уже проблемы с в...   Apr 20 2007, 11:51
- - Hexxx   Отвечает Александр Друзь! Payload - это масим...   Apr 23 2007, 12:40
- - Hexxx   Эпопея продолжается. Bulk-transfer не пашет. Отпра...   May 3 2007, 13:07
|- - misyachniy   Не знаю что и посоветовать. У меня был затык в том...   May 3 2007, 16:06
- - Hexxx   А меня опять оказался баг с переключением DATA0/DA...   May 4 2007, 12:08
- - Hexxx   Начал пробовать подключать разные устройства. Кто-...   May 7 2007, 08:32
- - Hexxx   А вообще когда проставляется TIMEOUT?   May 7 2007, 13:49
- - Hexxx   ап   May 8 2007, 13:41
|- - Ailinor   Я решил так: int Read(unsigned char *buff) { ...   May 10 2007, 15:18
- - Hexxx   Я тут тоже по этому вопросу мучаю разных людей. Од...   May 11 2007, 13:17
- - Hexxx   Кое-что еще выяснилось на счет таймаутов. Если де...   May 17 2007, 05:05
- - Hexxx   А фишка оказалась была в том, что я не делал SetAd...   Jun 18 2007, 12:58
RSS Текстовая версия Сейчас: 21st August 2025 - 18:11
Страница сгенерированна за 0.0141 секунд с 7
